[PATCH 0/2] efi_loader: set load options in boot manager
Up to now we have been using environment variable 'bootargs' in the boot manager to set the load options of the loaded image protocol. Instead we should use the optional data.
Heinrich Schuchardt (2): efi_loader: factor out efi_set_load_options() efi_loader: set load options in boot manager
cmd/bootefi.c | 75 +++++++++++++++--------------------- cmd/efidebug.c | 4 +- include/efi_loader.h | 5 ++- lib/efi_loader/efi_bootmgr.c | 70 +++++++++++++++++++++++++++------ 4 files changed, 96 insertions(+), 58 deletions(-)
-- 2.28.0
The bootefi bootmgr command has to set the load options for a loaded image from the value of BootXXXX variable. If the boot manager is not used, the value is set from the environment variable bootargs (or efi_selftest).
Factor out a common function efi_set_load_options().
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/bootefi.c | 55 +++++++++++++----------------------- include/efi_loader.h | 3 ++ lib/efi_loader/efi_bootmgr.c | 32 +++++++++++++++++++++ 3 files changed, 54 insertions(+), 36 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 8154efde52..5523405e13 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -31,55 +31,37 @@ static struct efi_device_path *bootefi_image_path; static struct efi_device_path *bootefi_device_path;
/** - * Set the load options of an image from an environment variable. + * efi_env_set_load_options() - set load options from environment variable * * @handle: the image handle * @env_var: name of the environment variable * @load_options: pointer to load options (output) * Return: status code */ -static efi_status_t set_load_options(efi_handle_t handle, const char *env_var, - u16 **load_options) +static efi_status_t efi_env_set_load_options(efi_handle_t handle, + const char *env_var, + u16 **load_options) { - struct efi_loaded_image *loaded_image_info; - size_t size; const char *env = env_get(env_var); + size_t size; u16 *pos; efi_status_t ret;
*load_options = NULL; - ret = EFI_CALL(systab.boottime->open_protocol( - handle, - &efi_guid_loaded_image, - (void **)&loaded_image_info, - efi_root, NULL, - EFI_OPEN_PROTOCOL_BY_HANDLE_PROTOCOL)); - if (ret != EFI_SUCCESS) - return EFI_INVALID_PARAMETER; - - loaded_image_info->load_options = NULL; - loaded_image_info->load_options_size = 0; if (!env) - goto out; - - size = utf8_utf16_strlen(env) + 1; - loaded_image_info->load_options = calloc(size, sizeof(u16)); - if (!loaded_image_info->load_options) { - log_err("ERROR: Out of memory\n"); - EFI_CALL(systab.boottime->close_protocol(handle, - &efi_guid_loaded_image, - efi_root, NULL)); + return EFI_SUCCESS; + size = sizeof(u16) * (utf8_utf16_strlen(env) + 1); + pos = calloc(size, 1); + if (!pos) return EFI_OUT_OF_RESOURCES; - } - pos = loaded_image_info->load_options; *load_options = pos; utf8_utf16_strcpy(&pos, env); - loaded_image_info->load_options_size = size * 2; - -out: - return EFI_CALL(systab.boottime->close_protocol(handle, - &efi_guid_loaded_image, - efi_root, NULL)); + ret = efi_set_load_options(handle, size, *load_options); + if (ret != EFI_SUCCESS) { + free(*load_options); + *load_options = NULL; + } + return ret; }
#if !CONFIG_IS_ENABLED(GENERATE_ACPI_TABLE) @@ -336,7 +318,7 @@ static efi_status_t do_bootefi_exec(efi_handle_t handle) u16 *load_options;
/* Transfer environment variable as load options */ - ret = set_load_options(handle, "bootargs", &load_options); + ret = efi_env_set_load_options(handle, "bootargs", &load_options); if (ret != EFI_SUCCESS) return ret;
@@ -509,8 +491,9 @@ static efi_status_t bootefi_run_prepare(const char *load_options_path, return ret;
/* Transfer environment variable as load options */ - return set_load_options((efi_handle_t)*image_objp, load_options_path, - &load_options); + return efi_env_set_load_options((efi_handle_t)*image_objp, + load_options_path, + &load_options); }
/** diff --git a/include/efi_loader.h b/include/efi_loader.h index 98944640be..ad580bd226 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -717,6 +717,9 @@ struct efi_load_option { efi_status_t efi_deserialize_load_option(struct efi_load_option *lo, u8 *data, efi_uintn_t *size); unsigned long efi_serialize_load_option(struct efi_load_option *lo, u8 **data); +efi_status_t efi_set_load_options(efi_handle_t handle, + efi_uintn_t load_options_size, + void *load_options); efi_status_t efi_bootmgr_load(efi_handle_t *handle);
/** diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index e03198b57a..a4bc272c34 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -30,6 +30,38 @@ static const struct efi_runtime_services *rs; * should do normal or recovery boot. */
+/** + * efi_set_load_options() - set the load options of a loaded image + * + * @handle: the image handle + * @load_options_size: size of load options + * @load_options: pointer to load options + * Return: status code + */ +efi_status_t efi_set_load_options(efi_handle_t handle, + efi_uintn_t load_options_size, + void *load_options) +{ + struct efi_loaded_image *loaded_image_info; + efi_status_t ret; + + ret = EFI_CALL(systab.boottime->open_protocol( + handle, + &efi_guid_loaded_image, + (void **)&loaded_image_info, + efi_root, NULL, + EFI_OPEN_PROTOCOL_BY_HANDLE_PROTOCOL)); + if (ret != EFI_SUCCESS) + return EFI_INVALID_PARAMETER; + + loaded_image_info->load_options = load_options; + loaded_image_info->load_options_size = load_options_size; + + return EFI_CALL(systab.boottime->close_protocol(handle, + &efi_guid_loaded_image, + efi_root, NULL)); +} +
/** * efi_deserialize_load_option() - parse serialized data -- 2.28.0
Up to now we used the value of the bootargs environment variable as load options in the boot manager. This is not correct. The data has to be taken from the Boot#### variable.
Let the boot manager copy the optional data of the EFI_LOAD_OPTION as load options to the loaded image protocol.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/bootefi.c | 22 +++++++++++---------- cmd/efidebug.c | 4 +++- include/efi_loader.h | 2 +- lib/efi_loader/efi_bootmgr.c | 38 +++++++++++++++++++++++++----------- 4 files changed, 43 insertions(+), 23 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 5523405e13..fbfed54e85 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -310,17 +310,11 @@ efi_status_t efi_install_fdt(void *fdt) * Load the EFI binary into a newly assigned memory unwinding the relocation * information, install the loaded image protocol, and call the binary. */ -static efi_status_t do_bootefi_exec(efi_handle_t handle) +static efi_status_t do_bootefi_exec(efi_handle_t handle, void *load_options) { efi_status_t ret; efi_uintn_t exit_data_size = 0; u16 *exit_data = NULL; - u16 *load_options; - - /* Transfer environment variable as load options */ - ret = efi_env_set_load_options(handle, "bootargs", &load_options); - if (ret != EFI_SUCCESS) - return ret;
/* Call our payload! */ ret = EFI_CALL(efi_start_image(handle, &exit_data_size, &exit_data)); @@ -349,14 +343,15 @@ static int do_efibootmgr(void) { efi_handle_t handle; efi_status_t ret; + void *load_options;
- ret = efi_bootmgr_load(&handle); + ret = efi_bootmgr_load(&handle, &load_options); if (ret != EFI_SUCCESS) { log_notice("EFI boot manager: Cannot load any image\n"); return CMD_RET_FAILURE; }
- ret = do_bootefi_exec(handle); + ret = do_bootefi_exec(handle, load_options);
if (ret != EFI_SUCCESS) return CMD_RET_FAILURE; @@ -467,7 +462,14 @@ efi_status_t efi_run_image(void *source_buffer, efi_uintn_t source_size) if (ret != EFI_SUCCESS) goto out;
- ret = do_bootefi_exec(handle); + u16 *load_options; + + /* Transfer environment variable as load options */ + ret = efi_env_set_load_options(handle, "bootargs", &load_options); + if (ret != EFI_SUCCESS) + goto out; + + ret = do_bootefi_exec(handle, load_options);
out: efi_delete_handle(mem_handle); diff --git a/cmd/efidebug.c b/cmd/efidebug.c index 58018f700c..d00d4247dc 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -1126,8 +1126,9 @@ static int do_efi_test_bootmgr(struct cmd_tbl *cmdtp, int flag, efi_uintn_t exit_data_size = 0; u16 *exit_data = NULL; efi_status_t ret; + void *load_options;
- ret = efi_bootmgr_load(&image); + ret = efi_bootmgr_load(&image, &load_options); printf("efi_bootmgr_load() returned: %ld\n", ret & ~EFI_ERROR_MASK);
/* We call efi_start_image() even if error for test purpose. */ @@ -1138,6 +1139,7 @@ static int do_efi_test_bootmgr(struct cmd_tbl *cmdtp, int flag,
efi_restore_gd();
+ free(load_options); return CMD_RET_SUCCESS; }
diff --git a/include/efi_loader.h b/include/efi_loader.h index ad580bd226..7f0ab1be56 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -720,7 +720,7 @@ unsigned long efi_serialize_load_option(struct efi_load_option *lo, u8 **data); efi_status_t efi_set_load_options(efi_handle_t handle, efi_uintn_t load_options_size, void *load_options); -efi_status_t efi_bootmgr_load(efi_handle_t *handle); +efi_status_t efi_bootmgr_load(efi_handle_t *handle, void **load_options);
/** * efi_image_regions - A list of memory regions diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index a4bc272c34..1e06e60963 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -206,11 +206,13 @@ static void *get_var(u16 *name, const efi_guid_t *vendor, * if successful. This checks that the EFI_LOAD_OPTION is active (enabled) * and that the specified file to boot exists. * - * @n: number of the boot option, e.g. 0x0a13 for Boot0A13 - * @handle: on return handle for the newly installed image - * Return: status code + * @n: number of the boot option, e.g. 0x0a13 for Boot0A13 + * @handle: on return handle for the newly installed image + * @load_options: load options set on the loaded image protocol + * Return: status code */ -static efi_status_t try_load_entry(u16 n, efi_handle_t *handle) +static efi_status_t try_load_entry(u16 n, efi_handle_t *handle, + void **load_options) { struct efi_load_option lo; u16 varname[] = L"Boot0000"; @@ -250,10 +252,9 @@ static efi_status_t try_load_entry(u16 n, efi_handle_t *handle)
attributes = EFI_VARIABLE_BOOTSERVICE_ACCESS | EFI_VARIABLE_RUNTIME_ACCESS; - size = sizeof(n); ret = efi_set_variable_int(L"BootCurrent", &efi_global_variable_guid, - attributes, size, &n, false); + attributes, sizeof(n), &n, false); if (ret != EFI_SUCCESS) { if (EFI_CALL(efi_unload_image(*handle)) != EFI_SUCCESS) @@ -266,6 +267,19 @@ static efi_status_t try_load_entry(u16 n, efi_handle_t *handle) ret = EFI_LOAD_ERROR; }
+ /* Set load options */ + if (size) { + *load_options = malloc(size); + if (!*load_options) { + ret = EFI_OUT_OF_RESOURCES; + goto error; + } + memcpy(*load_options, lo.optional_data, size); + ret = efi_set_load_options(*handle, size, *load_options); + } else { + load_options = NULL; + } + error: free(load_option);
@@ -279,10 +293,11 @@ error: * EFI variable, the available load-options, finding and returning * the first one that can be loaded successfully. * - * @handle: on return handle for the newly installed image - * Return: status code + * @handle: on return handle for the newly installed image + * @load_options: load options set on the loaded image protocol + * Return: status code */ -efi_status_t efi_bootmgr_load(efi_handle_t *handle) +efi_status_t efi_bootmgr_load(efi_handle_t *handle, void **load_options) { u16 bootnext, *bootorder; efi_uintn_t size; @@ -310,7 +325,8 @@ efi_status_t efi_bootmgr_load(efi_handle_t *handle) /* load BootNext */ if (ret == EFI_SUCCESS) { if (size == sizeof(u16)) { - ret = try_load_entry(bootnext, handle); + ret = try_load_entry(bootnext, handle, + load_options); if (ret == EFI_SUCCESS) return ret; log_warning( @@ -333,7 +349,7 @@ efi_status_t efi_bootmgr_load(efi_handle_t *handle) for (i = 0; i < num; i++) { log_debug("%s trying to load Boot%04X\n", __func__, bootorder[i]); - ret = try_load_entry(bootorder[i], handle); + ret = try_load_entry(bootorder[i], handle, load_options); if (ret == EFI_SUCCESS) break; } -- 2.28.0
