arm: lib1funcs.S: Plan to resync Linux code?
15 Feb
2023
15 Feb
'23
3:23 a.m.
Hi Marek,
Do you have plans to resync Linux lib1funcs.S to u-boot?
Tom mentioned it it this thread: https://lists.denx.de/pipermail/u-boot/2023-January/504287.html
And one of the reasons it came up was that an armv5 board (Pogo V4) has both CONFIG_LTO and CONFIG_SYS_THUMB_BUILD enabled. And we experienced build failure, so we had to disable CONFIG_LTO: https://lists.denx.de/pipermail/u-boot/2022-November/500460.html
It would be great to have the lib1funcs.S resync with Linux again, so we can reduce the binary size when needed. I don't have enough experience with ARM assembler code to attempt that task, but I would volunteer to be a tester for a few armv5 boards (Marvell Kirkwood) and armv7 (Marvell Armada 385) boards.
Thanks, Tony
812
Tony Dinh
