[PATCH] spi: migrate trace to dev and log macro in spi uclass
Define LOG_CATEGORY and change printf and pr_* to dev_ (when dev is available) or log_ macro.
This patch adds the support of logging feature with log command (filtering, display of device name in trace) and allows to suppress traces via the syslog driver.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
drivers/spi/spi-uclass.c | 51 ++++++++++++++++++++++------------------ 1 file changed, 28 insertions(+), 23 deletions(-)
diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index 55a8eed890..d5a1e3a676 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -3,12 +3,15 @@ * Copyright (c) 2014 Google, Inc */
+#define LOG_CATEGORY UCLASS_SPI + #include <common.h> #include <dm.h> #include <errno.h> #include <log.h> #include <malloc.h> #include <spi.h> +#include <dm/device_compat.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h> #include <dm/lists.h> @@ -29,7 +32,7 @@ static int spi_set_speed_mode(struct udevice *bus, int speed, int mode) else ret = -EINVAL; if (ret) { - printf("Cannot set speed (err=%d)\n", ret); + dev_err(bus, "Cannot set speed (err=%d)\n", ret); return ret; }
@@ -38,7 +41,7 @@ static int spi_set_speed_mode(struct udevice *bus, int speed, int mode) else ret = -EINVAL; if (ret) { - printf("Cannot set mode (err=%d)\n", ret); + dev_err(bus, "Cannot set mode (err=%d)\n", ret); return ret; }
@@ -138,13 +141,15 @@ int spi_write_then_read(struct spi_slave *slave, const u8 *opcode,
ret = spi_xfer(slave, n_opcode * 8, opcode, NULL, flags); if (ret) { - debug("spi: failed to send command (%zu bytes): %d\n", - n_opcode, ret); + dev_dbg(slave->dev, + "spi: failed to send command (%zu bytes): %d\n", + n_opcode, ret); } else if (n_buf != 0) { ret = spi_xfer(slave, n_buf * 8, txbuf, rxbuf, SPI_XFER_END); if (ret) - debug("spi: failed to transfer %zu bytes of data: %d\n", - n_buf, ret); + dev_dbg(slave->dev, + "spi: failed to transfer %zu bytes of data: %d\n", + n_buf, ret); }
return ret; @@ -248,7 +253,7 @@ int spi_find_chip_select(struct udevice *bus, int cs, struct udevice **devp) }
if (ret) { - printf("Invalid cs %d (err=%d)\n", cs, ret); + dev_err(bus, "Invalid cs %d (err=%d)\n", cs, ret); return ret; }
@@ -257,7 +262,7 @@ int spi_find_chip_select(struct udevice *bus, int cs, struct udevice **devp) struct dm_spi_slave_platdata *plat;
plat = dev_get_parent_platdata(dev); - debug("%s: plat=%p, cs=%d\n", __func__, plat, plat->cs); + dev_dbg(bus, "%s: plat=%p, cs=%d\n", __func__, plat, plat->cs); if (plat->cs == cs) { *devp = dev; return 0; @@ -275,7 +280,7 @@ int spi_cs_is_valid(unsigned int busnum, unsigned int cs)
ret = uclass_find_device_by_seq(UCLASS_SPI, busnum, false, &bus); if (ret) { - debug("%s: No bus %d\n", __func__, busnum); + log_debug("%s: No bus %d\n", __func__, busnum); return ret; }
@@ -304,12 +309,12 @@ int spi_find_bus_and_cs(int busnum, int cs, struct udevice **busp,
ret = uclass_find_device_by_seq(UCLASS_SPI, busnum, false, &bus); if (ret) { - debug("%s: No bus %d\n", __func__, busnum); + log_debug("%s: No bus %d\n", __func__, busnum); return ret; } ret = spi_find_chip_select(bus, cs, &dev); if (ret) { - debug("%s: No cs %d\n", __func__, cs); + dev_dbg(bus, "%s: No cs %d\n", __func__, cs); return ret; } *busp = bus; @@ -334,7 +339,7 @@ int spi_get_bus_and_cs(int busnum, int cs, int speed, int mode, ret = uclass_get_device_by_seq(UCLASS_SPI, busnum, &bus); #endif if (ret) { - printf("Invalid bus %d (err=%d)\n", busnum, ret); + log_err("Invalid bus %d (err=%d)\n", busnum, ret); return ret; } ret = spi_find_chip_select(bus, cs, &dev); @@ -345,12 +350,12 @@ int spi_get_bus_and_cs(int busnum, int cs, int speed, int mode, * SPI flash chip - we will bind to the correct driver. */ if (ret == -ENODEV && drv_name) { - debug("%s: Binding new device '%s', busnum=%d, cs=%d, driver=%s\n", - __func__, dev_name, busnum, cs, drv_name); + dev_dbg(bus, "%s: Binding new device '%s', busnum=%d, cs=%d, driver=%s\n", + __func__, dev_name, busnum, cs, drv_name); ret = device_bind_driver(bus, drv_name, dev_name, &dev); if (ret) { - debug("%s: Unable to bind driver (ret=%d)\n", __func__, - ret); + dev_dbg(bus, "%s: Unable to bind driver (ret=%d)\n", + __func__, ret); return ret; } plat = dev_get_parent_platdata(dev); @@ -358,15 +363,15 @@ int spi_get_bus_and_cs(int busnum, int cs, int speed, int mode, if (speed) { plat->max_hz = speed; } else { - printf("Warning: SPI speed fallback to %u kHz\n", - SPI_DEFAULT_SPEED_HZ / 1000); + dev_warn(bus, + "Warning: SPI speed fallback to %u kHz\n", + SPI_DEFAULT_SPEED_HZ / 1000); plat->max_hz = SPI_DEFAULT_SPEED_HZ; } plat->mode = mode; created = true; } else if (ret) { - printf("Invalid chip select %d:%d (err=%d)\n", busnum, cs, - ret); + dev_err(bus, "Invalid chip select %d:%d (err=%d)\n", busnum, cs, ret); return ret; }
@@ -394,13 +399,13 @@ int spi_get_bus_and_cs(int busnum, int cs, int speed, int mode,
*busp = bus; *devp = slave; - debug("%s: bus=%p, slave=%p\n", __func__, bus, *devp); + log_debug("%s: bus=%p, slave=%p\n", __func__, bus, *devp);
err: - debug("%s: Error path, created=%d, device '%s'\n", __func__, - created, dev->name); + log_debug("%s: Error path, created=%d, device '%s'\n", __func__, + created, dev->name); if (created) { device_remove(dev, DM_REMOVE_NORMAL); device_unbind(dev);
On Thu, Oct 15, 2020 at 8:48 PM Patrick Delaunay patrick.delaunay@st.com wrote:
Applied to u-boot-spi/master
Jagan Teki
Patrick Delaunay
