[U-Boot] mmc: sdhci: Add a quirk to add delay during completion of sdhci_send_cmd
I saw that you have been added the SDHCI_QUIRK_WAIT_SEND_CMD on below commit http://git.denx.de/?p=u-boot.git;a=commitdiff;h=13243f2eafc4292917178051fe1b...
I need few quires regarding the QUIRK delay. 1. Why the delay is 1000 + if (host->quirks & SDHCI_QUIRK_WAIT_SEND_CMD) + udelay(1000); + 2. is this delay specific to s5p_sdhci controller? 3. I have an issue "Controller never released inhibit bit(s)" but when I enable this quirk on my driver with udelay(10000), it's working.
Could you please help me.
Thanks, Jagan.
- Why the delay is 1000
udelay(1000);
- is this delay specific to s5p_sdhci controller?
This was specific to s5p_sdhci driver so as to replicate the behavior of s5p_mmc driver.
- I have an issue "Controller never released inhibit bit(s)" but when I enable this quirk on my driver with udelay(10000), it's
working.
I am not sure about the exact delay as per the spec. I have added Jaehoon to CC who might have additional information about this.
Thanks, Jagan.
udelay(1000);
It didn't be denoted to use the udelay(1000) in spec. But To ensure the completing previous request, it has added the udelay(1000).
working.
udelay(10000)? It's too long delay time for completing the request. Which SoC do you use?
If we can use the get_timer() for busy-waiting, i think that we can remove the udelay().
Best Regards, Jaehoon Chung
Thanks, Jagan.
Dear All,
udelay(1000);
But with some memory chips/workloads this udelay is indeed too short and "Controller never released inhibit bit(s)" appears.
it's working.
When I recently has been experimenting with ext4 it turned out, that for some load this value is not enough. Moreover I'm not quite sure if after several such errors we can still count that sent data are really stored on the chip.
I think that we shall try to improve the sdhci framework instead.
I've described this problem some time ago, but no relevant solution was devised:
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/150636/match=rfc+mmc...
Maybe now we can come up with some solution.
Thanks, Jagan.
On Mon, Apr 8, 2013 at 9:22 AM, Tushar Behera tushar.behera@linaro.org wrote:
udelay(1000);
May be you can give the QUIRK which includes s5p as it specific to this driver, i may be incorrect.
Thanks, Jagan.
working.
Thanks, Jagan.
-- Tushar Behera
Hi Tushar,
udelay(1000);
BTW: Can you please help me out what is the reason for max and min clocks are at 52000000 and 400000 respectively.
As per my knowledge the max clock of sdhci on spec-2 is 50000000 (50Mhz), I may be in correct.
Request for your help.
Thanks, Jagan.
working.
Thanks, Jagan.
-- Tushar Behera
On 04/09/2013 06:41 PM, Jagan Teki wrote:
Hi Tushar,
udelay(1000);
Right..But eMMC can use up to 52MHz. And see into the drivers/mmc/mmc.c..SD-card's max_dtr is set to 50MHz, if card is supported HS_MODE.
Thanks, Jagan.
working.
Thanks, Jagan.
-- Tushar Behera
Hi Tushar,
Hi Tushar,
udelay(1000);
Ok, Thanks for your information. means the max_clk 52MHz will handle eMMC as well.. is it? What is this min_clk as 400000? Any idea if the max_clk and min_clk value are initialized to 0 so-that sdhci will re-init based on the capabilities register Base_Clock_Frequency_for_SD_Clock[13:8].?
Thanks, Jagan.
Thanks, Jagan.
working.
Thanks, Jagan.
-- Tushar Behera
Jaehoon Chung
Jagan Teki
Lukasz Majewski
Tushar Behera
