[U-Boot-Users] slow memory running from flash.
4 Nov
2005
4 Nov
'05
3:16 p.m.
Hi.
I have an MPC8343 that runs its memory _VERY_ slowly when I run code from flash. Identical u-boot code loaded into RAM and run from there is fine, and 10x or more faster for memcopy and dma_xfer. I.e. the IMMBAR setup registers for memory are identical. Eg. the 'relocate_code()' routine takes 5 seconds if i am running from flash, but negligible time if running from RAM.
The only difference in u-boot code is that when running from ram, the remap_flash_by_XYZ games in start.S are not played. All dcache issues are the same either way.
I wonder if anyone has a clue for me about why this might be?
-dbu.
7124
David Updegraff
