[PATCH] rockchip: Rock960: fix up USB support
Fix up USB config options so keyboards and other USB devices work. --- configs/rock960-rk3399_defconfig | 9 ++++++--- include/configs/rock960_rk3399.h | 2 ++ 2 files changed, 8 insertions(+), 3 deletions(-)
diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index 1d997847c2..a5a50785c5 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -3,12 +3,12 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_ROCKCHIP_RK3399=y -CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 CONFIG_TARGET_ROCK960_RK3399=y CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock960" CONFIG_DEBUG_UART=y +CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock960.dtb" CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_BOARDINFO_LATE=y @@ -41,6 +41,8 @@ CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_DM_ETH=y CONFIG_NVME=y CONFIG_PCI=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_TYPEC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y @@ -54,10 +56,11 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_DWC3=y -CONFIG_ROCKCHIP_USB2_PHY=y +CONFIG_DM_KEYBOARD=y CONFIG_USB_KEYBOARD=y -CONFIG_USB_GADGET=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y diff --git a/include/configs/rock960_rk3399.h b/include/configs/rock960_rk3399.h index c6f9122154..2edad71028 100644 --- a/include/configs/rock960_rk3399.h +++ b/include/configs/rock960_rk3399.h @@ -15,4 +15,6 @@
#define SDRAM_BANK_SIZE (2UL << 30)
+#define CONFIG_USB_OHCI_NEW +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 #endif
Hi Peter,
Could you add you signature for this patch?
Thanks,
- Kever
On Fri, Oct 30, 2020 at 10:08 AM Kever Yang kever.yang@rock-chips.com wrote:
Hi Peter,
Apologies, not sure how I missed that, included below, let me know if you want me to resend the patch instead.
Signed-off-by: Peter Robinson pbrobinson@gmail.com
Thanks,
- Kever
Kever Yang
Peter Robinson
