[GIT PULL] Pull request: u-boot-imx u-boot-imx-20200804
Hi Tom,
please pull from u-boot-imx, thanks !
The following changes since commit ada61f1ee2a4eaa1b29d699b5ba940483171df8a:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-riscv (2020-07-24 08:43:08 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-20200804
for you to fetch changes up to 3e980a2d8bd13d0d1c2d5cec9e57a47b6cff8b92:
configs: pico-imx6: convert ethernet function to DM_ETH (2020-08-03 17:03:57 +0200)
---------------------------------------------------------------- For 2020.10 -----------
- fixes for Toradex board - fix warnings from previous PR - HAB: reset instead of panic after failure - new board: MYiR Tech MYS-6ULX - mx6cuboxi: use OF_PLATDATA - further changes for DM
Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/714513163
---------------------------------------------------------------- Dan Murphy (1): dm: Fix build error when OF_CONTROL is not set
Fabio Estevam (2): imx8m: ddrphy_utils: Improve coding style imx8m: soc: Remove unneeded space
Igor Opaniuk (14): imx: mx7: fix DDRC size in A7-M4 mapping table toradex: tdx-cfg-block: add EEPROM read/store wrappers toradex: tdx-cfg-block: add carrier boards and display adapters toradex: tdx-cfg-block: add support for EEPROM toradex: tdx-cfg-clock: add migration routine from PID8 toradex: tdx-cfg-block: add carrier board info printing ARM: dts: imx8mm-verdin: eeprom nodes adjustments verdin-imx8mm: add EEPROM support for carrier board ARM: dts: imx6ull-colibri: move u-boot specific node toradex: common: show boot logo ARM: dts: imx7-colibri: multiple node updates colibri-imx6ull: show boot logo colibri-imx6ull: fix splash screen logo drawing colibri-imx7: fix splash logo drawing
Marek Vasut (1): ARM: imx: hab: panic on authentication failure
Niel Fourie (1): arm: imx6q: pcm058: Rework SPI NOR configuration
Parthiban Nallathambi (1): imx: Add MYiR Tech MYS-6ULX support
Peng Fan (1): imx8m: enlarge CONFIG_SYS_BOOTM_LEN
Walter Lozano (6): mmc: fsl_esdhc_imx: rename driver name to match ll_entry mmc: fsl_esdhc_imx: add OF_PLATDATA support gpio: mxc_gpio: add OF_PLATDATA support mmc: fsl_esdhc_imx: add CD support when OF_PLATDATA is enabled drivers: rename more drivers to match compatible string mx6cuboxi: enable OF_PLATDATA
Wig Cheng (1): configs: pico-imx6: convert ethernet function to DM_ETH
arch/arm/Kconfig | 1 + arch/arm/dts/Makefile | 1 + arch/arm/dts/imx6ull-colibri-u-boot.dtsi | 45 +++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx6ull-colibri.dtsi | 43 ----------------------------------- arch/arm/dts/imx6ull-myir-mys-6ulx-eval.dts | 19 ++++++++++++++++ arch/arm/dts/imx6ull-myir-mys-6ulx.dtsi | 238 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx6ull-mys-6ulx-u-boot.dtsi | 24 ++++++++++++++++++++ arch/arm/dts/imx7-colibri-emmc.dts | 2 +- arch/arm/dts/imx7-colibri-rawnand.dts | 10 +++++---- arch/arm/dts/imx7-colibri-u-boot.dtsi | 39 ++++++++++++++++++++++++++++++++ arch/arm/dts/imx7-colibri.dtsi | 65 ++++++++++++++++++++++++++--------------------------- arch/arm/dts/imx8mm-verdin.dts | 22 +++++++++++------- arch/arm/mach-imx/imx8m/soc.c | 2 +- arch/arm/mach-imx/mx6/Kconfig | 12 ++++++++++ arch/arm/mach-imx/mx7/soc.c | 2 +- arch/arm/mach-imx/spl.c | 6 ++--- board/myir/mys_6ulx/Kconfig | 12 ++++++++++ board/myir/mys_6ulx/MAINTAINERS | 9 ++++++++ board/myir/mys_6ulx/Makefile | 4 ++++ board/myir/mys_6ulx/README | 52 ++++++++++++++++++++++++++++++++++++++++++ board/myir/mys_6ulx/mys_6ulx.c | 117 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/myir/mys_6ulx/spl.c | 206 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/phytec/pcm058/README | 20 ++++++++++------- board/toradex/colibri-imx6ull/colibri-imx6ull.c | 40 ++++++--------------------------- board/toradex/colibri_imx7/MAINTAINERS | 1 + board/toradex/colibri_imx7/colibri_imx7.c | 44 ++++++++++-------------------------- board/toradex/common/Kconfig | 18 +++++++++++++++ board/toradex/common/Makefile | 1 + board/toradex/common/tdx-cfg-block.c | 402 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++-------------------------------- board/toradex/common/tdx-cfg-block.h | 16 +++++++++++++ board/toradex/common/tdx-common.c | 54 ++++++++++++++++++++++++++++++++++++++++++++ board/toradex/common/tdx-common.h | 4 ++++ board/toradex/common/tdx-eeprom.c | 90 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/toradex/common/tdx-eeprom.h | 14 ++++++++++++ board/toradex/verdin-imx8mm/Kconfig | 6 +++++ configs/colibri-imx6ull_defconfig | 1 + configs/colibri_imx7_defconfig | 2 ++ configs/colibri_imx7_emmc_defconfig | 2 ++ configs/mx6cuboxi_defconfig | 1 + configs/myir_mys_6ulx_defconfig | 69 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ configs/pcm058_defconfig | 3 ++- configs/pico-imx6_defconfig | 3 +++ configs/verdin-imx8mm_defconfig | 1 + drivers/ddr/imx/imx8m/ddrphy_utils.c | 29 ++++++++++++------------ drivers/gpio/mxc_gpio.c | 27 +++++++++++++++++----- drivers/mmc/fsl_esdhc_imx.c | 92 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------- drivers/pinctrl/nxp/pinctrl-imx6.c | 6 +++-- drivers/video/imx/mxc_ipuv3_fb.c | 4 ++-- include/configs/imx8mn_evk.h | 2 ++ include/configs/imx8mp_evk.h | 2 ++ include/configs/imx8mq_evk.h | 2 ++ include/configs/mys_6ulx.h | 76 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/dm/read.h | 2 ++ 53 files changed, 1718 insertions(+), 247 deletions(-) create mode 100644 arch/arm/dts/imx6ull-myir-mys-6ulx-eval.dts create mode 100644 arch/arm/dts/imx6ull-myir-mys-6ulx.dtsi create mode 100644 arch/arm/dts/imx6ull-mys-6ulx-u-boot.dtsi create mode 100644 arch/arm/dts/imx7-colibri-u-boot.dtsi create mode 100644 board/myir/mys_6ulx/Kconfig create mode 100644 board/myir/mys_6ulx/MAINTAINERS create mode 100644 board/myir/mys_6ulx/Makefile create mode 100644 board/myir/mys_6ulx/README create mode 100644 board/myir/mys_6ulx/mys_6ulx.c create mode 100644 board/myir/mys_6ulx/spl.c create mode 100644 board/toradex/common/tdx-eeprom.c create mode 100644 board/toradex/common/tdx-eeprom.h create mode 100644 configs/myir_mys_6ulx_defconfig create mode 100644 include/configs/mys_6ulx.h
Best regards, Stefano
On Tue, Aug 04, 2020 at 11:02:59AM +0200, Stefano Babic wrote:
Hi Tom,
Stefano Babic
