[PATCH] clk: renesas: Fix broken clocks on all Gen2 boards
To prepare support for multiple register layouts pointers to register tables where added to struct cpg_mssr_info. These pointers are suppose to be filled in at probe time and no intended change in behavior was intended.
However the new pointers where only filled in by some paths of the driver implemented in clk-rcar-gen3.c. The path implemented in clk-rcar-gen2.c was not updated leaving the pointers uninitialized leading to a crash when trying to probe the clocks.
Fix this by filling in the pointers in the Gen2 code path with the values used before they where moved to struct cpg_mssr_info.
Fixes: d413214fb748 ("clk: renesas: Add register pointers into struct cpg_mssr_info") Signed-off-by: Niklas Söderlund niklas.soderlund+renesas@ragnatech.se --- drivers/clk/renesas/clk-rcar-gen2.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/clk/renesas/clk-rcar-gen2.c b/drivers/clk/renesas/clk-rcar-gen2.c index 66ffef96b695..89f2d9667469 100644 --- a/drivers/clk/renesas/clk-rcar-gen2.c +++ b/drivers/clk/renesas/clk-rcar-gen2.c @@ -298,6 +298,15 @@ int gen2_clk_probe(struct udevice *dev) if (!priv->cpg_pll_config->extal_div) return -EINVAL;
+ if (info->reg_layout == CLK_REG_LAYOUT_RCAR_GEN2_AND_GEN3) { + priv->info->status_regs = mstpsr; + priv->info->control_regs = smstpcr; + priv->info->reset_regs = srcr; + priv->info->reset_clear_regs = srstclr; + } else { + return -EINVAL; + } + ret = clk_get_by_name(dev, "extal", &priv->clk_extal); if (ret < 0) return ret;
Acked-by: Marek Vasut marek.vasut+renesas@mailbox.org Tested-by: Marek Vasut marek.vasut+renesas@mailbox.org # R8A7791 Porter
Hi Niklas,
Thanks for your patch!
On Fri, Feb 9, 2024 at 10:22 PM Niklas Söderlund niklas.soderlund+renesas@ragnatech.se wrote:
supposed
were
were
Reviewed-by: Geert Uytterhoeven geert+renesas@glider.be
Gr{oetje,eeting}s,
Geert
Geert Uytterhoeven
Niklas Söderlund
