[U-Boot] LL TEMAC V8 refactored
Back to the discussion from the last three months I have refactored the LL TEMAC driver again. The version V8 is ready to next review and testing. I myself have tested it successfully on an ML605 (TEMAC hard core) and on a SP3ADSP1800 (TEMAC soft core). Thanks to Marek, Wolfgang, Andy and Michal to review V4..7. Special thanks to Ricardo. He has tested the driver on a Xilinx Virtex5 FX (PPC440) platform.
To use the driver on Microblaze, you will need all additional platform patches by Michal Simek and me. All related patches are bundled on patchwork: - http://patchwork.ozlabs.org/bundle/rexut/net-ll_temac/
@Michal: Please merge the patches into the custodian git tree for final testing.
@Ricardo: Please test the new V8 patch on your PPC440 platform again and post the patches for xilinx/ppc440-generic if you want.
Xilinx LocalLink Tri-Mode Ether MAC driver can be used by Xilinx Microblaze or Xilinx ppc405/440 in SDMA and FIFO mode. DCR or XPS bus can be used.
The driver uses and requires MII and PHYLIB.
CP: 4 warnings: 'Use of volatile is usually wrong' I won't fix this, because it depends on the network driver subsystem.
Signed-off-by: Stephan Linz linz@li-pro.net --- v8: Remove deprecated interface: miiphy_register() Implement MDIO bus/phy access code as independent part of driver. Make the direct PHY access code accessible for upper layer like the MDIO command. Define proper device names for TEMAC and MII interfaces. Support of TEMAC0 and TEMAC1 at same time is prepared and should work.
v7: Call udelay() in polling loops to avoid unintended watchdog reset Define well known timeout values in usec Handle timeouts as error situations Reduce duplicated code in SDMA operations Add a real and plausible PHY detect mask Remove ETH_HALTING code exclusion Code cleanup as recommended Fix typos
v6: Code cleanup with ./tools/checkpatch.pl
v5: Remove more endless loops Remove useless parenthesis in pointer operations Move phyaddr predefinition on top Remove supernumerary newlines Remove parenthesis around numbers (globally)
v4: Separate fifo and sdma code from driver core Split sdma code into separate DCR and XPS bus access code Add extensive register struct definitions and enumerations Add new callbacks into fifo an sdma code Prepare CDMAC buffer handling to be unique for every instance Separate Xilinx specific indirect DCR access, so we can move to arch Remove useless 'emac' parameter from indirect access helper functions Correct MDIO clock setup. Remove endless loops Common code beautifying
v3: Use helper functions for fifo mode Use helper functions for indirect accesses Code cleanup Add comments for MAGIC values Simplify code in fifo mode
v2: Remove helper function for access to temac Remove SDMA/FIFO/DCR macros and configure it in board Setup mac by write_hwaddr --- drivers/net/Makefile | 2 + drivers/net/xilinx_ll_temac.c | 452 ++++++++++++++++++++++++++++++++++++ drivers/net/xilinx_ll_temac_fifo.c | 105 +++++++++ drivers/net/xilinx_ll_temac_mdio.c | 164 +++++++++++++ drivers/net/xilinx_ll_temac_sdma.c | 324 ++++++++++++++++++++++++++ include/netdev.h | 1 + include/xilinx_ll_temac.h | 381 ++++++++++++++++++++++++++++++ include/xilinx_ll_temac_fifo.h | 119 ++++++++++ include/xilinx_ll_temac_mdio.h | 54 +++++ include/xilinx_ll_temac_sdma.h | 289 +++++++++++++++++++++++ 10 files changed, 1891 insertions(+), 0 deletions(-) create mode 100644 drivers/net/xilinx_ll_temac.c create mode 100644 drivers/net/xilinx_ll_temac_fifo.c create mode 100644 drivers/net/xilinx_ll_temac_mdio.c create mode 100644 drivers/net/xilinx_ll_temac_sdma.c create mode 100644 include/xilinx_ll_temac.h create mode 100644 include/xilinx_ll_temac_fifo.h create mode 100644 include/xilinx_ll_temac_mdio.h create mode 100644 include/xilinx_ll_temac_sdma.h
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index f4f7ea3..430f90c 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -77,6 +77,8 @@ COBJS-$(CONFIG_ULI526X) += uli526x.o COBJS-$(CONFIG_VSC7385_ENET) += vsc7385.o COBJS-$(CONFIG_XILINX_AXIEMAC) += xilinx_axi_emac.o COBJS-$(CONFIG_XILINX_EMACLITE) += xilinx_emaclite.o +COBJS-$(CONFIG_XILINX_LL_TEMAC) += xilinx_ll_temac.o xilinx_ll_temac_mdio.o \ + xilinx_ll_temac_fifo.o xilinx_ll_temac_sdma.o
COBJS := $(sort $(COBJS-y)) SRCS := $(COBJS:.o=.c) diff --git a/drivers/net/xilinx_ll_temac.c b/drivers/net/xilinx_ll_temac.c new file mode 100644 index 0000000..8533358 --- /dev/null +++ b/drivers/net/xilinx_ll_temac.c @@ -0,0 +1,452 @@ +/* + * Xilinx xps_ll_temac ethernet driver for u-boot + * + * supports SDMA or FIFO access + * + * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu + * Copyright (C) 2008 - 2011 PetaLogix + * + * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net + * + * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver + * Copyright (C) 2008 Nissin Systems Co.,Ltd. + * March 2008 created + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + * + * [0]: http://www.xilinx.com/support/documentation + * + * [S]: [0]/ip_documentation/xps_ll_temac.pdf + * [A]: [0]/application_notes/xapp1041.pdf + */ + +#include <config.h> +#include <common.h> +#include <net.h> +#include <malloc.h> +#include <asm/io.h> +#include <miiphy.h> + +#include <xilinx_ll_temac.h> +#include <xilinx_ll_temac_fifo.h> +#include <xilinx_ll_temac_sdma.h> +#include <xilinx_ll_temac_mdio.h> + +#if !defined(CONFIG_MII) +# error "LL_TEMAC requires MII -- missing CONFIG_MII" +#endif + +#if !defined(CONFIG_PHYLIB) +# error "LL_TEMAC requires PHYLIB -- missing CONFIG_PHYLIB" +#endif + +/* Data buffer for LL TEMAC Rx and Tx direction */ +static unsigned char rx_buffer[PKTSIZE_ALIGN] __attribute((aligned(DMAALIGN))); +static unsigned char tx_buffer[PKTSIZE_ALIGN] __attribute((aligned(DMAALIGN))); + +/* CDMAC buffer descriptor for LL TEMAC Rx and Tx buffer handling */ +static struct cdmac_bd rx_descr __attribute((aligned(DMAALIGN))); +static struct cdmac_bd tx_descr __attribute((aligned(DMAALIGN))); + +static struct ll_temac_info ll_temac_info[] = { +#if defined(XILINX_LLTEMAC_BASEADDR) + /* LL_TEMAC0 */ +# if defined(XILINX_LLTEMAC_FIFO_BASEADDR) + /* ... via FIFO */ + STD_LL_TEMAC_INFO(0, XILINX_LLTEMAC_BASEADDR, + LL_TEMAC_M_FIFO, XILINX_LLTEMAC_FIFO_BASEADDR), +# elif defined(XILINX_LLTEMAC_SDMA_CTRL_BASEADDR) +# if (XILINX_LLTEMAC_SDMA_USE_DCR == 1) + /* ... via DCR bus indirect DMA access */ + STD_LL_TEMAC_INFO(0, XILINX_LLTEMAC_BASEADDR, + LL_TEMAC_M_DCR, XILINX_LLTEMAC_SDMA_CTRL_BASEADDR), +# else + /* ... via SDMA */ + STD_LL_TEMAC_INFO(0, XILINX_LLTEMAC_BASEADDR, + LL_TEMAC_M_SDMA, XILINX_LLTEMAC_SDMA_CTRL_BASEADDR), +# endif +# endif +#endif +#if defined(XILINX_LLTEMAC_BASEADDR1) + /* LL_TEMAC1 */ +# if defined(XILINX_LLTEMAC_FIFO_BASEADDR1) + /* ... via FIFO */ + STD_LL_TEMAC_INFO(1, XILINX_LLTEMAC_BASEADDR1, + LL_TEMAC_M_FIFO, XILINX_LLTEMAC_FIFO_BASEADDR1), +# elif defined(XILINX_LLTEMAC_SDMA_CTRL_BASEADDR1) +# if (XILINX_LLTEMAC_SDMA_USE_DCR == 1) + /* ... via DCR bus indirect DMA access */ + STD_LL_TEMAC_INFO(1, XILINX_LLTEMAC_BASEADDR1, + LL_TEMAC_M_DCR, XILINX_LLTEMAC_SDMA_CTRL_BASEADDR1), +# else + /* ... via SDMA */ + STD_LL_TEMAC_INFO(1, XILINX_LLTEMAC_BASEADDR1, + LL_TEMAC_M_SDMA, XILINX_LLTEMAC_SDMA_CTRL_BASEADDR1), +# endif +# endif +#endif +}; + +/* Ethernet interface ready status */ +int ll_temac_check_status(struct temac_reg *regs, u32 mask) +{ + unsigned timeout = 50; /* 1usec * 50 = 50usec */ + + /* + * Quote from LL TEMAC documentation: The bits in the RDY + * register are asserted when there is no access in progress. + * When an access is in progress, a bit corresponding to the + * type of access is automatically de-asserted. The bit is + * automatically re-asserted when the access is complete. + */ + while (timeout && (!(in_be32(®s->rdy) & mask))) { + timeout--; + udelay(1); + } + + if (!timeout) { + printf("%s: Timeout on 0x%08x @%p\n", __func__, + mask, ®s->rdy); + return 1; + } + + return 0; +} + +/* + * Indirect write to ll_temac. + * + * http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac.pd... + * page 23, second paragraph, The use of CTL0 register or CTL1 register + */ +int ll_temac_indirect_set(struct temac_reg *regs, u16 regn, u32 reg_data) +{ + out_be32(®s->lsw, (reg_data & MLSW_MASK)); + out_be32(®s->ctl, CTL_WEN | (regn & CTL_ADDR_MASK)); + + if (ll_temac_check_status(regs, RSE_CFG_WR)) + return 0; + + return 1; +} + +/* + * Indirect read from ll_temac. + * + * http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac.pd... + * page 23, second paragraph, The use of CTL0 register or CTL1 register + */ +int ll_temac_indirect_get(struct temac_reg *regs, u16 regn, u32* reg_data) +{ + out_be32(®s->ctl, (regn & CTL_ADDR_MASK)); + + if (ll_temac_check_status(regs, RSE_CFG_RR)) + return 0; + + *reg_data = in_be32(®s->lsw) & MLSW_MASK; + return 1; +} + +/* setting sub-controller and ll_temac to proper setting */ +static int ll_temac_setup_ctrl(struct eth_device *dev) +{ + struct ll_temac *ll_temac = dev->priv; + struct temac_reg *regs = (struct temac_reg *)dev->iobase; + + if (ll_temac->ctrlreset && ll_temac->ctrlreset(dev)) + return 0; + + if (ll_temac->ctrlinit && ll_temac->ctrlinit(dev)) + return 0; + + /* Promiscuous mode disable */ + if (!ll_temac_indirect_set(regs, TEMAC_AFM, 0)) + return 0; + + /* Enable Receiver - RX bit */ + if (!ll_temac_indirect_set(regs, TEMAC_RCW1, RCW1_RX)) + return 0; + + /* Enable Transmitter - TX bit */ + if (!ll_temac_indirect_set(regs, TEMAC_TC, TC_TX)) + return 0; + + return 1; +} + +/* + * Configure ll_temac based on negotiated speed and duplex + * reported by PHY handling code + */ +static int ll_temac_adjust_link(struct eth_device *dev) +{ + unsigned int speed, emmc_reg; + struct temac_reg *regs = (struct temac_reg *)dev->iobase; + struct ll_temac *ll_temac = dev->priv; + struct phy_device *phydev = ll_temac->phydev; + + if (!phydev->link) { + printf("%s: No link.\n", phydev->dev->name); + return 0; + } + + switch (phydev->speed) { + case 1000: + speed = EMMC_LSPD_1000; + break; + case 100: + speed = EMMC_LSPD_100; + break; + case 10: + speed = EMMC_LSPD_10; + break; + default: + return 0; + } + + if (!ll_temac_indirect_get(regs, TEMAC_EMMC, &emmc_reg)) + return 0; + + emmc_reg &= ~EMMC_LSPD_MASK; + emmc_reg |= speed; + + if (!ll_temac_indirect_set(regs, TEMAC_EMMC, emmc_reg)) + return 0; + + printf("%s: PHY is %s with %dbase%s, %s%s\n", + dev->name, phydev->drv->name, + phydev->speed, (phydev->port == PORT_TP) ? "T" : "X", + (phydev->duplex) ? "FDX" : "HDX", + (phydev->port == PORT_OTHER) ? ", unkown mode" : ""); + + return 1; +} + +/* setup mac addr */ +static int ll_temac_setup_mac_addr(struct eth_device *dev) +{ + struct temac_reg *regs = (struct temac_reg *)dev->iobase; + u32 val; + + /* set up unicast MAC address filter */ + val = ((dev->enetaddr[3] << 24) | (dev->enetaddr[2] << 16) | + (dev->enetaddr[1] << 8) | (dev->enetaddr[0])); + val &= UAW0_UADDR_MASK; + + if (!ll_temac_indirect_set(regs, TEMAC_UAW0, val)) + return 1; + + val = ((dev->enetaddr[5] << 8) | dev->enetaddr[4]); + val &= UAW1_UADDR_MASK; + + if (!ll_temac_indirect_set(regs, TEMAC_UAW1, val)) + return 1; + + return 0; +} + +/* halt device */ +static void ll_temac_halt(struct eth_device *dev) +{ + struct ll_temac *ll_temac = dev->priv; + struct temac_reg *regs = (struct temac_reg *)dev->iobase; + + /* Disable Receiver */ + ll_temac_indirect_set(regs, TEMAC_RCW0, 0); + + /* Disable Transmitter */ + ll_temac_indirect_set(regs, TEMAC_TC, 0); + + if (ll_temac->ctrlhalt) + ll_temac->ctrlhalt(dev); + + /* Shut down the PHY, as needed */ + phy_shutdown(ll_temac->phydev); +} + +static int ll_temac_init(struct eth_device *dev, bd_t *bis) +{ + struct ll_temac *ll_temac = dev->priv; + + printf("%s: Xilinx XPS LocalLink Tri-Mode Ether MAC #%d at 0x%08X.\n", + dev->name, dev->index, dev->iobase); + + if (!ll_temac_setup_ctrl(dev)) + return -1; + + /* Start up the PHY */ + phy_startup(ll_temac->phydev); + + if (!ll_temac_adjust_link(dev)) { + ll_temac_halt(dev); + return -1; + } + + /* If there's no link, fail */ + return ll_temac->phydev->link ? 0 : -1; +} + +/* + * Discover which PHY is attached to the device, and configure it + * properly. If the PHY is not recognized, then return 0 + * (failure). Otherwise, return 1 + */ +static int ll_temac_phy_init(struct eth_device *dev) +{ + struct ll_temac *ll_temac = dev->priv; + struct phy_device *phydev; + unsigned int supported = PHY_GBIT_FEATURES; + + /* interface - look at driver/net/tsec.c */ + phydev = phy_connect(ll_temac->bus, ll_temac->phyaddr, + dev, PHY_INTERFACE_MODE_NONE); + + phydev->supported &= supported; + phydev->advertising = phydev->supported; + + ll_temac->phydev = phydev; + + phy_config(phydev); + + return 1; +} + +/* + * Initialize a single ll_temac devices + * + * Returns the result of ll_temac phy interface that were initialized + */ +int xilinx_ll_temac_initialize(bd_t *bis, struct ll_temac_info *devinf) +{ + struct eth_device *dev; + struct ll_temac *ll_temac; + int i; + + dev = calloc(1, sizeof(*dev)); + if (dev == NULL) + return 0; + + ll_temac = calloc(1, sizeof(struct ll_temac)); + if (ll_temac == NULL) { + free(dev); + return 0; + } + + ll_temac->ctrladdr = devinf->ctrl_addr; + ll_temac->rx_bp = rx_buffer; + ll_temac->tx_bp = tx_buffer; + ll_temac->rx_dp = &rx_descr; + ll_temac->tx_dp = &tx_descr; + + strncpy(dev->name, devinf->devname, NAMESIZE); + dev->iobase = devinf->base_addr; + + dev->priv = ll_temac; + dev->init = ll_temac_init; + dev->halt = ll_temac_halt; + dev->write_hwaddr = ll_temac_setup_mac_addr; + + if (devinf->mode & LL_TEMAC_M_SDMA) { +#if defined(CONFIG_XILINX_440) || defined(CONFIG_XILINX_405) + if (devinf->mode & LL_TEMAC_M_DCR) { + ll_temac_collect_xldcr_sdma_reg_addr(dev); + ll_temac->in32 = ll_temac_xldcr_in32; + ll_temac->out32 = ll_temac_xldcr_out32; + } else +#endif + { + ll_temac_collect_xlplb_sdma_reg_addr(dev); + ll_temac->in32 = ll_temac_xlplb_in32; + ll_temac->out32 = ll_temac_xlplb_out32; + } + ll_temac->ctrlinit = ll_temac_init_sdma; + ll_temac->ctrlhalt = ll_temac_halt_sdma; + ll_temac->ctrlreset = ll_temac_reset_sdma; + dev->recv = ll_temac_recv_sdma; + dev->send = ll_temac_send_sdma; + } else { + ll_temac->in32 = NULL; + ll_temac->out32 = NULL; + ll_temac->ctrlinit = NULL; + ll_temac->ctrlhalt = NULL; + ll_temac->ctrlreset = ll_temac_reset_fifo; + dev->recv = ll_temac_recv_fifo; + dev->send = ll_temac_send_fifo; + } + + /* Link to specified MDIO bus */ + strncpy(ll_temac->mdio_busname, devinf->mdio_busname, MDIO_NAME_LEN); + ll_temac->bus = miiphy_get_dev_by_name(ll_temac->mdio_busname); + + /* Looking for a valid PHY address if it is not yet set */ + if (devinf->phyaddr == -1) + ll_temac->phyaddr = ll_temac_phy_addr(ll_temac->bus); + else + ll_temac->phyaddr = devinf->phyaddr; + + /* Tell u-boot to get the addr from the env */ + for (i = 0; i < 6; i++) + dev->enetaddr[i] = 0; + + eth_register(dev); + + /* Try to initialize PHY here, and return */ + return ll_temac_phy_init(dev); +} + +/* + * Initialize all the ll_temac devices + * + * Returns the number of ll_temac devices that were initialized + */ +int xilinx_ll_temac_eth_init(bd_t *bis, struct ll_temac_info *devinf, int num) +{ + int i; + int ret, count = 0; + + for (i = 0; i < num; i++) { + ret = xilinx_ll_temac_initialize(bis, &devinf[i]); + if (ret > 0) + count += ret; + } + + return count; +} + +/* + * Initialize all the mdio buses behind ll_temac + * + * Returns the number of mdio buses that were initialized + */ +int xilinx_ll_temac_mdio_init(bd_t *bis, struct ll_temac_info *devinf, int num) +{ + int i; + int ret, count = 0; + struct ll_temac_mdio_info mdioinf; + + for (i = 0; i < num; i++) { + mdioinf.name = devinf[i].mdio_busname; + mdioinf.regs = (struct temac_reg *)devinf[i].base_addr; + ret = ll_temac_mdio_init(bis, &mdioinf); + if (ret >= 0) + count++; + } + + return count; +} + +int xilinx_ll_temac_standard_init(bd_t *bis) +{ + int count = 0; + + count += xilinx_ll_temac_mdio_init(bis, + ll_temac_info, ARRAY_SIZE(ll_temac_info)); + + count += xilinx_ll_temac_eth_init(bis, + ll_temac_info, ARRAY_SIZE(ll_temac_info)); + + return !count || count % 2 ? -1 : count; +} diff --git a/drivers/net/xilinx_ll_temac_fifo.c b/drivers/net/xilinx_ll_temac_fifo.c new file mode 100644 index 0000000..6ce3265 --- /dev/null +++ b/drivers/net/xilinx_ll_temac_fifo.c @@ -0,0 +1,105 @@ +/* + * Xilinx xps_ll_temac ethernet driver for u-boot + * + * FIFO sub-controller + * + * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu + * Copyright (C) 2008 - 2011 PetaLogix + * + * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net + * + * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver + * Copyright (C) 2008 Nissin Systems Co.,Ltd. + * March 2008 created + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + * + * [0]: http://www.xilinx.com/support/documentation + * + * [S]: [0]/ip_documentation/xps_ll_temac.pdf + * [A]: [0]/application_notes/xapp1041.pdf + */ + +#include <config.h> +#include <common.h> +#include <net.h> + +#include <asm/types.h> +#include <asm/io.h> + +#include <xilinx_ll_temac.h> +#include <xilinx_ll_temac_fifo.h> + +#ifdef DEBUG +static void debugll(struct eth_device *dev, int count) +{ + struct ll_temac *ll_temac = dev->priv; + struct fifo_ctrl *fifo_ctrl = (void *)ll_temac->ctrladdr; + + printf("FIFO: %d isr 0x%08x, ier 0x%08x, rdfr 0x%08x, " + "rdfo 0x%08x rlr 0x%08x\n", count, + in_be32(&fifo_ctrl->isr), in_be32(&fifo_ctrl->ier), + in_be32(&fifo_ctrl->rdfr), in_be32(&fifo_ctrl->rdfo), + in_be32(&fifo_ctrl->rlf)); +} +#endif + +int ll_temac_reset_fifo(struct eth_device *dev) +{ + struct ll_temac *ll_temac = dev->priv; + struct fifo_ctrl *fifo_ctrl = (void *)ll_temac->ctrladdr; + + out_be32(&fifo_ctrl->tdfr, LL_FIFO_TDFR_KEY); + out_be32(&fifo_ctrl->rdfr, LL_FIFO_RDFR_KEY); + out_be32(&fifo_ctrl->isr, ~0UL); + out_be32(&fifo_ctrl->ier, 0); + + return 0; +} + +int ll_temac_recv_fifo(struct eth_device *dev) +{ + struct ll_temac *ll_temac = dev->priv; + struct fifo_ctrl *fifo_ctrl = (void *)ll_temac->ctrladdr; + uchar *rx_bp = ll_temac->rx_bp; + u32 *buf = (u32 *)rx_bp; + u32 i, len = 0; + + if (in_be32(&fifo_ctrl->isr) & LL_FIFO_ISR_RC) { + + /* reset isr */ + out_be32(&fifo_ctrl->isr, ~0UL); + + /* while (fifo_ctrl->isr); */ + len = in_be32(&fifo_ctrl->rlf) & LL_FIFO_RLF_MASK; + + for (i = 0; i < len; i += 4) + *buf++ = in_be32(&fifo_ctrl->rdfd); + +#ifdef DEBUG + debugll(dev, 1); +#endif + + NetReceive((uchar *)rx_bp, len); + } + + return len; +} + +int ll_temac_send_fifo(struct eth_device *dev, + volatile void *buffer, int length) +{ + struct ll_temac *ll_temac = dev->priv; + struct fifo_ctrl *fifo_ctrl = (void *)ll_temac->ctrladdr; + u32 *buf = (u32 *)buffer; + u32 i; + + for (i = 0; i < length; i += 4) + out_be32(&fifo_ctrl->tdfd, *buf++); + + out_be32(&fifo_ctrl->tlf, length); + return 0; +} diff --git a/drivers/net/xilinx_ll_temac_mdio.c b/drivers/net/xilinx_ll_temac_mdio.c new file mode 100644 index 0000000..b637fe3 --- /dev/null +++ b/drivers/net/xilinx_ll_temac_mdio.c @@ -0,0 +1,164 @@ +/* + * Xilinx xps_ll_temac ethernet driver for u-boot + * + * MDIO bus access + * + * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu + * Copyright (C) 2008 - 2011 PetaLogix + * + * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net + * + * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver + * Copyright (C) 2008 Nissin Systems Co.,Ltd. + * March 2008 created + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + * + * [0]: http://www.xilinx.com/support/documentation + * + * [S]: [0]/ip_documentation/xps_ll_temac.pdf + * [A]: [0]/application_notes/xapp1041.pdf + */ + +#include <config.h> +#include <common.h> +#include <miiphy.h> +#include <phy.h> +#include <malloc.h> +#include <asm/io.h> + +#include <xilinx_ll_temac.h> +#include <xilinx_ll_temac_mdio.h> + +/* + * Prior to PHY access, the MDIO clock must be setup. This driver will set a + * safe default that should work with PLB bus speeds of up to 150 MHz and keep + * the MDIO clock below 2.5 MHz. If the user wishes faster access to the PHY + * then the clock divisor can be set to a different value by setting the + * correct bus speed value with CONFIG_XILINX_LL_TEMAC_CLK. + */ +#if !defined(CONFIG_XILINX_LL_TEMAC_CLK) +#define MDIO_CLOCK_DIV MC_CLKDIV_10(150000000) +#else +#define MDIO_CLOCK_DIV MC_CLKDIV_25(CONFIG_XILINX_LL_TEMAC_CLK) +#endif + +static int ll_temac_mdio_setup(struct mii_dev *bus) +{ + struct temac_reg *regs = (struct temac_reg *)bus->priv; + + /* setup MDIO clock */ + ll_temac_indirect_set(regs, TEMAC_MC, + MC_MDIOEN | (MDIO_CLOCK_DIV & MC_CLKDIV_MASK)); + + return 0; +} + +/* + * Indirect MII PHY read via ll_temac. + * + * http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac.pd... + * page 67, Using the MII Management to Access PHY Registers + */ +int ll_temac_local_mdio_read(struct temac_reg *regs, int addr, int devad, + int regnum) +{ + out_be32(®s->lsw, + ((addr << LSW_PHYAD_POS) & LSW_PHYAD_MASK) | + (regnum & LSW_REGAD_MASK)); + out_be32(®s->ctl, TEMAC_MIIMAI); + + ll_temac_check_status(regs, RSE_MIIM_RR); + + return in_be32(®s->lsw) & LSW_REGDAT_MASK; +} + +/* + * Indirect MII PHY write via ll_temac. + * + * http://www.xilinx.com/support/documentation/ip_documentation/xps_ll_temac.pd... + * page 67, Using the MII Management to Access PHY Registers + */ +void ll_temac_local_mdio_write(struct temac_reg *regs, int addr, int devad, + int regnum, u16 value) +{ + out_be32(®s->lsw, (value & LSW_REGDAT_MASK)); + out_be32(®s->ctl, CTL_WEN | TEMAC_MIIMWD); + + out_be32(®s->lsw, + ((addr << LSW_PHYAD_POS) & LSW_PHYAD_MASK) | + (regnum & LSW_REGAD_MASK)); + out_be32(®s->ctl, CTL_WEN | TEMAC_MIIMAI); + + ll_temac_check_status(regs, RSE_MIIM_WR); +} + +int ll_temac_phy_read(struct mii_dev *bus, int addr, int devad, int regnum) +{ + struct temac_reg *regs = (struct temac_reg *)bus->priv; + + return ll_temac_local_mdio_read(regs, addr, devad, regnum); +} + +int ll_temac_phy_write(struct mii_dev *bus, int addr, int devad, int regnum, + u16 value) +{ + struct temac_reg *regs = (struct temac_reg *)bus->priv; + + ll_temac_local_mdio_write(regs, addr, devad, regnum, value); + + return 0; +} + +/* + * Use MII register 1 (MII status register) to detect PHY + * + * A Mask used to verify certain PHY features (register content) + * in the PHY detection register: + * Auto-negotiation support, 10Mbps half/full duplex support + */ +#define PHY_DETECT_REG MII_BMSR +#define PHY_DETECT_MASK (BMSR_10FULL | BMSR_10HALF | BMSR_ANEGCAPABLE) + +/* Looking for a valid PHY address */ +int ll_temac_phy_addr(struct mii_dev *bus) +{ + struct temac_reg *regs = (struct temac_reg *)bus->priv; + unsigned short val; + unsigned int phy; + + for (phy = PHY_MAX_ADDR; phy >= 0; phy--) { + val = ll_temac_local_mdio_read(regs, phy, 0, PHY_DETECT_REG); + if ((val != 0xFFFF) && + ((val & PHY_DETECT_MASK) == PHY_DETECT_MASK)) { + /* Found a valid PHY address */ + return phy; + } + } + + return -1; +} + +int ll_temac_mdio_init(bd_t *bis, struct ll_temac_mdio_info *info) +{ + struct mii_dev *bus = mdio_alloc(); + + if (!bus) { + printf("Failed to allocate LL_TEMAC MDIO bus: %s\n", + info->name); + return -1; + } + + bus->read = ll_temac_phy_read; + bus->write = ll_temac_phy_write; + bus->reset = NULL; + sprintf(bus->name, info->name); + + bus->priv = info->regs; + + ll_temac_mdio_setup(bus); + return mdio_register(bus); +} diff --git a/drivers/net/xilinx_ll_temac_sdma.c b/drivers/net/xilinx_ll_temac_sdma.c new file mode 100644 index 0000000..c9b6a1b --- /dev/null +++ b/drivers/net/xilinx_ll_temac_sdma.c @@ -0,0 +1,324 @@ +/* + * Xilinx xps_ll_temac ethernet driver for u-boot + * + * SDMA sub-controller + * + * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu + * Copyright (C) 2008 - 2011 PetaLogix + * + * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net + * + * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver + * Copyright (C) 2008 Nissin Systems Co.,Ltd. + * March 2008 created + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + * + * [0]: http://www.xilinx.com/support/documentation + * + * [S]: [0]/ip_documentation/xps_ll_temac.pdf + * [A]: [0]/application_notes/xapp1041.pdf + */ + +#include <config.h> +#include <common.h> +#include <net.h> + +#include <asm/types.h> +#include <asm/io.h> + +#include <xilinx_ll_temac.h> +#include <xilinx_ll_temac_sdma.h> + +#if defined(CONFIG_XILINX_440) || defined(CONFIG_XILINX_405) + +/* + * Indirect DCR access operations mi{ft}dcr_xilinx() espacialy + * for Xilinx PowerPC implementations on FPGA. + * + * FIXME: This part should go up to arch/powerpc -- but where? + */ +#include <asm/processor.h> +#define XILINX_INDIRECT_DCR_ADDRESS_REG 0 +#define XILINX_INDIRECT_DCR_ACCESS_REG 1 +inline unsigned mifdcr_xilinx(const unsigned dcrn) +{ + mtdcr(XILINX_INDIRECT_DCR_ADDRESS_REG, dcrn); + return mfdcr(XILINX_INDIRECT_DCR_ACCESS_REG); +} +inline void mitdcr_xilinx(const unsigned dcrn, int val) +{ + mtdcr(XILINX_INDIRECT_DCR_ADDRESS_REG, dcrn); + mtdcr(XILINX_INDIRECT_DCR_ACCESS_REG, val); +} + +/* Xilinx Device Control Register (DCR) in/out accessors */ +inline unsigned ll_temac_xldcr_in32(phys_addr_t addr) +{ + return mifdcr_xilinx((const unsigned)addr); +} +inline void ll_temac_xldcr_out32(phys_addr_t addr, unsigned value) +{ + mitdcr_xilinx((const unsigned)addr, value); +} + +void ll_temac_collect_xldcr_sdma_reg_addr(struct eth_device *dev) +{ + struct ll_temac *ll_temac = dev->priv; + phys_addr_t dmac_ctrl = ll_temac->ctrladdr; + phys_addr_t *ra = ll_temac->sdma_reg_addr; + + ra[TX_NXTDESC_PTR] = dmac_ctrl + TX_NXTDESC_PTR; + ra[TX_CURBUF_ADDR] = dmac_ctrl + TX_CURBUF_ADDR; + ra[TX_CURBUF_LENGTH] = dmac_ctrl + TX_CURBUF_LENGTH; + ra[TX_CURDESC_PTR] = dmac_ctrl + TX_CURDESC_PTR; + ra[TX_TAILDESC_PTR] = dmac_ctrl + TX_TAILDESC_PTR; + ra[TX_CHNL_CTRL] = dmac_ctrl + TX_CHNL_CTRL; + ra[TX_IRQ_REG] = dmac_ctrl + TX_IRQ_REG; + ra[TX_CHNL_STS] = dmac_ctrl + TX_CHNL_STS; + ra[RX_NXTDESC_PTR] = dmac_ctrl + RX_NXTDESC_PTR; + ra[RX_CURBUF_ADDR] = dmac_ctrl + RX_CURBUF_ADDR; + ra[RX_CURBUF_LENGTH] = dmac_ctrl + RX_CURBUF_LENGTH; + ra[RX_CURDESC_PTR] = dmac_ctrl + RX_CURDESC_PTR; + ra[RX_TAILDESC_PTR] = dmac_ctrl + RX_TAILDESC_PTR; + ra[RX_CHNL_CTRL] = dmac_ctrl + RX_CHNL_CTRL; + ra[RX_IRQ_REG] = dmac_ctrl + RX_IRQ_REG; + ra[RX_CHNL_STS] = dmac_ctrl + RX_CHNL_STS; + ra[DMA_CONTROL_REG] = dmac_ctrl + DMA_CONTROL_REG; +} + +#endif /* CONFIG_XILINX_440 || ONFIG_XILINX_405 */ + +/* Xilinx Processor Local Bus (PLB) in/out accessors */ +inline unsigned ll_temac_xlplb_in32(phys_addr_t addr) +{ + return in_be32((void *)addr); +} +inline void ll_temac_xlplb_out32(phys_addr_t addr, unsigned value) +{ + out_be32((void *)addr, value); +} + +/* collect all register addresses for Xilinx PLB in/out accessors */ +void ll_temac_collect_xlplb_sdma_reg_addr(struct eth_device *dev) +{ + struct ll_temac *ll_temac = dev->priv; + struct sdma_ctrl *sdma_ctrl = (void *)ll_temac->ctrladdr; + phys_addr_t *ra = ll_temac->sdma_reg_addr; + + ra[TX_NXTDESC_PTR] = (phys_addr_t)&sdma_ctrl->tx_nxtdesc_ptr; + ra[TX_CURBUF_ADDR] = (phys_addr_t)&sdma_ctrl->tx_curbuf_addr; + ra[TX_CURBUF_LENGTH] = (phys_addr_t)&sdma_ctrl->tx_curbuf_length; + ra[TX_CURDESC_PTR] = (phys_addr_t)&sdma_ctrl->tx_curdesc_ptr; + ra[TX_TAILDESC_PTR] = (phys_addr_t)&sdma_ctrl->tx_taildesc_ptr; + ra[TX_CHNL_CTRL] = (phys_addr_t)&sdma_ctrl->tx_chnl_ctrl; + ra[TX_IRQ_REG] = (phys_addr_t)&sdma_ctrl->tx_irq_reg; + ra[TX_CHNL_STS] = (phys_addr_t)&sdma_ctrl->tx_chnl_sts; + ra[RX_NXTDESC_PTR] = (phys_addr_t)&sdma_ctrl->rx_nxtdesc_ptr; + ra[RX_CURBUF_ADDR] = (phys_addr_t)&sdma_ctrl->rx_curbuf_addr; + ra[RX_CURBUF_LENGTH] = (phys_addr_t)&sdma_ctrl->rx_curbuf_length; + ra[RX_CURDESC_PTR] = (phys_addr_t)&sdma_ctrl->rx_curdesc_ptr; + ra[RX_TAILDESC_PTR] = (phys_addr_t)&sdma_ctrl->rx_taildesc_ptr; + ra[RX_CHNL_CTRL] = (phys_addr_t)&sdma_ctrl->rx_chnl_ctrl; + ra[RX_IRQ_REG] = (phys_addr_t)&sdma_ctrl->rx_irq_reg; + ra[RX_CHNL_STS] = (phys_addr_t)&sdma_ctrl->rx_chnl_sts; + ra[DMA_CONTROL_REG] = (phys_addr_t)&sdma_ctrl->dma_control_reg; +} + +/* Check for TX and RX channel errors. */ +static inline int ll_temac_sdma_error(struct eth_device *dev) +{ + int err; + struct ll_temac *ll_temac = dev->priv; + phys_addr_t *ra = ll_temac->sdma_reg_addr; + + err = ll_temac->in32(ra[TX_CHNL_STS]) & CHNL_STS_ERROR; + err |= ll_temac->in32(ra[TX_CHNL_STS]) & CHNL_STS_ERROR; + + return err; +} + +int ll_temac_init_sdma(struct eth_device *dev) +{ + struct ll_temac *ll_temac = dev->priv; + struct cdmac_bd *rx_dp = ll_temac->rx_dp; + struct cdmac_bd *tx_dp = ll_temac->tx_dp; + phys_addr_t *ra = ll_temac->sdma_reg_addr; + + memset(tx_dp, 0, sizeof(*tx_dp)); + memset(rx_dp, 0, sizeof(*rx_dp)); + + /* from LL TEMAC (Rx) */ + rx_dp->phys_buf_p = ll_temac->rx_bp; + + rx_dp->next_p = rx_dp; + rx_dp->buf_len = PKTSIZE_ALIGN; + flush_cache((u32)rx_dp, sizeof(*tx_dp)); + flush_cache((u32)rx_dp->phys_buf_p, PKTSIZE_ALIGN); + + /* setup first fd */ + ll_temac->out32(ra[RX_CURDESC_PTR], (int)rx_dp); + ll_temac->out32(ra[RX_TAILDESC_PTR], (int)rx_dp); + ll_temac->out32(ra[RX_NXTDESC_PTR], (int)rx_dp); + + /* to LL TEMAC (Tx) */ + tx_dp->phys_buf_p = ll_temac->tx_bp; + tx_dp->next_p = tx_dp; + + flush_cache((u32)tx_dp, sizeof(*tx_dp)); + ll_temac->out32(ra[TX_CURDESC_PTR], (int)tx_dp); + + return 0; +} + +int ll_temac_halt_sdma(struct eth_device *dev) +{ + unsigned timeout = 50; /* 1usec * 50 = 50usec */ + struct ll_temac *ll_temac = dev->priv; + phys_addr_t *ra = ll_temac->sdma_reg_addr; + + /* + * Soft reset the DMA + * + * Quote from MPMC documentation: Writing a 1 to this field + * forces the DMA engine to shutdown and reset itself. After + * setting this bit, software must poll it until the bit is + * cleared by the DMA. This indicates that the reset process + * is done and the pipeline has been flushed. + */ + ll_temac->out32(ra[DMA_CONTROL_REG], DMA_CONTROL_RESET); + while (timeout && (ll_temac->in32(ra[DMA_CONTROL_REG]) + & DMA_CONTROL_RESET)) { + timeout--; + udelay(1); + } + + if (!timeout) { + printf("%s: Timeout\n", __func__); + return -1; + } + + return 0; +} + +int ll_temac_reset_sdma(struct eth_device *dev) +{ + u32 r; + struct ll_temac *ll_temac = dev->priv; + phys_addr_t *ra = ll_temac->sdma_reg_addr; + + /* Soft reset the DMA. */ + if (ll_temac_halt_sdma(dev)) + return -1; + + /* Now clear the interrupts. */ + r = ll_temac->in32(ra[TX_CHNL_CTRL]); + r &= ~CHNL_CTRL_IRQ_MASK; + ll_temac->out32(ra[TX_CHNL_CTRL], r); + + r = ll_temac->in32(ra[RX_CHNL_CTRL]); + r &= ~CHNL_CTRL_IRQ_MASK; + ll_temac->out32(ra[RX_CHNL_CTRL], r); + + /* Now ACK pending IRQs. */ + ll_temac->out32(ra[TX_IRQ_REG], IRQ_REG_IRQ_MASK); + ll_temac->out32(ra[RX_IRQ_REG], IRQ_REG_IRQ_MASK); + + /* Set tail-ptr mode, disable errors for both channels. */ + ll_temac->out32(ra[DMA_CONTROL_REG], + /* Enable use of tail pointer register */ + DMA_CONTROL_TPE | + /* Disable error when 2 or 4 bit coalesce cnt overfl */ + DMA_CONTROL_RXOCEID | + /* Disable error when 2 or 4 bit coalesce cnt overfl */ + DMA_CONTROL_TXOCEID); + + return 0; +} + +int ll_temac_recv_sdma(struct eth_device *dev) +{ + int length; + struct ll_temac *ll_temac = dev->priv; + struct cdmac_bd *rx_dp = ll_temac->rx_dp; + phys_addr_t *ra = ll_temac->sdma_reg_addr; + + if (ll_temac_sdma_error(dev)) { + + if (ll_temac_reset_sdma(dev)) + return -1; + + ll_temac_init_sdma(dev); + } + + flush_cache((u32)rx_dp, sizeof(*rx_dp)); + + if (!(rx_dp->sca.stctrl & CDMAC_BD_STCTRL_COMPLETED)) + return 0; + + /* + * Read out the packet info and start the DMA + * onto the second buffer to enable the ethernet rx + * path to run in parallel with sw processing + * packets. + */ + length = rx_dp->sca.app[4] & CDMAC_BD_APP4_RXBYTECNT_MASK; + if (length > 0) + NetReceive(rx_dp->phys_buf_p, length); + + /* flip the buffer and re-enable the DMA. */ + flush_cache((u32)rx_dp->phys_buf_p, length); + + rx_dp->buf_len = PKTSIZE_ALIGN; + rx_dp->sca.stctrl = 0; + rx_dp->sca.app[4] = 0; + + flush_cache((u32)rx_dp, sizeof(*rx_dp)); + ll_temac->out32(ra[RX_TAILDESC_PTR], (int)rx_dp); + + return length; +} + +int ll_temac_send_sdma(struct eth_device *dev, volatile void *buffer, + int length) +{ + unsigned timeout = 50; /* 1usec * 50 = 50usec */ + struct ll_temac *ll_temac = dev->priv; + struct cdmac_bd *tx_dp = ll_temac->tx_dp; + phys_addr_t *ra = ll_temac->sdma_reg_addr; + + if (ll_temac_sdma_error(dev)) { + + if (ll_temac_reset_sdma(dev)) + return -1; + + ll_temac_init_sdma(dev); + } + + memcpy(ll_temac->tx_bp, (void *)buffer, length); + flush_cache((u32)ll_temac->tx_bp, length); + + tx_dp->sca.stctrl = CDMAC_BD_STCTRL_SOP | CDMAC_BD_STCTRL_EOP | + CDMAC_BD_STCTRL_STOP_ON_END; + tx_dp->buf_len = length; + flush_cache((u32)tx_dp, sizeof(*tx_dp)); + + /* DMA start */ + ll_temac->out32(ra[TX_CURDESC_PTR], (int)tx_dp); + ll_temac->out32(ra[TX_TAILDESC_PTR], (int)tx_dp); + + do { + flush_cache((u32)tx_dp, sizeof(*tx_dp)); + udelay(1); + } while (timeout-- && !(tx_dp->sca.stctrl & CDMAC_BD_STCTRL_COMPLETED)); + + if (!timeout) { + printf("%s: Timeout\n", __func__); + return -1; + } + + return 0; +} diff --git a/include/netdev.h b/include/netdev.h index b0c21d5..bf95f88 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -102,6 +102,7 @@ int xilinx_axiemac_initialize(bd_t *bis, unsigned long base_addr, unsigned long dma_addr); int xilinx_emaclite_initialize(bd_t *bis, unsigned long base_addr, int txpp, int rxpp); +int xilinx_ll_temac_standard_init(bd_t *bis);
/* Boards with PCI network controllers can call this from their board_eth_init() * function to initialize whatever's on board. diff --git a/include/xilinx_ll_temac.h b/include/xilinx_ll_temac.h new file mode 100644 index 0000000..1da6b8e --- /dev/null +++ b/include/xilinx_ll_temac.h @@ -0,0 +1,381 @@ +/* + * Xilinx xps_ll_temac ethernet driver for u-boot + * + * LL_TEMAC interface + * + * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu + * Copyright (C) 2008 - 2011 PetaLogix + * + * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net + * + * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver + * Copyright (C) 2008 Nissin Systems Co.,Ltd. + * March 2008 created + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + * + * [0]: http://www.xilinx.com/support/documentation + * + * [S]: [0]/ip_documentation/xps_ll_temac.pdf + * [A]: [0]/application_notes/xapp1041.pdf + */ +#ifndef _XILINX_LL_TEMAC_ +#define _XILINX_LL_TEMAC_ + +#include <config.h> +#include <net.h> +#include <phy.h> +#include <miiphy.h> + +#include <asm/types.h> +#include <asm/byteorder.h> + +#include <xilinx_ll_temac_sdma.h> + +#if !defined(__BIG_ENDIAN) +# error LL_TEMAC requires big endianess +#endif + +/* default ETH device name */ +#if !defined(CONFIG_XILINX_LL_TEMAC0_NAME) +#define CONFIG_XILINX_LL_TEMAC0_NAME "LLTEMAC0" +#endif + +#if !defined(CONFIG_XILINX_LL_TEMAC1_NAME) +#define CONFIG_XILINX_LL_TEMAC1_NAME "LLTEMAC1" +#endif + +/* default MII device name */ +#if !defined(CONFIG_XILINX_LL_TEMAC0_MII_NAME) +#define CONFIG_XILINX_LL_TEMAC0_MII_NAME "LLTEMAC0_MII" +#endif + +#if !defined(CONFIG_XILINX_LL_TEMAC1_MII_NAME) +#define CONFIG_XILINX_LL_TEMAC1_MII_NAME "LLTEMAC1_MII" +#endif + +/* default PHY device address on MII */ +#if !defined(CONFIG_PHY_ADDR) +#define CONFIG_PHY_ADDR -1 +#endif +#define CONFIG_PHY0_ADDR CONFIG_PHY_ADDR + +#if !defined(CONFIG_PHY1_ADDR) +#define CONFIG_PHY1_ADDR -1 +#endif + +#define STD_LL_TEMAC_INFO(num, ba, cm, ca) \ +{ \ + .devname = CONFIG_XILINX_LL_TEMAC##num##_NAME, \ + .base_addr = ba, \ + .ctrl_addr = ca, \ + .mode = cm, \ + .mdio_busname = CONFIG_XILINX_LL_TEMAC##num##_MII_NAME, \ + .phyaddr = CONFIG_PHY##num##_ADDR, \ +} + +#define SET_STD_LL_TEMAC_INFO(x, num, ba, cm, ca) \ +{ \ + x.devname = CONFIG_XILINX_LL_TEMAC##num##_NAME, \ + x.base_addr = ba, \ + x.ctrl_addr = ca, \ + x.mode = cm, \ + x.mdio_busname = CONFIG_XILINX_LL_TEMAC##num##_MII_NAME, \ + x.phyaddr = CONFIG_PHY##num##_ADDR, \ +} + +/* + * TEMAC Memory and Register Definition + * + * [1]: [0]/ip_documentation/xps_ll_temac.pdf + * page 19, Memory and Register Descriptions + */ +struct temac_reg { + /* direct soft registers (low part) */ + u32 raf; /* Reset and Address Filter */ + u32 tpf; /* Transmit Pause Frame */ + u32 ifgp; /* Transmit Inter Frame Gap Adjustment */ + u32 is; /* Interrupt Status */ + u32 ip; /* Interrupt Pending */ + u32 ie; /* Interrupt Enable */ + u32 ttag; /* Transmit VLAN Tag */ + u32 rtag; /* Receive VLAN Tag */ + /* hard TEMAC registers */ + u32 msw; /* Most Significant Word Data */ + u32 lsw; /* Least Significant Word Data */ + u32 ctl; /* Control */ + u32 rdy; /* Ready Status */ + /* direct soft registers (high part) */ + u32 uawl; /* Unicast Address Word Lower */ + u32 uawu; /* Unicast Address Word Upper */ + u32 tpid0; /* VLAN TPID Word 0 */ + u32 tpid1; /* VLAN TPID Word 1 */ +}; + +/* Reset and Address Filter Registers (raf), [1] p25 */ +#define RAF_SR (1 << 13) +#define RAF_EMFE (1 << 12) +#define RAF_NFE (1 << 11) +#define RAF_RVSTM_POS 9 +#define RAF_RVSTM_MASK (3 << RAF_RVSTM_POS) +#define RAF_TVSTM_POS 7 +#define RAF_TVSTM_MASK (3 << RAF_TVSTM_POS) +#define RAF_RVTM_POS 5 +#define RAF_RVTM_MASK (3 << RAF_RVTM_POS) +#define RAF_TVTM_POS 3 +#define RAF_TVTM_MASK (3 << RAF_TVTM_POS) +#define RAF_BCREJ (1 << 2) +#define RAF_MCREJ (1 << 1) +#define RAF_HTRST (1 << 0) + +/* Transmit Pause Frame Registers (tpf), [1] p28 */ +#define TPF_TPFV_POS 0 +#define TPF_TPFV_MASK (0xFFFF << TPF_TPFV_POS) + +/* Transmit Inter Frame Gap Adjustment Registers (ifgp), [1] p28 */ +#define IFGP_POS 0 +#define IFGP_MASK (0xFF << IFGP_POS) + +/* Interrupt Status, Pending, Enable Registers (is, ip, ie), [1] p29-33 */ +#define ISPE_MR (1 << 7) +#define ISPE_RDL (1 << 6) +#define ISPE_TC (1 << 5) +#define ISPE_RFO (1 << 4) +#define ISPE_RR (1 << 3) +#define ISPE_RC (1 << 2) +#define ISPE_AN (1 << 1) +#define ISPE_HAC (1 << 0) + +/* Transmit, Receive VLAN Tag Registers (ttag, rtag), [1] p34-35 */ +#define TRTAG_TPID_POS 16 +#define TRTAG_TPID_MASK (0xFFFF << TRTAG_TPID_POS) +#define TRTAG_PRIO_POS 13 +#define TRTAG_PRIO_MASK (7 << TRTAG_PRIO_POS) +#define TRTAG_CFI (1 << 12) +#define TRTAG_VID_POS 0 +#define TRTAG_VID_MASK (0xFFF << TRTAG_VID_POS) + +/* Most, Least Significant Word Data Register (msw, lsw), [1] p46 */ +#define MLSW_POS 0 +#define MLSW_MASK (~0UL << MLSW_POS) + +/* LSW Data Register for PHY addresses (lsw), [1] p66 */ +#define LSW_REGAD_POS 0 +#define LSW_REGAD_MASK (0x1F << LSW_REGAD_POS) +#define LSW_PHYAD_POS 5 +#define LSW_PHYAD_MASK (0x1F << LSW_PHYAD_POS) + +/* LSW Data Register for PHY data (lsw), [1] p66 */ +#define LSW_REGDAT_POS 0 +#define LSW_REGDAT_MASK (0xFFFF << LSW_REGDAT_POS) + +/* Control Register (ctl), [1] p47 */ +#define CTL_WEN (1 << 15) +#define CTL_ADDR_POS 0 +#define CTL_ADDR_MASK (0x3FF << CTL_ADDR_POS) + +/* Ready Status Register Ethernet (rdy), [1] p48 */ +#define RSE_HACS_RDY (1 << 14) +#define RSE_CFG_WR (1 << 6) +#define RSE_CFG_RR (1 << 5) +#define RSE_AF_WR (1 << 4) +#define RSE_AF_RR (1 << 3) +#define RSE_MIIM_WR (1 << 2) +#define RSE_MIIM_RR (1 << 1) +#define RSE_FABR_RR (1 << 0) + +/* Unicast Address Word Lower, Upper Registers (uawl, uawu), [1] p35-36 */ +#define UAWL_UADDR_POS 0 +#define UAWL_UADDR_MASK (~0UL << UAWL_UADDR_POS) +#define UAWU_UADDR_POS 0 +#define UAWU_UADDR_MASK (0xFFFF << UAWU_UADDR_POS) + +/* VLAN TPID Word 0, 1 Registers (tpid0, tpid1), [1] p37 */ +#define TPID0_V0_POS 0 +#define TPID0_V0_MASK (0xFFFF << TPID0_V0_POS) +#define TPID0_V1_POS 16 +#define TPID0_V1_MASK (0xFFFF << TPID0_V1_POS) +#define TPID1_V2_POS 0 +#define TPID1_V2_MASK (0xFFFF << TPID1_V2_POS) +#define TPID1_V3_POS 16 +#define TPID1_V3_MASK (0xFFFF << TPID1_V3_POS) + +/* + * TEMAC Indirectly Addressable Register Index Enumeration + * + * [0]: http://www.xilinx.com/support/documentation + * + * [1]: [0]/ip_documentation/xps_ll_temac.pdf + * page 23, PLB Indirectly Addressable TEMAC Registers + */ +enum temac_ctrl { + TEMAC_RCW0 = 0x200, + TEMAC_RCW1 = 0x240, + TEMAC_TC = 0x280, + TEMAC_FCC = 0x2C0, + TEMAC_EMMC = 0x300, + TEMAC_PHYC = 0x320, + TEMAC_MC = 0x340, + TEMAC_UAW0 = 0x380, + TEMAC_UAW1 = 0x384, + TEMAC_MAW0 = 0x388, + TEMAC_MAW1 = 0x38C, + TEMAC_AFM = 0x390, + TEMAC_TIS = 0x3A0, + TEMAC_TIE = 0x3A4, + TEMAC_MIIMWD = 0x3B0, + TEMAC_MIIMAI = 0x3B4 +}; + +/* Receive Configuration Word 0, 1 Registers (RCW0, RCW1), [1] p50-51 */ +#define RCW0_PADDR_POS 0 +#define RCW0_PADDR_MASK (~0UL << RCW_PADDR_POS) +#define RCW1_RST (1 << 31) +#define RCW1_JUM (1 << 30) +#define RCW1_FCS (1 << 29) +#define RCW1_RX (1 << 28) +#define RCW1_VLAN (1 << 27) +#define RCW1_HD (1 << 26) +#define RCW1_LT_DIS (1 << 25) +#define RCW1_PADDR_POS 0 +#define RCW1_PADDR_MASK (0xFFFF << RCW_PADDR_POS) + +/* Transmit Configuration Registers (TC), [1] p52 */ +#define TC_RST (1 << 31) +#define TC_JUM (1 << 30) +#define TC_FCS (1 << 29) +#define TC_TX (1 << 28) +#define TC_VLAN (1 << 27) +#define TC_HD (1 << 26) +#define TC_IFG (1 << 25) + +/* Flow Control Configuration Registers (FCC), [1] p54 */ +#define FCC_FCTX (1 << 30) +#define FCC_FCRX (1 << 29) + +/* Ethernet MAC Mode Configuration Registers (EMMC), [1] p54 */ +#define EMMC_LSPD_POS 30 +#define EMMC_LSPD_MASK (3 << EMMC_LSPD_POS) +#define EMMC_LSPD_1000 (2 << EMMC_LSPD_POS) +#define EMMC_LSPD_100 (1 << EMMC_LSPD_POS) +#define EMMC_LSPD_10 0 +#define EMMC_RGMII (1 << 29) +#define EMMC_SGMII (1 << 28) +#define EMMC_GPCS (1 << 27) +#define EMMC_HOST (1 << 26) +#define EMMC_TX16 (1 << 25) +#define EMMC_RX16 (1 << 24) + +/* RGMII/SGMII Configuration Registers (PHYC), [1] p56 */ +#define PHYC_SLSPD_POS 30 +#define PHYC_SLSPD_MASK (3 << EMMC_SLSPD_POS) +#define PHYC_SLSPD_1000 (2 << EMMC_SLSPD_POS) +#define PHYC_SLSPD_100 (1 << EMMC_SLSPD_POS) +#define PHYC_SLSPD_10 0 +#define PHYC_RLSPD_POS 2 +#define PHYC_RLSPD_MASK (3 << EMMC_RLSPD_POS) +#define PHYC_RLSPD_1000 (2 << EMMC_RLSPD_POS) +#define PHYC_RLSPD_100 (1 << EMMC_RLSPD_POS) +#define PHYC_RLSPD_10 0 +#define PHYC_RGMII_HD (1 << 1) +#define PHYC_RGMII_LINK (1 << 0) + +/* Management Configuration Registers (MC), [1] p57 */ +#define MC_MDIOEN (1 << 6) +#define MC_CLKDIV_POS 0 +#define MC_CLKDIV_MASK (0x3F << MC_CLKDIV_POS) + +/* + * fHOSTCLK fMDC = fHOSTCLK + * fMDC = ------------------- ---------> MC_CLKDIV = -------- - 1 + * (1 + MC_CLKDIV) * 2 2.5 MHz 5MHz + */ +#define MC_CLKDIV(f, m) ((f / (2 * m)) - 1) +#define MC_CLKDIV_25(f) MC_CLKDIV(f, 2500000) +#define MC_CLKDIV_20(f) MC_CLKDIV(f, 2000000) +#define MC_CLKDIV_15(f) MC_CLKDIV(f, 1500000) +#define MC_CLKDIV_10(f) MC_CLKDIV(f, 1000000) + +/* Unicast Address Word 0, 1 Registers (UAW0, UAW1), [1] p58-59 */ +#define UAW0_UADDR_POS 0 +#define UAW0_UADDR_MASK (~0UL << UAW0_UADDR_POS) +#define UAW1_UADDR_POS 0 +#define UAW1_UADDR_MASK (0xFFFF << UAW1_UADDR_POS) + +/* Multicast Address Word 0, 1 Registers (MAW0, MAW1), [1] p60 */ +#define MAW0_MADDR_POS 0 +#define MAW0_MADDR_MASK (~0UL << MAW0_MADDR_POS) +#define MAW1_RNW (1 << 23) +#define MAW1_MAIDX_POS 16 +#define MAW1_MAIDX_MASK (3 << MAW1_MAIDX_POS) +#define MAW1_MADDR_POS 0 +#define MAW1_MADDR_MASK (0xFFFF << MAW1_MADDR_POS) + +/* Address Filter Mode Registers (AFM), [1] p63 */ +#define AFM_PM (1 << 31) + +/* Interrupt Status, Enable Registers (TIS, TIE), [1] p63-65 */ +#define TISE_CFG_W (1 << 6) +#define TISE_CFG_R (1 << 5) +#define TISE_AF_W (1 << 4) +#define TISE_AF_R (1 << 3) +#define TISE_MIIM_W (1 << 2) +#define TISE_MIIM_R (1 << 1) +#define TISE_FABR_R (1 << 0) + +/* MII Management Write Data Registers (MIIMWD), [1] p66 */ +#define MIIMWD_DATA_POS 0 +#define MIIMWD_DATA_MASK (0xFFFF << MIIMWD_DATA_POS) + +/* Ethernet interface ready status */ +int ll_temac_check_status(struct temac_reg *regs, u32 mask); + +/* Indirect write to ll_temac. */ +int ll_temac_indirect_set(struct temac_reg *regs, u16 regn, u32 reg_data); + +/* Indirect read from ll_temac. */ +int ll_temac_indirect_get(struct temac_reg *regs, u16 regn, u32* reg_data); + +struct ll_temac { + phys_addr_t ctrladdr; + phys_addr_t sdma_reg_addr[SDMA_CTRL_REGNUMS]; + + unsigned (*in32)(phys_addr_t); + void (*out32)(phys_addr_t, unsigned); + + int (*ctrlinit) (struct eth_device *); + int (*ctrlhalt) (struct eth_device *); + int (*ctrlreset) (struct eth_device *); + + unsigned char *rx_bp; + unsigned char *tx_bp; + + struct cdmac_bd *rx_dp; + struct cdmac_bd *tx_dp; + + int phyaddr; + struct phy_device *phydev; + struct mii_dev *bus; + char mdio_busname[MDIO_NAME_LEN]; +}; + +struct ll_temac_info { + int mode; + unsigned long base_addr; + unsigned long ctrl_addr; + char *devname; + unsigned int phyaddr; + char *mdio_busname; +}; + +/* Driver mode bit flags */ +#define LL_TEMAC_M_FIFO 0 /* use FIFO Ctrl */ +#define LL_TEMAC_M_SDMA (1 << 0) /* use SDMA Ctrl */ +#define LL_TEMAC_M_DCR (1 << 1) /* use DCR Bus */ + +int xilinx_ll_temac_initialize(bd_t *bis, struct ll_temac_info *devinf); + +#endif /* _XILINX_LL_TEMAC_ */ diff --git a/include/xilinx_ll_temac_fifo.h b/include/xilinx_ll_temac_fifo.h new file mode 100644 index 0000000..db62f69 --- /dev/null +++ b/include/xilinx_ll_temac_fifo.h @@ -0,0 +1,119 @@ +/* + * Xilinx xps_ll_temac ethernet driver for u-boot + * + * FIFO interface + * + * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu + * Copyright (C) 2008 - 2011 PetaLogix + * + * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net + * + * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver + * Copyright (C) 2008 Nissin Systems Co.,Ltd. + * March 2008 created + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + * + * [0]: http://www.xilinx.com/support/documentation + * + * [S]: [0]/ip_documentation/xps_ll_temac.pdf + * [A]: [0]/application_notes/xapp1041.pdf + */ +#ifndef _XILINX_LL_TEMAC_FIFO_ +#define _XILINX_LL_TEMAC_FIFO_ + +#include <net.h> + +#include <asm/types.h> +#include <asm/byteorder.h> + +#if !defined(__BIG_ENDIAN) +# error LL_TEMAC requires big endianess +#endif + +/* + * FIFO Register Definition + * + * Used for memory mapped access from and to (Rd/Td) the LocalLink (LL) + * Tri-Mode Ether MAC (TEMAC) via the 2 kb full duplex FIFO Controller, + * one for each. + * + * [1]: [0]/ip_documentation/xps_ll_fifo.pdf + * page 10, Registers Definition + */ +struct fifo_ctrl { + u32 isr; /* Interrupt Status Register (RW) */ + u32 ier; /* Interrupt Enable Register (RW) */ + u32 tdfr; /* Transmit Data FIFO Reset (WO) */ + u32 tdfv; /* Transmit Data FIFO Vacancy (RO) */ + u32 tdfd; /* Transmit Data FIFO 32bit wide Data write port (WO) */ + u32 tlf; /* Transmit Length FIFO (WO) */ + u32 rdfr; /* Receive Data FIFO Reset (WO) */ + u32 rdfo; /* Receive Data FIFO Occupancy (RO) */ + u32 rdfd; /* Receive Data FIFO 32bit wide Data read port (RO) */ + u32 rlf; /* Receive Length FIFO (RO) */ + u32 llr; /* LocalLink Reset (WO) */ +}; + +/* Interrupt Status Register (ISR), [1] p11 */ +#define LL_FIFO_ISR_RPURE (1 << 31) /* Receive Packet Underrun Read Err */ +#define LL_FIFO_ISR_RPORE (1 << 30) /* Receive Packet Overrun Read Err */ +#define LL_FIFO_ISR_RPUE (1 << 29) /* Receive Packet Underrun Error */ +#define LL_FIFO_ISR_TPOE (1 << 28) /* Transmit Packet Overrun Error */ +#define LL_FIFO_ISR_TC (1 << 27) /* Transmit Complete */ +#define LL_FIFO_ISR_RC (1 << 26) /* Receive Complete */ +#define LL_FIFO_ISR_TSE (1 << 25) /* Transmit Size Error */ +#define LL_FIFO_ISR_TRC (1 << 24) /* Transmit Reset Complete */ +#define LL_FIFO_ISR_RRC (1 << 23) /* Receive Reset Complete */ + +/* Interrupt Enable Register (IER), [1] p12/p13 */ +#define LL_FIFO_IER_RPURE (1 << 31) /* Receive Packet Underrun Read Err */ +#define LL_FIFO_IER_RPORE (1 << 30) /* Receive Packet Overrun Read Err */ +#define LL_FIFO_IER_RPUE (1 << 29) /* Receive Packet Underrun Error */ +#define LL_FIFO_IER_TPOE (1 << 28) /* Transmit Packet Overrun Error */ +#define LL_FIFO_IER_TC (1 << 27) /* Transmit Complete */ +#define LL_FIFO_IER_RC (1 << 26) /* Receive Complete */ +#define LL_FIFO_IER_TSE (1 << 25) /* Transmit Size Error */ +#define LL_FIFO_IER_TRC (1 << 24) /* Transmit Reset Complete */ +#define LL_FIFO_IER_RRC (1 << 23) /* Receive Reset Complete */ + +/* Transmit Data FIFO Reset (TDFR), [1] p13/p14 */ +#define LL_FIFO_TDFR_KEY 0x000000A5UL + +/* Transmit Data FIFO Vacancy (TDFV), [1] p14 */ +#define LL_FIFO_TDFV_POS 0 +#define LL_FIFO_TDFV_MASK (0x000001FFUL << LL_FIFO_TDFV_POS) + +/* Transmit Length FIFO (TLF), [1] p16/p17 */ +#define LL_FIFO_TLF_POS 0 +#define LL_FIFO_TLF_MASK (0x000007FFUL << LL_FIFO_TLF_POS) + +/* Receive Data FIFO Reset (RDFR), [1] p15 */ +#define LL_FIFO_RDFR_KEY 0x000000A5UL + +/* Receive Data FIFO Occupancy (RDFO), [1] p16 */ +#define LL_FIFO_RDFO_POS 0 +#define LL_FIFO_RDFO_MASK (0x000001FFUL << LL_FIFO_RDFO_POS) + +/* Receive Length FIFO (TLF), [1] p17/p18 */ +#define LL_FIFO_RLF_POS 0 +#define LL_FIFO_RLF_MASK (0x000007FFUL << LL_FIFO_RLF_POS) + +/* LocalLink Reset (LLR), [1] p18 */ +#define LL_FIFO_LLR_KEY 0x000000A5UL + + +/* reset FIFO and IRQ, disable interrupts */ +int ll_temac_reset_fifo(struct eth_device *dev); + +/* receive buffered data from FIFO (polling ISR) */ +int ll_temac_recv_fifo(struct eth_device *dev); + +/* send buffered data to FIFO */ +int ll_temac_send_fifo(struct eth_device *dev, volatile void *buffer, + int length); + +#endif /* _XILINX_LL_TEMAC_FIFO_ */ diff --git a/include/xilinx_ll_temac_mdio.h b/include/xilinx_ll_temac_mdio.h new file mode 100644 index 0000000..d50546a --- /dev/null +++ b/include/xilinx_ll_temac_mdio.h @@ -0,0 +1,54 @@ +/* + * Xilinx xps_ll_temac ethernet driver for u-boot + * + * MDIO interface + * + * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu + * Copyright (C) 2008 - 2011 PetaLogix + * + * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net + * + * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver + * Copyright (C) 2008 Nissin Systems Co.,Ltd. + * March 2008 created + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + * + * [0]: http://www.xilinx.com/support/documentation + * + * [S]: [0]/ip_documentation/xps_ll_temac.pdf + * [A]: [0]/application_notes/xapp1041.pdf + */ +#ifndef _XILINX_LL_TEMAC_MDIO_ +#define _XILINX_LL_TEMAC_MDIO_ + +#include <net.h> +#include <miiphy.h> + +#include <asm/types.h> +#include <asm/byteorder.h> + +#include <xilinx_ll_temac.h> + +int ll_temac_local_mdio_read(struct temac_reg *regs, int addr, int devad, + int regnum); +void ll_temac_local_mdio_write(struct temac_reg *regs, int addr, int devad, + int regnum, u16 value); + +int ll_temac_phy_read(struct mii_dev *bus, int addr, int devad, int regnum); +int ll_temac_phy_write(struct mii_dev *bus, int addr, int devad, int regnum, + u16 value); + +int ll_temac_phy_addr(struct mii_dev *bus); + +struct ll_temac_mdio_info { + struct temac_reg *regs; + char *name; +}; + +int ll_temac_mdio_init(bd_t *bis, struct ll_temac_mdio_info *info); + +#endif /* _XILINX_LL_TEMAC_MDIO_ */ diff --git a/include/xilinx_ll_temac_sdma.h b/include/xilinx_ll_temac_sdma.h new file mode 100644 index 0000000..6215560 --- /dev/null +++ b/include/xilinx_ll_temac_sdma.h @@ -0,0 +1,289 @@ +/* + * Xilinx xps_ll_temac ethernet driver for u-boot + * + * SDMA interface + * + * Copyright (C) 2008 - 2011 Michal Simek monstr@monstr.eu + * Copyright (C) 2008 - 2011 PetaLogix + * + * Copyright (C) 2011 - 2012 Stephan Linz linz@li-pro.net + * + * Based on Yoshio Kashiwagi kashiwagi@co-nss.co.jp driver + * Copyright (C) 2008 Nissin Systems Co.,Ltd. + * March 2008 created + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + * + * [0]: http://www.xilinx.com/support/documentation + * + * [S]: [0]/ip_documentation/xps_ll_temac.pdf + * [A]: [0]/application_notes/xapp1041.pdf + */ +#ifndef _XILINX_LL_TEMAC_SDMA_ +#define _XILINX_LL_TEMAC_SDMA_ + +#include <net.h> + +#include <asm/types.h> +#include <asm/byteorder.h> + +#include <linux/compiler.h> + +#if !defined(__BIG_ENDIAN) +# error LL_TEMAC requires big endianess +#endif + +#if defined(CONFIG_SYS_CACHELINE_SIZE) +#define DMAALIGN CONFIG_SYS_CACHELINE_SIZE +#else +/* we expact to live in a 32 bit processor environment */ +#define DMAALIGN 32 +#endif + +/* + * DMA Buffer Descriptor for CDMAC + * + * Used for data connection from and to (Rx/Tx) the LocalLink (LL) TEMAC via + * the Communications Direct Memory Access Controller (CDMAC) -- one for each. + * + * overview: + * ftp://ftp.xilinx.com/pub/documentation/misc/mpmc_getting_started.pdf + * + * [1]: [0]/ip_documentation/mpmc.pdf + * page 140, DMA Operation Descriptors + * + * [2]: [0]/user_guides/ug200.pdf + * page 229, DMA Controller -- Descriptor Format + * + * [3]: [0]/ip_documentation/xps_ll_temac.pdf + * page 72, Transmit LocalLink Frame Format + * page 73, Receive LocalLink Frame Format + */ +struct cdmac_bd { + struct cdmac_bd *next_p; /* Next Descriptor Pointer */ + u8 *phys_buf_p; /* Buffer Address */ + u32 buf_len; /* Buffer Length */ + union { + u8 stctrl; /* Status/Control the DMA transfer */ + u32 app[5]; /* application specific data */ + } __packed __aligned(1) sca; +}; + +/* CDMAC Descriptor Status and Control (stctrl), [1] p140, [2] p230 */ +#define CDMAC_BD_STCTRL_ERROR (1 << 7) +#define CDMAC_BD_STCTRL_IRQ_ON_END (1 << 6) +#define CDMAC_BD_STCTRL_STOP_ON_END (1 << 5) +#define CDMAC_BD_STCTRL_COMPLETED (1 << 4) +#define CDMAC_BD_STCTRL_SOP (1 << 3) +#define CDMAC_BD_STCTRL_EOP (1 << 2) +#define CDMAC_BD_STCTRL_DMACHBUSY (1 << 1) + +/* CDMAC Descriptor APP0: Transmit LocalLink Footer Word 3, [3] p72 */ +#define CDMAC_BD_APP0_TXCSCNTRL (1 << 0) + +/* CDMAC Descriptor APP1: Transmit LocalLink Footer Word 4, [3] p73 */ +#define CDMAC_BD_APP1_TXCSBEGIN_POS 16 +#define CDMAC_BD_APP1_TXCSBEGIN_MASK (0xFFFF << CDMAC_BD_APP1_TXCSBEGIN_POS) +#define CDMAC_BD_APP1_TXCSINSERT_POS 0 +#define CDMAC_BD_APP1_TXCSINSERT_MASK (0xFFFF << CDMAC_BD_APP1_TXCSINSERT_POS) + +/* CDMAC Descriptor APP2: Transmit LocalLink Footer Word 5, [3] p73 */ +#define CDMAC_BD_APP2_TXCSINIT_POS 0 +#define CDMAC_BD_APP2_TXCSINIT_MASK (0xFFFF << CDMAC_BD_APP2_TXCSINIT_POS) + +/* CDMAC Descriptor APP0: Receive LocalLink Footer Word 3, [3] p73 */ +#define CDMAC_BD_APP0_MADDRU_POS 0 +#define CDMAC_BD_APP0_MADDRU_MASK (0xFFFF << CDMAC_BD_APP0_MADDRU_POS) + +/* CDMAC Descriptor APP1: Receive LocalLink Footer Word 4, [3] p74 */ +#define CDMAC_BD_APP1_MADDRL_POS 0 +#define CDMAC_BD_APP1_MADDRL_MASK (~0UL << CDMAC_BD_APP1_MADDRL_POS) + +/* CDMAC Descriptor APP2: Receive LocalLink Footer Word 5, [3] p74 */ +#define CDMAC_BD_APP2_BCAST_FRAME (1 << 2) +#define CDMAC_BD_APP2_IPC_MCAST_FRAME (1 << 1) +#define CDMAC_BD_APP2_MAC_MCAST_FRAME (1 << 0) + +/* CDMAC Descriptor APP3: Receive LocalLink Footer Word 6, [3] p74 */ +#define CDMAC_BD_APP3_TLTPID_POS 16 +#define CDMAC_BD_APP3_TLTPID_MASK (0xFFFF << CDMAC_BD_APP3_TLTPID_POS) +#define CDMAC_BD_APP3_RXCSRAW_POS 0 +#define CDMAC_BD_APP3_RXCSRAW_MASK (0xFFFF << CDMAC_BD_APP3_RXCSRAW_POS) + +/* CDMAC Descriptor APP4: Receive LocalLink Footer Word 7, [3] p74 */ +#define CDMAC_BD_APP4_VLANTAG_POS 16 +#define CDMAC_BD_APP4_VLANTAG_MASK (0xFFFF << CDMAC_BD_APP4_VLANTAG_POS) +#define CDMAC_BD_APP4_RXBYTECNT_POS 0 +#define CDMAC_BD_APP4_RXBYTECNT_MASK (0x3FFF << CDMAC_BD_APP4_RXBYTECNT_POS) + +/* + * SDMA Register Definition + * + * [0]: http://www.xilinx.com/support/documentation + * + * [1]: [0]/ip_documentation/mpmc.pdf + * page 54, SDMA Register Summary + * page 160, SDMA Registers + * + * [2]: [0]/user_guides/ug200.pdf + * page 244, DMA Controller -- Programming Interface and Registers + */ +#define SDMA_CTRL_REGTYPE u32 +#define SDMA_CTRL_REGSIZE sizeof(SDMA_CTRL_REGTYPE) +struct sdma_ctrl { + /* Transmit Registers */ + SDMA_CTRL_REGTYPE tx_nxtdesc_ptr; /* TX Next Description Pointer */ + SDMA_CTRL_REGTYPE tx_curbuf_addr; /* TX Current Buffer Address */ + SDMA_CTRL_REGTYPE tx_curbuf_length; /* TX Current Buffer Length */ + SDMA_CTRL_REGTYPE tx_curdesc_ptr; /* TX Current Descriptor Pointer */ + SDMA_CTRL_REGTYPE tx_taildesc_ptr; /* TX Tail Descriptor Pointer */ + SDMA_CTRL_REGTYPE tx_chnl_ctrl; /* TX Channel Control */ + SDMA_CTRL_REGTYPE tx_irq_reg; /* TX Interrupt Register */ + SDMA_CTRL_REGTYPE tx_chnl_sts; /* TX Status Register */ + /* Receive Registers */ + SDMA_CTRL_REGTYPE rx_nxtdesc_ptr; /* RX Next Descriptor Pointer */ + SDMA_CTRL_REGTYPE rx_curbuf_addr; /* RX Current Buffer Address */ + SDMA_CTRL_REGTYPE rx_curbuf_length; /* RX Current Buffer Length */ + SDMA_CTRL_REGTYPE rx_curdesc_ptr; /* RX Current Descriptor Pointer */ + SDMA_CTRL_REGTYPE rx_taildesc_ptr; /* RX Tail Descriptor Pointer */ + SDMA_CTRL_REGTYPE rx_chnl_ctrl; /* RX Channel Control */ + SDMA_CTRL_REGTYPE rx_irq_reg; /* RX Interrupt Register */ + SDMA_CTRL_REGTYPE rx_chnl_sts; /* RX Status Register */ + /* Control Registers */ + SDMA_CTRL_REGTYPE dma_control_reg; /* DMA Control Register */ +}; + +#define SDMA_CTRL_REGNUMS sizeof(struct sdma_ctrl)/SDMA_CTRL_REGSIZE + +/* + * DMAC Register Index Enumeration + * + * [2]: http://www.xilinx.com/support/documentation/user_guides/ug200.pdf + * page 244, DMA Controller -- Programming Interface and Registers + */ +enum dmac_ctrl { + /* Transmit Registers */ + TX_NXTDESC_PTR = 0, /* TX Next Description Pointer */ + TX_CURBUF_ADDR, /* TX Current Buffer Address */ + TX_CURBUF_LENGTH, /* TX Current Buffer Length */ + TX_CURDESC_PTR, /* TX Current Descriptor Pointer */ + TX_TAILDESC_PTR, /* TX Tail Descriptor Pointer */ + TX_CHNL_CTRL, /* TX Channel Control */ + TX_IRQ_REG, /* TX Interrupt Register */ + TX_CHNL_STS, /* TX Status Register */ + /* Receive Registers */ + RX_NXTDESC_PTR, /* RX Next Descriptor Pointer */ + RX_CURBUF_ADDR, /* RX Current Buffer Address */ + RX_CURBUF_LENGTH, /* RX Current Buffer Length */ + RX_CURDESC_PTR, /* RX Current Descriptor Pointer */ + RX_TAILDESC_PTR, /* RX Tail Descriptor Pointer */ + RX_CHNL_CTRL, /* RX Channel Control */ + RX_IRQ_REG, /* RX Interrupt Register */ + RX_CHNL_STS, /* RX Status Register */ + /* Control Registers */ + DMA_CONTROL_REG /* DMA Control Register */ +}; + +/* Rx/Tx Channel Control Register (*_chnl_ctrl), [1] p163, [2] p246/p252 */ +#define CHNL_CTRL_ITO_POS 24 +#define CHNL_CTRL_ITO_MASK (0xFF << CHNL_CTRL_ITO_POS) +#define CHNL_CTRL_IC_POS 16 +#define CHNL_CTRL_IC_MASK (0xFF << CHNL_CTRL_IC_POS) +#define CHNL_CTRL_MSBADDR_POS 12 +#define CHNL_CTRL_MSBADDR_MASK (0xF << CHNL_CTRL_MSBADDR_POS) +#define CHNL_CTRL_AME (1 << 11) +#define CHNL_CTRL_OBWC (1 << 10) +#define CHNL_CTRL_IOE (1 << 9) +#define CHNL_CTRL_LIC (1 << 8) +#define CHNL_CTRL_IE (1 << 7) +#define CHNL_CTRL_IEE (1 << 2) +#define CHNL_CTRL_IDE (1 << 1) +#define CHNL_CTRL_ICE (1 << 0) + +/* All interrupt enable bits */ +#define CHNL_CTRL_IRQ_MASK (CHNL_CTRL_IE | \ + CHNL_CTRL_IEE | \ + CHNL_CTRL_IDE | \ + CHNL_CTRL_ICE) + +/* Rx/Tx Interrupt Status Register (*_irq_reg), [1] p164, [2] p247/p253 */ +#define IRQ_REG_DTV_POS 24 +#define IRQ_REG_DTV_MASK (0xFF << IRQ_REG_DTV_POS) +#define IRQ_REG_CCV_POS 16 +#define IRQ_REG_CCV_MASK (0xFF << IRQ_REG_CCV_POS) +#define IRQ_REG_WRCQ_EMPTY (1 << 14) +#define IRQ_REG_CIC_POS 10 +#define IRQ_REG_CIC_MASK (0xF << IRQ_REG_CIC_POS) +#define IRQ_REG_DIC_POS 8 +#define IRQ_REG_DIC_MASK (3 << 8) +#define IRQ_REG_PLB_RD_NMI (1 << 4) +#define IRQ_REG_PLB_WR_NMI (1 << 3) +#define IRQ_REG_EI (1 << 2) +#define IRQ_REG_DI (1 << 1) +#define IRQ_REG_CI (1 << 0) + +/* All interrupt bits */ +#define IRQ_REG_IRQ_MASK (IRQ_REG_PLB_RD_NMI | \ + IRQ_REG_PLB_WR_NMI | \ + IRQ_REG_EI | IRQ_REG_DI | IRQ_REG_CI) + +/* Rx/Tx Channel Status Register (*_chnl_sts), [1] p165, [2] p249/p255 */ +#define CHNL_STS_ERROR_TAIL (1 << 21) +#define CHNL_STS_ERROR_CMP (1 << 20) +#define CHNL_STS_ERROR_ADDR (1 << 19) +#define CHNL_STS_ERROR_NXTP (1 << 18) +#define CHNL_STS_ERROR_CURP (1 << 17) +#define CHNL_STS_ERROR_BSYWR (1 << 16) +#define CHNL_STS_ERROR (1 << 7) +#define CHNL_STS_IOE (1 << 6) +#define CHNL_STS_SOE (1 << 5) +#define CHNL_STS_CMPLT (1 << 4) +#define CHNL_STS_SOP (1 << 3) +#define CHNL_STS_EOP (1 << 2) +#define CHNL_STS_EBUSY (1 << 1) + +/* DMA Control Register (dma_control_reg), [1] p166, [2] p256 */ +#define DMA_CONTROL_PLBED (1 << 5) +#define DMA_CONTROL_RXOCEID (1 << 4) +#define DMA_CONTROL_TXOCEID (1 << 3) +#define DMA_CONTROL_TPE (1 << 2) +#define DMA_CONTROL_RESET (1 << 0) + +#if defined(CONFIG_XILINX_440) || defined(CONFIG_XILINX_405) + +/* Xilinx Device Control Register (DCR) in/out accessors */ +unsigned ll_temac_xldcr_in32(phys_addr_t addr); +void ll_temac_xldcr_out32(phys_addr_t addr, unsigned value); + +/* collect all register addresses for Xilinx DCR in/out accessors */ +void ll_temac_collect_xldcr_sdma_reg_addr(struct eth_device *dev); + +#endif /* CONFIG_XILINX_440 || CONFIG_XILINX_405 */ + +/* Xilinx Processor Local Bus (PLB) in/out accessors */ +unsigned ll_temac_xlplb_in32(phys_addr_t base); +void ll_temac_xlplb_out32(phys_addr_t base, unsigned value); + +/* collect all register addresses for Xilinx PLB in/out accessors */ +void ll_temac_collect_xlplb_sdma_reg_addr(struct eth_device *dev); + +/* initialize both Rx/Tx buffer descriptors */ +int ll_temac_init_sdma(struct eth_device *dev); + +/* halt both Rx/Tx transfers */ +int ll_temac_halt_sdma(struct eth_device *dev); + +/* reset SDMA and IRQ, disable interrupts and errors */ +int ll_temac_reset_sdma(struct eth_device *dev); + +/* receive buffered data from SDMA (polling ISR) */ +int ll_temac_recv_sdma(struct eth_device *dev); + +/* send buffered data to SDMA */ +int ll_temac_send_sdma(struct eth_device *dev, volatile void *buffer, + int length); + +#endif /* _XILINX_LL_TEMAC_SDMA_ */
come code already declares PktBuf ... can't you use that ?
this looks like a struct that should get allocated on the fly based on arguments given to the driver's registration func
+int xilinx_ll_temac_initialize(bd_t *bis, struct ll_temac_info *devinf) ...
- dev = calloc(1, sizeof(*dev));
- /* Tell u-boot to get the addr from the env */
- for (i = 0; i < 6; i++)
the memory is already zero-ed by the call to calloc, so this for loop is useless (and if it wasn't, you'd still use memset()) -mike
Am Sonntag, den 15.01.2012, 12:28 -0500 schrieb Mike Frysinger:
Hm, what do you mean exactly here?
These are the two DMA transfer buffers. I have no idea if there are buffers in the upper layer (NET) and how I can use it for DMA transfers. Therfore I create my own rx/tx buffers and copy data. That reduce the performance a little bit, but it's OK. Furthermore I have to use DMA safe buffers here (no cache, 32 byte alignment).
OK, it wast a little bit RAM. We can optimize the code later. I want to see more testing results on differnet Microblaze and PPC platforms.
Sure, we can remove this part in one of the next code optimization.
from doc/README.drivers.eth: The recv function should process packets as long as the hardware has them readily available before returning. i.e. you should drain the hardware fifo. For each packet you receive, you should call the NetReceive() function on it along with the packet length. The common code sets up packet buffers for you already in the .bss (NetRxPackets), so there should be no need to allocate your own.
so you already have an array of packet buffers declared for you. the first one is &NetRxPackets[0], etc... since you're just DMA-ing to random external memory, i don't think the address matters.
the core code atm however doesn't align things at all, so we'll have to fix that before this driver could use it.
the point wasn't optimization but to kill off defines influencing how the code behaves. drivers should operate based on on their per-device state (addresses/settings/etc...) which is given to them via their registration func. that way multiple devices can be registered in different modes.
or do it now and re-submit a v2 ... -mike
Am Sonntag, den 15.01.2012, 13:47 -0500 schrieb Mike Frysinger:
OK, I'll try to change the buffer handling as soon as possible in one of the next optimization stages of this driver. Looks interesting and important to me ...
The alignment is essential for the LL TEMAC driver, especially the 32 byte alignment. I look to continue to optimize this part after the patch has been added.
I have already done. Patch is coming up ... :-)
Dear Stephan Linz,
No, please do it now. I will not pull the current patch.
No, you misunderstant. You submitted an incremental, separate patch.
But we don't want to add code that is known to have problems / shortcomings now and fix / improve it 5 minutes later. We let the patch ripe and add it only when we consider it ready.
So please do not defer weorkign on the review comments.
+/* Data buffer for LL TEMAC Rx and Tx direction */ +static unsigned char rx_buffer[PKTSIZE_ALIGN] __attribute((aligned(DMAALIGN))); +static unsigned char tx_buffer[PKTSIZE_ALIGN] __attribute((aligned(DMAALIGN)));
Hello Mike and all others,
is there already a simple ETH driver that use these kind of buffer handling? Up to now I've learned from the Freescale TSEC driver, especially the MDIO bus implementation. It seems this driver implement this packet buffer, or not?
Is the TSEC driver DMA alignment safe (especially the DMA buffer data, not the DMA buffer descriptor)? What do I need to make the internal array of packet buffer DMA secure (cache, alignment)?
Dear Stephan Linz,
It's a bad thing not to look at common code, but thnings like that happen too easily.
However, now that this has been pointed out, you cannot simply ignore such a request.
I could imagine this to be a pretty common requirement.
we can fix this now, right?
No. Please fix this now, and then add a cleaned up driver. This is what the peer review process is all about.
Am Montag, den 16.01.2012, 09:14 +0100 schrieb Wolfgang Denk:
Dear Stephan Linz,
Hi Wolfgang,
you are right in all points. I'll go into the next round and handle all new request.
br, Stephan
In xilinx_ll_temac_initialize() the memory is already zero-ed by the call to calloc, so this loop is useless.
Signed-off-by: Stephan Linz linz@li-pro.net --- drivers/net/xilinx_ll_temac.c | 4 ---- 1 files changed, 0 insertions(+), 4 deletions(-)
diff --git a/drivers/net/xilinx_ll_temac.c b/drivers/net/xilinx_ll_temac.c index 8533358..e050250 100644 --- a/drivers/net/xilinx_ll_temac.c +++ b/drivers/net/xilinx_ll_temac.c @@ -387,10 +387,6 @@ int xilinx_ll_temac_initialize(bd_t *bis, struct ll_temac_info *devinf) else ll_temac->phyaddr = devinf->phyaddr;
- /* Tell u-boot to get the addr from the env */ - for (i = 0; i < 6; i++) - dev->enetaddr[i] = 0; - eth_register(dev);
has this driver already been merged ? if not, the process is to update the patch and send the new version to the list as a v2 ... -mike
Am Sonntag, den 15.01.2012, 18:44 -0500 schrieb Mike Frysinger:
You are right, I will post a new V9 patch ...
Dear Stephan Linz,
Please squash this into the patch that adds the driver.
NET_MULTI enables to use several ethernet drivers but microblaze-generic platform config file select only one driver.
Reported-by: Michal Simek monstr@monstr.eu Signed-off-by: Stephan Linz linz@li-pro.net --- include/configs/microblaze-generic.h | 10 ++++++---- 1 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 03a6f5a..29a86d1 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -65,11 +65,12 @@
/* ethernet */ #undef CONFIG_SYS_ENET -#ifdef XILINX_EMACLITE_BASEADDR -# define CONFIG_XILINX_EMACLITE 1 +#if defined(XILINX_EMACLITE_BASEADDR) +# define CONFIG_XILINX_EMACLITE 1 # define CONFIG_SYS_ENET -#elif XILINX_LLTEMAC_BASEADDR -# define CONFIG_XILINX_LL_TEMAC 1 +#endif +#if defined(XILINX_LLTEMAC_BASEADDR) || defined(XILINX_LLTEMAC_BASEADDR1) +# define CONFIG_XILINX_LL_TEMAC 1 # define CONFIG_SYS_ENET #endif #if defined(XILINX_AXIEMAC_BASEADDR) @@ -312,6 +313,7 @@ #define CONFIG_SERVERIP 192.168.0.5 #define CONFIG_GATEWAYIP 192.168.0.1 #define CONFIG_ETHADDR 00:E0:0C:00:00:FD +#define CONFIG_ETH1ADDR 00:E0:0C:00:00:FC
/* architecture dependent code */ #define CONFIG_SYS_USR_EXCEP /* user exception */
Initialize ll_temac driver.
Reported-by: Michal Simek monstr@monstr.eu Signed-off-by: Stephan Linz linz@li-pro.net --- .../xilinx/microblaze-generic/microblaze-generic.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/board/xilinx/microblaze-generic/microblaze-generic.c b/board/xilinx/microblaze-generic/microblaze-generic.c index c4c13a6..517b2f1 100644 --- a/board/xilinx/microblaze-generic/microblaze-generic.c +++ b/board/xilinx/microblaze-generic/microblaze-generic.c @@ -90,5 +90,10 @@ int board_eth_init(bd_t *bis) ret |= xilinx_emaclite_initialize(bis, XILINX_EMACLITE_BASEADDR, txpp, rxpp); #endif + +#ifdef CONFIG_XILINX_LL_TEMAC + ret |= xilinx_ll_temac_standard_init(bis); +#endif + return ret; }
Enable phylib and mii support for LLTEMAC or AXI EMAC ethernet drivers on Microblaze systems.
Signed-off-by: Michal Simek monstr@monstr.eu Acked-by: Stephan Linz linz@li-pro.net --- include/configs/microblaze-generic.h | 21 +++++++++++++++++++++ 1 files changed, 21 insertions(+), 0 deletions(-)
diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 29a86d1..ec2e49e 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -340,4 +340,25 @@ #define CONFIG_FIT 1 #define CONFIG_OF_LIBFDT 1
+#if defined(CONFIG_XILINX_LL_TEMAC) || defined(CONFIG_XILINX_AXIEMAC) +# define CONFIG_MII 1 +# define CONFIG_CMD_MII 1 +# define CONFIG_PHY_GIGE 1 +# define CONFIG_SYS_FAULT_ECHO_LINK_DOWN 1 +# define CONFIG_PHYLIB 1 +# define CONFIG_PHY_ATHEROS 1 +# define CONFIG_PHY_BROADCOM 1 +# define CONFIG_PHY_DAVICOM 1 +# define CONFIG_PHY_LXT 1 +# define CONFIG_PHY_MARVELL 1 +# define CONFIG_PHY_MICREL 1 +# define CONFIG_PHY_NATSEMI 1 +# define CONFIG_PHY_REALTEK 1 +# define CONFIG_PHY_VITESSE 1 +#else +# undef CONFIG_MII +# undef CONFIG_CMD_MII +# undef CONFIG_PHYLIB +#endif + #endif /* __CONFIG_H */
Expand the specific configuration for the microblaze-generic board in xparameters.h with a faked setup to enable the LL_TEMAC driver.
Note: From now the microblaze-generic board is no longer a valid board configuration for a real piece of hardware. Rather than, we use the file config.mk and xparameters.h as a faked board configuration to force the compilation of all potential driver code for Microblaze systems.
Signed-off-by: Stephan Linz linz@li-pro.net --- board/xilinx/microblaze-generic/config.mk | 6 ++++-- board/xilinx/microblaze-generic/xparameters.h | 12 ++++++++++-- 2 files changed, 14 insertions(+), 4 deletions(-)
diff --git a/board/xilinx/microblaze-generic/config.mk b/board/xilinx/microblaze-generic/config.mk index f8d7e26..9fd1015 100644 --- a/board/xilinx/microblaze-generic/config.mk +++ b/board/xilinx/microblaze-generic/config.mk @@ -21,8 +21,10 @@ # Foundation, Inc., 59 Temple Place, Suite 330, Boston, # MA 02111-1307 USA # -# CAUTION: This file is automatically generated by libgen. -# Version: Xilinx EDK 6.3 EDK_Gmm.12.3 +# CAUTION: This file is a faked configuration !!! +# There is no real target for the microblaze-generic +# configuration. You have to replace this file with +# the generated file from your Xilinx design flow. #
CONFIG_SYS_TEXT_BASE = 0x29000000 diff --git a/board/xilinx/microblaze-generic/xparameters.h b/board/xilinx/microblaze-generic/xparameters.h index fae03bf..fcbd55e 100644 --- a/board/xilinx/microblaze-generic/xparameters.h +++ b/board/xilinx/microblaze-generic/xparameters.h @@ -21,8 +21,10 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA * - * CAUTION: This file is automatically generated by libgen. - * Version: Xilinx EDK 8.2.02 EDK_Im_Sp2.4 + * CAUTION: This file is a faked configuration !!! + * There is no real target for the microblaze-generic + * configuration. You have to replace this file with + * the generated file from your Xilinx design flow. */
#define XILINX_BOARD_NAME microblaze-generic @@ -69,3 +71,9 @@
/* Ethernet controller is Ethernet_MAC */ #define XILINX_EMACLITE_BASEADDR 0x40C00000 + +/* Ethernet controller is Ethernet_MAC */ +#define XILINX_LLTEMAC_BASEADDR 0x44000000 +#define XILINX_LLTEMAC_SDMA_CTRL_BASEADDR 0x42000180 +#define XILINX_LLTEMAC_BASEADDR1 0x44000040 +#define XILINX_LLTEMAC_SDMA_CTRL_BASEADDR1 0x42000200
Mike Frysinger
Stephan Linz
