[U-Boot] [PATCH v1 0/2] imx6ull: Fix missing initial output from UART
For Colibri iMX6ULL we have to set pinmux for uart configuration ASAP (ideally before relocation) to get serial console working. Without this we miss almost the half of output (U-boot version, CPU defails, Reset cause, DRAM details etc.).
To achieve this we need to force pinctrl-mx6 to get probed before relocation and add u-boot,dm-pre-reloc properties to uart pinmux configuration nodes. Setting pinmux configuration for UART before was done in board_early_init_f().
Fixes: cd69e8ef9b ("colibri-imx6ull: migrate pinctrl and regulators to dtb/dm")
Igor Opaniuk (2): pinctrl: nxp: mx6: DM_FLAG_PRE_RELOC by default ARM: dts: imx6ull-colibri: pre-reloc for uart pinmux modes
arch/arm/dts/imx6ull-colibri.dts | 2 ++ drivers/pinctrl/nxp/pinctrl-imx6.c | 2 -- 2 files changed, 2 insertions(+), 2 deletions(-)
For Colibri iMX6ULL we have to set pinmux configuration ASAP (ideally before relocation) to get serial console working. Without this we miss almost the half of output (U-boot version, CPU defails, Reset cause, DRAM details etc.).
To achieve this we need to force pinctrl-mx6 to get probed before relocation. Setting pinmux configuration for UART before was done in board_early_init_f().
Fixes: cd69e8ef9b ("colibri-imx6ull: migrate pinctrl and regulators to dtb/dm") Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com ---
drivers/pinctrl/nxp/pinctrl-imx6.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/drivers/pinctrl/nxp/pinctrl-imx6.c b/drivers/pinctrl/nxp/pinctrl-imx6.c index 0c1e7a9c05..aafa3057ad 100644 --- a/drivers/pinctrl/nxp/pinctrl-imx6.c +++ b/drivers/pinctrl/nxp/pinctrl-imx6.c @@ -49,7 +49,5 @@ U_BOOT_DRIVER(imx6_pinctrl) = { .remove = imx_pinctrl_remove, .priv_auto_alloc_size = sizeof(struct imx_pinctrl_priv), .ops = &imx_pinctrl_ops, -#if !CONFIG_IS_ENABLED(OF_CONTROL) .flags = DM_FLAG_PRE_RELOC, -#endif };
Hi Igor,
It seems that this is not i.MX6 specific (maybe not even i.MX specific. I noticed this issue on i.MX7 too).
Could this be handled in the drivers/pinctrl core instead?
Just wanted to see if we can get a more generic solution for this issue.
Thanks
Hi Fabio,
On Mon, Jul 15, 2019 at 10:10 PM Fabio Estevam festevam@gmail.com wrote:
Hi Igor,
Right. Currently there are no any output issues on Colibri iMX7 because board_early_init_f() does apply initial pinmux configuration for uart [1].
Thanks
AFAIK, DM_FLAG_PRE_RELOC flag can be set for a driver, not for the whole uclass (but I might be mistaken). Also taking into account memory limitations (small malloc pool etc) before U-boot is relocated, I would force driver to be bounded only in the cases when it's really vital (like this particular case with serial console issue).
Thanks!
[1] board/toradex/colibri_imx7/colibri_imx7.c
-- Best regards - Freundliche Grüsse - Meilleures salutations
Igor Opaniuk
mailto: igor.opaniuk@gmail.com skype: igor.opanyuk +380 (93) 836 40 67 http://ua.linkedin.com/in/iopaniuk
Hi Fabio,
On Tue, Jul 16, 2019 at 3:44 PM Igor Opaniuk igor.opaniuk@gmail.com wrote:
Hi Fabio,
Hi Igor,
Thanks
I'm currently in the middle of preparing v2, just wanted to know if you do agree with this point and in general have any additional suggestions regarding this?
Thanks!
Igor Opaniuk
Thanks
Hi Igor,
On Wed, Jul 24, 2019 at 10:58 AM Igor Opaniuk igor.opaniuk@toradex.com wrote:
My only suggestion is to do a single patch that touches all the drivers/pinctrl/nxp/ drivers, not ony the mx6 one.
Thanks
Add u-boot,dm-pre-reloc property for uart pinmux configuration nodes, which enables UART as early as possible (before relocation).
arch/arm/dts/imx6ull-colibri.dts | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/imx6ull-colibri.dts b/arch/arm/dts/imx6ull-colibri.dts index 6c847ab792..8cc67a1fa7 100644 --- a/arch/arm/dts/imx6ull-colibri.dts +++ b/arch/arm/dts/imx6ull-colibri.dts @@ -458,6 +458,7 @@ };
pinctrl_uart1: uart1-grp { + u-boot,dm-pre-reloc; fsl,pins = < MX6UL_PAD_UART1_TX_DATA__UART1_DTE_RX 0x1b0b1 MX6UL_PAD_UART1_RX_DATA__UART1_DTE_TX 0x1b0b1 @@ -467,6 +468,7 @@ };
pinctrl_uart1_ctrl1: uart1-ctrl1-grp { /* Additional DTR, DCD */ + u-boot,dm-pre-reloc; fsl,pins = < MX6UL_PAD_JTAG_TDI__GPIO1_IO13 0x1b0b1 /* DCD */ MX6UL_PAD_LCD_DATA18__GPIO3_IO23 0x1b0b1 /* DSR */
Hi Igor,
Shouldn't this U-Boot specific property go to arch/arm/dts/imx6ull-colibri-uboot.dtsi instead?
This way you could keep arch/arm/dts/imx6ull-colibri.dts in sync with Linux.
Hi Fabio,
On Tue, Jul 16, 2019 at 12:31 AM Fabio Estevam festevam@gmail.com wrote:
Hi Igor,
Thanks for the suggestion, will do in v2.
Fabio Estevam
Igor Opaniuk
Igor Opaniuk
