[U-Boot] [PATCH] mtd: Use get_mtdids() instead of env_get("mtdids") in mtd_search_alternate_name()
The environment is not guaranteed to contain a valid mtdids variable when called from mtd_search_alternate_name(). Call get_mtdids() instead of env_get("mtdids").
Fixes: ff4afa8a981e ("mtd: uboot: search for an equivalent MTD name with the mtdids") Signed-off-by: Boris Brezillon boris.brezillon@bootlin.com --- drivers/mtd/mtd_uboot.c | 45 ++++++++++++++++++++--------------------- 1 file changed, 22 insertions(+), 23 deletions(-)
diff --git a/drivers/mtd/mtd_uboot.c b/drivers/mtd/mtd_uboot.c index 6a3e64395de2..b38771d0497f 100644 --- a/drivers/mtd/mtd_uboot.c +++ b/drivers/mtd/mtd_uboot.c @@ -13,6 +13,27 @@
#define MTD_NAME_MAX_LEN 20
+static const char *get_mtdids(void) +{ + __maybe_unused const char *mtdparts = NULL; + const char *mtdids = env_get("mtdids"); + + if (mtdids) + return mtdids; + +#if defined(CONFIG_SYS_MTDPARTS_RUNTIME) + board_mtdparts_default(&mtdids, &mtdparts); +#elif defined(MTDIDS_DEFAULT) + mtdids = MTDIDS_DEFAULT; +#elif defined(CONFIG_MTDIDS_DEFAULT) + mtdids = CONFIG_MTDIDS_DEFAULT; +#endif + + if (mtdids) + env_set("mtdids", mtdids); + + return mtdids; +}
/** * mtd_search_alternate_name - Search an alternate name for @mtdname thanks to @@ -34,7 +55,7 @@ int mtd_search_alternate_name(const char *mtdname, char *altname, const char *mtdids, *equal, *comma, *dev_id, *mtd_id; int dev_id_len, mtd_id_len;
- mtdids = env_get("mtdids"); + mtdids = get_mtdids(); if (!mtdids) return -EINVAL;
@@ -95,28 +116,6 @@ static void mtd_probe_uclass_mtd_devs(void) { } extern void board_mtdparts_default(const char **mtdids, const char **mtdparts);
-static const char *get_mtdids(void) -{ - __maybe_unused const char *mtdparts = NULL; - const char *mtdids = env_get("mtdids"); - - if (mtdids) - return mtdids; - -#if defined(CONFIG_SYS_MTDPARTS_RUNTIME) - board_mtdparts_default(&mtdids, &mtdparts); -#elif defined(MTDIDS_DEFAULT) - mtdids = MTDIDS_DEFAULT; -#elif defined(CONFIG_MTDIDS_DEFAULT) - mtdids = CONFIG_MTDIDS_DEFAULT; -#endif - - if (mtdids) - env_set("mtdids", mtdids); - - return mtdids; -} - #define MTDPARTS_MAXLEN 512
static const char *get_mtdparts(void)
Hi Boris,
Boris Brezillon boris.brezillon@bootlin.com wrote on Fri, 16 Nov 2018 23:15:42 +0100:
Reviewed-by: Miquel Raynal miquel.raynal@bootlin.com
Thanks, Miquèl
On Sat, 17 Nov 2018 11:59:52 +0100 Miquel Raynal miquel.raynal@bootlin.com wrote:
Hi Boris,
Forgot to move board_mtdparts_default(). Please don't apply this patch, I'll send a v2.
Thanks, Miquèl
Boris Brezillon
Miquel Raynal
