[U-Boot] building u-boot x86 with device tree disabled , still refers to device tree function
Hi there I'm building u-boot as payload for x86 platform. I didn't enable device tree in menuconfig (CONFIG_OF_CONTROL is not set) because I use a board config file coreboot.h. When I built u-boot, it reports error during linking stage : undefined reference to dm_scan_fdt_dev
arch/x86/lib/built-in.o:(.u_boot_list_2_uclass_2_lpc+0x8): undefined reference to `dm_scan_fdt_dev' common/built-in.o:(.u_boot_list_2_uclass_2_usb_hub+0x8): undefined reference to `dm_scan_fdt_dev' drivers/built-in.o:(.u_boot_list_2_uclass_2_pch+0x8): undefined reference to `dm_scan_fdt_dev' drivers/pci/built-in.o:(.u_boot_list_2_uclass_2_pci+0x8): undefined reference to `dm_scan_fdt_dev' drivers/spi/built-in.o:(.u_boot_list_2_uclass_2_spi+0x8): undefined reference to `dm_scan_fdt_dev' drivers/usb/host/built-in.o:(.u_boot_list_2_uclass_2_usb+0x8): more undefined references to `dm_scan_fdt_dev' follow Makefile:1189: recipe for target 'u-boot' failed
I looked at the code and see arch/x86/lib/lpc-uclass.c refers to a function "dm_scan_fdt_dev " which is defined in drivers/core/root.c and it looks like a device tree function
UCLASS_DRIVER(lpc) = { .id = UCLASS_LPC, .name = "lpc", .post_bind = dm_scan_fdt_dev, };
Because device tree isn't enabled, the function isn't compiled and causes the problem while linking. It's only compiled when the following is true #if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) If I comment out the line, it would compile and build. But I'm not sure if it's the right way to do it.
Is it normal behavior? I thought that when not enabling device tree, the code shouldn't use device tree function? Can anyone help on this please?
Thanks alot, Chi
-------------------------------------------------------------- Intel Research and Development Ireland Limited Registered in Ireland Registered Office: Collinstown Industrial Park, Leixlip, County Kildare Registered Number: 308263
This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
Which board are you building?
Please refer to README.x86 for how to build U-Boot as the coreboot payload.
Regards, Bin
Hi Bin Thanks for the reply. I'm building for Intel Harrisonville board with Denverton chipset.
Cheers, Chi
-----Original Message----- From: Bin Meng [mailto:bmeng.cn@gmail.com] Sent: Friday, August 12, 2016 5:12 AM To: Ding, ChiX chix.ding@intel.com; Simon Glass sjg@chromium.org Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] building u-boot x86 with device tree disabled , still refers to device tree function
Regards, Bin -------------------------------------------------------------- Intel Research and Development Ireland Limited Registered in Ireland Registered Office: Collinstown Industrial Park, Leixlip, County Kildare Registered Number: 308263
+Bin
Even when running as a coreboot payload you should use DT. As Bin says, this is described in README.x86 so you should be able to follow along there.
If there is a specific reason for disabling the DT, can you explain it a bit?
Hi Simon We have an older version u-boot code that is built without device tree. It works fine as coreboot payload on the target board with Denverton chipset. With the current u-boot code from git://git.denx.de/u-boot.git, I run coreboot-x86_defconfig, then make menuconfig, and by default qemu-x86 is the target board. I use device tree in the beginning which is enalbed by default, but I didn't see the dts file for my target board. Since I'm new to the bootloader world, I 'm not sure how to define it correctly for my target board. I did experiments of the dst file and menuconfig to use it, but the built u-boot file doesn't work properly as Coreboot payload when booting : it gets stuck when jumping into u-boot from coreboot.
Jumping to boot code at 01110020(7f6ea000) CPU0: stack: 0012d000 - 0012e000, lowest used address 0012d9cc, stack used: 1588 bytes entry = 0x01110020 lb_start = 0x00100000 lb_size = 0x00036870 buffer = 0x7f67c000
After that I tried to use the board configure file instead (taken from my older version u-boot code) of device tree, therefore I disabled device tree in menuconfig. That's how my question comes from.
I also tried to make u-boot work as payload of coreboot on qemu-x86. I ran make dist clean, make coreboot-x86_defconfig and built uboot using the default menuconfig setting of device tree enabled, and embedded Then I built coreboot using u-boot as ELF payload. Somehow when I run it with qemu-86, it crashes inside uboot :
[root@localhost cid_iafw_opensource-coreboot]# qemu-system-x86_64 --nographic -bios build/coreboot.rom
U-Boot 2016.09-rc1-00324-g2863a9b-dirty (Aug 12 2016 - 11:13:50 +0100)
CPU: x86_64, vendor AMD, device 663h DRAM: 127.6 MiB Using default environment
Video: No video mode configured in coreboot! Model: QEMU x86 (I440FX) Net: General Protection EIP: 0010:[<07f1440a>] EFLAGS: 00000002 Original EIP :[<0111040a>] EAX: 00000002 EBX: 07d15668 ECX: 00000001 EDX: c0020000 ESI: 00000041 EDI: 000000c8 EBP: 00010001 ESP: 07d129d4 DS: 0018 ES: 0018 FS: 0020 GS: 0018 SS: 0018 CR0: 00000033 CR2: 00000000 CR3: 00000000 CR4: 00000000 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 DR6: ffff0ff0 DR7: 00000400 Stack: 0x07d12a14 : 0x00000001 0x07d12a10 : 0x00000000 0x07d12a0c : 0x07d15668 0x07d12a08 : 0x00000000 0x07d12a04 : 0x159dc191 0x07d12a00 : 0x00000000 0x07d129fc : 0x00000000 0x07d129f8 : 0x00001800 0x07d129f4 : 0x00000001 0x07d129f0 : 0x07d12a5c 0x07d129ec : 0x07f35f29 0x07d129e8 : 0x07d15668 0x07d129e4 : 0x00000001 0x07d129e0 : 0x00000001 0x07d129dc : 0x00000202 0x07d129d8 : 0x00000010 --->0x07d129d4 : 0x07f35efc 0x07d129d0 : 0x00000002 0x07d129cc : 0x00000010 0x07d129c8 : 0x07f1440a ### ERROR ### Please RESET the board ###
When looking at the code, I see it crashes here /* IRQ Low-Level Service Routine */ void irq_llsr(struct irq_regs *regs) { /* * For detailed description of each exception, refer to: * IntelĀ® 64 and IA-32 Architectures Software Developer's Manual * Volume 1: Basic Architecture * Order Number: 253665-029US, November 2008 * Table 6-1. Exceptions and Interrupts */ if (regs->irq_id < 32) { /* Architecture defined exception */ do_exception(regs);
Any suggestion on this issue?
Thanks a lot, Chi
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Friday, August 12, 2016 7:21 PM To: Ding, ChiX Cc: u-boot@lists.denx.de; Bin Meng Subject: Re: [U-Boot] building u-boot x86 with device tree disabled , still refers to device tree function
+Bin
Regards, Simon -------------------------------------------------------------- Intel Research and Development Ireland Limited Registered in Ireland Registered Office: Collinstown Industrial Park, Leixlip, County Kildare Registered Number: 308263
Are you using a recent-enough version of qemu? I think you need 2.3 or later.
Thanks a lot, Chi
+Bin
Bin Meng
Ding, ChiX
