[PATCH V5 0/9] arm64: binman: use binman symbols for imx
V5: Introduce no-u-boot-any property to drop the X86 guard patch 1 Add blob-ext type for ddr firmware node Include a missing dts change
V4: Fix three boards build failure
V3: Add R-b/T-b Fix build warning
V2: resolve some CI failure include patch 7
binman symbol is a good feature, but only used on X86 for now. This patchset is to use it for i.MX8M platform.
The current imx8m ddr phy firmware consumes lots of space, because we pad them to the largest 32KB and 16KB for IMEM and DMEM.
With this patchset we use binman symbols to get firmware location and size, we could save near 36KB with i.MX8MP-EVK.
Please help check and test
Peng Fan (9): arm: dts: imx8m: update binman ddr firmware node name armv8: u-boot-spl.lds: mark __image_copy_start as symbol tools: binman: section: replace @ with - binman: introduce no-u-boot-any property arm: dts: imx8m: add no-u-boot-any property ddr: imx8m: helper: load ddr firmware according to binman symbols arm: dts: imx8m: shrink ddr firmware size to actual file size binman_sym: guard with CONFIG_SPL_BINMAN_SYMBOLS imx: imx8mm-icore: migrate to use BINMAN
arch/arm/cpu/armv8/u-boot-spl.lds | 2 +- arch/arm/dts/imx8mm-u-boot.dtsi | 17 ++++--- arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi | 21 +++++--- .../dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi | 9 ++-- arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi | 21 +++++--- arch/arm/dts/imx8mn-evk-u-boot.dtsi | 21 +++++--- .../dts/imx8mn-var-som-symphony-u-boot.dtsi | 17 ++++--- arch/arm/dts/imx8mn-venice-u-boot.dtsi | 17 ++++--- arch/arm/dts/imx8mp-u-boot.dtsi | 21 +++++--- arch/arm/dts/imx8mq-cm-u-boot.dtsi | 21 +++++--- arch/arm/dts/imx8mq-u-boot.dtsi | 17 ++++--- arch/arm/mach-imx/imx8m/Kconfig | 1 + .../mach-imx/imx8m/imximage-8mm-lpddr4.cfg | 10 +--- configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 2 +- configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 2 +- drivers/ddr/imx/imx8m/helper.c | 51 ++++++++++++++++--- include/binman_sym.h | 2 +- tools/binman/binman.rst | 6 +++ tools/binman/etype/section.py | 7 ++- tools/binman/test/u_boot_binman_syms.c | 1 + tools/binman/test/u_boot_binman_syms_size.c | 1 + 21 files changed, 169 insertions(+), 98 deletions(-)
We are migrating to use BINMAN SYMBOLS, the current name is not a valid binman type, so update to unify them.
Also add `type = "blob-ext";` for generating a valid binman symbol
Tested-by: Tim Harvey tharvey@gateworks.com #imx8m[m,n,p]-venice Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mm-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi | 12 ++++++++---- arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi | 4 ++-- arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi | 12 ++++++++---- arch/arm/dts/imx8mn-evk-u-boot.dtsi | 12 ++++++++---- arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-venice-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mp-u-boot.dtsi | 12 ++++++++---- arch/arm/dts/imx8mq-cm-u-boot.dtsi | 12 ++++++++---- arch/arm/dts/imx8mq-u-boot.dtsi | 8 ++++---- 10 files changed, 58 insertions(+), 38 deletions(-)
diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index 9f66cdb65a9..dc036894d82 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -39,25 +39,25 @@ filename = "u-boot-spl.bin"; };
- 1d-imem { + imem-1d { filename = "lpddr4_pmu_train_1d_imem.bin"; size = <0x8000>; type = "blob-ext"; };
- 1d-dmem { + dmem-1d { filename = "lpddr4_pmu_train_1d_dmem.bin"; size = <0x4000>; type = "blob-ext"; };
- 2d-imem { + imem-2d { filename = "lpddr4_pmu_train_2d_imem.bin"; size = <0x8000>; type = "blob-ext"; };
- 2d-dmem { + dmem-2d { filename = "lpddr4_pmu_train_2d_dmem.bin"; size = <0x4000>; type = "blob-ext"; diff --git a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi index eb1dd8debba..3c29f71ec6c 100644 --- a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi @@ -147,24 +147,28 @@ align-end = <4>; };
- blob_1: blob-ext@1 { + imem-1d { filename = "lpddr4_pmu_train_1d_imem.bin"; size = <0x8000>; + type = "blob-ext"; };
- blob_2: blob-ext@2 { + dmem-1d { filename = "lpddr4_pmu_train_1d_dmem.bin"; size = <0x4000>; + type = "blob-ext"; };
- blob_3: blob-ext@3 { + imem-2d { filename = "lpddr4_pmu_train_2d_imem.bin"; size = <0x8000>; + type = "blob-ext"; };
- blob_4: blob-ext@4 { + dmem-2d { filename = "lpddr4_pmu_train_2d_dmem.bin"; size = <0x4000>; + type = "blob-ext"; }; };
diff --git a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi index 46a9d7fd78b..904f1d795a3 100644 --- a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi +++ b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi @@ -111,13 +111,13 @@ filename = "u-boot-spl.bin"; };
- 1d-imem { + imem-1d { filename = "ddr3_imem_1d.bin"; size = <0x8000>; type = "blob-ext"; };
- 1d_dmem { + dmem-1d { filename = "ddr3_dmem_1d.bin"; size = <0x4000>; type = "blob-ext"; diff --git a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi index 4d0ecb07d4f..3f6b67e22df 100644 --- a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi @@ -155,24 +155,28 @@ align-end = <4>; };
- blob_1: blob-ext@1 { + imem-1d { filename = "ddr4_imem_1d_201810.bin"; size = <0x8000>; + type = "blob-ext"; };
- blob_2: blob-ext@2 { + dmem-1d { filename = "ddr4_dmem_1d_201810.bin"; size = <0x4000>; + type = "blob-ext"; };
- blob_3: blob-ext@3 { + imem-2d { filename = "ddr4_imem_2d_201810.bin"; size = <0x8000>; + type = "blob-ext"; };
- blob_4: blob-ext@4 { + dmem-2d { filename = "ddr4_dmem_2d_201810.bin"; size = <0x4000>; + type = "blob-ext"; }; };
diff --git a/arch/arm/dts/imx8mn-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-evk-u-boot.dtsi index 3db46d4cbcb..b73ce32221f 100644 --- a/arch/arm/dts/imx8mn-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-evk-u-boot.dtsi @@ -36,24 +36,28 @@ align-end = <4>; };
diff --git a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi index 6e37622cca7..c5fa37a3b8a 100644 --- a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi @@ -130,25 +130,25 @@ filename = "u-boot-spl.bin"; };
- 1d-imem { + imem-1d { filename = "ddr4_imem_1d.bin"; size = <0x8000>; type = "blob-ext"; };
- 1d_dmem { + dmem-1d { filename = "ddr4_dmem_1d.bin"; size = <0x4000>; type = "blob-ext"; };
- 2d_imem { + imem-2d { filename = "ddr4_imem_2d.bin"; size = <0x8000>; type = "blob-ext"; };
- 2d_dmem { + dmem-2d { filename = "ddr4_dmem_2d.bin"; size = <0x4000>; type = "blob-ext"; diff --git a/arch/arm/dts/imx8mn-venice-u-boot.dtsi b/arch/arm/dts/imx8mn-venice-u-boot.dtsi index 35819553879..1e8b0e2aeed 100644 --- a/arch/arm/dts/imx8mn-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-venice-u-boot.dtsi @@ -126,25 +126,25 @@ filename = "u-boot-spl.bin"; };
- 1d_dmem { + dmem-1d { filename = "lpddr4_pmu_train_1d_dmem.bin"; size = <0x4000>; type = "blob-ext"; };
- 2d_imem { + imem-2d { filename = "lpddr4_pmu_train_2d_imem.bin"; size = <0x8000>; type = "blob-ext"; };
- 2d_dmem { + dmem-2d { filename = "lpddr4_pmu_train_2d_dmem.bin"; size = <0x4000>; type = "blob-ext"; diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp-u-boot.dtsi index 20edd90cfad..aaf70d92dfb 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -61,24 +61,28 @@ align-end = <4>; };
- blob_1: blob-ext@1 { + imem-1d { filename = "lpddr4_pmu_train_1d_imem_202006.bin"; size = <0x8000>; + type = "blob-ext"; };
- blob_2: blob-ext@2 { + dmem-1d { filename = "lpddr4_pmu_train_1d_dmem_202006.bin"; size = <0x4000>; + type = "blob-ext"; };
- blob_3: blob-ext@3 { + imem-2d { filename = "lpddr4_pmu_train_2d_imem_202006.bin"; size = <0x8000>; + type = "blob-ext"; };
- blob_4: blob-ext@4 { + dmem-2d { filename = "lpddr4_pmu_train_2d_dmem_202006.bin"; size = <0x4000>; + type = "blob-ext"; }; };
diff --git a/arch/arm/dts/imx8mq-cm-u-boot.dtsi b/arch/arm/dts/imx8mq-cm-u-boot.dtsi index e2f4b0e740d..79a71c2a414 100644 --- a/arch/arm/dts/imx8mq-cm-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-cm-u-boot.dtsi @@ -28,24 +28,28 @@ align-end = <4>; };
diff --git a/arch/arm/dts/imx8mq-u-boot.dtsi b/arch/arm/dts/imx8mq-u-boot.dtsi index 912a3d4a356..31c96f919c0 100644 --- a/arch/arm/dts/imx8mq-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-u-boot.dtsi @@ -46,25 +46,25 @@ filename = "u-boot-spl.bin"; };
'not a valid binman type, so' here is misleading. Names do not need to be binman types if you have the 'type' property. 'the current names are inconsistent across different boards, so' would be better.
The 'type' doesn't matter for symbol generation. '... since the new names are not valid binman types' is the real reason.
1d-imem {
imem-1d {
I suggested 'ddr-1d-imem-fw' in the diff I sent. Saying again in case you didn't notice. But these names are fine too.
In arch/arm/lib/sections.c there is below code: char __image_copy_start[0] __section(".__image_copy_start"); But actually 'objdump -t spl/u-boot-spl' not able to find out symbol '__image_copy_start' for binman update image-pos/size.
So update link file
Reviewed-by: Tom Rini trini@konsulko.com Tested-by: Tim Harvey tharvey@gateworks.com #imx8m[m,n,p]-venice Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/cpu/armv8/u-boot-spl.lds | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/u-boot-spl.lds b/arch/arm/cpu/armv8/u-boot-spl.lds index 730eb93dbc3..9b1e7d46287 100644 --- a/arch/arm/cpu/armv8/u-boot-spl.lds +++ b/arch/arm/cpu/armv8/u-boot-spl.lds @@ -23,7 +23,7 @@ SECTIONS { .text : { . = ALIGN(8); - *(.__image_copy_start) + __image_copy_start = .; CPUDIR/start.o (.text*) *(.text*) } >.sram
In arch/arm/dts/imx8mp-u-boot.dtsi, there are blob-ext@1, blob-ext@2 and etc which is for packing ddr phy firmware. However we could not declare symbol name such as 'binman_sym_declare(ulong, blob_ext@1, image_pos)', because '@' is not allowed, so we choose to declare the symbol 'binman_sym_declare(ulong, blob_ext_1, image_pos);' with '@' replaced with '_'. It does not impact if there is no '@' in section name.
Tested-by: Tim Harvey tharvey@gateworks.com #imx8m[m,n,p]-venice Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Peng Fan peng.fan@nxp.com --- tools/binman/etype/section.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index bd67238b919..e3f362b442b 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -875,7 +875,7 @@ class Entry_section(Entry): entries[entry.GetPath()] = entry for entry in to_add.values(): self._CollectEntries(entries, entries_by_name, entry) - entries_by_name[add_entry.name] = add_entry + entries_by_name[add_entry.name.replace('@', '-')] = add_entry
def MissingArgs(self, entry, missing): """Report a missing argument, if enabled
You don't need this patch after the entry name changes.
Either drop this patch, or handle this in the LookupSymbol() function.
By default when BINMAN_SYMBOLS is enabled, common/spl/spl.c has a code piece `binman_sym_declare(ulong, u_boot_any, image_pos);` which requires u-boot* node in device tree binman node section. But some platforms(i.MX8M) not need it. To avoid build break with BINMAN_SYMBOLS, introduce a no-u-boot-any property.
Signed-off-by: Peng Fan peng.fan@nxp.com --- tools/binman/binman.rst | 6 ++++++ tools/binman/etype/section.py | 5 +++++ 2 files changed, 11 insertions(+)
diff --git a/tools/binman/binman.rst b/tools/binman/binman.rst index 935839c433e..9dab83b45c8 100644 --- a/tools/binman/binman.rst +++ b/tools/binman/binman.rst @@ -502,6 +502,12 @@ no-expanded: `no-expanded` property disables this just for a single entry. Put the `no-expanded` boolean property in the node to select this behaviour.
+no-u-boot-any: + By default when BINMAN_SYMBOLS are enabled, + `binman_sym_declare(ulong, u_boot_any, image_pos);` requires a u-boot node + in binman section. Some platforms not need it with the help of this flag + set. + The attributes supported for images and sections are described below. Several are similar to those for entries.
diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index e3f362b442b..a09c539a12b 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -164,6 +164,7 @@ class Entry_section(Entry): self._skip_at_start = None self._end_4gb = False self._ignore_missing = False + self._no_uboot_any = False
def ReadNode(self): """Read properties from the section node""" @@ -172,6 +173,7 @@ class Entry_section(Entry): self._sort = fdt_util.GetBool(self._node, 'sort-by-offset') self._end_4gb = fdt_util.GetBool(self._node, 'end-at-4gb') self._skip_at_start = fdt_util.GetInt(self._node, 'skip-at-start') + self._no_uboot_any = fdt_util.GetBool(self._node, 'no-u-boot-any') if self._end_4gb: if not self.size: self.Raise("Section size must be provided when using end-at-4gb") @@ -565,9 +567,12 @@ class Entry_section(Entry): rest = name[len(root):] if rest in ['', '-img', '-nodtb']: entry = entries[name] + if not entry: err = ("%s: Entry '%s' not found in list (%s)" % (msg, entry_name, ','.join(entries.keys()))) + if entry_name == 'u-boot-any' and self._no_uboot_any: + return None if optional: print('Warning: %s' % err, file=sys.stderr) return None
This is just a hacky workaround, I don't think it's OK.
Anyway, turns out you don't need this patch (and 5/9) either. I tried a few things and found CONFIG_SPL_RAW_IMAGE_SUPPORT (enabled on most imx8m) and CONFIG_SPL_RAM_DEVICE (enabled on imx8mm_data_modul_edm_sbc) are using the 'u_boot_any' symbols. Disable them and the symbols get optimized away and the error disappears.
I also found some relevant discussions from a while back, see [1], [2].
[1] using binman fails boot https://lore.kernel.org/u-boot/CAJ+vNU0BZDr2q0ZPQkoQBP1eBhbYmQfJMYraSgOvWXwZ...
[2] imx8: ls1028a: Drop raw image support https://lore.kernel.org/u-boot/20210801205951.2202789-1-sjg@chromium.org/T/#...
Preparing to support BINMAN_SYMBOLS, i.MX8M no need u-boot-any in spl stage, so add no-u-boot-any property to avoid binman report error.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mm-u-boot.dtsi | 1 + arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi | 1 + arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi | 1 + arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi | 1 + arch/arm/dts/imx8mn-evk-u-boot.dtsi | 1 + arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi | 1 + arch/arm/dts/imx8mn-venice-u-boot.dtsi | 1 + arch/arm/dts/imx8mp-u-boot.dtsi | 1 + arch/arm/dts/imx8mq-cm-u-boot.dtsi | 1 + arch/arm/dts/imx8mq-u-boot.dtsi | 1 + 10 files changed, 10 insertions(+)
diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index dc036894d82..769b7963db1 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -33,6 +33,7 @@ align-size = <4>; filename = "u-boot-spl-ddr.bin"; pad-byte = <0xff>; + no-u-boot-any;
u-boot-spl { align-end = <4>; diff --git a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi index 3c29f71ec6c..024d57712b8 100644 --- a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi @@ -142,6 +142,7 @@ pad-byte = <0xff>; align-size = <4>; align = <4>; + no-u-boot-any;
u-boot-spl { align-end = <4>; diff --git a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi index 904f1d795a3..8f95f0efe65 100644 --- a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi +++ b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi @@ -105,6 +105,7 @@ align-size = <4>; filename = "u-boot-spl-ddr.bin"; pad-byte = <0xff>; + no-u-boot-any;
u-boot-spl { align-end = <4>; diff --git a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi index 3f6b67e22df..ef1f60bff8d 100644 --- a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi @@ -150,6 +150,7 @@ pad-byte = <0xff>; align-size = <4>; align = <4>; + no-u-boot-any;
u-boot-spl { align-end = <4>; diff --git a/arch/arm/dts/imx8mn-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-evk-u-boot.dtsi index b73ce32221f..bd035f2e780 100644 --- a/arch/arm/dts/imx8mn-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-evk-u-boot.dtsi @@ -31,6 +31,7 @@ pad-byte = <0xff>; align-size = <4>; align = <4>; + no-u-boot-any;
u-boot-spl { align-end = <4>; diff --git a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi index c5fa37a3b8a..484b55d4668 100644 --- a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi @@ -124,6 +124,7 @@ align-size = <4>; filename = "u-boot-spl-ddr.bin"; pad-byte = <0xff>; + no-u-boot-any;
u-boot-spl { align-end = <4>; diff --git a/arch/arm/dts/imx8mn-venice-u-boot.dtsi b/arch/arm/dts/imx8mn-venice-u-boot.dtsi index 1e8b0e2aeed..62ca7cae0ec 100644 --- a/arch/arm/dts/imx8mn-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-venice-u-boot.dtsi @@ -120,6 +120,7 @@ align-size = <4>; filename = "u-boot-spl-ddr.bin"; pad-byte = <0xff>; + no-u-boot-any;
u-boot-spl { align-end = <4>; diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp-u-boot.dtsi index aaf70d92dfb..2c66e30708f 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -56,6 +56,7 @@ pad-byte = <0xff>; align-size = <4>; align = <4>; + no-u-boot-any;
u-boot-spl { align-end = <4>; diff --git a/arch/arm/dts/imx8mq-cm-u-boot.dtsi b/arch/arm/dts/imx8mq-cm-u-boot.dtsi index 79a71c2a414..afa0d07296d 100644 --- a/arch/arm/dts/imx8mq-cm-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-cm-u-boot.dtsi @@ -23,6 +23,7 @@ pad-byte = <0xff>; align-size = <4>; align = <4>; + no-u-boot-any;
u-boot-spl { align-end = <4>; diff --git a/arch/arm/dts/imx8mq-u-boot.dtsi b/arch/arm/dts/imx8mq-u-boot.dtsi index 31c96f919c0..90014710ea5 100644 --- a/arch/arm/dts/imx8mq-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-u-boot.dtsi @@ -40,6 +40,7 @@ align-size = <4>; filename = "u-boot-spl-ddr.bin"; pad-byte = <0xff>; + no-u-boot-any;
By reading binman symbols, we no need hard coded IMEM_LEN/DMEM_LEN after we update the binman dtsi to drop 0x8000/0x4000 length for the firmware.
And that could save binary size for many KBs.
Tested-by: Tim Harvey tharvey@gateworks.com #imx8m[m,n,p]-venice Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/ddr/imx/imx8m/helper.c | 51 ++++++++++++++++++++++++++++------ 1 file changed, 43 insertions(+), 8 deletions(-)
diff --git a/drivers/ddr/imx/imx8m/helper.c b/drivers/ddr/imx/imx8m/helper.c index f23904bf712..5d7f6110639 100644 --- a/drivers/ddr/imx/imx8m/helper.c +++ b/drivers/ddr/imx/imx8m/helper.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <binman_sym.h> #include <log.h> #include <spl.h> #include <asm/global_data.h> @@ -25,15 +26,30 @@ DECLARE_GLOBAL_DATA_PTR; #define DMEM_OFFSET_ADDR 0x00054000 #define DDR_TRAIN_CODE_BASE_ADDR IP2APB_DDRPHY_IPS_BASE_ADDR(0)
+binman_sym_declare(ulong, imem_1d, image_pos); +binman_sym_declare(ulong, imem_1d, size); + +binman_sym_declare(ulong, dmem_1d, image_pos); +binman_sym_declare(ulong, dmem_1d, size); + +#if !IS_ENABLED(CONFIG_IMX8M_DDR3L) +binman_sym_declare(ulong, imem_2d, image_pos); +binman_sym_declare(ulong, imem_2d, size); + +binman_sym_declare(ulong, dmem_2d, image_pos); +binman_sym_declare(ulong, dmem_2d, size); +#endif + /* We need PHY iMEM PHY is 32KB padded */ void ddr_load_train_firmware(enum fw_type type) { u32 tmp32, i; u32 error = 0; unsigned long pr_to32, pr_from32; - unsigned long fw_offset = type ? IMEM_2D_OFFSET : 0; - unsigned long imem_start = (unsigned long)&_end + fw_offset; - unsigned long dmem_start; + uint32_t fw_offset = type ? IMEM_2D_OFFSET : 0; + uint32_t imem_start = (unsigned long)&_end + fw_offset; + uint32_t dmem_start; + uint32_t imem_len = IMEM_LEN, dmem_len = DMEM_LEN;
#ifdef CONFIG_SPL_OF_CONTROL if (gd->fdt_blob && !fdt_check_header(gd->fdt_blob)) { @@ -43,11 +59,30 @@ void ddr_load_train_firmware(enum fw_type type) } #endif
- dmem_start = imem_start + IMEM_LEN; + dmem_start = imem_start + imem_len; + + if (CONFIG_IS_ENABLED(BINMAN_SYMBOLS)) { + switch (type) { + case FW_1D_IMAGE: + imem_start = binman_sym(ulong, imem_1d, image_pos); + imem_len = binman_sym(ulong, imem_1d, size); + dmem_start = binman_sym(ulong, dmem_1d, image_pos); + dmem_len = binman_sym(ulong, dmem_1d, size); + break; + case FW_2D_IMAGE: +#if !IS_ENABLED(CONFIG_IMX8M_DDR3L) + imem_start = binman_sym(ulong, imem_2d, image_pos); + imem_len = binman_sym(ulong, imem_2d, size); + dmem_start = binman_sym(ulong, dmem_2d, image_pos); + dmem_len = binman_sym(ulong, dmem_2d, size); +#endif + break; + } + }
pr_from32 = imem_start; pr_to32 = DDR_TRAIN_CODE_BASE_ADDR + 4 * IMEM_OFFSET_ADDR; - for (i = 0x0; i < IMEM_LEN; ) { + for (i = 0x0; i < imem_len; ) { tmp32 = readl(pr_from32); writew(tmp32 & 0x0000ffff, pr_to32); pr_to32 += 4; @@ -59,7 +94,7 @@ void ddr_load_train_firmware(enum fw_type type)
pr_from32 = dmem_start; pr_to32 = DDR_TRAIN_CODE_BASE_ADDR + 4 * DMEM_OFFSET_ADDR; - for (i = 0x0; i < DMEM_LEN; ) { + for (i = 0x0; i < dmem_len; ) { tmp32 = readl(pr_from32); writew(tmp32 & 0x0000ffff, pr_to32); pr_to32 += 4; @@ -72,7 +107,7 @@ void ddr_load_train_firmware(enum fw_type type) debug("check ddr_pmu_train_imem code\n"); pr_from32 = imem_start; pr_to32 = DDR_TRAIN_CODE_BASE_ADDR + 4 * IMEM_OFFSET_ADDR; - for (i = 0x0; i < IMEM_LEN; ) { + for (i = 0x0; i < imem_len; ) { tmp32 = (readw(pr_to32) & 0x0000ffff); pr_to32 += 4; tmp32 += ((readw(pr_to32) & 0x0000ffff) << 16); @@ -93,7 +128,7 @@ void ddr_load_train_firmware(enum fw_type type) debug("check ddr4_pmu_train_dmem code\n"); pr_from32 = dmem_start; pr_to32 = DDR_TRAIN_CODE_BASE_ADDR + 4 * DMEM_OFFSET_ADDR; - for (i = 0x0; i < DMEM_LEN;) { + for (i = 0x0; i < dmem_len;) { tmp32 = (readw(pr_to32) & 0x0000ffff); pr_to32 += 4; tmp32 += ((readw(pr_to32) & 0x0000ffff) << 16);
After we switch to use BINMAN_SYMBOLS, there is no need to pad the file size to 0x8000 and 0x4000. After we use BINMAN_SYMBOLS, the u-boot-spl-ddr.bin shrink about 36KB with i.MX8MP-EVK.
Tested-by: Tim Harvey tharvey@gateworks.com #imx8m[m,n,p]-venice Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mm-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi | 4 ++-- arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-evk-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-venice-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mp-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mq-cm-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mq-u-boot.dtsi | 8 ++++---- 10 files changed, 38 insertions(+), 38 deletions(-)
diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index 769b7963db1..7600bd3d30a 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -42,25 +42,25 @@
imem-1d { filename = "lpddr4_pmu_train_1d_imem.bin"; - size = <0x8000>; + align-end = <4>; type = "blob-ext"; };
dmem-1d { filename = "lpddr4_pmu_train_1d_dmem.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; };
imem-2d { filename = "lpddr4_pmu_train_2d_imem.bin"; - size = <0x8000>; + align-end = <4>; type = "blob-ext"; };
dmem-2d { filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; }; }; diff --git a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi index 024d57712b8..090a17c93a7 100644 --- a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi @@ -150,26 +150,26 @@
imem-1d { filename = "lpddr4_pmu_train_1d_imem.bin"; - size = <0x8000>; type = "blob-ext"; + align-end = <4>; };
dmem-1d { filename = "lpddr4_pmu_train_1d_dmem.bin"; - size = <0x4000>; type = "blob-ext"; + align-end = <4>; };
imem-2d { filename = "lpddr4_pmu_train_2d_imem.bin"; - size = <0x8000>; type = "blob-ext"; + align-end = <4>; };
dmem-2d { filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; type = "blob-ext"; + align-end = <4>; }; };
diff --git a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi index 8f95f0efe65..6a79e2743f8 100644 --- a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi +++ b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi @@ -114,13 +114,13 @@
imem-1d { filename = "ddr3_imem_1d.bin"; - size = <0x8000>; + align-end = <4>; type = "blob-ext"; };
dmem-1d { filename = "ddr3_dmem_1d.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; }; }; diff --git a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi index ef1f60bff8d..7660ab8d58b 100644 --- a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi @@ -158,26 +158,26 @@
imem-1d { filename = "ddr4_imem_1d_201810.bin"; - size = <0x8000>; type = "blob-ext"; + align-end = <4>; };
dmem-1d { filename = "ddr4_dmem_1d_201810.bin"; - size = <0x4000>; type = "blob-ext"; + align-end = <4>; };
imem-2d { filename = "ddr4_imem_2d_201810.bin"; - size = <0x8000>; type = "blob-ext"; + align-end = <4>; };
dmem-2d { filename = "ddr4_dmem_2d_201810.bin"; - size = <0x4000>; type = "blob-ext"; + align-end = <4>; }; };
diff --git a/arch/arm/dts/imx8mn-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-evk-u-boot.dtsi index bd035f2e780..4ba563922ed 100644 --- a/arch/arm/dts/imx8mn-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-evk-u-boot.dtsi @@ -39,26 +39,26 @@
diff --git a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi index 484b55d4668..f701cd18d70 100644 --- a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi @@ -133,25 +133,25 @@
imem-1d { filename = "ddr4_imem_1d.bin"; - size = <0x8000>; + align-end = <4>; type = "blob-ext"; };
dmem-1d { filename = "ddr4_dmem_1d.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; };
imem-2d { filename = "ddr4_imem_2d.bin"; - size = <0x8000>; + align-end = <4>; type = "blob-ext"; };
dmem-2d { filename = "ddr4_dmem_2d.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; }; }; diff --git a/arch/arm/dts/imx8mn-venice-u-boot.dtsi b/arch/arm/dts/imx8mn-venice-u-boot.dtsi index 62ca7cae0ec..5ef9082cef3 100644 --- a/arch/arm/dts/imx8mn-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-venice-u-boot.dtsi @@ -129,25 +129,25 @@
dmem-2d { filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; }; }; diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp-u-boot.dtsi index 2c66e30708f..9ad5d439d00 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -64,26 +64,26 @@
imem-1d { filename = "lpddr4_pmu_train_1d_imem_202006.bin"; - size = <0x8000>; type = "blob-ext"; + align-end = <4>; };
dmem-1d { filename = "lpddr4_pmu_train_1d_dmem_202006.bin"; - size = <0x4000>; type = "blob-ext"; + align-end = <4>; };
imem-2d { filename = "lpddr4_pmu_train_2d_imem_202006.bin"; - size = <0x8000>; type = "blob-ext"; + align-end = <4>; };
dmem-2d { filename = "lpddr4_pmu_train_2d_dmem_202006.bin"; - size = <0x4000>; type = "blob-ext"; + align-end = <4>; }; };
diff --git a/arch/arm/dts/imx8mq-cm-u-boot.dtsi b/arch/arm/dts/imx8mq-cm-u-boot.dtsi index afa0d07296d..51db64bdd59 100644 --- a/arch/arm/dts/imx8mq-cm-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-cm-u-boot.dtsi @@ -31,26 +31,26 @@
diff --git a/arch/arm/dts/imx8mq-u-boot.dtsi b/arch/arm/dts/imx8mq-u-boot.dtsi index 90014710ea5..d0e1c521c33 100644 --- a/arch/arm/dts/imx8mq-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-u-boot.dtsi @@ -49,25 +49,25 @@
There is case that CONFIG_BINMAN is defined, but CONFIG_SPL_BINMAN_SYMBOLS is not defined. In that case, there will be build failure. So use CONFIG_SPL_BINMAN_SYMBOLS to guard the macros, and define CONFIG_SPL_BINMAN_SYMBOLS in binman syms test.
Tested-by: Tim Harvey tharvey@gateworks.com #imx8m[m,n,p]-venice Signed-off-by: Peng Fan peng.fan@nxp.com --- include/binman_sym.h | 2 +- tools/binman/test/u_boot_binman_syms.c | 1 + tools/binman/test/u_boot_binman_syms_size.c | 1 + 3 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/include/binman_sym.h b/include/binman_sym.h index 72e6765fe52..548d8f5654c 100644 --- a/include/binman_sym.h +++ b/include/binman_sym.h @@ -13,7 +13,7 @@
#define BINMAN_SYM_MISSING (-1UL)
-#ifdef CONFIG_BINMAN +#ifdef CONFIG_SPL_BINMAN_SYMBOLS
/** * binman_symname() - Internal function to get a binman symbol name diff --git a/tools/binman/test/u_boot_binman_syms.c b/tools/binman/test/u_boot_binman_syms.c index 37fc339ce84..f4a4d1f6846 100644 --- a/tools/binman/test/u_boot_binman_syms.c +++ b/tools/binman/test/u_boot_binman_syms.c @@ -6,6 +6,7 @@ */
#define CONFIG_BINMAN +#define CONFIG_SPL_BINMAN_SYMBOLS #include <binman_sym.h>
binman_sym_declare(unsigned long, u_boot_spl_any, offset); diff --git a/tools/binman/test/u_boot_binman_syms_size.c b/tools/binman/test/u_boot_binman_syms_size.c index 7224bc1863c..3a01d8ca4be 100644 --- a/tools/binman/test/u_boot_binman_syms_size.c +++ b/tools/binman/test/u_boot_binman_syms_size.c @@ -6,6 +6,7 @@ */
binman_sym_declare(char, u_boot_spl, pos);
This must handle all of CONFIG_{TPL,VPL,SPL}_BINMAN_SYMBOLS.
You can use CONFIG_IS_ENABLED(BINMAN_SYMBOLS) if you:
- Create a binman/test/generated/autoconf.h with binman CONFIGs - Add `-I $(SRC)` to CFLAGS in binman/test/Makefile - Add `#include <linux/kconfig.h>` to test .c files - Maybe add `#define CONFIG_SPL_BUILD` to test .c files
- binman_symname() - Internal function to get a binman symbol name
Use BINMAN instead of imx specific packing method.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/Kconfig | 1 + arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg | 10 +--------- configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 2 +- configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 2 +- 4 files changed, 4 insertions(+), 11 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 61397bf88d1..ba26975544c 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -68,6 +68,7 @@ config TARGET_IMX8MM_EVK
config TARGET_IMX8MM_ICORE_MX8MM bool "Engicam i.Core MX8M Mini SOM" + select BINMAN select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 diff --git a/arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg b/arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg index e06d53ef417..5dcb8ae72f0 100644 --- a/arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg +++ b/arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg @@ -3,13 +3,5 @@ * Copyright 2019 NXP */
- -FIT BOOT_FROM sd -LOADER spl/u-boot-spl-ddr.bin 0x7E1000 -SECOND_LOADER u-boot.itb 0x40200000 0x60000 - -DDR_FW lpddr4_pmu_train_1d_imem.bin -DDR_FW lpddr4_pmu_train_1d_dmem.bin -DDR_FW lpddr4_pmu_train_2d_imem.bin -DDR_FW lpddr4_pmu_train_2d_dmem.bin +LOADER u-boot-spl-ddr.bin 0x7E1000 diff --git a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig index d95a74a7237..dcb12e5d026 100644 --- a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig +++ b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig @@ -20,7 +20,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mm-icore-mx8mm-ctouch2.dtb" CONFIG_SPL_BOARD_INIT=y diff --git a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig index 43c697a39d8..22acf7317b4 100644 --- a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig +++ b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig @@ -20,7 +20,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mm-icore-mx8mm-edimm2.2.dtb" CONFIG_SPL_BOARD_INIT=y
Alper Nebi Yasak
Peng Fan (OSS)
