[U-Boot] [PATCH 1/2] mmc: sdhci: set to INT_DATA_END when there are data
There is no data, it doesn't needs to wait for completing data transfer. (It seems that it can be removed.) Almost all timeout error is occured from stop command without data. After applied this patch, I hope that we don't need to increase timeout value anymore.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/sdhci.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 604f18d..0a38a56 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -175,7 +175,8 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, flags = SDHCI_CMD_RESP_LONG; else if (cmd->resp_type & MMC_RSP_BUSY) { flags = SDHCI_CMD_RESP_SHORT_BUSY; - mask |= SDHCI_INT_DATA_END; + if (data) + mask |= SDHCI_INT_DATA_END; } else flags = SDHCI_CMD_RESP_SHORT;
Unset the SDHCI_QUIRK_BROKEN_R1B for exynos SoC. (Tested on Exynos4 Boards.)
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/s5p_sdhci.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 44353c7..3bace21 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -68,7 +68,7 @@ static int s5p_sdhci_core_init(struct sdhci_host *host) host->name = S5P_NAME;
host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE | - SDHCI_QUIRK_BROKEN_R1B | SDHCI_QUIRK_32BIT_DMA_ADDR | + SDHCI_QUIRK_32BIT_DMA_ADDR | SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_USE_WIDE8; host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; host->version = sdhci_readw(host, SDHCI_HOST_VERSION);
Hi Jaehoon,
SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_USE_WIDE8; host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 |SDHCI_QUIRK_32BIT_DMA_ADDR |
Acked-by: Lukasz Majewski l.majewski@samsung.com Tested-by: Lukasz Majewski l.majewski@samsung.com
Test HW: Odroid U3 (Exynos4):
Odroid # ext4load mmc 0:2 0x41000000 dat_31M.img 32505856 bytes read in 1471 ms (21.1 MiB/s) Odroid # ext4write mmc 0:2 0x41000000 /dat_w55.img 0x1f00000 File System is consistent update journal finished 32505856 bytes written in 3528 ms (8.8 MiB/s)
Performance improvement is even better than with previously proposed patches.
Test HW: Odroid XU3 (Exynos5):
ODROID-XU3 # ext4load mmc 0:2 0x41000000 dat_31M.img 32505856 bytes read in 6309 ms (4.9 MiB/s) ODROID-XU3 # ext4write mmc 0:2 0x41000000 /dat_w1.img 0x1f00000 File System is consistent update journal finished 32505856 bytes written in 4884 ms (6.3 MiB/s)
Applied on u-boot-mmc. Thanks!
Best Regards, Jaehoon Chung
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com Tested-by: Lukasz Majewski l.majewski@samsung.com
SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_USE_WIDE8; host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; host->version = sdhci_readw(host, SDHCI_HOST_VERSION);SDHCI_QUIRK_32BIT_DMA_ADDR |
Hi Jaehoon,
This patch fixes issue (in a better way) for Odroid U3 write performance (http://patchwork.ozlabs.org/patch/646932/) and hence should be used.
if (data)
} else flags = SDHCI_CMD_RESP_SHORT;mask |= SDHCI_INT_DATA_END;
Hi All,
On 07/12/2016 09:55 PM, Lukasz Majewski wrote:
Hi Jaehoon,
Is there any other opinion for this patch? Who is maintaining u-boot-mmc? Is Pantelis still maintaining u-boot-mmc?
Who can apply this patch and patch relevant to mmc?
if (data)
On 25/07/16 13:55, Jaehoon Chung wrote:
Hi All,
Hi Jaehoon,
looks reasonable.
Acked-by: Minkyu Kang mk7.kang@samsung.com
Pantelis seems to away from mailing list. If so, I think we need discuss about new custodian for mmc.
Thanks, Minkyu Kang.
Hi Jaehoon,
Hi All,
Hi Jaehoon,
To be honest, I do look forward to see this patch included to u-boot master branch.
Addition of some extra Odroid U3 tests hinge on it.
if (data)
Hi Jaehoon,
On Mon, Jul 25, 2016 at 3:21 AM, Lukasz Majewski l.majewski@samsung.com wrote:
Hi Jaehoon,
Hi All,
Hi Jaehoon,
if (data)
-- Best regards,
Lukasz Majewski
Samsung R&D Institute Poland (SRPOL) | Linux Platform Group
with this change, I can also set the following back to 100:
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index de8d8ea..d593dc6 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -128,7 +128,7 @@ static int sdhci_transfer_data(struct sdhci_host *host, struct mmc_data *data, #define CONFIG_SDHCI_CMD_MAX_TIMEOUT 3200 #endif #define CONFIG_SDHCI_CMD_DEFAULT_TIMEOUT 100 -#define SDHCI_READ_STATUS_TIMEOUT 1000 +#define SDHCI_READ_STATUS_TIMEOUT 100
#ifdef CONFIG_DM_MMC_OPS static int sdhci_send_command(struct udevice *dev, struct mmc_cmd *cmd,
And it still works on my board ! Thanks !
Tested-by: Steve Rae steve.rae@raedomain.com [Test HW: bcm235xx board]
On Mon, Jul 25, 2016 at 4:23 PM, Steve Rae steve.rae@raedomain.com wrote:
Hi Jaehoon,
Hi Jaehoon,
Hi All,
Hi Jaehoon,
if (data)
-- Best regards,
Lukasz Majewski
patchworks added a new entry; so try again: Tested-by: Steve Rae steve.rae@raedomain.com [Test HW: bcm235xx board]
Hi Steve,
Could you prepare proper revert patch?
HI Lukasz,
On Tue, Jul 26, 2016 at 2:13 AM, Lukasz Majewski l.majewski@samsung.com wrote:
Hi Steve,
-- Best regards,
Lukasz Majewski
Looking at the code, I don't think there is any value changing the SDHCI_READ_STATUS_TIMEOUT from 1000 to 100. But maybe someone (Jaehoon ?) could comment on the impact of this SDHCI_READ_STATUS_TIMEOUT value in the SDHCI_QUIRK_BROKEN_R1B case... Does it affect performance in anyway? If it does, the I'll prepare a patch....
Thanks, Steve
Hi
On 07/27/2016 01:10 AM, Steve Rae wrote:
HI Lukasz,
Hi Steve,
-- Best regards,
Lukasz Majewski
There is no performance effect whatever SDHCI_READ_STATUS_TIMEOUT is using value. So i think that we don't need to revert it..
SDHCI_QUIRK_BROKEN_R1B had been added from me. At that time, i didn't know why added SDHCI_INT_DAT_END. I'm not sure but if remove the SDHCI_INT_DAT_END, I guess that SDHCI_QUIRK_BROKEN_R1B can be also removed. (quirks is workaround flags, so if it can be removed, it's best.)
In future, I want to remove SDHCI_QUIRK_BROKEN_R1B.
Thanks, Steve
Dear All,
Hi All,
Hi Jaehoon,
Gentle ping .....
Pantelis could you pull this patch to u-boot-mmc tree?
if (data)
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com Tested-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Minkyu Kang mk7.kang@samsung.com
if (data)
Jaehoon Chung
Lukasz Majewski
Minkyu Kang
Steve Rae
