[PATCH 00/11] stm32mp1: migrate MTD and DFU configuration in Kconfig
This serie migrate the dynamically build MTD (CONFIG_SYS_MTDPARTS_RUNTIME) and the DFU configuration (CONFIG_SET_DFU_ALT_INFO) previously based on ENV variables to CONFIG_.
These patches reduce the size of the environment and allow to tune for each target with a specific defconfig file.
This serie also removes the TEE deconfig, replaced by a dynamic detection based on op-tee driver probe.
This serie depends on previous CONFIG migration proposed in http://patchwork.ozlabs.org/project/uboot/list/?series=160899 - configs: migrate CONFIG_SET_DFU_ALT_INFO to defconfigs - configs: migrate CONFIG_SYS_MTDPARTS_RUNTIME to defconfigs
Patrick Delaunay (11): board: stm32mp1: move board_get_mtdparts in st common directory board: stm32mp1: move set_dfu_alt_info in st common directory stm32mp1: dynamically build DFU_ALT_INFO stm32mp1: move MTDPART configuration in Kconfig board: stm32mp1: reserve memory for OP-TEE in device tree stm32mp1: dynamically detect op-tee presence board: stm32mp1: use FDT address provided by TF-A at boot time configs: stm32mp1: remove optee defconfig board: stm32mp1: support boot from spi-nand board: stm32mp1: adapt MTD partition for BOOT from NOR or NAND doc: stm32mp1: update DFU support example
arch/arm/dts/stm32mp157a-dk1.dts | 5 + arch/arm/dts/stm32mp157c-ed1.dts | 5 + arch/arm/mach-stm32mp/Kconfig | 10 - arch/arm/mach-stm32mp/Makefile | 1 + arch/arm/mach-stm32mp/boot_params.c | 45 ++++ arch/arm/mach-stm32mp/cpu.c | 4 + arch/arm/mach-stm32mp/dram_init.c | 18 ++ arch/arm/mach-stm32mp/fdt.c | 25 ++ arch/arm/mach-stm32mp/include/mach/stm32.h | 3 + arch/arm/mach-stm32mp/spl.c | 2 + board/dhelectronics/dh_stm32mp1/Kconfig | 1 + board/dhelectronics/dh_stm32mp1/Makefile | 3 + board/dhelectronics/dh_stm32mp1/board.c | 143 +----------- board/st/common/Kconfig | 64 ++++++ board/st/common/Makefile | 5 + board/st/common/stm32mp_dfu.c | 225 ++++++++++++++++++ board/st/common/stm32mp_mtdparts.c | 157 +++++++++++++ board/st/stm32mp1/MAINTAINERS | 1 - board/st/stm32mp1/stm32mp1.c | 253 +-------------------- configs/stm32mp15_optee_defconfig | 132 ----------- configs/stm32mp15_trusted_defconfig | 3 + doc/board/st/stm32mp1.rst | 147 +++++------- include/configs/stm32mp1.h | 64 +----- 23 files changed, 634 insertions(+), 682 deletions(-) create mode 100644 arch/arm/mach-stm32mp/boot_params.c create mode 100644 board/st/common/stm32mp_dfu.c create mode 100644 board/st/common/stm32mp_mtdparts.c delete mode 100644 configs/stm32mp15_optee_defconfig
Move the stm32mp1 common code board_get_mtdparts() in common directory, this patch reduce the maintenance effort on this generic part (not board dependent).
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
board/dhelectronics/dh_stm32mp1/Makefile | 1 + board/dhelectronics/dh_stm32mp1/board.c | 89 ------------------ board/st/common/Makefile | 4 + board/st/common/stm32mp_mtdparts.c | 115 +++++++++++++++++++++++ board/st/stm32mp1/stm32mp1.c | 102 -------------------- 5 files changed, 120 insertions(+), 191 deletions(-) create mode 100644 board/st/common/stm32mp_mtdparts.c
diff --git a/board/dhelectronics/dh_stm32mp1/Makefile b/board/dhelectronics/dh_stm32mp1/Makefile index b42c4e4c04..c77a1e3a84 100644 --- a/board/dhelectronics/dh_stm32mp1/Makefile +++ b/board/dhelectronics/dh_stm32mp1/Makefile @@ -8,3 +8,4 @@ obj-y += ../../st/stm32mp1/spl.o endif
obj-y += ../../st/stm32mp1/board.o board.o +obj-$(CONFIG_SYS_MTDPARTS_RUNTIME) += ../../st/common/stm32mp_mtdparts.o diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index b663696983..2baa36278c 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -519,95 +519,6 @@ enum env_location env_get_location(enum env_operation op, int prio) #endif }
-#ifdef CONFIG_SYS_MTDPARTS_RUNTIME - -#define MTDPARTS_LEN 256 -#define MTDIDS_LEN 128 - -/** - * The mtdparts_nand0 and mtdparts_nor0 variable tends to be long. - * If we need to access it before the env is relocated, then we need - * to use our own stack buffer. gd->env_buf will be too small. - * - * @param buf temporary buffer pointer MTDPARTS_LEN long - * @return mtdparts variable string, NULL if not found - */ -static const char *env_get_mtdparts(const char *str, char *buf) -{ - if (gd->flags & GD_FLG_ENV_READY) - return env_get(str); - if (env_get_f(str, buf, MTDPARTS_LEN) != -1) - return buf; - - return NULL; -} - -/** - * update the variables "mtdids" and "mtdparts" with content of mtdparts_<dev> - */ -static void board_get_mtdparts(const char *dev, - char *mtdids, - char *mtdparts) -{ - char env_name[32] = "mtdparts_"; - char tmp_mtdparts[MTDPARTS_LEN]; - const char *tmp; - - /* name of env variable to read = mtdparts_<dev> */ - strcat(env_name, dev); - tmp = env_get_mtdparts(env_name, tmp_mtdparts); - if (tmp) { - /* mtdids: "<dev>=<dev>, ...." */ - if (mtdids[0] != '\0') - strcat(mtdids, ","); - strcat(mtdids, dev); - strcat(mtdids, "="); - strcat(mtdids, dev); - - /* mtdparts: "mtdparts=<dev>:<mtdparts_<dev>>;..." */ - if (mtdparts[0] != '\0') - strncat(mtdparts, ";", MTDPARTS_LEN); - else - strcat(mtdparts, "mtdparts="); - strncat(mtdparts, dev, MTDPARTS_LEN); - strncat(mtdparts, ":", MTDPARTS_LEN); - strncat(mtdparts, tmp, MTDPARTS_LEN); - } -} - -void board_mtdparts_default(const char **mtdids, const char **mtdparts) -{ - struct udevice *dev; - static char parts[3 * MTDPARTS_LEN + 1]; - static char ids[MTDIDS_LEN + 1]; - static bool mtd_initialized; - - if (mtd_initialized) { - *mtdids = ids; - *mtdparts = parts; - return; - } - - memset(parts, 0, sizeof(parts)); - memset(ids, 0, sizeof(ids)); - - /* probe all MTD devices */ - for (uclass_first_device(UCLASS_MTD, &dev); - dev; - uclass_next_device(&dev)) { - pr_debug("mtd device = %s\n", dev->name); - } - - if (!uclass_get_device(UCLASS_SPI_FLASH, 0, &dev)) - board_get_mtdparts("nor0", ids, parts); - - mtd_initialized = true; - *mtdids = ids; - *mtdparts = parts; - debug("%s:mtdids=%s & mtdparts=%s\n", __func__, ids, parts); -} -#endif - #if defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, bd_t *bd) { diff --git a/board/st/common/Makefile b/board/st/common/Makefile index 8553606b90..4bb8b49867 100644 --- a/board/st/common/Makefile +++ b/board/st/common/Makefile @@ -4,3 +4,7 @@ #
obj-$(CONFIG_CMD_STBOARD) += cmd_stboard.o + +ifeq ($(CONFIG_ARCH_STM32MP),y) +obj-$(CONFIG_SYS_MTDPARTS_RUNTIME) += stm32mp_mtdparts.o +endif diff --git a/board/st/common/stm32mp_mtdparts.c b/board/st/common/stm32mp_mtdparts.c new file mode 100644 index 0000000000..d77e075864 --- /dev/null +++ b/board/st/common/stm32mp_mtdparts.c @@ -0,0 +1,115 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2020, STMicroelectronics - All Rights Reserved + */ + +#include <common.h> +#include <dm.h> +#include <env.h> +#include <env_internal.h> +#include <mtd.h> +#include <mtd_node.h> + +#define MTDPARTS_LEN 256 +#define MTDIDS_LEN 128 + +/* + * Get a global data pointer + */ +DECLARE_GLOBAL_DATA_PTR; + +/** + * The mtdparts_nand0 and mtdparts_nor0 variable tends to be long. + * If we need to access it before the env is relocated, then we need + * to use our own stack buffer. gd->env_buf will be too small. + * + * @param buf temporary buffer pointer MTDPARTS_LEN long + * @return mtdparts variable string, NULL if not found + */ +static const char *env_get_mtdparts(const char *str, char *buf) +{ + if (gd->flags & GD_FLG_ENV_READY) + return env_get(str); + if (env_get_f(str, buf, MTDPARTS_LEN) != -1) + return buf; + + return NULL; +} + +/** + * update the variables "mtdids" and "mtdparts" with content of mtdparts_<dev> + */ +static void board_get_mtdparts(const char *dev, + char *mtdids, + char *mtdparts) +{ + char env_name[32] = "mtdparts_"; + char tmp_mtdparts[MTDPARTS_LEN]; + const char *tmp; + + /* name of env variable to read = mtdparts_<dev> */ + strcat(env_name, dev); + tmp = env_get_mtdparts(env_name, tmp_mtdparts); + if (tmp) { + /* mtdids: "<dev>=<dev>, ...." */ + if (mtdids[0] != '\0') + strcat(mtdids, ","); + strcat(mtdids, dev); + strcat(mtdids, "="); + strcat(mtdids, dev); + + /* mtdparts: "mtdparts=<dev>:<mtdparts_<dev>>;..." */ + if (mtdparts[0] != '\0') + strncat(mtdparts, ";", MTDPARTS_LEN); + else + strcat(mtdparts, "mtdparts="); + strncat(mtdparts, dev, MTDPARTS_LEN); + strncat(mtdparts, ":", MTDPARTS_LEN); + strncat(mtdparts, tmp, MTDPARTS_LEN); + } +} + +void board_mtdparts_default(const char **mtdids, const char **mtdparts) +{ + struct mtd_info *mtd; + struct udevice *dev; + static char parts[3 * MTDPARTS_LEN + 1]; + static char ids[MTDIDS_LEN + 1]; + static bool mtd_initialized; + + if (mtd_initialized) { + *mtdids = ids; + *mtdparts = parts; + return; + } + + memset(parts, 0, sizeof(parts)); + memset(ids, 0, sizeof(ids)); + + /* probe all MTD devices */ + for (uclass_first_device(UCLASS_MTD, &dev); + dev; + uclass_next_device(&dev)) { + pr_debug("mtd device = %s\n", dev->name); + } + + mtd = get_mtd_device_nm("nand0"); + if (!IS_ERR_OR_NULL(mtd)) { + board_get_mtdparts("nand0", ids, parts); + put_mtd_device(mtd); + } + + mtd = get_mtd_device_nm("spi-nand0"); + if (!IS_ERR_OR_NULL(mtd)) { + board_get_mtdparts("spi-nand0", ids, parts); + put_mtd_device(mtd); + } + + if (!uclass_get_device(UCLASS_SPI_FLASH, 0, &dev)) + board_get_mtdparts("nor0", ids, parts); + + mtd_initialized = true; + *mtdids = ids; + *mtdparts = parts; + debug("%s:mtdids=%s & mtdparts=%s\n", __func__, ids, parts); +} diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index b9d852efa4..bbeeb15d7e 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -828,108 +828,6 @@ const char *env_ext4_get_dev_part(void) } #endif
-#ifdef CONFIG_SYS_MTDPARTS_RUNTIME - -#define MTDPARTS_LEN 256 -#define MTDIDS_LEN 128 - -/** - * The mtdparts_nand0 and mtdparts_nor0 variable tends to be long. - * If we need to access it before the env is relocated, then we need - * to use our own stack buffer. gd->env_buf will be too small. - * - * @param buf temporary buffer pointer MTDPARTS_LEN long - * @return mtdparts variable string, NULL if not found - */ -static const char *env_get_mtdparts(const char *str, char *buf) -{ - if (gd->flags & GD_FLG_ENV_READY) - return env_get(str); - if (env_get_f(str, buf, MTDPARTS_LEN) != -1) - return buf; - - return NULL; -} - -/** - * update the variables "mtdids" and "mtdparts" with content of mtdparts_<dev> - */ -static void board_get_mtdparts(const char *dev, - char *mtdids, - char *mtdparts) -{ - char env_name[32] = "mtdparts_"; - char tmp_mtdparts[MTDPARTS_LEN]; - const char *tmp; - - /* name of env variable to read = mtdparts_<dev> */ - strcat(env_name, dev); - tmp = env_get_mtdparts(env_name, tmp_mtdparts); - if (tmp) { - /* mtdids: "<dev>=<dev>, ...." */ - if (mtdids[0] != '\0') - strcat(mtdids, ","); - strcat(mtdids, dev); - strcat(mtdids, "="); - strcat(mtdids, dev); - - /* mtdparts: "mtdparts=<dev>:<mtdparts_<dev>>;..." */ - if (mtdparts[0] != '\0') - strncat(mtdparts, ";", MTDPARTS_LEN); - else - strcat(mtdparts, "mtdparts="); - strncat(mtdparts, dev, MTDPARTS_LEN); - strncat(mtdparts, ":", MTDPARTS_LEN); - strncat(mtdparts, tmp, MTDPARTS_LEN); - } -} - -void board_mtdparts_default(const char **mtdids, const char **mtdparts) -{ - struct mtd_info *mtd; - struct udevice *dev; - static char parts[3 * MTDPARTS_LEN + 1]; - static char ids[MTDIDS_LEN + 1]; - static bool mtd_initialized; - - if (mtd_initialized) { - *mtdids = ids; - *mtdparts = parts; - return; - } - - memset(parts, 0, sizeof(parts)); - memset(ids, 0, sizeof(ids)); - - /* probe all MTD devices */ - for (uclass_first_device(UCLASS_MTD, &dev); - dev; - uclass_next_device(&dev)) { - pr_debug("mtd device = %s\n", dev->name); - } - - mtd = get_mtd_device_nm("nand0"); - if (!IS_ERR_OR_NULL(mtd)) { - board_get_mtdparts("nand0", ids, parts); - put_mtd_device(mtd); - } - - mtd = get_mtd_device_nm("spi-nand0"); - if (!IS_ERR_OR_NULL(mtd)) { - board_get_mtdparts("spi-nand0", ids, parts); - put_mtd_device(mtd); - } - - if (!uclass_get_device(UCLASS_SPI_FLASH, 0, &dev)) - board_get_mtdparts("nor0", ids, parts); - - mtd_initialized = true; - *mtdids = ids; - *mtdparts = parts; - debug("%s:mtdids=%s & mtdparts=%s\n", __func__, ids, parts); -} -#endif - #if defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, bd_t *bd) {
Hi Patrick
Reviewed-by: Patrice Chotard patrice.chotard@st.com
Patrice
- The mtdparts_nand0 and mtdparts_nor0 variable tends to be long.
- If we need to access it before the env is relocated, then we need
- to use our own stack buffer. gd->env_buf will be too small.
- @param buf temporary buffer pointer MTDPARTS_LEN long
- @return mtdparts variable string, NULL if not found
return buf;
- return NULL;
- update the variables "mtdids" and "mtdparts" with content of mtdparts_<dev>
char *mtdids,
char *mtdparts)
- const char *tmp;
- if (tmp) {
else
*mtdids = ids;
*mtdparts = parts;
return;
dev;
- *mtdids = ids;
-} -#endif
- Copyright (C) 2020, STMicroelectronics - All Rights Reserved
- Get a global data pointer
return buf;
- return NULL;
char *mtdids,
char *mtdparts)
- const char *tmp;
- if (tmp) {
else
*mtdids = ids;
*mtdparts = parts;
return;
dev;
- *mtdids = ids;
return buf;
- return NULL;
char *mtdids,
char *mtdparts)
- const char *tmp;
- if (tmp) {
else
*mtdids = ids;
*mtdparts = parts;
return;
dev;
- *mtdids = ids;
-} -#endif
Move the stm32mp1 common code set_dfu_alt_info() in common directory, this patch reduce the maintenance effort on this generic part (not board dependent).
board/dhelectronics/dh_stm32mp1/Makefile | 2 + board/dhelectronics/dh_stm32mp1/board.c | 50 -------- board/st/common/Makefile | 1 + board/st/common/stm32mp_dfu.c | 151 +++++++++++++++++++++++ board/st/stm32mp1/stm32mp1.c | 145 ---------------------- 5 files changed, 154 insertions(+), 195 deletions(-) create mode 100644 board/st/common/stm32mp_dfu.c
diff --git a/board/dhelectronics/dh_stm32mp1/Makefile b/board/dhelectronics/dh_stm32mp1/Makefile index c77a1e3a84..e8f218da08 100644 --- a/board/dhelectronics/dh_stm32mp1/Makefile +++ b/board/dhelectronics/dh_stm32mp1/Makefile @@ -8,4 +8,6 @@ obj-y += ../../st/stm32mp1/spl.o endif
obj-y += ../../st/stm32mp1/board.o board.o + obj-$(CONFIG_SYS_MTDPARTS_RUNTIME) += ../../st/common/stm32mp_mtdparts.o +obj-$(CONFIG_SET_DFU_ALT_INFO) += ../../st/common/stm32mp_dfu.o diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index 2baa36278c..bd6540a2aa 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -526,56 +526,6 @@ int ft_board_setup(void *blob, bd_t *bd) } #endif
-#ifdef CONFIG_SET_DFU_ALT_INFO -#define DFU_ALT_BUF_LEN SZ_1K - -static void board_get_alt_info(const char *dev, char *buff) -{ - char var_name[32] = "dfu_alt_info_"; - int ret; - - ALLOC_CACHE_ALIGN_BUFFER(char, tmp_alt, DFU_ALT_BUF_LEN); - - /* name of env variable to read = dfu_alt_info_<dev> */ - strcat(var_name, dev); - ret = env_get_f(var_name, tmp_alt, DFU_ALT_BUF_LEN); - if (ret) { - if (buff[0] != '\0') - strcat(buff, "&"); - strncat(buff, tmp_alt, DFU_ALT_BUF_LEN); - } -} - -void set_dfu_alt_info(char *interface, char *devstr) -{ - struct udevice *dev; - - ALLOC_CACHE_ALIGN_BUFFER(char, buf, DFU_ALT_BUF_LEN); - - if (env_get("dfu_alt_info")) - return; - - memset(buf, 0, sizeof(buf)); - - /* probe all MTD devices */ - mtd_probe_devices(); - - board_get_alt_info("ram", buf); - - if (!uclass_get_device(UCLASS_MMC, 0, &dev)) - board_get_alt_info("mmc0", buf); - - if (!uclass_get_device(UCLASS_MMC, 1, &dev)) - board_get_alt_info("mmc1", buf); - - if (!uclass_get_device(UCLASS_SPI_FLASH, 0, &dev)) - board_get_alt_info("nor0", buf); - - env_set("dfu_alt_info", buf); - puts("DFU alt info setting: done\n"); -} -#endif - static void board_copro_image_process(ulong fw_image, size_t fw_size) { int ret, id = 0; /* Copro id fixed to 0 as only one coproc on mp1 */ diff --git a/board/st/common/Makefile b/board/st/common/Makefile index 4bb8b49867..aa030bacd8 100644 --- a/board/st/common/Makefile +++ b/board/st/common/Makefile @@ -7,4 +7,5 @@ obj-$(CONFIG_CMD_STBOARD) += cmd_stboard.o
ifeq ($(CONFIG_ARCH_STM32MP),y) obj-$(CONFIG_SYS_MTDPARTS_RUNTIME) += stm32mp_mtdparts.o +obj-$(CONFIG_SET_DFU_ALT_INFO) += stm32mp_dfu.o endif diff --git a/board/st/common/stm32mp_dfu.c b/board/st/common/stm32mp_dfu.c new file mode 100644 index 0000000000..99ea21ce15 --- /dev/null +++ b/board/st/common/stm32mp_dfu.c @@ -0,0 +1,151 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2020, STMicroelectronics - All Rights Reserved + */ + +#include <common.h> +#include <dfu.h> +#include <env.h> +#include <memalign.h> +#include <misc.h> +#include <mtd.h> +#include <mtd_node.h> + +#define DFU_ALT_BUF_LEN SZ_1K + +static void board_get_alt_info(const char *dev, char *buff) +{ + char var_name[32] = "dfu_alt_info_"; + int ret; + + ALLOC_CACHE_ALIGN_BUFFER(char, tmp_alt, DFU_ALT_BUF_LEN); + + /* name of env variable to read = dfu_alt_info_<dev> */ + strcat(var_name, dev); + ret = env_get_f(var_name, tmp_alt, DFU_ALT_BUF_LEN); + if (ret) { + if (buff[0] != '\0') + strcat(buff, "&"); + strncat(buff, tmp_alt, DFU_ALT_BUF_LEN); + } +} + +void set_dfu_alt_info(char *interface, char *devstr) +{ + struct udevice *dev; + struct mtd_info *mtd; + + ALLOC_CACHE_ALIGN_BUFFER(char, buf, DFU_ALT_BUF_LEN); + + if (env_get("dfu_alt_info")) + return; + + memset(buf, 0, sizeof(buf)); + + /* probe all MTD devices */ + mtd_probe_devices(); + + board_get_alt_info("ram", buf); + + if (!uclass_get_device(UCLASS_MMC, 0, &dev)) + board_get_alt_info("mmc0", buf); + + if (!uclass_get_device(UCLASS_MMC, 1, &dev)) + board_get_alt_info("mmc1", buf); + + if (!uclass_get_device(UCLASS_SPI_FLASH, 0, &dev)) + board_get_alt_info("nor0", buf); + + mtd = get_mtd_device_nm("nand0"); + if (!IS_ERR_OR_NULL(mtd)) + board_get_alt_info("nand0", buf); + + mtd = get_mtd_device_nm("spi-nand0"); + if (!IS_ERR_OR_NULL(mtd)) + board_get_alt_info("spi-nand0", buf); + +#ifdef CONFIG_DFU_VIRT + strncat(buf, "&virt 0=OTP", DFU_ALT_BUF_LEN); + + if (IS_ENABLED(CONFIG_PMIC_STPMIC1)) + strncat(buf, "&virt 1=PMIC", DFU_ALT_BUF_LEN); +#endif + + env_set("dfu_alt_info", buf); + puts("DFU alt info setting: done\n"); +} + +#if CONFIG_IS_ENABLED(DFU_VIRT) +#include <dfu.h> +#include <power/stpmic1.h> + +static int dfu_otp_read(u64 offset, u8 *buffer, long *size) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(stm32mp_bsec), + &dev); + if (ret) + return ret; + + ret = misc_read(dev, offset + STM32_BSEC_OTP_OFFSET, buffer, *size); + if (ret >= 0) { + *size = ret; + ret = 0; + } + + return 0; +} + +static int dfu_pmic_read(u64 offset, u8 *buffer, long *size) +{ + int ret; +#ifdef CONFIG_PMIC_STPMIC1 + struct udevice *dev; + + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(stpmic1_nvm), + &dev); + if (ret) + return ret; + + ret = misc_read(dev, 0xF8 + offset, buffer, *size); + if (ret >= 0) { + *size = ret; + ret = 0; + } + if (ret == -EACCES) { + *size = 0; + ret = 0; + } +#else + pr_err("PMIC update not supported"); + ret = -EOPNOTSUPP; +#endif + + return ret; +} + +int dfu_read_medium_virt(struct dfu_entity *dfu, u64 offset, + void *buf, long *len) +{ + switch (dfu->data.virt.dev_num) { + case 0x0: + return dfu_otp_read(offset, buf, len); + case 0x1: + return dfu_pmic_read(offset, buf, len); + } + *len = 0; + return 0; +} + +int __weak dfu_get_medium_size_virt(struct dfu_entity *dfu, u64 *size) +{ + *size = SZ_1K; + + return 0; +} + +#endif diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index bbeeb15d7e..2ab3b5cc9a 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -7,7 +7,6 @@ #include <bootm.h> #include <clk.h> #include <config.h> -#include <dfu.h> #include <dm.h> #include <env.h> #include <env_internal.h> @@ -18,9 +17,7 @@ #include <init.h> #include <led.h> #include <malloc.h> -#include <memalign.h> #include <misc.h> -#include <mtd.h> #include <mtd_node.h> #include <netdev.h> #include <phy.h> @@ -843,148 +840,6 @@ int ft_board_setup(void *blob, bd_t *bd) } #endif
-#ifdef CONFIG_SET_DFU_ALT_INFO -#define DFU_ALT_BUF_LEN SZ_1K - -static void board_get_alt_info(const char *dev, char *buff) -{ - char var_name[32] = "dfu_alt_info_"; - int ret; - - ALLOC_CACHE_ALIGN_BUFFER(char, tmp_alt, DFU_ALT_BUF_LEN); - - /* name of env variable to read = dfu_alt_info_<dev> */ - strcat(var_name, dev); - ret = env_get_f(var_name, tmp_alt, DFU_ALT_BUF_LEN); - if (ret) { - if (buff[0] != '\0') - strcat(buff, "&"); - strncat(buff, tmp_alt, DFU_ALT_BUF_LEN); - } -} - -void set_dfu_alt_info(char *interface, char *devstr) -{ - struct udevice *dev; - struct mtd_info *mtd; - - ALLOC_CACHE_ALIGN_BUFFER(char, buf, DFU_ALT_BUF_LEN); - - if (env_get("dfu_alt_info")) - return; - - memset(buf, 0, sizeof(buf)); - - /* probe all MTD devices */ - mtd_probe_devices(); - - board_get_alt_info("ram", buf); - - if (!uclass_get_device(UCLASS_MMC, 0, &dev)) - board_get_alt_info("mmc0", buf); - - if (!uclass_get_device(UCLASS_MMC, 1, &dev)) - board_get_alt_info("mmc1", buf); - - if (!uclass_get_device(UCLASS_SPI_FLASH, 0, &dev)) - board_get_alt_info("nor0", buf); - - mtd = get_mtd_device_nm("nand0"); - if (!IS_ERR_OR_NULL(mtd)) - board_get_alt_info("nand0", buf); - - mtd = get_mtd_device_nm("spi-nand0"); - if (!IS_ERR_OR_NULL(mtd)) - board_get_alt_info("spi-nand0", buf); - -#ifdef CONFIG_DFU_VIRT - strncat(buf, "&virt 0=OTP", DFU_ALT_BUF_LEN); - - if (IS_ENABLED(CONFIG_PMIC_STPMIC1)) - strncat(buf, "&virt 1=PMIC", DFU_ALT_BUF_LEN); -#endif - - env_set("dfu_alt_info", buf); - puts("DFU alt info setting: done\n"); -} - -#if CONFIG_IS_ENABLED(DFU_VIRT) -#include <dfu.h> -#include <power/stpmic1.h> - -static int dfu_otp_read(u64 offset, u8 *buffer, long *size) -{ - struct udevice *dev; - int ret; - - ret = uclass_get_device_by_driver(UCLASS_MISC, - DM_GET_DRIVER(stm32mp_bsec), - &dev); - if (ret) - return ret; - - ret = misc_read(dev, offset + STM32_BSEC_OTP_OFFSET, buffer, *size); - if (ret >= 0) { - *size = ret; - ret = 0; - } - - return 0; -} - -static int dfu_pmic_read(u64 offset, u8 *buffer, long *size) -{ - int ret; -#ifdef CONFIG_PMIC_STPMIC1 - struct udevice *dev; - - ret = uclass_get_device_by_driver(UCLASS_MISC, - DM_GET_DRIVER(stpmic1_nvm), - &dev); - if (ret) - return ret; - - ret = misc_read(dev, 0xF8 + offset, buffer, *size); - if (ret >= 0) { - *size = ret; - ret = 0; - } - if (ret == -EACCES) { - *size = 0; - ret = 0; - } -#else - pr_err("PMIC update not supported"); - ret = -EOPNOTSUPP; -#endif - - return ret; -} - -int dfu_read_medium_virt(struct dfu_entity *dfu, u64 offset, - void *buf, long *len) -{ - switch (dfu->data.virt.dev_num) { - case 0x0: - return dfu_otp_read(offset, buf, len); - case 0x1: - return dfu_pmic_read(offset, buf, len); - } - *len = 0; - return 0; -} - -int __weak dfu_get_medium_size_virt(struct dfu_entity *dfu, u64 *size) -{ - *size = SZ_1K; - - return 0; -} - -#endif - -#endif - static void board_copro_image_process(ulong fw_image, size_t fw_size) { int ret, id = 0; /* Copro id fixed to 0 as only one coproc on mp1 */
Hi
Patrice
- int ret;
- if (ret) {
strcat(buff, "&");
return;
-} -#endif
- int ret;
- if (ret) {
strcat(buff, "&");
return;
- int ret;
&dev);
- if (ret)
return ret;
- if (ret >= 0) {
*size = ret;
ret = 0;
- int ret;
&dev);
- if (ret)
return ret;
- if (ret >= 0) {
*size = ret;
ret = 0;
*size = 0;
ret = 0;
+#else
- return ret;
- case 0x0:
- case 0x1:
- *len = 0;
- *size = SZ_1K;
- int ret;
- if (ret) {
strcat(buff, "&");
return;
-#endif
- int ret;
&dev);
- if (ret)
return ret;
- if (ret >= 0) {
*size = ret;
ret = 0;
- int ret;
&dev);
- if (ret)
return ret;
- if (ret >= 0) {
*size = ret;
ret = 0;
*size = 0;
ret = 0;
-#else
-#endif
- return ret;
- case 0x0:
- case 0x1:
- *len = 0;
- *size = SZ_1K;
-#endif
-#endif
This patch reduces the stm32mp1 environment size and builds dynamically the DFU board configuration with gpt and mtd partitions and information from defconfig (CONFIG_DFU_ALT_RAM0).
board/dhelectronics/dh_stm32mp1/Kconfig | 1 + board/st/common/Kconfig | 7 ++ board/st/common/stm32mp_dfu.c | 130 +++++++++++++++++++----- include/configs/stm32mp1.h | 33 ------ 4 files changed, 110 insertions(+), 61 deletions(-)
diff --git a/board/dhelectronics/dh_stm32mp1/Kconfig b/board/dhelectronics/dh_stm32mp1/Kconfig index 8eab986640..69cc48f120 100644 --- a/board/dhelectronics/dh_stm32mp1/Kconfig +++ b/board/dhelectronics/dh_stm32mp1/Kconfig @@ -18,4 +18,5 @@ config ENV_OFFSET config ENV_OFFSET_REDUND default 0x1F0000 if ENV_IS_IN_SPI_FLASH
+source "board/st/common/Kconfig" endif diff --git a/board/st/common/Kconfig b/board/st/common/Kconfig index af01ca4891..08df845982 100644 --- a/board/st/common/Kconfig +++ b/board/st/common/Kconfig @@ -5,3 +5,10 @@ config CMD_STBOARD help This compile the stboard command to read and write the board in the OTP. + +config DFU_ALT_RAM0 + string "dfu for ram0" + default "uImage ram 0xc2000000 0x2000000;devicetree.dtb ram 0xc4000000 0x100000;uramdisk.image.gz ram 0xc4400000 0x10000000" + depends on ARCH_STM32MP && SET_DFU_ALT_INFO + help + This defines the partitions of ram used to build dfu dynamically. diff --git a/board/st/common/stm32mp_dfu.c b/board/st/common/stm32mp_dfu.c index 99ea21ce15..e129f8c8b5 100644 --- a/board/st/common/stm32mp_dfu.c +++ b/board/st/common/stm32mp_dfu.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <blk.h> #include <dfu.h> #include <env.h> #include <memalign.h> @@ -13,20 +14,86 @@
-static void board_get_alt_info(const char *dev, char *buff) +static void board_get_alt_info_mmc(struct udevice *dev, char *buf) { - char var_name[32] = "dfu_alt_info_"; - int ret; + disk_partition_t info; + int p, len, devnum; + bool first = true; + const char *name; + struct mmc *mmc; + struct blk_desc *desc; + + mmc = mmc_get_mmc_dev(dev); + if (!mmc) + return; + + if (mmc_init(mmc)) + return; + + desc = mmc_get_blk_desc(mmc); + if (!desc) + return; + + name = blk_get_if_type_name(desc->if_type); + devnum = desc->devnum; + len = strlen(buf); + + if (buf[0] != '\0') + len += snprintf(buf + len, + DFU_ALT_BUF_LEN - len, "&"); + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, + "%s %d=", name, devnum); + + if (IS_MMC(mmc) && mmc->capacity_boot) { + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, + "%s%d_boot1 raw 0x0 0x%llx mmcpart 1;", + name, devnum, mmc->capacity_boot); + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, + "%s%d_boot2 raw 0x0 0x%llx mmcpart 2", + name, devnum, mmc->capacity_boot); + first = false; + }
- ALLOC_CACHE_ALIGN_BUFFER(char, tmp_alt, DFU_ALT_BUF_LEN); + for (p = 1; p < MAX_SEARCH_PARTITIONS; p++) { + if (part_get_info(desc, p, &info)) + continue; + if (!first) + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, ";"); + first = false; + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, + "%s%d_%s part %d %d", + name, devnum, info.name, devnum, p); + } +}
- /* name of env variable to read = dfu_alt_info_<dev> */ - strcat(var_name, dev); - ret = env_get_f(var_name, tmp_alt, DFU_ALT_BUF_LEN); - if (ret) { - if (buff[0] != '\0') - strcat(buff, "&"); - strncat(buff, tmp_alt, DFU_ALT_BUF_LEN); +static void board_get_alt_info_mtd(struct mtd_info *mtd, char *buf) +{ + struct mtd_info *part; + bool first = true; + const char *name; + int len, partnum = 0; + + name = mtd->name; + len = strlen(buf); + + if (buf[0] != '\0') + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, "&"); + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, + "mtd %s=", name); + + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, + "%s raw 0x0 0x%llx ", + name, mtd->size); + + list_for_each_entry(part, &mtd->partitions, node) { + partnum++; + if (!first) + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, ";"); + first = false; + + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, + "%s_%s part %d", + name, part->name, partnum); } }
@@ -42,27 +109,34 @@ void set_dfu_alt_info(char *interface, char *devstr)
- /* probe all MTD devices */ - mtd_probe_devices(); - - board_get_alt_info("ram", buf); + snprintf(buf, DFU_ALT_BUF_LEN, + "ram 0=%s", CONFIG_DFU_ALT_RAM0);
if (!uclass_get_device(UCLASS_MMC, 0, &dev)) - board_get_alt_info("mmc0", buf); + board_get_alt_info_mmc(dev, buf);
if (!uclass_get_device(UCLASS_MMC, 1, &dev)) - board_get_alt_info("mmc1", buf); - - if (!uclass_get_device(UCLASS_SPI_FLASH, 0, &dev)) - board_get_alt_info("nor0", buf); - - mtd = get_mtd_device_nm("nand0"); - if (!IS_ERR_OR_NULL(mtd)) - board_get_alt_info("nand0", buf); - - mtd = get_mtd_device_nm("spi-nand0"); - if (!IS_ERR_OR_NULL(mtd)) - board_get_alt_info("spi-nand0", buf); + board_get_alt_info_mmc(dev, buf); + + if (CONFIG_IS_ENABLED(MTD)) { + /* probe all MTD devices */ + mtd_probe_devices(); + + /* probe SPI flash device on a bus */ + if (!uclass_get_device(UCLASS_SPI_FLASH, 0, &dev)) { + mtd = get_mtd_device_nm("nor0"); + if (!IS_ERR_OR_NULL(mtd)) + board_get_alt_info_mtd(mtd, buf); + } + + mtd = get_mtd_device_nm("nand0"); + if (!IS_ERR_OR_NULL(mtd)) + board_get_alt_info_mtd(mtd, buf); + + mtd = get_mtd_device_nm("spi-nand0"); + if (!IS_ERR_OR_NULL(mtd)) + board_get_alt_info_mtd(mtd, buf); + }
#ifdef CONFIG_DFU_VIRT strncat(buf, "&virt 0=OTP", DFU_ALT_BUF_LEN); diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index f451edad36..a9631d2a92 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -170,37 +170,6 @@ #define STM32MP_MTDPARTS #endif
-#define STM32MP_DFU_ALT_RAM \ - "dfu_alt_info_ram=ram 0=" \ - "uImage ram ${kernel_addr_r} 0x2000000;" \ - "devicetree.dtb ram ${fdt_addr_r} 0x100000;" \ - "uramdisk.image.gz ram ${ramdisk_addr_r} 0x10000000\0" - -#ifdef CONFIG_SET_DFU_ALT_INFO -#define STM32MP_DFU_ALT_INFO \ - "dfu_alt_info_nor0=mtd nor0=" \ - "nor_fsbl1 part 1;nor_fsbl2 part 2;" \ - "nor_ssbl part 3;nor_env part 4\0" \ - "dfu_alt_info_nand0=mtd nand0="\ - "nand_fsbl part 1;nand_ssbl1 part 2;" \ - "nand_ssbl2 part 3;nand_UBI partubi 4\0" \ - "dfu_alt_info_spi-nand0=mtd spi-nand0="\ - "spi-nand_fsbl part 1;spi-nand_ssbl1 part 2;" \ - "spi-nand_ssbl2 part 3;spi-nand_UBI partubi 4\0" \ - "dfu_alt_info_mmc0=mmc 0=" \ - "sdcard_fsbl1 part 0 1;sdcard_fsbl2 part 0 2;" \ - "sdcard_ssbl part 0 3;sdcard_bootfs part 0 4;" \ - "sdcard_vendorfs part 0 5;sdcard_rootfs part 0 6;" \ - "sdcard_userfs part 0 7\0" \ - "dfu_alt_info_mmc1=mmc 1=" \ - "emmc_fsbl1 raw 0x0 0x200 mmcpart 1;" \ - "emmc_fsbl2 raw 0x0 0x200 mmcpart 2;emmc_ssbl part 1 1;" \ - "emmc_bootfs part 1 2;emmc_vendorfs part 1 3;" \ - "emmc_rootfs part 1 4;emmc_userfs part 1 5\0" -#else -#define STM32MP_DFU_ALT_INFO -#endif - /* * memory layout for 32M uncompressed/compressed kernel, * 1M fdt, 1M script, 1M pxe and 1M for splashimage @@ -220,8 +189,6 @@ " then env set env_default 0;env save;fi\0" \ STM32MP_BOOTCMD \ STM32MP_MTDPARTS \ - STM32MP_DFU_ALT_RAM \ - STM32MP_DFU_ALT_INFO \ BOOTENV \ "boot_net_usb_start=true\0"
Hi
Patrice
- string "dfu for ram0"
- default "uImage ram 0xc2000000 0x2000000;devicetree.dtb ram 0xc4000000 0x100000;uramdisk.image.gz ram 0xc4400000 0x10000000"
- depends on ARCH_STM32MP && SET_DFU_ALT_INFO
- help
- int ret;
- disk_partition_t info;
- int p, len, devnum;
- bool first = true;
- const char *name;
- struct mmc *mmc;
- struct blk_desc *desc;
- mmc = mmc_get_mmc_dev(dev);
- if (!mmc)
return;
- if (mmc_init(mmc))
return;
- desc = mmc_get_blk_desc(mmc);
- if (!desc)
return;
- name = blk_get_if_type_name(desc->if_type);
- devnum = desc->devnum;
- len = strlen(buf);
- if (buf[0] != '\0')
- len += snprintf(buf + len, DFU_ALT_BUF_LEN - len,
- if (IS_MMC(mmc) && mmc->capacity_boot) {
first = false;
- for (p = 1; p < MAX_SEARCH_PARTITIONS; p++) {
continue;
if (!first)
first = false;
- if (ret) {
strcat(buff, "&");
- struct mtd_info *part;
- const char *name;
- int len, partnum = 0;
- name = mtd->name;
"mtd %s=", name);
name, mtd->size);
- list_for_each_entry(part, &mtd->partitions, node) {
partnum++;
if (!first)
first = false;
"%s_%s part %d",
}name, part->name, partnum);
- if (CONFIG_IS_ENABLED(MTD)) {
- memory layout for 32M uncompressed/compressed kernel,
- 1M fdt, 1M script, 1M pxe and 1M for splashimage
This patch reduces the stm32mp1 environment size and builds dynamically the MTD partitions with information from defconfig (CONFIG_MTDPARTS_...).
board/st/common/Kconfig | 57 ++++++++++++++++++ board/st/common/stm32mp_mtdparts.c | 93 +++++++++++++++--------------- include/configs/stm32mp1.h | 22 ------- 3 files changed, 104 insertions(+), 68 deletions(-)
diff --git a/board/st/common/Kconfig b/board/st/common/Kconfig index 08df845982..015ba40939 100644 --- a/board/st/common/Kconfig +++ b/board/st/common/Kconfig @@ -6,6 +6,63 @@ config CMD_STBOARD This compile the stboard command to read and write the board in the OTP.
+config MTDPARTS_NAND0_BOOT + string "mtd boot partitions for nand0" + default "2m(fsbl),2m(ssbl1),2m(ssbl2)" + depends on SYS_MTDPARTS_RUNTIME && ARCH_STM32MP + help + This define the partitions of nand0 used to build mtparts dynamically + for boot from nand0. + Each partition need to be aligned with the device erase block size, + 512KB is the max size for the NAND supported by stm32mp1 platform. + +config MTDPARTS_NAND0_TEE + string "mtd tee partitions for nand0" + default "512k(teeh),512k(teed),512k(teex)" + depends on SYS_MTDPARTS_RUNTIME && ARCH_STM32MP + help + This define the tee partitions added in mtparts dynamically + when tee is supported with boot from nand0. + Each partition need to be aligned with the device erase block size, + 512KB is the max size for the NAND supported by stm32mp1 platform. + +config MTDPARTS_NOR0_BOOT + string "mtd boot partitions for nor0" + default "256k(fsbl1),256k(fsbl2),2m(ssbl),512k(u-boot-env)" + depends on SYS_MTDPARTS_RUNTIME && ARCH_STM32MP + help + This define the partitions of nand0 used to build mtparts dynamically + for boot from nor0. + Each partition need to be aligned with the device erase block size, + with 256KB we support all the NOR. + U-Boot env partition (512kB) use 2 erase block for redundancy. + +config MTDPARTS_NOR0_TEE + string "mtd tee partitions for nor0" + default "256k(teeh),256k(teed),256k(teex)" + depends on SYS_MTDPARTS_RUNTIME && ARCH_STM32MP + help + This define the tee partitions added in mtparts dynamically + when tee is supported with boot from nor0. + +config MTDPARTS_SPINAND0_BOOT + string "mtd boot partitions for spi-nand0" + default "2m(fsbl),2m(ssbl1),2m(ssbl2)" + depends on SYS_MTDPARTS_RUNTIME && ARCH_STM32MP + help + This define the partitions of nand0 used to build mtparts dynamically + for boot from spi-nand0, + 512KB is the max size for the NAND supported by stm32mp1 platform. + +config MTDPARTS_SPINAND0_TEE + string "mtd tee partitions for spi-nand0" + default "512k(teeh),512k(teed),512k(teex)" + depends on SYS_MTDPARTS_RUNTIME && ARCH_STM32MP + help + This define the tee partitions added in mtparts dynamically + when tee is supported with boot from spi-nand0, + 512KB is the max size for the NAND supported by stm32mp1 platform. + config DFU_ALT_RAM0 string "dfu for ram0" default "uImage ram 0xc2000000 0x2000000;devicetree.dtb ram 0xc4000000 0x100000;uramdisk.image.gz ram 0xc4400000 0x10000000" diff --git a/board/st/common/stm32mp_mtdparts.c b/board/st/common/stm32mp_mtdparts.c index d77e075864..d4c0a7db9f 100644 --- a/board/st/common/stm32mp_mtdparts.c +++ b/board/st/common/stm32mp_mtdparts.c @@ -19,54 +19,42 @@ DECLARE_GLOBAL_DATA_PTR;
/** - * The mtdparts_nand0 and mtdparts_nor0 variable tends to be long. - * If we need to access it before the env is relocated, then we need - * to use our own stack buffer. gd->env_buf will be too small. - * - * @param buf temporary buffer pointer MTDPARTS_LEN long - * @return mtdparts variable string, NULL if not found - */ -static const char *env_get_mtdparts(const char *str, char *buf) -{ - if (gd->flags & GD_FLG_ENV_READY) - return env_get(str); - if (env_get_f(str, buf, MTDPARTS_LEN) != -1) - return buf; - - return NULL; -} - -/** - * update the variables "mtdids" and "mtdparts" with content of mtdparts_<dev> + * update the variables "mtdids" and "mtdparts" with boot, tee and user strings */ static void board_get_mtdparts(const char *dev, char *mtdids, - char *mtdparts) + char *mtdparts, + const char *boot, + const char *tee, + const char *user) { - char env_name[32] = "mtdparts_"; - char tmp_mtdparts[MTDPARTS_LEN]; - const char *tmp; - - /* name of env variable to read = mtdparts_<dev> */ - strcat(env_name, dev); - tmp = env_get_mtdparts(env_name, tmp_mtdparts); - if (tmp) { - /* mtdids: "<dev>=<dev>, ...." */ - if (mtdids[0] != '\0') - strcat(mtdids, ","); - strcat(mtdids, dev); - strcat(mtdids, "="); - strcat(mtdids, dev); - - /* mtdparts: "mtdparts=<dev>:<mtdparts_<dev>>;..." */ - if (mtdparts[0] != '\0') - strncat(mtdparts, ";", MTDPARTS_LEN); - else - strcat(mtdparts, "mtdparts="); - strncat(mtdparts, dev, MTDPARTS_LEN); - strncat(mtdparts, ":", MTDPARTS_LEN); - strncat(mtdparts, tmp, MTDPARTS_LEN); + /* mtdids: "<dev>=<dev>, ...." */ + if (mtdids[0] != '\0') + strcat(mtdids, ","); + strcat(mtdids, dev); + strcat(mtdids, "="); + strcat(mtdids, dev); + + /* mtdparts: "mtdparts=<dev>:<mtdparts_<dev>>;..." */ + if (mtdparts[0] != '\0') + strncat(mtdparts, ";", MTDPARTS_LEN); + else + strcat(mtdparts, "mtdparts="); + + strncat(mtdparts, dev, MTDPARTS_LEN); + strncat(mtdparts, ":", MTDPARTS_LEN); + + if (boot) { + strncat(mtdparts, boot, MTDPARTS_LEN); + strncat(mtdparts, ",", MTDPARTS_LEN); + } + + if (CONFIG_IS_ENABLED(STM32MP1_OPTEE) && tee) { + strncat(mtdparts, tee, MTDPARTS_LEN); + strncat(mtdparts, ",", MTDPARTS_LEN); } + + strncat(mtdparts, user, MTDPARTS_LEN); }
void board_mtdparts_default(const char **mtdids, const char **mtdparts) @@ -76,6 +64,7 @@ void board_mtdparts_default(const char **mtdids, const char **mtdparts) static char parts[3 * MTDPARTS_LEN + 1]; static char ids[MTDIDS_LEN + 1]; static bool mtd_initialized; + bool tee = false;
if (mtd_initialized) { *mtdids = ids; @@ -83,6 +72,9 @@ void board_mtdparts_default(const char **mtdids, const char **mtdparts) return; }
+ if (CONFIG_IS_ENABLED(STM32MP1_OPTEE)) + tee = true; + memset(parts, 0, sizeof(parts)); memset(ids, 0, sizeof(ids));
@@ -95,18 +87,27 @@ void board_mtdparts_default(const char **mtdids, const char **mtdparts)
mtd = get_mtd_device_nm("nand0"); if (!IS_ERR_OR_NULL(mtd)) { - board_get_mtdparts("nand0", ids, parts); + board_get_mtdparts("nand0", ids, parts, + CONFIG_MTDPARTS_NAND0_BOOT, + tee ? CONFIG_MTDPARTS_NAND0_TEE : NULL, + "-(UBI)"); put_mtd_device(mtd); }
mtd = get_mtd_device_nm("spi-nand0"); if (!IS_ERR_OR_NULL(mtd)) { - board_get_mtdparts("spi-nand0", ids, parts); + board_get_mtdparts("spi-nand0", ids, parts, + CONFIG_MTDPARTS_SPINAND0_BOOT, + tee ? CONFIG_MTDPARTS_SPINAND0_TEE : NULL, + "-(UBI)"); put_mtd_device(mtd); }
if (!uclass_get_device(UCLASS_SPI_FLASH, 0, &dev)) - board_get_mtdparts("nor0", ids, parts); + board_get_mtdparts("nor0", ids, parts, + CONFIG_MTDPARTS_NOR0_BOOT, + tee ? CONFIG_MTDPARTS_NOR0_TEE : NULL, + "-(nor_user)");
mtd_initialized = true; *mtdids = ids; diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index a9631d2a92..a80741f6a2 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -149,27 +149,6 @@
#include <config_distro_bootcmd.h>
-#ifdef CONFIG_STM32MP1_OPTEE -/* with OPTEE: define specific MTD partitions = teeh, teed, teex */ -#define STM32MP_MTDPARTS \ - "mtdparts_nor0=256k(fsbl1),256k(fsbl2),2m(ssbl),256k(u-boot-env),256k(teeh),256k(teed),256k(teex),-(nor_user)\0" \ - "mtdparts_nand0=2m(fsbl),2m(ssbl1),2m(ssbl2),512k(teeh),512k(teed),512k(teex),-(UBI)\0" \ - "mtdparts_spi-nand0=2m(fsbl),2m(ssbl1),2m(ssbl2),"\ - "512k(teeh),512k(teed),512k(teex),-(UBI)\0" - -#else /* CONFIG_STM32MP1_OPTEE */ -#define STM32MP_MTDPARTS \ - "mtdparts_nor0=256k(fsbl1),256k(fsbl2),2m(ssbl),256k(u-boot-env),-(nor_user)\0" \ - "mtdparts_nand0=2m(fsbl),2m(ssbl1),2m(ssbl2),-(UBI)\0" \ - "mtdparts_spi-nand0=2m(fsbl),2m(ssbl1),2m(ssbl2),-(UBI)\0" - -#endif /* CONFIG_STM32MP1_OPTEE */ - -#ifndef CONFIG_SYS_MTDPARTS_RUNTIME -#undef STM32MP_MTDPARTS -#define STM32MP_MTDPARTS -#endif - /* * memory layout for 32M uncompressed/compressed kernel, * 1M fdt, 1M script, 1M pxe and 1M for splashimage @@ -188,7 +167,6 @@ "env_check=if test $env_default -eq 1;"\ " then env set env_default 0;env save;fi\0" \ STM32MP_BOOTCMD \ - STM32MP_MTDPARTS \ BOOTENV \ "boot_net_usb_start=true\0"
Hi
Patrice
- string "mtd boot partitions for nand0"
- default "2m(fsbl),2m(ssbl1),2m(ssbl2)"
- depends on SYS_MTDPARTS_RUNTIME && ARCH_STM32MP
- help
- string "mtd tee partitions for nand0"
- default "512k(teeh),512k(teed),512k(teex)"
- help
- string "mtd boot partitions for nor0"
- default "256k(fsbl1),256k(fsbl2),2m(ssbl),512k(u-boot-env)"
- help
for boot from nor0.
- string "mtd tee partitions for nor0"
- default "256k(teeh),256k(teed),256k(teex)"
- help
- string "mtd boot partitions for spi-nand0"
- help
- string "mtd tee partitions for spi-nand0"
- help
return buf;
- return NULL;
- update the variables "mtdids" and "mtdparts" with boot, tee and user strings
char *mtdparts)
char *mtdparts,
const char *boot,
const char *tee,
const char *user)
- const char *tmp;
- if (tmp) {
else
- else
- if (boot) {
- if (CONFIG_IS_ENABLED(STM32MP1_OPTEE) && tee) {
}strncat(mtdparts, ",", MTDPARTS_LEN);
- strncat(mtdparts, user, MTDPARTS_LEN);
bool tee = false;
- if (CONFIG_IS_ENABLED(STM32MP1_OPTEE))
tee = true;
- memset(parts, 0, sizeof(parts)); memset(ids, 0, sizeof(ids));
"-(UBI)");
"-(UBI)");
"-(nor_user)");
Add reserve memory for OP-TEE in U-Boot and in kernel device tree: - no more reduce the DDR size in "memory" node: CONFIG_SYS_MEM_TOP_HIDE is no more used - U-Boot device-tree defines the needed "reserved-memory" for OP-TEE and U-Boot should not use this reserved memory: board_get_usable_ram_top use lmb lib to found the first free region, the not reserved memory, enough to relocate U-Boot: the needed size of U-Boot is estimated with gd->mon_len + CONFIG_SYS_MALLOC_LEN. - the optee node ("optee@...": firmware with compatible "linaro,optee-tz") and the associated "reserved-memory" are deactivated in kernel device tree when OP-TEE is not detected by U-Boot to prevent kernel issue (memory is reserved but not used, optee driver probe failed).
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com --- This patch depends on "ARM: bootm: take into account gd->ram_top" http://patchwork.ozlabs.org/project/uboot/list/?series=158413
arch/arm/dts/stm32mp157a-dk1.dts | 5 +++++ arch/arm/dts/stm32mp157c-ed1.dts | 5 +++++ arch/arm/mach-stm32mp/dram_init.c | 18 ++++++++++++++++++ arch/arm/mach-stm32mp/fdt.c | 23 +++++++++++++++++++++++ include/configs/stm32mp1.h | 4 ---- 5 files changed, 51 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/stm32mp157a-dk1.dts b/arch/arm/dts/stm32mp157a-dk1.dts index 624bf6954b..70e7aa2fd7 100644 --- a/arch/arm/dts/stm32mp157a-dk1.dts +++ b/arch/arm/dts/stm32mp157a-dk1.dts @@ -74,6 +74,11 @@ reg = <0xd4000000 0x4000000>; no-map; }; + + optee@de000000 { + reg = <0xde000000 0x02000000>; + no-map; + }; };
led { diff --git a/arch/arm/dts/stm32mp157c-ed1.dts b/arch/arm/dts/stm32mp157c-ed1.dts index ae4da39ce8..27a0d05d82 100644 --- a/arch/arm/dts/stm32mp157c-ed1.dts +++ b/arch/arm/dts/stm32mp157c-ed1.dts @@ -68,6 +68,11 @@ reg = <0xe8000000 0x8000000>; no-map; }; + + optee@fe000000 { + reg = <0xfe000000 0x02000000>; + no-map; + }; };
aliases { diff --git a/arch/arm/mach-stm32mp/dram_init.c b/arch/arm/mach-stm32mp/dram_init.c index 7688b3e315..3233415eff 100644 --- a/arch/arm/mach-stm32mp/dram_init.c +++ b/arch/arm/mach-stm32mp/dram_init.c @@ -5,6 +5,7 @@
#include <common.h> #include <dm.h> +#include <lmb.h> #include <ram.h>
DECLARE_GLOBAL_DATA_PTR; @@ -31,3 +32,20 @@ int dram_init(void)
return 0; } + +ulong board_get_usable_ram_top(ulong total_size) +{ + phys_addr_t reg; + struct lmb lmb; + + /* found enough not-reserved memory to relocated U-Boot */ + lmb_init(&lmb); + lmb_add(&lmb, gd->ram_base, gd->ram_size); + boot_fdt_add_mem_rsv_regions(&lmb, (void *)gd->fdt_blob); + reg = lmb_alloc(&lmb, CONFIG_SYS_MALLOC_LEN + total_size, SZ_4K); + + if (reg) + return ALIGN(reg + CONFIG_SYS_MALLOC_LEN + total_size, SZ_4K); + + return gd->ram_top; +} diff --git a/arch/arm/mach-stm32mp/fdt.c b/arch/arm/mach-stm32mp/fdt.c index 3ee7d6a833..ae82270e42 100644 --- a/arch/arm/mach-stm32mp/fdt.c +++ b/arch/arm/mach-stm32mp/fdt.c @@ -218,6 +218,26 @@ static void stm32_fdt_disable(void *fdt, int offset, u32 addr, string, addr, name); }
+static void stm32_fdt_disable_optee(void *blob) +{ + int off, node; + + off = fdt_node_offset_by_compatible(blob, -1, "linaro,optee-tz"); + if (off >= 0 && fdtdec_get_is_enabled(blob, off)) + fdt_status_disabled(blob, off); + + /* Disabled "optee@..." reserved-memory node */ + off = fdt_path_offset(blob, "/reserved-memory/"); + if (off < 0) + return; + for (node = fdt_first_subnode(blob, off); + node >= 0; + node = fdt_next_subnode(blob, node)) { + if (!strncmp(fdt_get_name(blob, node, NULL), "optee@", 6)) + fdt_status_disabled(blob, node); + } +} + /* * This function is called right before the kernel is booted. "blob" is the * device tree that will be passed to the kernel. @@ -302,5 +322,8 @@ int ft_system_setup(void *blob, bd_t *bd) "st,package", pkg, false); }
+ if (!CONFIG_IS_ENABLED(STM32MP1_OPTEE)) + stm32_fdt_disable_optee(blob); + return ret; } diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index a80741f6a2..c5b09f1a2a 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -23,10 +23,6 @@ #define CONFIG_SYS_SDRAM_BASE STM32_DDR_BASE #define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE
-#ifdef CONFIG_STM32MP1_OPTEE -#define CONFIG_SYS_MEM_TOP_HIDE SZ_32M -#endif /* CONFIG_STM32MP1_OPTEE */ - /* * Console I/O buffer size */
Hi
optee@de000000 {
no-map;
led {
optee@fe000000 {
no-map;
aliases {
return 0; }
- phys_addr_t reg;
- struct lmb lmb;
- /* found enough not-reserved memory to relocated U-Boot */
- lmb_init(&lmb);
- lmb_add(&lmb, gd->ram_base, gd->ram_size);
- boot_fdt_add_mem_rsv_regions(&lmb, (void *)gd->fdt_blob);
- reg = lmb_alloc(&lmb, CONFIG_SYS_MALLOC_LEN + total_size, SZ_4K);
- if (reg)
- return gd->ram_top;
- int off, node;
- off = fdt_node_offset_by_compatible(blob, -1, "linaro,optee-tz");
- if (off >= 0 && fdtdec_get_is_enabled(blob, off))
- /* Disabled "optee@..." reserved-memory node */
- off = fdt_path_offset(blob, "/reserved-memory/");
- if (off < 0)
return;
- for (node = fdt_first_subnode(blob, off);
node >= 0;
- This function is called right before the kernel is booted. "blob" is the
- device tree that will be passed to the kernel.
- if (!CONFIG_IS_ENABLED(STM32MP1_OPTEE))
- return ret;
- Console I/O buffer size
Patrice
Activate OP-TEE driver for trusted and optee defconfig.
This driver allows detection of TEE presence for boot from flash; CONFIG_STM32MP1_OPTEE is also removed.
arch/arm/mach-stm32mp/Kconfig | 10 ---------- arch/arm/mach-stm32mp/fdt.c | 4 +++- board/dhelectronics/dh_stm32mp1/board.c | 4 +--- board/st/common/stm32mp_mtdparts.c | 6 ++++-- board/st/stm32mp1/stm32mp1.c | 4 +--- configs/stm32mp15_optee_defconfig | 4 +++- configs/stm32mp15_trusted_defconfig | 3 +++ 7 files changed, 15 insertions(+), 20 deletions(-)
diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index 96153693a7..1a5545b98d 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -93,16 +93,6 @@ config STM32MP1_TRUSTED BootRom => TF-A.stm32 (clock & DDR) => U-Boot.stm32 TF-A monitor provides proprietary SMC to manage secure devices
-config STM32MP1_OPTEE - bool "Support trusted boot with TF-A and OP-TEE" - depends on STM32MP1_TRUSTED - default n - help - Say Y here to enable boot with TF-A and OP-TEE - Trusted boot chain is : - BootRom => TF-A.stm32 (clock & DDR) => OP-TEE => U-Boot.stm32 - OP-TEE monitor provides ST SMC to access to secure resources - config SYS_TEXT_BASE default 0xC0100000
diff --git a/arch/arm/mach-stm32mp/fdt.c b/arch/arm/mach-stm32mp/fdt.c index ae82270e42..21b5f09728 100644 --- a/arch/arm/mach-stm32mp/fdt.c +++ b/arch/arm/mach-stm32mp/fdt.c @@ -5,6 +5,7 @@
#include <common.h> #include <fdt_support.h> +#include <tee.h> #include <asm/arch/sys_proto.h> #include <dt-bindings/pinctrl/stm32-pinfunc.h> #include <linux/io.h> @@ -322,7 +323,8 @@ int ft_system_setup(void *blob, bd_t *bd) "st,package", pkg, false); }
- if (!CONFIG_IS_ENABLED(STM32MP1_OPTEE)) + if (!CONFIG_IS_ENABLED(OPTEE) || + !tee_find_device(NULL, NULL, NULL, NULL)) stm32_fdt_disable_optee(blob);
return ret; diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index bd6540a2aa..ea51b92282 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -117,9 +117,7 @@ int checkboard(void) const char *fdt_compat; int fdt_compat_len;
- if (IS_ENABLED(CONFIG_STM32MP1_OPTEE)) - mode = "trusted with OP-TEE"; - else if (IS_ENABLED(CONFIG_STM32MP1_TRUSTED)) + if (IS_ENABLED(CONFIG_STM32MP1_TRUSTED)) mode = "trusted"; else mode = "basic"; diff --git a/board/st/common/stm32mp_mtdparts.c b/board/st/common/stm32mp_mtdparts.c index d4c0a7db9f..2b6413be16 100644 --- a/board/st/common/stm32mp_mtdparts.c +++ b/board/st/common/stm32mp_mtdparts.c @@ -9,6 +9,7 @@ #include <env_internal.h> #include <mtd.h> #include <mtd_node.h> +#include <tee.h>
#define MTDPARTS_LEN 256 #define MTDIDS_LEN 128 @@ -49,7 +50,7 @@ static void board_get_mtdparts(const char *dev, strncat(mtdparts, ",", MTDPARTS_LEN); }
- if (CONFIG_IS_ENABLED(STM32MP1_OPTEE) && tee) { + if (tee) { strncat(mtdparts, tee, MTDPARTS_LEN); strncat(mtdparts, ",", MTDPARTS_LEN); } @@ -72,7 +73,8 @@ void board_mtdparts_default(const char **mtdids, const char **mtdparts) return; }
- if (CONFIG_IS_ENABLED(STM32MP1_OPTEE)) + if (CONFIG_IS_ENABLED(OPTEE) && + tee_find_device(NULL, NULL, NULL, NULL)) tee = true;
memset(parts, 0, sizeof(parts)); diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 2ab3b5cc9a..14c56a0f24 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -87,9 +87,7 @@ int checkboard(void) const char *fdt_compat; int fdt_compat_len;
- if (IS_ENABLED(CONFIG_STM32MP1_OPTEE)) - mode = "trusted with OP-TEE"; - else if (IS_ENABLED(CONFIG_STM32MP1_TRUSTED)) + if (CONFIG_IS_ENABLED(STM32MP1_TRUSTED)) mode = "trusted"; else mode = "basic"; diff --git a/configs/stm32mp15_optee_defconfig b/configs/stm32mp15_optee_defconfig index 317cd55862..f0d524d344 100644 --- a/configs/stm32mp15_optee_defconfig +++ b/configs/stm32mp15_optee_defconfig @@ -4,7 +4,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_ENV_OFFSET=0x280000 CONFIG_TARGET_ST_STM32MP15x=y -CONFIG_STM32MP1_OPTEE=y CONFIG_ENV_OFFSET_REDUND=0x2C0000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y @@ -111,6 +110,9 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y CONFIG_STM32_SPI=y +CONFIG_TEE=y +CONFIG_OPTEE=y +# CONFIG_OPTEE_TA_AVB is not set CONFIG_USB=y CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 73cbe6c7d6..f0d524d344 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -110,6 +110,9 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y CONFIG_STM32_SPI=y +CONFIG_TEE=y +CONFIG_OPTEE=y +# CONFIG_OPTEE_TA_AVB is not set CONFIG_USB=y CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y
Hi
- default n
- help
return ret;
- if (IS_ENABLED(CONFIG_STM32MP1_TRUSTED)) mode = "trusted"; else mode = "basic";
- if (tee) { strncat(mtdparts, tee, MTDPARTS_LEN); strncat(mtdparts, ",", MTDPARTS_LEN); }
tee = true;
- if (CONFIG_IS_ENABLED(STM32MP1_TRUSTED)) mode = "trusted"; else mode = "basic";
Patrice
Save and use the FDT address provided by TF-A in r2 at boot time (it is NT_FW_CONFIG = Non Trusted Firmware configuration file)
Address is saved in save_boot_params(), called by start.S and the used DTB is gd->fdt_blob = board_fdt_blob_setup().
If dtb is not provided or invalid, U-Boot use as fallback the builtin DTB.
arch/arm/mach-stm32mp/Makefile | 1 + arch/arm/mach-stm32mp/boot_params.c | 45 +++++++++++++++++++++++++++++ 2 files changed, 46 insertions(+) create mode 100644 arch/arm/mach-stm32mp/boot_params.c
diff --git a/arch/arm/mach-stm32mp/Makefile b/arch/arm/mach-stm32mp/Makefile index eee39c27c3..19ca3b08a5 100644 --- a/arch/arm/mach-stm32mp/Makefile +++ b/arch/arm/mach-stm32mp/Makefile @@ -13,6 +13,7 @@ else obj-y += bsec.o obj-$(CONFIG_CMD_STM32KEY) += cmd_stm32key.o obj-$(CONFIG_ARMV7_PSCI) += psci.o +obj-$(CONFIG_STM32MP1_TRUSTED) += boot_params.o endif
obj-$(CONFIG_$(SPL_)DM_REGULATOR) += pwr_regulator.o diff --git a/arch/arm/mach-stm32mp/boot_params.c b/arch/arm/mach-stm32mp/boot_params.c new file mode 100644 index 0000000000..e4351de939 --- /dev/null +++ b/arch/arm/mach-stm32mp/boot_params.c @@ -0,0 +1,45 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2019, STMicroelectronics - All Rights Reserved + */ + +#include <common.h> +#include <asm/sections.h> +#include <asm/system.h> + +/* + * Force data-section, as .bss will not be valid + * when save_boot_params is invoked. + */ +static unsigned long nt_fw_dtb __section(".data"); + +/* + * Save the FDT address provided by TF-A in r2 at boot time + * This function is called from start.S + */ +void save_boot_params(unsigned long r0, unsigned long r1, unsigned long r2, + unsigned long r3) +{ + nt_fw_dtb = r2; + + save_boot_params_ret(); +} + +/* + * Use the saved FDT address provided by TF-A at boot time (NT_FW_CONFIG = + * Non Trusted Firmware configuration file) when the pointer is valid + */ +void *board_fdt_blob_setup(void) +{ + debug("%s: nt_fw_dtb=%lx\n", __func__, nt_fw_dtb); + + /* use external device tree only if address is valid */ + if (nt_fw_dtb >= STM32_DDR_BASE) { + if (fdt_magic(nt_fw_dtb) == FDT_MAGIC) + return (void *)nt_fw_dtb; + debug("%s: DTB not found.\n", __func__); + } + debug("%s: fall back to builtin DTB, %p\n", __func__, &_end); + + return (void *)&_end; +}
Hi
- Copyright (C) 2019, STMicroelectronics - All Rights Reserved
- Force data-section, as .bss will not be valid
- when save_boot_params is invoked.
- Save the FDT address provided by TF-A in r2 at boot time
- This function is called from start.S
unsigned long r3)
- nt_fw_dtb = r2;
- save_boot_params_ret();
- Use the saved FDT address provided by TF-A at boot time (NT_FW_CONFIG =
- Non Trusted Firmware configuration file) when the pointer is valid
- debug("%s: nt_fw_dtb=%lx\n", __func__, nt_fw_dtb);
- /* use external device tree only if address is valid */
- if (nt_fw_dtb >= STM32_DDR_BASE) {
- debug("%s: fall back to builtin DTB, %p\n", __func__, &_end);
- return (void *)&_end;
Patrice
As the op-tee presence is detected by U-boot, the stm32mp15_optee_defconfig is identical to stm32mp15_trusted_defconfig and can be removed.
board/st/stm32mp1/MAINTAINERS | 1 - configs/stm32mp15_optee_defconfig | 134 ------------------------------ doc/board/st/stm32mp1.rst | 32 ++----- 3 files changed, 7 insertions(+), 160 deletions(-) delete mode 100644 configs/stm32mp15_optee_defconfig
diff --git a/board/st/stm32mp1/MAINTAINERS b/board/st/stm32mp1/MAINTAINERS index 2930947716..96c4559033 100644 --- a/board/st/stm32mp1/MAINTAINERS +++ b/board/st/stm32mp1/MAINTAINERS @@ -6,6 +6,5 @@ S: Maintained F: arch/arm/dts/stm32mp15* F: board/st/stm32mp1/ F: configs/stm32mp15_basic_defconfig -F: configs/stm32mp15_optee_defconfig F: configs/stm32mp15_trusted_defconfig F: include/configs/stm32mp1.h diff --git a/configs/stm32mp15_optee_defconfig b/configs/stm32mp15_optee_defconfig deleted file mode 100644 index f0d524d344..0000000000 --- a/configs/stm32mp15_optee_defconfig +++ /dev/null @@ -1,134 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_STM32MP=y -CONFIG_SYS_MALLOC_F_LEN=0x3000 -CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_ENV_OFFSET=0x280000 -CONFIG_TARGET_ST_STM32MP15x=y -CONFIG_ENV_OFFSET_REDUND=0x2C0000 -CONFIG_DISTRO_DEFAULTS=y -CONFIG_FIT=y -CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" -CONFIG_SYS_PROMPT="STM32MP> " -# CONFIG_CMD_BOOTD is not set -# CONFIG_CMD_ELF is not set -# CONFIG_CMD_IMI is not set -# CONFIG_CMD_XIMG is not set -# CONFIG_CMD_EXPORTENV is not set -# CONFIG_CMD_IMPORTENV is not set -CONFIG_CMD_MEMINFO=y -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_ADC=y -CONFIG_CMD_CLK=y -CONFIG_CMD_DFU=y -CONFIG_CMD_FUSE=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_MTD=y -CONFIG_CMD_REMOTEPROC=y -CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_BMP=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -CONFIG_CMD_TIMER=y -CONFIG_CMD_PMIC=y -CONFIG_CMD_REGULATOR=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_MTDPARTS=y -CONFIG_CMD_UBI=y -CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" -CONFIG_ENV_IS_NOWHERE=y -CONFIG_ENV_IS_IN_EXT4=y -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_ENV_IS_IN_UBI=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_ENV_EXT4_INTERFACE="mmc" -CONFIG_ENV_EXT4_DEVICE_AND_PART="0:auto" -CONFIG_ENV_EXT4_FILE="/uboot.env" -CONFIG_ENV_UBI_PART="UBI" -CONFIG_ENV_UBI_VOLUME="uboot_config" -CONFIG_ENV_UBI_VOLUME_REDUND="uboot_config_r" -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_STM32_ADC=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_DFU_MTD=y -CONFIG_DFU_VIRT=y -CONFIG_SET_DFU_ALT_INFO=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0xC0000000 -CONFIG_FASTBOOT_BUF_SIZE=0x02000000 -CONFIG_FASTBOOT_USB_DEV=1 -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=1 -CONFIG_DM_HWSPINLOCK=y -CONFIG_HWSPINLOCK_STM32=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_STM32F7=y -CONFIG_LED=y -CONFIG_LED_GPIO=y -CONFIG_DM_MAILBOX=y -CONFIG_STM32_IPCC=y -CONFIG_DM_MMC=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_STM32_SDMMC2=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_SYS_MTDPARTS_RUNTIME=y -CONFIG_MTD_RAW_NAND=y -CONFIG_NAND_STM32_FMC2=y -CONFIG_MTD_SPI_NAND=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_WINBOND=y -# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_SPI_FLASH_MTD=y -CONFIG_DM_ETH=y -CONFIG_DWC_ETH_QOS=y -CONFIG_PHY=y -CONFIG_PHY_STM32_USBPHYC=y -CONFIG_PINCONF=y -CONFIG_PINCTRL_STMFX=y -CONFIG_DM_PMIC=y -CONFIG_PMIC_STPMIC1=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_DM_REGULATOR_STM32_VREFBUF=y -CONFIG_DM_REGULATOR_STPMIC1=y -CONFIG_REMOTEPROC_STM32_COPRO=y -CONFIG_DM_RNG=y -CONFIG_RNG_STM32MP1=y -CONFIG_DM_RTC=y -CONFIG_RTC_STM32=y -CONFIG_SERIAL_RX_BUFFER=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_STM32_QSPI=y -CONFIG_STM32_SPI=y -CONFIG_TEE=y -CONFIG_OPTEE=y -# CONFIG_OPTEE_TA_AVB is not set -CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_EHCI_GENERIC=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="STMicroelectronics" -CONFIG_USB_GADGET_VENDOR_NUM=0x0483 -CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 -CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_DM_VIDEO=y -CONFIG_BACKLIGHT_GPIO=y -CONFIG_VIDEO_LCD_ORISETECH_OTM8009A=y -CONFIG_VIDEO_LCD_RAYDIUM_RM68200=y -CONFIG_VIDEO_STM32=y -CONFIG_VIDEO_STM32_DSI=y -CONFIG_VIDEO_STM32_MAX_XRES=1280 -CONFIG_VIDEO_STM32_MAX_YRES=800 -CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/doc/board/st/stm32mp1.rst b/doc/board/st/stm32mp1.rst index b7a0fbfd03..7fccdfbb94 100644 --- a/doc/board/st/stm32mp1.rst +++ b/doc/board/st/stm32mp1.rst @@ -80,32 +80,16 @@ defconfig_file : stm32mp15_trusted_defconfig + +-------------------------+------------+-------+ | |Trusted Firmware-A (TF-A)| U-Boot | Linux | +-------------+-------------------------+------------+-------+ - | TrustZone |TF-A secure monitor | + | TrustZone |secure monitor | +-------------+-------------------------+------------+-------+
TF-A performs a full initialization of Secure peripherals and installs a -secure monitor (BL32=SPMin). +secure monitor, BL32:
-U-Boot is running in normal world and uses TF-A monitor to access -to secure resources. - -The **Trusted** boot chain with **OP-TEE** -`````````````````````````````````````````` - -defconfig_file : stm32mp15_optee_defconfig - - +-------------+-------------------------+------------+-------+ - | ROM code | FSBL | SSBL | OS | - + +-------------------------+------------+-------+ - | |Trusted Firmware-A (TF-A)| U-Boot | Linux | - +-------------+-------------------------+------------+-------+ - | TrustZone |OP-TEE | - +-------------+-------------------------+------------+-------+ - -TF-A performs a full initialization of Secure peripherals and installs OP-TEE -from specific partitions (teeh, teed, teex). + * SPMin provided by TF-A or + * OP-TEE from specific partitions (teeh, teed, teex).
-U-Boot is running in normal world and uses OP-TEE monitor to access +U-Boot is running in normal world and uses the secure monitor to access to secure resources.
The **Basic** boot chain @@ -180,7 +164,6 @@ Build Procedure for example: use one output directory for each configuration::
# export KBUILD_OUTPUT=stm32mp15_trusted - # export KBUILD_OUTPUT=stm32mp15_optee # export KBUILD_OUTPUT=stm32mp15_basic
you can build outside of code directory:: @@ -194,7 +177,6 @@ Build Procedure with <defconfig_file>:
- For **trusted** boot mode : **stm32mp15_trusted_defconfig** - - For **trusted** with OP-TEE boot mode : **stm32mp15_optee_defconfig** - For basic boot mode: stm32mp15_basic_defconfig
5. Configure the device-tree and build the U-Boot image:: @@ -211,8 +193,8 @@ Build Procedure
b) trusted with OP-TEE boot on dk2::
- # export KBUILD_OUTPUT=stm32mp15_optee - # make stm32mp15_optee_defconfig + # export KBUILD_OUTPUT=stm32mp15_trusted + # make stm32mp15_trusted_defconfig # make DEVICE_TREE=stm32mp157c-dk2 all
c) basic boot on ev1::
Hi
Patrice
- | TrustZone |secure monitor | +-------------+-------------------------+------------+-------+
- SPMin provided by TF-A or
- OP-TEE from specific partitions (teeh, teed, teex).
- Configure the device-tree and build the U-Boot image::
Manage BOOT_FLASH_SPINAND, with boot_device="spi-nand" and treat this value in bootcmd_stm32mp.
arch/arm/mach-stm32mp/cpu.c | 4 ++++ arch/arm/mach-stm32mp/include/mach/stm32.h | 3 +++ arch/arm/mach-stm32mp/spl.c | 2 ++ board/st/stm32mp1/stm32mp1.c | 2 ++ include/configs/stm32mp1.h | 5 +++-- 5 files changed, 14 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index 9aa5794334..e14e3e47f2 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -435,6 +435,10 @@ static void setup_boot_mode(void) env_set("boot_device", "nand"); env_set("boot_instance", "0"); break; + case BOOT_FLASH_SPINAND: + env_set("boot_device", "spi-nand"); + env_set("boot_instance", "0"); + break; case BOOT_FLASH_NOR: env_set("boot_device", "nor"); env_set("boot_instance", "0"); diff --git a/arch/arm/mach-stm32mp/include/mach/stm32.h b/arch/arm/mach-stm32mp/include/mach/stm32.h index 6daf9f7121..a9bd5bdc1b 100644 --- a/arch/arm/mach-stm32mp/include/mach/stm32.h +++ b/arch/arm/mach-stm32mp/include/mach/stm32.h @@ -79,6 +79,9 @@ enum boot_device {
BOOT_SERIAL_USB = 0x60, BOOT_SERIAL_USB_OTG = 0x62, + + BOOT_FLASH_SPINAND = 0x70, + BOOT_FLASH_SPINAND_1 = 0x71, };
/* TAMP registers */ diff --git a/arch/arm/mach-stm32mp/spl.c b/arch/arm/mach-stm32mp/spl.c index ca4231cd0d..9cd7b418a4 100644 --- a/arch/arm/mach-stm32mp/spl.c +++ b/arch/arm/mach-stm32mp/spl.c @@ -39,6 +39,8 @@ u32 spl_boot_device(void) return BOOT_DEVICE_NAND; case BOOT_FLASH_NOR_QSPI: return BOOT_DEVICE_SPI; + case BOOT_FLASH_SPINAND_1: + return BOOT_DEVICE_NONE; /* SPINAND not supported in SPL */ }
return BOOT_DEVICE_MMC1; diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 14c56a0f24..423be23555 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -789,6 +789,7 @@ enum env_location env_get_location(enum env_operation op, int prio) #endif #ifdef CONFIG_ENV_IS_IN_UBI case BOOT_FLASH_NAND: + case BOOT_FLASH_SPINAND: return ENVL_UBI; #endif #ifdef CONFIG_ENV_IS_IN_SPI_FLASH @@ -829,6 +830,7 @@ int ft_board_setup(void *blob, bd_t *bd) #ifdef CONFIG_FDT_FIXUP_PARTITIONS struct node_info nodes[] = { { "st,stm32f469-qspi", MTD_DEV_TYPE_NOR, }, + { "st,stm32f469-qspi", MTD_DEV_TYPE_SPINAND}, { "st,stm32mp15-fmc2", MTD_DEV_TYPE_NAND, }, }; fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes)); diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index c5b09f1a2a..c34a720e0c 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -127,7 +127,7 @@ * bootcmd for stm32mp1: * for serial/usb: execute the stm32prog command * for mmc boot (eMMC, SD card), boot only on the same device - * for nand boot, boot with on ubifs partition on nand + * for nand or spi-nand boot, boot with on ubifs partition on UBI partition * for nor boot, use the default order */ #define STM32MP_BOOTCMD "bootcmd_stm32mp=" \ @@ -138,7 +138,8 @@ "run env_check;" \ "if test ${boot_device} = mmc;" \ "then env set boot_targets "mmc${boot_instance}"; fi;" \ - "if test ${boot_device} = nand;" \ + "if test ${boot_device} = nand ||" \ + " test ${boot_device} = spi-nand ;" \ "then env set boot_targets ubifs0; fi;" \ "run distro_bootcmd;" \ "fi;\0"
Hi
- case BOOT_FLASH_SPINAND:
case BOOT_FLASH_NOR: env_set("boot_device", "nor"); env_set("boot_instance", "0");break;
- BOOT_FLASH_SPINAND = 0x70,
- BOOT_FLASH_SPINAND_1 = 0x71,
- case BOOT_FLASH_SPINAND: return ENVL_UBI;
{ "st,stm32mp15-fmc2", MTD_DEV_TYPE_NAND, }, }; fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes));{ "st,stm32f469-qspi", MTD_DEV_TYPE_SPINAND},
- bootcmd for stm32mp1:
- for serial/usb: execute the stm32prog command
- for mmc boot (eMMC, SD card), boot only on the same device
- for nand boot, boot with on ubifs partition on nand
- for nand or spi-nand boot, boot with on ubifs partition on UBI partition
- for nor boot, use the default order
"then env set boot_targets ubifs0; fi;" \ "run distro_bootcmd;" \ "fi;\0"" test ${boot_device} = spi-nand ;" \
Patrice
Dynamically adapt the MTD partitions in NAND and SPI-NAND when boot from NOR or NAND/SPI-NAND is detected.
This patch avoids to define the save MTD partition name for NOR and NAND devices and issue with latest kernel: only the needed MTD partitions are defined.
For boot from NOR 1/ bootloader (TF-A, U-Boot and OP-TE) in NOR 2/ one large UBI partition in NAND
For boot from NAND 1/ bootloader (TF-A, U-Boot and OP-TE) in MTD raw partition 2/ one large UBI partition
# Conflicts: # board/st/common/stm32mp_mtdparts.c ---
board/st/common/stm32mp_mtdparts.c | 81 ++++++++++++++++++++++-------- 1 file changed, 60 insertions(+), 21 deletions(-)
diff --git a/board/st/common/stm32mp_mtdparts.c b/board/st/common/stm32mp_mtdparts.c index 2b6413be16..5028511077 100644 --- a/board/st/common/stm32mp_mtdparts.c +++ b/board/st/common/stm32mp_mtdparts.c @@ -10,6 +10,7 @@ #include <mtd.h> #include <mtd_node.h> #include <tee.h> +#include <asm/arch/sys_proto.h>
#define MTDPARTS_LEN 256 #define MTDIDS_LEN 128 @@ -22,7 +23,7 @@ DECLARE_GLOBAL_DATA_PTR; /** * update the variables "mtdids" and "mtdparts" with boot, tee and user strings */ -static void board_get_mtdparts(const char *dev, +static void board_set_mtdparts(const char *dev, char *mtdids, char *mtdparts, const char *boot, @@ -65,7 +66,7 @@ void board_mtdparts_default(const char **mtdids, const char **mtdparts) static char parts[3 * MTDPARTS_LEN + 1]; static char ids[MTDIDS_LEN + 1]; static bool mtd_initialized; - bool tee = false; + bool tee, nor, nand, spinand;
if (mtd_initialized) { *mtdids = ids; @@ -73,6 +74,28 @@ void board_mtdparts_default(const char **mtdids, const char **mtdparts) return; }
+ tee = false; + nor = false; + nand = false; + spinand = false; + + switch (get_bootmode() & TAMP_BOOT_DEVICE_MASK) { + case BOOT_SERIAL_UART: + case BOOT_SERIAL_USB: + break; + case BOOT_FLASH_NAND: + nand = true; + break; + case BOOT_FLASH_SPINAND: + spinand = true; + break; + case BOOT_FLASH_NOR: + nor = true; + break; + default: + break; + } + if (CONFIG_IS_ENABLED(OPTEE) && tee_find_device(NULL, NULL, NULL, NULL)) tee = true; @@ -87,29 +110,45 @@ void board_mtdparts_default(const char **mtdids, const char **mtdparts) pr_debug("mtd device = %s\n", dev->name); }
- mtd = get_mtd_device_nm("nand0"); - if (!IS_ERR_OR_NULL(mtd)) { - board_get_mtdparts("nand0", ids, parts, - CONFIG_MTDPARTS_NAND0_BOOT, - tee ? CONFIG_MTDPARTS_NAND0_TEE : NULL, - "-(UBI)"); - put_mtd_device(mtd); + if (nor || nand) { + mtd = get_mtd_device_nm("nand0"); + if (!IS_ERR_OR_NULL(mtd)) { + const char *mtd_boot = CONFIG_MTDPARTS_NAND0_BOOT; + const char *mtd_tee = CONFIG_MTDPARTS_NAND0_TEE; + + board_set_mtdparts("nand0", ids, parts, + !nor ? mtd_boot : NULL, + !nor && tee ? mtd_tee : NULL, + "-(UBI)"); + put_mtd_device(mtd); + } }
- mtd = get_mtd_device_nm("spi-nand0"); - if (!IS_ERR_OR_NULL(mtd)) { - board_get_mtdparts("spi-nand0", ids, parts, - CONFIG_MTDPARTS_SPINAND0_BOOT, - tee ? CONFIG_MTDPARTS_SPINAND0_TEE : NULL, - "-(UBI)"); - put_mtd_device(mtd); + if (nor || spinand) { + mtd = get_mtd_device_nm("spi-nand0"); + if (!IS_ERR_OR_NULL(mtd)) { + const char *mtd_boot = CONFIG_MTDPARTS_SPINAND0_BOOT; + const char *mtd_tee = CONFIG_MTDPARTS_SPINAND0_TEE; + + board_set_mtdparts("spi-nand0", ids, parts, + !nor ? mtd_boot : NULL, + !nor && tee ? mtd_tee : NULL, + "-(UBI)"); + put_mtd_device(mtd); + } }
- if (!uclass_get_device(UCLASS_SPI_FLASH, 0, &dev)) - board_get_mtdparts("nor0", ids, parts, - CONFIG_MTDPARTS_NOR0_BOOT, - tee ? CONFIG_MTDPARTS_NOR0_TEE : NULL, - "-(nor_user)"); + if (nor) { + if (!uclass_get_device(UCLASS_SPI_FLASH, 0, &dev)) { + const char *mtd_boot = CONFIG_MTDPARTS_NOR0_BOOT; + const char *mtd_tee = CONFIG_MTDPARTS_NOR0_TEE; + + board_set_mtdparts("nor0", ids, parts, + mtd_boot, + tee ? mtd_tee : NULL, + "-(nor_user)"); + } + }
Hi
# Conflicts:
- bool tee = false;
- tee = false;
- nor = false;
- nand = false;
- spinand = false;
- switch (get_bootmode() & TAMP_BOOT_DEVICE_MASK) {
- case BOOT_SERIAL_UART:
- case BOOT_SERIAL_USB:
break;
- case BOOT_FLASH_NAND:
nand = true;
break;
spinand = true;
break;
- case BOOT_FLASH_NOR:
nor = true;
break;
- default:
break;
- if (CONFIG_IS_ENABLED(OPTEE) && tee_find_device(NULL, NULL, NULL, NULL)) tee = true;
"-(UBI)");
- if (nor || nand) {
"-(UBI)");
"-(UBI)");
- if (nor || spinand) {
"-(UBI)");
"-(nor_user)");
if (nor) {
mtd_boot,
"-(nor_user)");
Patrice
Update stm32mp1 board documentation with new management of MMC and MTD partitions and new PID df11.
doc/board/st/stm32mp1.rst | 115 ++++++++++++++++++-------------------- 1 file changed, 54 insertions(+), 61 deletions(-)
diff --git a/doc/board/st/stm32mp1.rst b/doc/board/st/stm32mp1.rst index 7fccdfbb94..41d0206d34 100644 --- a/doc/board/st/stm32mp1.rst +++ b/doc/board/st/stm32mp1.rst @@ -518,61 +518,49 @@ On EV1 board, booting from SD card, without OP-TEE:: dev: RAM alt: 0 name: uImage layout: RAM_ADDR dev: RAM alt: 1 name: devicetree.dtb layout: RAM_ADDR dev: RAM alt: 2 name: uramdisk.image.gz layout: RAM_ADDR - dev: eMMC alt: 3 name: sdcard_fsbl1 layout: RAW_ADDR - dev: eMMC alt: 4 name: sdcard_fsbl2 layout: RAW_ADDR - dev: eMMC alt: 5 name: sdcard_ssbl layout: RAW_ADDR - dev: eMMC alt: 6 name: sdcard_bootfs layout: RAW_ADDR - dev: eMMC alt: 7 name: sdcard_vendorfs layout: RAW_ADDR - dev: eMMC alt: 8 name: sdcard_rootfs layout: RAW_ADDR - dev: eMMC alt: 9 name: sdcard_userfs layout: RAW_ADDR - dev: eMMC alt: 10 name: emmc_fsbl1 layout: RAW_ADDR - dev: eMMC alt: 11 name: emmc_fsbl2 layout: RAW_ADDR - dev: eMMC alt: 12 name: emmc_ssbl layout: RAW_ADDR - dev: eMMC alt: 13 name: emmc_bootfs layout: RAW_ADDR - dev: eMMC alt: 14 name: emmc_vendorfs layout: RAW_ADDR - dev: eMMC alt: 15 name: emmc_rootfs layout: RAW_ADDR - dev: eMMC alt: 16 name: emmc_userfs layout: RAW_ADDR - dev: MTD alt: 17 name: nor_fsbl1 layout: RAW_ADDR - dev: MTD alt: 18 name: nor_fsbl2 layout: RAW_ADDR - dev: MTD alt: 19 name: nor_ssbl layout: RAW_ADDR - dev: MTD alt: 20 name: nor_env layout: RAW_ADDR - dev: MTD alt: 21 name: nand_fsbl layout: RAW_ADDR - dev: MTD alt: 22 name: nand_ssbl1 layout: RAW_ADDR - dev: MTD alt: 23 name: nand_ssbl2 layout: RAW_ADDR - dev: MTD alt: 24 name: nand_UBI layout: RAW_ADDR - dev: VIRT alt: 25 name: OTP layout: RAW_ADDR - dev: VIRT alt: 26 name: PMIC layout: RAW_ADDR + dev: eMMC alt: 3 name: mmc0_fsbl1 layout: RAW_ADDR + dev: eMMC alt: 4 name: mmc0_fsbl2 layout: RAW_ADDR + dev: eMMC alt: 5 name: mmc0_ssbl layout: RAW_ADDR + dev: eMMC alt: 6 name: mmc0_bootfs layout: RAW_ADDR + dev: eMMC alt: 7 name: mmc0_vendorfs layout: RAW_ADDR + dev: eMMC alt: 8 name: mmc0_rootfs layout: RAW_ADDR + dev: eMMC alt: 9 name: mmc0_userfs layout: RAW_ADDR + dev: eMMC alt: 10 name: mmc1_boot1 layout: RAW_ADDR + dev: eMMC alt: 11 name: mmc1_boot2 layout: RAW_ADDR + dev: eMMC alt: 12 name: mmc1_ssbl layout: RAW_ADDR + dev: eMMC alt: 13 name: mmc1_bootfs layout: RAW_ADDR + dev: eMMC alt: 14 name: mmc1_vendorfs layout: RAW_ADDR + dev: eMMC alt: 15 name: mmc1_rootfs layout: RAW_ADDR + dev: eMMC alt: 16 name: mmc1_userfs layout: RAW_ADDR + dev: MTD alt: 17 name: nor0 layout: RAW_ADDR + dev: MTD alt: 18 name: nand0 layout: RAW_ADDR + dev: VIRT alt: 19 name: OTP layout: RAW_ADDR + dev: VIRT alt: 20 name: PMIC layout: RAW_ADDR
All the supported device are exported for dfu-util tool::
$> dfu-util -l - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=26, name="PMIC", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=25, name="OTP", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=24, name="nand_UBI", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=23, name="nand_ssbl2", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=22, name="nand_ssbl1", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=21, name="nand_fsbl", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=20, name="nor_env", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=19, name="nor_ssbl", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=18, name="nor_fsbl2", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=17, name="nor_fsbl1", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=16, name="emmc_userfs", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=15, name="emmc_rootfs", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=14, name="emmc_vendorfs", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=13, name="emmc_bootfs", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=12, name="emmc_ssbl", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=11, name="emmc_fsbl2", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=10, name="emmc_fsbl1", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=9, name="sdcard_userfs", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=8, name="sdcard_rootfs", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=7, name="sdcard_vendorfs", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=6, name="sdcard_bootfs", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=5, name="sdcard_ssbl", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=4, name="sdcard_fsbl2", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=3, name="sdcard_fsbl1", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=2, name="uramdisk.image.gz", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=1, name="devicetree.dtb", serial="002700333338511934383330" - Found DFU: [0483:5720] ver=9999, devnum=99, cfg=1, intf=0, alt=0, name="uImage", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=20, name="PMIC", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=19, name="OTP", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=18, name="nand0", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=17, name="nor0", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=16, name="mmc1_userfs", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=15, name="mmc1_rootfs", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=14, name="mmc1_vendorfs", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=13, name="mmc1_bootfs", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=12, name="mmc1_ssbl", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=11, name="mmc1_boot2", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=10, name="mmc1_boot1", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=9, name="mmc0_userfs", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=8, name="mmc0_rootfs", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=7, name="mmc0_vendorfs", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=6, name="mmc0_bootfs", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=5, name="mmc0_ssbl", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=4, name="mmc0_fsbl2", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=3, name="mmc0_fsbl1", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=2, name="uramdisk.image.gz", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=1, name="devicetree.dtb", serial="002700333338511934383330" + Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=0, name="uImage", serial="002700333338511934383330"
You can update the boot device:
@@ -596,20 +584,25 @@ You can update the boot device: $> dfu-util -d 0483:5720 -a 15 -D st-image-weston-openstlinux-weston-stm32mp1.ext4 $> dfu-util -d 0483:5720 -a 16 -D st-image-userfs-openstlinux-weston-stm32mp1.ext4
-- NOR:: +- you can also dump the OTP and the PMIC NVM with:: + + $> dfu-util -d 0483:5720 -a 19 -U otp.bin + $> dfu-util -d 0483:5720 -a 20 -U pmic.bin +
- $> dfu-util -d 0483:5720 -a 17 -D tf-a-stm32mp157c-ev1-trusted.stm32 - $> dfu-util -d 0483:5720 -a 18 -D tf-a-stm32mp157c-ev1-trusted.stm32 - $> dfu-util -d 0483:5720 -a 19 -D u-boot-stm32mp157c-ev1-trusted.img +When the board is booting for nor0 or nand0, +only the MTD partition on the boot devices are available, for example:
-- NAND (UBI partition used for NAND only boot or NOR + NAND boot):: +- NOR (nor0 = alt 20) & NAND (nand0 = alt 26) ::
$> dfu-util -d 0483:5720 -a 21 -D tf-a-stm32mp157c-ev1-trusted.stm32 - $> dfu-util -d 0483:5720 -a 22 -D u-boot-stm32mp157c-ev1-trusted.img + $> dfu-util -d 0483:5720 -a 22 -D tf-a-stm32mp157c-ev1-trusted.stm32 $> dfu-util -d 0483:5720 -a 23 -D u-boot-stm32mp157c-ev1-trusted.img - $> dfu-util -d 0483:5720 -a 24 -D st-image-weston-openstlinux-weston-stm32mp1_nand_4_256_multivolume.ubi + $> dfu-util -d 0483:5720 -a 27 -D st-image-weston-openstlinux-weston-stm32mp1_nand_4_256_multivolume.ubi
-- you can also dump the OTP and the PMIC NVM with:: +- NAND (nand0 = alt 21)::
- $> dfu-util -d 0483:5720 -a 25 -U otp.bin - $> dfu-util -d 0483:5720 -a 26 -U pmic.bin + $> dfu-util -d 0483:5720 -a 22 -D tf-a-stm32mp157c-ev1-trusted.stm32 + $> dfu-util -d 0483:5720 -a 23 -D u-boot-stm32mp157c-ev1-trusted.img + $> dfu-util -d 0483:5720 -a 24 -D u-boot-stm32mp157c-ev1-trusted.img + $> dfu-util -d 0483:5720 -a 25 -D st-image-weston-openstlinux-weston-stm32mp1_nand_4_256_multivolume.ubi
Hi
- dev: eMMC alt: 3 name: mmc0_fsbl1 layout: RAW_ADDR
- dev: eMMC alt: 4 name: mmc0_fsbl2 layout: RAW_ADDR
- dev: eMMC alt: 5 name: mmc0_ssbl layout: RAW_ADDR
- dev: eMMC alt: 6 name: mmc0_bootfs layout: RAW_ADDR
- dev: eMMC alt: 7 name: mmc0_vendorfs layout: RAW_ADDR
- dev: eMMC alt: 8 name: mmc0_rootfs layout: RAW_ADDR
- dev: eMMC alt: 9 name: mmc0_userfs layout: RAW_ADDR
- dev: eMMC alt: 10 name: mmc1_boot1 layout: RAW_ADDR
- dev: eMMC alt: 11 name: mmc1_boot2 layout: RAW_ADDR
- dev: eMMC alt: 12 name: mmc1_ssbl layout: RAW_ADDR
- dev: eMMC alt: 13 name: mmc1_bootfs layout: RAW_ADDR
- dev: eMMC alt: 14 name: mmc1_vendorfs layout: RAW_ADDR
- dev: eMMC alt: 15 name: mmc1_rootfs layout: RAW_ADDR
- dev: eMMC alt: 16 name: mmc1_userfs layout: RAW_ADDR
- dev: MTD alt: 17 name: nor0 layout: RAW_ADDR
- dev: MTD alt: 18 name: nand0 layout: RAW_ADDR
- dev: VIRT alt: 19 name: OTP layout: RAW_ADDR
- dev: VIRT alt: 20 name: PMIC layout: RAW_ADDR
$> dfu-util -l
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=20, name="PMIC", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=19, name="OTP", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=18, name="nand0", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=17, name="nor0", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=16, name="mmc1_userfs", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=15, name="mmc1_rootfs", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=14, name="mmc1_vendorfs", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=13, name="mmc1_bootfs", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=12, name="mmc1_ssbl", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=11, name="mmc1_boot2", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=10, name="mmc1_boot1", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=9, name="mmc0_userfs", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=8, name="mmc0_rootfs", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=7, name="mmc0_vendorfs", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=6, name="mmc0_bootfs", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=5, name="mmc0_ssbl", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=4, name="mmc0_fsbl2", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=3, name="mmc0_fsbl1", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=2, name="uramdisk.image.gz", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=1, name="devicetree.dtb", serial="002700333338511934383330"
- Found DFU: [0483:df11] ver=9999, devnum=99, cfg=1, intf=0, alt=0, name="uImage", serial="002700333338511934383330"
- $> dfu-util -d 0483:5720 -a 19 -U otp.bin
- $> dfu-util -d 0483:5720 -a 20 -U pmic.bin
- $> dfu-util -d 0483:5720 -a 22 -D tf-a-stm32mp157c-ev1-trusted.stm32 $> dfu-util -d 0483:5720 -a 23 -D u-boot-stm32mp157c-ev1-trusted.img
- $> dfu-util -d 0483:5720 -a 27 -D st-image-weston-openstlinux-weston-stm32mp1_nand_4_256_multivolume.ubi
- $> dfu-util -d 0483:5720 -a 23 -D u-boot-stm32mp157c-ev1-trusted.img
- $> dfu-util -d 0483:5720 -a 24 -D u-boot-stm32mp157c-ev1-trusted.img
- $> dfu-util -d 0483:5720 -a 25 -D st-image-weston-openstlinux-weston-stm32mp1_nand_4_256_multivolume.ubi
Reviewed-by: Patrice Chotard patrice.chotard@st.com
Patrice
From: Patrick DELAUNAY patrick.delaunay@st.com Sent: mercredi 18 mars 2020 09:23
This serie migrate the dynamically build MTD (CONFIG_SYS_MTDPARTS_RUNTIME) and the DFU configuration (CONFIG_SET_DFU_ALT_INFO) previously based on ENV variables to CONFIG_.
These patches reduce the size of the environment and allow to tune for each target with a specific defconfig file.
This serie also removes the TEE deconfig, replaced by a dynamic detection based on op-tee driver probe.
This serie depends on previous CONFIG migration proposed in http://patchwork.ozlabs.org/project/uboot/list/?series=160899
- configs: migrate CONFIG_SET_DFU_ALT_INFO to defconfigs
- configs: migrate CONFIG_SYS_MTDPARTS_RUNTIME to defconfigs
Patrick Delaunay (11): board: stm32mp1: move board_get_mtdparts in st common directory board: stm32mp1: move set_dfu_alt_info in st common directory stm32mp1: dynamically build DFU_ALT_INFO stm32mp1: move MTDPART configuration in Kconfig board: stm32mp1: reserve memory for OP-TEE in device tree stm32mp1: dynamically detect op-tee presence board: stm32mp1: use FDT address provided by TF-A at boot time configs: stm32mp1: remove optee defconfig board: stm32mp1: support boot from spi-nand board: stm32mp1: adapt MTD partition for BOOT from NOR or NAND doc: stm32mp1: update DFU support example
arch/arm/dts/stm32mp157a-dk1.dts | 5 + arch/arm/dts/stm32mp157c-ed1.dts | 5 + arch/arm/mach-stm32mp/Kconfig | 10 - arch/arm/mach-stm32mp/Makefile | 1 + arch/arm/mach-stm32mp/boot_params.c | 45 ++++ arch/arm/mach-stm32mp/cpu.c | 4 + arch/arm/mach-stm32mp/dram_init.c | 18 ++ arch/arm/mach-stm32mp/fdt.c | 25 ++ arch/arm/mach-stm32mp/include/mach/stm32.h | 3 + arch/arm/mach-stm32mp/spl.c | 2 + board/dhelectronics/dh_stm32mp1/Kconfig | 1 + board/dhelectronics/dh_stm32mp1/Makefile | 3 + board/dhelectronics/dh_stm32mp1/board.c | 143 +----------- board/st/common/Kconfig | 64 ++++++ board/st/common/Makefile | 5 + board/st/common/stm32mp_dfu.c | 225 ++++++++++++++++++ board/st/common/stm32mp_mtdparts.c | 157 +++++++++++++ board/st/stm32mp1/MAINTAINERS | 1 - board/st/stm32mp1/stm32mp1.c | 253 +-------------------- configs/stm32mp15_optee_defconfig | 132 ----------- configs/stm32mp15_trusted_defconfig | 3 + doc/board/st/stm32mp1.rst | 147 +++++------- include/configs/stm32mp1.h | 64 +----- 23 files changed, 634 insertions(+), 682 deletions(-) create mode 100644 arch/arm/mach-stm32mp/boot_params.c create mode 100644 board/st/common/stm32mp_dfu.c create mode 100644 board/st/common/stm32mp_mtdparts.c delete mode 100644 configs/stm32mp15_optee_defconfig
-- 2.17.1
For the serie applied to u-boot-stm/master, thanks!
Regards
Patrick
Patrice CHOTARD
Patrick DELAUNAY
Patrick Delaunay
