[U-Boot] [PATCH 4/4] powerpc/85xx:Fix NAND code base to support debugger
Update NAND code base to ovecome e500 and e500v2's second limitation i.e. IVPR + IVOR15 should be valid fetchable OP code address.
As NAND SPL does not compile vector table so making sure IVOR + IVOR15 points to any fetchable valid data
Signed-off-by: Radu Lazarescu radu.lazarescu@freescale.com Signed-off-by: Marius Grigoras marius.grigoras@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Based upon git://git.denx.de/u-boot.git branch master
No change, Resending again
Tested on - SoC having E500 Family processor (P1010RDB, BSC9131RDB) - SoC having E500MC Family processor (P4080DS, P3041DS)
arch/powerpc/cpu/mpc85xx/start.S | 18 +++++++++++++----- 1 files changed, 13 insertions(+), 5 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index cef00ba..0d50f6f 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -1431,17 +1431,25 @@ relocate_code: 7: sync /* Wait for all icbi to complete on bus */ isync
- /* - * Re-point the IVPR at RAM - */ - mtspr IVPR,r10 - /* * We are done. Do not return, instead branch to second part of board * initialization, now running from RAM. */
addi r0,r10,in_ram - _start + _START_OFFSET + +#if defined(CONFIG_E500) && defined(CONFIG_NAND_SPL) +/* + * As IVPR is going to point RAM address, + * Make sure IVOR15 has valid opcode to support debugger + */ + mtspr IVOR15,r0 +#endif + /* + * Re-point the IVPR at RAM + */ + mtspr IVPR,r10 + mtlr r0 blr /* NEVER RETURNS! */ .globl in_ram
Prabhakar Kushwaha
