[U-Boot] [PATCH 1/3] evb-rk3128: Migrate CONFIG_ENV_IS_IN_MMC to defconfig
This board is setting CONFIG_ENV_IS_IN_MMC in the header rather than defconfig, fix.
Cc: Kever Yang kever.yang@rock-chips.com Signed-off-by: Tom Rini trini@konsulko.com --- configs/evb-rk3128_defconfig | 1 + include/configs/evb_rk3128.h | 1 - 2 files changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/evb-rk3128_defconfig b/configs/evb-rk3128_defconfig index ec2f143ddeca..cb3c5372aa81 100644 --- a/configs/evb-rk3128_defconfig +++ b/configs/evb-rk3128_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y CONFIG_DEFAULT_DEVICE_TREE="rk3128-evb" +CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/include/configs/evb_rk3128.h b/include/configs/evb_rk3128.h index 73ceab03732a..bf6c7eaf4c19 100644 --- a/include/configs/evb_rk3128.h +++ b/include/configs/evb_rk3128.h @@ -8,7 +8,6 @@
#include <configs/rk3128_common.h>
-#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
#endif
This board is setting CONFIG_ENV_IS_IN_SPI_FLASH in the header rather than defconfig, fix.
Cc: Stefano Babic sbabic@denx.de Signed-off-by: Tom Rini trini@konsulko.com --- configs/pfla02_defconfig | 1 + include/configs/pfla02.h | 1 - 2 files changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/pfla02_defconfig b/configs/pfla02_defconfig index 7bd146d1ba77..d8ecf8e3dc24 100644 --- a/configs/pfla02_defconfig +++ b/configs/pfla02_defconfig @@ -42,6 +42,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:-(nand);spi2.0:1024k(bootloader),64k(env1),64k(env2),-(rescue)" CONFIG_CMD_UBI=y # CONFIG_SPL_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_USDHC=y CONFIG_MTD=y diff --git a/include/configs/pfla02.h b/include/configs/pfla02.h index 8731d89af2cb..c21b993a62bb 100644 --- a/include/configs/pfla02.h +++ b/include/configs/pfla02.h @@ -74,7 +74,6 @@ #define CONFIG_SYS_FSL_USDHC_NUM 2
/* Environment organization */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_OFFSET (1024 * SZ_1K) #define CONFIG_ENV_SECT_SIZE (64 * SZ_1K)
Move this symbol to Kconfig. As part of this we can drop a UBI-specific symbol that was a stop-gap for not having this particular symbol in Kconfig.
Signed-off-by: Tom Rini trini@konsulko.com --- configs/MPC8308RDB_defconfig | 1 + configs/MPC8313ERDB_NAND_33_defconfig | 1 + configs/MPC8313ERDB_NAND_66_defconfig | 1 + configs/MPC8349EMDS_PCI64_defconfig | 1 + configs/MPC8349EMDS_SDRAM_defconfig | 1 + configs/MPC8349EMDS_SLAVE_defconfig | 1 + configs/MPC8349EMDS_defconfig | 1 + configs/TQM834x_defconfig | 1 + configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_igep003x_defconfig | 1 + configs/am335x_shc_defconfig | 1 + configs/am335x_shc_ict_defconfig | 1 + configs/am335x_shc_netboot_defconfig | 1 + configs/am335x_shc_sdboot_defconfig | 1 + configs/am335x_sl50_defconfig | 1 + configs/am43xx_evm_qspiboot_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/am57xx_hs_evm_usb_defconfig | 1 + configs/am65x_evm_a53_defconfig | 1 + configs/apf27_defconfig | 1 + configs/apx4devkit_defconfig | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/at91sam9260ek_nandflash_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9263ek_norflash_boot_defconfig | 1 + configs/at91sam9263ek_norflash_defconfig | 1 + configs/at91sam9g10ek_nandflash_defconfig | 1 + configs/at91sam9g20ek_2mmc_nandflash_defconfig | 1 + configs/at91sam9g20ek_nandflash_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9rlek_nandflash_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9xeek_nandflash_defconfig | 1 + configs/axm_defconfig | 1 + configs/bcm7260_defconfig | 1 + configs/bcm7445_defconfig | 1 + configs/bk4r1_defconfig | 1 + configs/brppt1_mmc_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brsmarc1_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/caddy2_defconfig | 1 + configs/chiliboard_defconfig | 1 + configs/cm_t54_defconfig | 1 + configs/corvus_defconfig | 1 + configs/dh_imx6_defconfig | 1 + configs/display5_defconfig | 1 + configs/display5_factory_defconfig | 1 + configs/dra7xx_evm_defconfig | 1 + configs/dra7xx_hs_evm_defconfig | 1 + configs/dra7xx_hs_evm_usb_defconfig | 1 + configs/draco_defconfig | 1 + configs/edb9315a_defconfig | 1 + configs/edison_defconfig | 1 + configs/etamin_defconfig | 1 + configs/flea3_defconfig | 1 + .../gardena-smart-gateway-at91sam_defconfig | 1 + .../gardena-smart-gateway-mt7688-ram_defconfig | 1 + configs/gardena-smart-gateway-mt7688_defconfig | 1 + configs/gazerbeam_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/hrcon_defconfig | 1 + configs/hrcon_dh_defconfig | 1 + configs/ids8313_defconfig | 1 + configs/igep00x0_defconfig | 1 + configs/km_kirkwood_128m16_defconfig | 1 + configs/km_kirkwood_defconfig | 1 + configs/km_kirkwood_pci_defconfig | 1 + configs/kmcoge4_defconfig | 1 + configs/kmcoge5ne_defconfig | 1 + configs/kmcoge5un_defconfig | 1 + configs/kmeter1_defconfig | 1 + configs/kmnusa_defconfig | 1 + configs/kmopti2_defconfig | 1 + configs/kmsugp1_defconfig | 1 + configs/kmsupx5_defconfig | 1 + configs/kmsuv31_defconfig | 1 + configs/kmtegr1_defconfig | 1 + configs/kmtepr2_defconfig | 1 + configs/kp_imx53_defconfig | 1 + configs/kp_imx6q_tpc_defconfig | 1 + configs/m53menlo_defconfig | 1 + configs/mccmon6_nor_defconfig | 1 + configs/mccmon6_sd_defconfig | 1 + configs/mgcoge3un_defconfig | 1 + configs/mpc8308_p1m_defconfig | 1 + configs/mscc_jr2_defconfig | 1 + configs/mscc_luton_defconfig | 1 + configs/mscc_ocelot_defconfig | 1 + configs/mscc_serval_defconfig | 1 + configs/mscc_servalt_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx31pdk_defconfig | 1 + configs/mx35pdk_defconfig | 1 + configs/novena_defconfig | 1 + configs/omap5_uevm_defconfig | 1 + configs/opos6uldev_defconfig | 1 + configs/pcm052_defconfig | 1 + configs/pcm058_defconfig | 1 + configs/pfla02_defconfig | 1 + configs/platinum_picon_defconfig | 1 + configs/platinum_titanium_defconfig | 1 + configs/pm9g45_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/sam9x60ek_nandflash_defconfig | 1 + configs/sama5d2_ptc_ek_nandflash_defconfig | 1 + configs/sama5d36ek_cmp_nandflash_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sbc8349_PCI_33_defconfig | 1 + configs/sbc8349_PCI_66_defconfig | 1 + configs/sbc8349_defconfig | 1 + configs/sh7763rdp_defconfig | 1 + configs/sksimx6_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/socrates_defconfig | 1 + configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_optee_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + configs/strider_con_defconfig | 1 + configs/strider_con_dp_defconfig | 1 + configs/strider_cpu_defconfig | 1 + configs/strider_cpu_dp_defconfig | 1 + configs/suvd3_defconfig | 1 + configs/taurus_defconfig | 1 + ...rable-x86-conga-qa3-e3845-pcie-x4_defconfig | 1 + .../theadorable-x86-conga-qa3-e3845_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + configs/thuban_defconfig | 1 + configs/ti816x_evm_defconfig | 1 + configs/titanium_defconfig | 1 + configs/tqma6dl_mba6_spi_defconfig | 1 + configs/tqma6q_mba6_spi_defconfig | 1 + configs/tqma6s_mba6_spi_defconfig | 1 + configs/tricorder_defconfig | 1 + configs/tuge1_defconfig | 1 + configs/tuxx1_defconfig | 1 + configs/vct_platinum_defconfig | 1 + configs/vct_platinum_small_defconfig | 1 + configs/vct_platinumavc_defconfig | 1 + configs/vct_platinumavc_small_defconfig | 1 + configs/vct_premium_defconfig | 1 + configs/vct_premium_small_defconfig | 1 + configs/ve8313_defconfig | 1 + configs/vining_2000_defconfig | 1 + configs/vme8349_defconfig | 1 + configs/wb45n_defconfig | 1 + configs/wb50n_defconfig | 1 + configs/woodburn_defconfig | 1 + configs/woodburn_sd_defconfig | 1 + configs/work_92105_defconfig | 1 + configs/x600_defconfig | 1 + env/Kconfig | 18 +++++++++++------- include/configs/UCP1020.h | 2 -- include/configs/am335x_evm.h | 2 -- include/configs/am335x_sl50.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/am57xx_evm.h | 1 - include/configs/am65x_evm.h | 1 - include/configs/aristainetos-common.h | 1 - include/configs/bav335x.h | 2 -- include/configs/bcmstb.h | 1 - include/configs/brppt1.h | 2 -- include/configs/brsmarc1.h | 1 - include/configs/brxre1.h | 1 - include/configs/chiliboard.h | 1 - include/configs/cm_t54.h | 1 - include/configs/dart_6ul.h | 1 - include/configs/dh_imx6.h | 1 - include/configs/display5.h | 1 - include/configs/dra7xx_evm.h | 2 -- include/configs/gardena-smart-gateway-mt7688.h | 1 - include/configs/km/km_arm.h | 2 -- include/configs/kmp204x.h | 2 -- include/configs/kp_imx53.h | 1 - include/configs/kp_imx6q_tpc.h | 1 - include/configs/mccmon6.h | 1 - include/configs/mx28evk.h | 1 - include/configs/omap5_uevm.h | 1 - include/configs/pcl063_ull.h | 1 - include/configs/pcm058.h | 1 - include/configs/pfla02.h | 1 - include/configs/sksimx6.h | 1 - include/configs/socfpga_sr1500.h | 1 - include/configs/socfpga_vining_fpga.h | 1 - include/configs/theadorable-x86-common.h | 1 - include/configs/tqma6.h | 1 - include/configs/vcoreiii.h | 1 - include/env_internal.h | 15 --------------- scripts/config_whitelist.txt | 1 - tools/envcrc.c | 3 --- 202 files changed, 174 insertions(+), 68 deletions(-)
diff --git a/configs/MPC8308RDB_defconfig b/configs/MPC8308RDB_defconfig index 5faf20f16369..55ecf758863c 100644 --- a/configs/MPC8308RDB_defconfig +++ b/configs/MPC8308RDB_defconfig @@ -126,6 +126,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8313ERDB_NAND_33_defconfig b/configs/MPC8313ERDB_NAND_33_defconfig index 4c30f7546fd0..a3c81174b119 100644 --- a/configs/MPC8313ERDB_NAND_33_defconfig +++ b/configs/MPC8313ERDB_NAND_33_defconfig @@ -150,6 +150,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=e2800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=e2800000.flash:512k(uboot),128k(env),6m@1m(kernel),-(fs)" # CONFIG_ENV_IS_IN_FLASH is not set CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8313ERDB_NAND_66_defconfig b/configs/MPC8313ERDB_NAND_66_defconfig index 1c7c72d74a57..4e2ffab6091d 100644 --- a/configs/MPC8313ERDB_NAND_66_defconfig +++ b/configs/MPC8313ERDB_NAND_66_defconfig @@ -149,6 +149,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=e2800000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=e2800000.flash:512k(uboot),128k(env),6m@1m(kernel),-(fs)" # CONFIG_ENV_IS_IN_FLASH is not set CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8349EMDS_PCI64_defconfig b/configs/MPC8349EMDS_PCI64_defconfig index 00dc72d81cf1..873fabc60bc7 100644 --- a/configs/MPC8349EMDS_PCI64_defconfig +++ b/configs/MPC8349EMDS_PCI64_defconfig @@ -93,6 +93,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8349EMDS_SDRAM_defconfig b/configs/MPC8349EMDS_SDRAM_defconfig index ee2de0ad683b..ed7445ca98c2 100644 --- a/configs/MPC8349EMDS_SDRAM_defconfig +++ b/configs/MPC8349EMDS_SDRAM_defconfig @@ -102,6 +102,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8349EMDS_SLAVE_defconfig b/configs/MPC8349EMDS_SLAVE_defconfig index 7550aa30c7f6..c39c36208792 100644 --- a/configs/MPC8349EMDS_SLAVE_defconfig +++ b/configs/MPC8349EMDS_SLAVE_defconfig @@ -93,6 +93,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/MPC8349EMDS_defconfig b/configs/MPC8349EMDS_defconfig index ba00a275cd80..87e041944cfc 100644 --- a/configs/MPC8349EMDS_defconfig +++ b/configs/MPC8349EMDS_defconfig @@ -94,6 +94,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/TQM834x_defconfig b/configs/TQM834x_defconfig index d2e85c9408be..f7d7d58af426 100644 --- a/configs/TQM834x_defconfig +++ b/configs/TQM834x_defconfig @@ -138,6 +138,7 @@ CONFIG_CMD_JFFS2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=TQM834x-0" CONFIG_MTDPARTS_DEFAULT="mtdparts=TQM834x-0:256k(u-boot),256k(env),1m(kernel),2m(initrd),-(user);" +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 5f11264bb38d..39b8d1c3f266 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_SPL=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-boneblack" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y # CONFIG_SPL_BLK is not set CONFIG_BOOTCOUNT_LIMIT=y diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index 8ed52a5ffb79..92a550deada1 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -56,6 +56,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-base0033" CONFIG_ENV_IS_IN_UBI=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_UBI_PART="UBI" CONFIG_ENV_UBI_VOLUME="config" CONFIG_ENV_UBI_VOLUME_REDUND="config_r" diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index 5698208f8488..fc40d1780edf 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_MMC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index 3f8a6bad03be..ffd03a84dc0b 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -44,6 +44,7 @@ CONFIG_CMD_MMC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index d0a7d62a2469..f9c1d50d7608 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -45,6 +45,7 @@ CONFIG_CMD_MMC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index 30fa40abdaf6..1839b7c3e731 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -44,6 +44,7 @@ CONFIG_CMD_MMC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index 01fc52b4ed7f..9b1ffa593369 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-sl50" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DM_MMC=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 7a7591ec7f92..b8ddeadbec00 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -32,6 +32,7 @@ CONFIG_OF_LIST="am4372-generic am437x-sk-evm am437x-idk-evm" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_DFU_MMC=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 8a867f662bbd..588e58947d35 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -40,6 +40,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am572x-idk" CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am57xx-beagle-x15-revc am572x-idk am571x-idk am574x-idk" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index d62581f4014f..a09a1e0603d7 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -42,6 +42,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am57xx-beagle-x15" CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am57xx-beagle-x15-revc am572x-idk am571x-idk am574x-idk" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index 438662bf83a5..c9e008350893 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am57xx-beagle-x15" CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am57xx-beagle-x15-revc am572x-idk am571x-idk am574x-idk" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index c60978c9be5a..3e6c773e28e8 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -45,6 +45,7 @@ CONFIG_DEFAULT_DEVICE_TREE="k3-am654-base-board" CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index 2b82f05dc677..650c2d21a678 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -39,6 +39,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=mxc_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=mxc_nand.0:1M(u-boot)ro,512K(env),512K(env2),512K(firmware),512K(dtb),5M(kernel),-(rootfs)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_SPARTAN3=y CONFIG_MXC_GPIO=y diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index 89f58e5c349b..993a4f627600 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -31,6 +31,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:128k(bootstrap),1024k(boot),768k(env),-(root)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y CONFIG_NAND=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 0bfc1177622e..5c286a01b465 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index e2da747a8f93..f19501d51ae6 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 5caf95c22f52..f79c37e73a7f 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index 3b4706ba456f..2a2c9a6c7d9a 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index bb1c1b809a88..a21671667a4b 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9261ek" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index 53eddd8141db..f286c5a02027 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index 9345a421e7fa..5253e63f6452 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index 86ae5f7ee2fe..a008368f6673 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 007f11d671a7..74992931e034 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9261ek" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index c28b81bff4e1..6fb3a95647ea 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek_2mmc" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index 3d97a52ea547..addefca5f33f 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index 44c50739a047..33b42e692198 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9m10g45ek" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index 51175fb6d5a4..0644f0bd5360 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -31,6 +31,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9n12ek" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index 7b741807098c..4d3f3cf81f2a 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9rlek" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_NET is not set CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index 8f9efdf98a69..dc3fec2039e2 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g35ek" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index 68d43ff81419..417626f0f39c 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index 9947ed90b9fc..8a635d2e4d56 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -50,6 +50,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20-taurus" CONFIG_SPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SPL_DM=y CONFIG_BLK=y CONFIG_HAVE_BLOCK_DEVICE=y diff --git a/configs/bcm7260_defconfig b/configs/bcm7260_defconfig index 2c18d36afc8b..163ba87c3bb1 100644 --- a/configs/bcm7260_defconfig +++ b/configs/bcm7260_defconfig @@ -13,6 +13,7 @@ CONFIG_SYS_PROMPT="U-Boot>" CONFIG_EFI_PARTITION=y CONFIG_OF_PRIOR_STAGE=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_BCMSTB=y diff --git a/configs/bcm7445_defconfig b/configs/bcm7445_defconfig index a3d6a61b6e5d..017a8da04abd 100644 --- a/configs/bcm7445_defconfig +++ b/configs/bcm7445_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_SF_TEST=y CONFIG_CMD_SPI=y CONFIG_OF_PRIOR_STAGE=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_BCMSTB=y diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index 6ad2b7c9e6b7..68f0f24956bd 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="vf610-bk4r1" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_BOOTCOUNT_LIMIT=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index d0ee6194cf2b..50e447abdc2e 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -66,6 +66,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-brppt1-mmc" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent interrupt-controller interrupt-cells dma-names dmas " CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index aa4c7f74fa59..ad7ae4d4cb5f 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -72,6 +72,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-brppt1-spi" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent interrupt-controller interrupt-cells dma-names dmas " CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig index b6626e15facf..1598a212c079 100644 --- a/configs/brsmarc1_defconfig +++ b/configs/brsmarc1_defconfig @@ -71,6 +71,7 @@ CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-brsmarc1" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index d9b0e320f58e..e1fb1022a8fc 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -65,6 +65,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-brxre1" CONFIG_OF_SPL_REMOVE_PROPS="" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y diff --git a/configs/caddy2_defconfig b/configs/caddy2_defconfig index 51c37e2e1a33..0760986f40a5 100644 --- a/configs/caddy2_defconfig +++ b/configs/caddy2_defconfig @@ -106,6 +106,7 @@ CONFIG_CMD_TSI148=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index f275d21d162a..84517b350cc1 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -35,6 +35,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=8000000.nand:128k(NAND.SPL),128k(NAND.SPL.back CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-chiliboard" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DM_GPIO=y CONFIG_MISC=y diff --git a/configs/cm_t54_defconfig b/configs/cm_t54_defconfig index 09c0a3655a30..6c066752a51e 100644 --- a/configs/cm_t54_defconfig +++ b/configs/cm_t54_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_USB=y # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_SCSI_AHCI=y CONFIG_SUPPORT_EMMC_BOOT=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 56c61239586f..7683a80b1936 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -41,6 +41,7 @@ CONFIG_DOS_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g45-corvus" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BLK=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index db3341e8cbb3..4055812007e3 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -45,6 +45,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-dhcom-pdk2" CONFIG_OF_LIST="imx6q-dhcom-pdk2 imx6dl-dhcom-pdk2" CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DWC_AHSATA=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DM_GPIO=y diff --git a/configs/display5_defconfig b/configs/display5_defconfig index 7169b334ab1a..cd96272e5f19 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -68,6 +68,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=02008000.spi.1:128k(SPL),1m(u-boot),64k(env1), CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-display5" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_I2C_SET_DEFAULT_BUS_NUM=y diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index 221f4b557c59..d4e738eb2f40 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -71,6 +71,7 @@ CONFIG_PARTITION_TYPE_GUID=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-display5" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index a1a5dc549ecd..cb2cdcb350a6 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -46,6 +46,7 @@ CONFIG_SPL_MULTI_DTB_FIT_UNCOMPRESS_SZ=0xA000 CONFIG_OF_SPL_REMOVE_PROPS="clocks clock-names interrupt-parent" # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 85b5f5971000..1dff8899757f 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -49,6 +49,7 @@ CONFIG_SPL_MULTI_DTB_FIT_UNCOMPRESS_SZ=0xA000 CONFIG_OF_SPL_REMOVE_PROPS="clocks clock-names interrupt-parent" # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig index 8d8cc2215685..fa18e1d07697 100644 --- a/configs/dra7xx_hs_evm_usb_defconfig +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -48,6 +48,7 @@ CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT_UNCOMPRESS_SZ=0x9000 CONFIG_OF_SPL_REMOVE_PROPS="clocks clock-names interrupt-parent" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 4ba3bde2e6b6..52b234d73cba 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -59,6 +59,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="am335x-draco" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/edb9315a_defconfig b/configs/edb9315a_defconfig index f8f2e16f8567..3c506fdcdb2e 100644 --- a/configs/edb9315a_defconfig +++ b/configs/edb9315a_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y # CONFIG_DOS_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y CONFIG_LED_STATUS_BIT=0 diff --git a/configs/edison_defconfig b/configs/edison_defconfig index 553b22cf6902..672b2bb70ae8 100644 --- a/configs/edison_defconfig +++ b/configs/edison_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="edison" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_CPU=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 31e711d32f05..a74cad9e5e77 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -60,6 +60,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="am335x-draco" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/flea3_defconfig b/configs/flea3_defconfig index a13f609da428..81c29714bd3b 100644 --- a/configs/flea3_defconfig +++ b/configs/flea3_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=mxc_nand,nor0=physmap-flash.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=mxc_nand:50m(root1),32m(rootfb),64m(pcache),64m(app1),10m(app2),-(spool);physmap-flash.0:512k(u-boot),64k(env1),64k(env2),3776k(kernel1),3776k(kernel2)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_MXC_GPIO=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index 4a2cc331a6bf..e695b414903f 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -52,6 +52,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g25-gardena-smart-gateway" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupts interrupt-parent interrupts-extended dmas dma-names" CONFIG_ENV_IS_IN_UBI=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_UBI_PART="ubi" CONFIG_ENV_UBI_VOLUME="env" CONFIG_ENV_UBI_VOLUME_REDUND="env_r" diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig index d97b95ddd7c1..fc45eb3e5b37 100644 --- a/configs/gardena-smart-gateway-mt7688-ram_defconfig +++ b/configs/gardena-smart-gateway-mt7688-ram_defconfig @@ -40,6 +40,7 @@ CONFIG_MTDPARTS_DEFAULT="spi0.0:640k(uboot),64k(uboot_env0),64k(uboot_env1),64k( CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="gardena-smart-gateway-mt7688" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_HAVE_BLOCK_DEVICE=y diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index 8bf69c366648..7d189cfbdaa4 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -43,6 +43,7 @@ CONFIG_MTDPARTS_DEFAULT="spi0.0:640k(uboot),64k(uboot_env0),64k(uboot_env1),64k( CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="gardena-smart-gateway-mt7688" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_HAVE_BLOCK_DEVICE=y diff --git a/configs/gazerbeam_defconfig b/configs/gazerbeam_defconfig index 3a29bb12777f..f7a6b1153b6c 100644 --- a/configs/gazerbeam_defconfig +++ b/configs/gazerbeam_defconfig @@ -140,6 +140,7 @@ CONFIG_DOS_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIVE=y CONFIG_DEFAULT_DEVICE_TREE="gazerbeam" +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_REGMAP=y CONFIG_AXI=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 8c79cbad402c..c1365cd29d8c 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -59,6 +59,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:16m(uboot),1m(env),-(rootfs)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 6b2e0c7fc4ac..78e3bd946474 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -59,6 +59,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:16m(uboot),1m(env),-(rootfs)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index a485fc9b5e9d..dfa2b189afe9 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -62,6 +62,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:16m(uboot),1m(env),-(rootfs)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y diff --git a/configs/hrcon_defconfig b/configs/hrcon_defconfig index 6afd64733d1f..bfbe37262505 100644 --- a/configs/hrcon_defconfig +++ b/configs/hrcon_defconfig @@ -119,6 +119,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/hrcon_dh_defconfig b/configs/hrcon_dh_defconfig index 544a98c504d8..fdf8af9015e4 100644 --- a/configs/hrcon_dh_defconfig +++ b/configs/hrcon_dh_defconfig @@ -117,6 +117,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index 418a4b3706fb..241763d1ca78 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -147,6 +147,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=ff800000.flash,nand0=e1000000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff800000.flash:7m(dum),768k(BOOT-BIN),128k(BOOT-ENV),128k(BOOT-REDENV);e1000000.flash:-(ubi)" CONFIG_CMD_UBI=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_I2C=y # CONFIG_MMC is not set diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 04e9c95b5172..ab0b3b743a1b 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="omap3-igep0020" CONFIG_ENV_IS_IN_UBI=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_UBI_PART="UBI" CONFIG_ENV_UBI_VOLUME="config" CONFIG_ENV_UBI_VOLUME_REDUND="config_r" diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index 1a3dee1fd0b8..c86392638e9e 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_EEPROM=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index 79e57e71f34b..7ac5be4b788a 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_EEPROM=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index e5eda1aa826d..3ee8b76ccced 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_EEPROM=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/kmcoge4_defconfig b/configs/kmcoge4_defconfig index 7ee4ce44aab5..3b7ee334ab52 100644 --- a/configs/kmcoge4_defconfig +++ b/configs/kmcoge4_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/kmcoge5ne_defconfig b/configs/kmcoge5ne_defconfig index faeb0c7175af..edd9af9adbb7 100644 --- a/configs/kmcoge5ne_defconfig +++ b/configs/kmcoge5ne_defconfig @@ -177,6 +177,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=boot,nand0=app" CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi0);app:-(ubi1);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index aebe52d90e9c..18c96472b598 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/kmeter1_defconfig b/configs/kmeter1_defconfig index 518e9f4229f3..eb598b8ccca1 100644 --- a/configs/kmeter1_defconfig +++ b/configs/kmeter1_defconfig @@ -140,6 +140,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=boot" CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index bca8e9b481e9..15cb7d17308b 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/kmopti2_defconfig b/configs/kmopti2_defconfig index 8231ce4d7c9a..c33b25660813 100644 --- a/configs/kmopti2_defconfig +++ b/configs/kmopti2_defconfig @@ -160,6 +160,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=boot" CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/kmsugp1_defconfig b/configs/kmsugp1_defconfig index 4b4dff5bc117..afb0dc4ee467 100644 --- a/configs/kmsugp1_defconfig +++ b/configs/kmsugp1_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/kmsupx5_defconfig b/configs/kmsupx5_defconfig index 72931a716f46..2f7cca59527f 100644 --- a/configs/kmsupx5_defconfig +++ b/configs/kmsupx5_defconfig @@ -140,6 +140,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=boot" CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/kmsuv31_defconfig b/configs/kmsuv31_defconfig index c63f3e53728f..33925073402e 100644 --- a/configs/kmsuv31_defconfig +++ b/configs/kmsuv31_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/kmtegr1_defconfig b/configs/kmtegr1_defconfig index 14f7c2f8ceb4..d8a84658dc92 100644 --- a/configs/kmtegr1_defconfig +++ b/configs/kmtegr1_defconfig @@ -141,6 +141,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),256k(qe-fw),128k(env),128k(e CONFIG_CMD_DIAG=y CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/kmtepr2_defconfig b/configs/kmtepr2_defconfig index 42fbbbbac3b2..8e838eac0944 100644 --- a/configs/kmtepr2_defconfig +++ b/configs/kmtepr2_defconfig @@ -160,6 +160,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=boot" CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/kp_imx53_defconfig b/configs/kp_imx53_defconfig index ea6f8f6d313a..9a4c08c703ac 100644 --- a/configs/kp_imx53_defconfig +++ b/configs/kp_imx53_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx53-kp" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0x1 CONFIG_FSL_ESDHC_IMX=y diff --git a/configs/kp_imx6q_tpc_defconfig b/configs/kp_imx6q_tpc_defconfig index 2484e91635ba..72f7d21eca7b 100644 --- a/configs/kp_imx6q_tpc_defconfig +++ b/configs/kp_imx6q_tpc_defconfig @@ -42,6 +42,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-kp" CONFIG_OF_SPL_REMOVE_PROPS="interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents interrupts dmas dma-names" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_BLOCK_CACHE is not set CONFIG_SPL_CLK_IMX6Q=y CONFIG_CLK_IMX6Q=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index b3660880a531..2f31045b3c6f 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -56,6 +56,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx53-m53menlo" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index 1c545959fa3f..d46c996709d9 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -39,6 +39,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=8000000.nor:32m@0x0(mccmon6-image.nor),256k@0x CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-mccmon6" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_SYS_I2C_MXC=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index 80b5c5cf4a3b..196c7b3f99c7 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -37,6 +37,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=8000000.nor:32m@0x0(mccmon6-image.nor),256k@0x CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-mccmon6" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_SYS_I2C_MXC=y diff --git a/configs/mgcoge3un_defconfig b/configs/mgcoge3un_defconfig index 8c21e11c197a..a7944bf99ccb 100644 --- a/configs/mgcoge3un_defconfig +++ b/configs/mgcoge3un_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_ENV_IS_IN_EEPROM=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/mpc8308_p1m_defconfig b/configs/mpc8308_p1m_defconfig index cb0da4701fb8..68d20b1f55f5 100644 --- a/configs/mpc8308_p1m_defconfig +++ b/configs/mpc8308_p1m_defconfig @@ -107,6 +107,7 @@ CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/mscc_jr2_defconfig b/configs/mscc_jr2_defconfig index f6e7785d11ee..4256a75c6eb0 100644 --- a/configs/mscc_jr2_defconfig +++ b/configs/mscc_jr2_defconfig @@ -40,6 +40,7 @@ CONFIG_OF_LIST="jr2_pcb110 jr2_pcb111 serval2_pcb112" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_DM_GPIO=y diff --git a/configs/mscc_luton_defconfig b/configs/mscc_luton_defconfig index c30e52f94526..0b2ae5834681 100644 --- a/configs/mscc_luton_defconfig +++ b/configs/mscc_luton_defconfig @@ -43,6 +43,7 @@ CONFIG_OF_LIST="luton_pcb090 luton_pcb091" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_DM_GPIO=y diff --git a/configs/mscc_ocelot_defconfig b/configs/mscc_ocelot_defconfig index 53f8b323e89f..a839526bb7ad 100644 --- a/configs/mscc_ocelot_defconfig +++ b/configs/mscc_ocelot_defconfig @@ -42,6 +42,7 @@ CONFIG_OF_LIST="ocelot_pcb120 ocelot_pcb123" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_DM_GPIO=y diff --git a/configs/mscc_serval_defconfig b/configs/mscc_serval_defconfig index 9f58764b5c9f..543d4505224f 100644 --- a/configs/mscc_serval_defconfig +++ b/configs/mscc_serval_defconfig @@ -37,6 +37,7 @@ CONFIG_OF_LIST="serval_pcb106 serval_pcb105" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_DM_GPIO=y diff --git a/configs/mscc_servalt_defconfig b/configs/mscc_servalt_defconfig index aca97a0e78db..5ef5bd64aeb0 100644 --- a/configs/mscc_servalt_defconfig +++ b/configs/mscc_servalt_defconfig @@ -35,6 +35,7 @@ CONFIG_DEFAULT_DEVICE_TREE="servalt_pcb116" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_DM_GPIO=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index d34d50a94d66..7f1de12091c1 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -37,6 +37,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:3m(bootloader)ro,512k(environment),512k(redundant-environment),4m(kernel),512k(fdt),8m(ramdisk),-(filesystem)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_MXS_GPIO=y CONFIG_MMC_MXS=y CONFIG_NAND=y diff --git a/configs/mx31pdk_defconfig b/configs/mx31pdk_defconfig index bdeb6b259095..cdf0853fd172 100644 --- a/configs/mx31pdk_defconfig +++ b/configs/mx31pdk_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_MXC_GPIO=y # CONFIG_MMC is not set CONFIG_NAND=y diff --git a/configs/mx35pdk_defconfig b/configs/mx35pdk_defconfig index 3d36045ab56d..59457e35c842 100644 --- a/configs/mx35pdk_defconfig +++ b/configs/mx35pdk_defconfig @@ -25,6 +25,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=mxc_nand:1m(boot),5m(linux),96m(root),8m(cfg), CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_MXC_GPIO=y CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index f9fc289b9dbf..034514e31f98 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -45,6 +45,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-novena" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_DM_GPIO=y diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index cd30110ab97c..036a3675167b 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_SCSI_AHCI=y CONFIG_DFU_MMC=y diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index 352d10a0d8d1..5757a101101e 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -62,6 +62,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-opos6uldev" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index 736a2e75490f..d1c7cf9d4dfd 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="vf610-pcm052" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_VYBRID_GPIO=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index 879f9932be8c..3534d003ed61 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -43,6 +43,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:16m(uboot),1m(env),-(rootfs)" CONFIG_CMD_UBI=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_FSL_USDHC=y CONFIG_MTD=y diff --git a/configs/pfla02_defconfig b/configs/pfla02_defconfig index d8ecf8e3dc24..9af0fa90b238 100644 --- a/configs/pfla02_defconfig +++ b/configs/pfla02_defconfig @@ -43,6 +43,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:-(nand);spi2.0:1024k(bootloader),64k CONFIG_CMD_UBI=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_FSL_USDHC=y CONFIG_MTD=y diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index fc0768a304fe..053931e8249d 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -48,6 +48,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:14M(spl),2M(uboot),512k(env1),512k(env2),495M(ubi0),14M(res0),2M(res1),512k(res2),512k(res3),-(ubi1)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index 8ab916ec9d87..56212205f6ad 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -48,6 +48,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:14M(spl),2M(uboot),512k(env1),512k(env2),-(ubi)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index b5304b963cac..0811d1ece1e7 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9m10g45ek" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 452e7614123f..15f75e69dc9d 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -59,6 +59,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="am335x-draco" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/sam9x60ek_nandflash_defconfig b/configs/sam9x60ek_nandflash_defconfig index b31bbec831ef..c2a0f2f23ba1 100644 --- a/configs/sam9x60ek_nandflash_defconfig +++ b/configs/sam9x60ek_nandflash_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="sam9x60ek" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/sama5d2_ptc_ek_nandflash_defconfig b/configs/sama5d2_ptc_ek_nandflash_defconfig index 4210a52a1319..f886c6b567d8 100644 --- a/configs/sama5d2_ptc_ek_nandflash_defconfig +++ b/configs/sama5d2_ptc_ek_nandflash_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d2_ptc_ek" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/sama5d36ek_cmp_nandflash_defconfig b/configs/sama5d36ek_cmp_nandflash_defconfig index c7f47cc2fd6a..d48f47eeed74 100644 --- a/configs/sama5d36ek_cmp_nandflash_defconfig +++ b/configs/sama5d36ek_cmp_nandflash_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="sama5d36ek_cmp" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 8a2b01f3867f..f9b9563a5887 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -45,6 +45,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d3_xplained" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index bf5e861bf724..a9df5181f201 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -44,6 +44,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="sama5d36ek" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index f8ba5d5d453b..0f7178dbfb25 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -40,6 +40,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d4_xplained" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_CLK=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index e42180a7f172..e042f0fe145a 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -42,6 +42,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d4ek" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sbc8349_PCI_33_defconfig b/configs/sbc8349_PCI_33_defconfig index 915ba3664b44..c0e513dc2733 100644 --- a/configs/sbc8349_PCI_33_defconfig +++ b/configs/sbc8349_PCI_33_defconfig @@ -99,6 +99,7 @@ CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/sbc8349_PCI_66_defconfig b/configs/sbc8349_PCI_66_defconfig index c224fea1c9e5..f35973f94ce1 100644 --- a/configs/sbc8349_PCI_66_defconfig +++ b/configs/sbc8349_PCI_66_defconfig @@ -99,6 +99,7 @@ CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/sbc8349_defconfig b/configs/sbc8349_defconfig index 6231057d6bba..0c90e576a4bc 100644 --- a/configs/sbc8349_defconfig +++ b/configs/sbc8349_defconfig @@ -76,6 +76,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/sh7763rdp_defconfig b/configs/sh7763rdp_defconfig index 89fdc98ee681..74c174b27b91 100644 --- a/configs/sh7763rdp_defconfig +++ b/configs/sh7763rdp_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_JFFS2=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/sksimx6_defconfig b/configs/sksimx6_defconfig index d8739fdae98f..7d3322dfe452 100644 --- a/configs/sksimx6_defconfig +++ b/configs/sksimx6_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 9e73051def10..b585a9faa8b0 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -43,6 +43,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9260-smartweb" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 0d4f5821f9d5..1a3b673d5717 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_UBI=y # CONFIG_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sr1500" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DM_GPIO=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index f7f882f019c0..e68267f55c30 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_UBI=y # CONFIG_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_vining_fpga" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 2241fbb2c276..99e65f495dfe 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_EXT2=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="socrates" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_BLK=y CONFIG_DM_I2C=y diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index c078b5cac3cc..79d892368c0b 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -54,6 +54,7 @@ CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_EXT4=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_IS_IN_UBI=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_EXT4_INTERFACE="mmc" CONFIG_ENV_EXT4_DEVICE_AND_PART="0:auto" CONFIG_ENV_EXT4_FILE="/uboot.env" diff --git a/configs/stm32mp15_optee_defconfig b/configs/stm32mp15_optee_defconfig index 4f4102c40b18..73a1c0298867 100644 --- a/configs/stm32mp15_optee_defconfig +++ b/configs/stm32mp15_optee_defconfig @@ -41,6 +41,7 @@ CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_EXT4=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_IS_IN_UBI=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_EXT4_INTERFACE="mmc" CONFIG_ENV_EXT4_DEVICE_AND_PART="0:auto" CONFIG_ENV_EXT4_FILE="/uboot.env" diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 8712c7942bb8..5bb0ba586e20 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_EXT4=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_IS_IN_UBI=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_EXT4_INTERFACE="mmc" CONFIG_ENV_EXT4_DEVICE_AND_PART="0:auto" CONFIG_ENV_EXT4_FILE="/uboot.env" diff --git a/configs/strider_con_defconfig b/configs/strider_con_defconfig index 6a561d0cd1eb..8fb955c6f478 100644 --- a/configs/strider_con_defconfig +++ b/configs/strider_con_defconfig @@ -116,6 +116,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/strider_con_dp_defconfig b/configs/strider_con_dp_defconfig index eb4ad77456b3..05272bd26679 100644 --- a/configs/strider_con_dp_defconfig +++ b/configs/strider_con_dp_defconfig @@ -116,6 +116,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/strider_cpu_defconfig b/configs/strider_cpu_defconfig index 8a48df25f60d..f6bb254319a9 100644 --- a/configs/strider_cpu_defconfig +++ b/configs/strider_cpu_defconfig @@ -116,6 +116,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/strider_cpu_dp_defconfig b/configs/strider_cpu_dp_defconfig index 26793dbdd611..0b1f16134f71 100644 --- a/configs/strider_cpu_dp_defconfig +++ b/configs/strider_cpu_dp_defconfig @@ -116,6 +116,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/suvd3_defconfig b/configs/suvd3_defconfig index bb21bde3eea3..a7782d50cd1d 100644 --- a/configs/suvd3_defconfig +++ b/configs/suvd3_defconfig @@ -161,6 +161,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=boot" CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 027ae66bea54..fcb9030c6cd0 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -58,6 +58,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20-taurus" CONFIG_SPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SPL_DM=y CONFIG_BLK=y CONFIG_CLK=y diff --git a/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig b/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig index 770804f89347..d0e6464f92e1 100644 --- a/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig +++ b/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig @@ -45,6 +45,7 @@ CONFIG_ISO_PARTITION=y CONFIG_AMIGA_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="conga-qeval20-qa3-e3845" +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CPU=y diff --git a/configs/theadorable-x86-conga-qa3-e3845_defconfig b/configs/theadorable-x86-conga-qa3-e3845_defconfig index d69c2a91dbc6..eccfc5afb491 100644 --- a/configs/theadorable-x86-conga-qa3-e3845_defconfig +++ b/configs/theadorable-x86-conga-qa3-e3845_defconfig @@ -44,6 +44,7 @@ CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="conga-qeval20-qa3-e3845" +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CPU=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index d53aff0ea012..e0678f4ddf94 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -42,6 +42,7 @@ CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="theadorable-x86-dfi-bt700" +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CPU=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index ade82c86e315..682f70c454d4 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -59,6 +59,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="am335x-draco" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 2a817ed3baee..c84cf4804c29 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -40,6 +40,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand.0:128k(NAND.SPL),128k(NAND.SPL.backup1),1 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="dm8168-evm" CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y diff --git a/configs/titanium_defconfig b/configs/titanium_defconfig index 86d1da33241b..cb1dd5607fda 100644 --- a/configs/titanium_defconfig +++ b/configs/titanium_defconfig @@ -34,6 +34,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:16M(uboot),512k(env1),512k(env2),-(ubi)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/tqma6dl_mba6_spi_defconfig b/configs/tqma6dl_mba6_spi_defconfig index 9ad9ea3c2d4f..f5585a494e71 100644 --- a/configs/tqma6dl_mba6_spi_defconfig +++ b/configs/tqma6dl_mba6_spi_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/tqma6q_mba6_spi_defconfig b/configs/tqma6q_mba6_spi_defconfig index 21bc3fab758b..38c662c0c88a 100644 --- a/configs/tqma6q_mba6_spi_defconfig +++ b/configs/tqma6q_mba6_spi_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/tqma6s_mba6_spi_defconfig b/configs/tqma6s_mba6_spi_defconfig index e02b8a5c10b7..85d4a2233715 100644 --- a/configs/tqma6s_mba6_spi_defconfig +++ b/configs/tqma6s_mba6_spi_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index 730fd7fc1067..4487ca2bcf69 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -26,6 +26,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:128k(SPL),1m(u-boot),384k(u-boot-env1),1152k(mtdoops),384k(u-boot-env2),5m(kernel),2m(fdt),-(ubi)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_NET is not set CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y diff --git a/configs/tuge1_defconfig b/configs/tuge1_defconfig index 22ba1929c703..30a36ee03941 100644 --- a/configs/tuge1_defconfig +++ b/configs/tuge1_defconfig @@ -140,6 +140,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=boot" CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/tuxx1_defconfig b/configs/tuxx1_defconfig index 94214a2356aa..bccc459002ca 100644 --- a/configs/tuxx1_defconfig +++ b/configs/tuxx1_defconfig @@ -162,6 +162,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=boot" CONFIG_MTDPARTS_DEFAULT="mtdparts=boot:768k(u-boot),128k(env),128k(envred),-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set diff --git a/configs/vct_platinum_defconfig b/configs/vct_platinum_defconfig index 2a35ace0e0f8..2dacc1c2f0d5 100644 --- a/configs/vct_platinum_defconfig +++ b/configs/vct_platinum_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/vct_platinum_small_defconfig b/configs/vct_platinum_small_defconfig index 8a3f94aadf7b..d53fd4fe513d 100644 --- a/configs/vct_platinum_small_defconfig +++ b/configs/vct_platinum_small_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_IMLS=y # CONFIG_CMD_MISC is not set # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_NET is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/vct_platinumavc_defconfig b/configs/vct_platinumavc_defconfig index 3783becc8ab3..21f04a763543 100644 --- a/configs/vct_platinumavc_defconfig +++ b/configs/vct_platinumavc_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_NET is not set # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/vct_platinumavc_small_defconfig b/configs/vct_platinumavc_small_defconfig index 0d8cd07f9f12..e7b2b1b19894 100644 --- a/configs/vct_platinumavc_small_defconfig +++ b/configs/vct_platinumavc_small_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_IMLS=y # CONFIG_CMD_MISC is not set # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_NET is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/vct_premium_defconfig b/configs/vct_premium_defconfig index 2396b24d5542..2b53b0904808 100644 --- a/configs/vct_premium_defconfig +++ b/configs/vct_premium_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/vct_premium_small_defconfig b/configs/vct_premium_small_defconfig index a8eba61827a8..706799a89e5d 100644 --- a/configs/vct_premium_small_defconfig +++ b/configs/vct_premium_small_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_IMLS=y # CONFIG_CMD_MISC is not set # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_NET is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/ve8313_defconfig b/configs/ve8313_defconfig index 53777093a056..2581d3cf2559 100644 --- a/configs/ve8313_defconfig +++ b/configs/ve8313_defconfig @@ -134,6 +134,7 @@ CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/vining_2000_defconfig b/configs/vining_2000_defconfig index b007a7603581..0eefc76dd27b 100644 --- a/configs/vining_2000_defconfig +++ b/configs/vining_2000_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6sx-softing-vining-2000" +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y diff --git a/configs/vme8349_defconfig b/configs/vme8349_defconfig index f6b9eb6c2c24..8533c4da94d3 100644 --- a/configs/vme8349_defconfig +++ b/configs/vme8349_defconfig @@ -108,6 +108,7 @@ CONFIG_CMD_TSI148=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/wb45n_defconfig b/configs/wb45n_defconfig index 0f22a1ee42a3..5d783d24b176 100644 --- a/configs/wb45n_defconfig +++ b/configs/wb45n_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y diff --git a/configs/wb50n_defconfig b/configs/wb50n_defconfig index 3e7f03a86773..b976d3571d4c 100644 --- a/configs/wb50n_defconfig +++ b/configs/wb50n_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig index 73b76aa65bb2..40cd074e3c05 100644 --- a/configs/woodburn_defconfig +++ b/configs/woodburn_defconfig @@ -27,6 +27,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=mxc_nand:50m(root1),32m(rootfb),64m(pcache),64 CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_MXC_GPIO=y CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index b26b084d2226..c4826f4f01c5 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -39,6 +39,7 @@ CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_MXC_GPIO=y CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index a5d76e819400..1196b7806c67 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y # CONFIG_MMC is not set CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/x600_defconfig b/configs/x600_defconfig index 62ca1d64ac8d..c7c9dc4d2cc5 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -44,6 +44,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:64M(ubi0),64M(ubi1)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_SPARTAN3=y diff --git a/env/Kconfig b/env/Kconfig index bc03816bc8b3..090cc795f91b 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -393,6 +393,16 @@ config ENV_IS_IN_UBI the environment in. This will enable redundant environments in UBI. It is assumed that both volumes are in the same MTD partition.
+config SYS_REDUNDAND_ENVIRONMENT + bool "Enable redundant environment support" + depends on ENV_IS_IN_EEPROM || ENV_IS_IN_FLASH || ENV_IS_IN_MMC || \ + ENV_IS_IN_NAND || ENV_IS_IN_SPI_FLASH || ENV_IS_IN_UBI + help + Normally, the environemt is stored in a single location. By + selecting this option, you can then define where to hold a redundant + copy of the environment data, so that there is a valid backup copy in + case there is a power failure during a "saveenv" operation. + config ENV_FAT_INTERFACE string "Name of the block device for the environment" depends on ENV_IS_IN_FAT @@ -512,16 +522,10 @@ config ENV_UBI_VOLUME
config ENV_UBI_VOLUME_REDUND string "UBI redundant volume name" - depends on ENV_IS_IN_UBI + depends on ENV_IS_IN_UBI && SYS_REDUNDAND_ENVIRONMENT help Name of the redundant volume that you want to store the environment in.
-config ENV_UBI_IS_VOLUME_REDUND - bool - depends on ENV_IS_IN_UBI - default y if ENV_UBI_VOLUME_REDUND != "" - default n - config ENV_UBI_VID_OFFSET int "ubi environment VID offset" depends on ENV_IS_IN_UBI diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 6a01a904254f..40080f512b53 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -120,8 +120,6 @@ #define CONFIG_NETMASK 255.255.255.0 #define CONFIG_ETHPRIME "eTSEC1"
-#undef CONFIG_SYS_REDUNDAND_ENVIRONMENT - #define CONFIG_SYS_L2_SIZE (256 << 10)
#endif diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index be571066f282..15cda803cc2b 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -275,7 +275,6 @@ #if defined(CONFIG_SPI_BOOT) /* SPL related */
-#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ #define CONFIG_ENV_OFFSET (768 << 10) /* 768 KiB in */ #define CONFIG_ENV_OFFSET_REDUND (896 << 10) /* 896 KiB in */ @@ -284,7 +283,6 @@ #define CONFIG_SYS_MMC_ENV_PART 0 #define CONFIG_ENV_OFFSET 0x260000 #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_SYS_MMC_MAX_DEVICE 2 #elif defined(CONFIG_NOR_BOOT) #define CONFIG_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ diff --git a/include/configs/am335x_sl50.h b/include/configs/am335x_sl50.h index a08e6bfe083a..7bb2bff5d18e 100644 --- a/include/configs/am335x_sl50.h +++ b/include/configs/am335x_sl50.h @@ -80,7 +80,6 @@ #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET 0x0 #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #endif
/* Network. */ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index d355b80c2f57..9db006880b88 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -109,7 +109,6 @@ #endif
#ifdef CONFIG_QSPI_BOOT -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_OFFSET_REDUND 0x120000 #endif
diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index 531f79ee702c..baeca5417d22 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -20,7 +20,6 @@ #define CONFIG_SYS_MMC_ENV_DEV 1 /* eMMC */ #define CONFIG_SYS_MMC_ENV_PART 0 #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT
#define CONFIG_SYS_BOOTM_LEN SZ_64M
diff --git a/include/configs/am65x_evm.h b/include/configs/am65x_evm.h index 1149d55937a2..9c06f10a2f18 100644 --- a/include/configs/am65x_evm.h +++ b/include/configs/am65x_evm.h @@ -121,7 +121,6 @@ #define CONFIG_ENV_SIZE (128 << 10) #define CONFIG_ENV_OFFSET 0x680000 #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #endif
#define CONFIG_SUPPORT_EMMC_BOOT diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index b451c7e7dccb..041abb5ac1f6 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -147,7 +147,6 @@
/* Environment organization */ #define CONFIG_ENV_SIZE (12 * 1024) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SECT_SIZE (0x010000) #define CONFIG_ENV_OFFSET (0x0d0000) #define CONFIG_ENV_OFFSET_REDUND (0x0e0000) diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index db21a473f143..4ecf8de33344 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -444,7 +444,6 @@ DEFAULT_LINUX_BOOT_ENV \ #if defined(CONFIG_SPI_BOOT) /* SPL related */
-#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ #define CONFIG_ENV_OFFSET (768 << 10) /* 768 KiB in */ #define CONFIG_ENV_OFFSET_REDUND (896 << 10) /* 896 KiB in */ @@ -453,7 +452,6 @@ DEFAULT_LINUX_BOOT_ENV \ #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET 0x0 #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #endif
/* SPI flash. */ diff --git a/include/configs/bcmstb.h b/include/configs/bcmstb.h index b8437052a926..2feabdd6c6df 100644 --- a/include/configs/bcmstb.h +++ b/include/configs/bcmstb.h @@ -149,7 +149,6 @@ extern phys_addr_t prior_stage_fdt_address; /* * Environment configuration. */ -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SIZE (64 << 10) /* 64 KiB */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index bc0dabb51b53..c9c28bef0421 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -182,7 +182,6 @@ NANDTGTS \ #if defined(CONFIG_SPI) /* SPI Flash */ /* Environment */ -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SECT_SIZE) #elif defined(CONFIG_ENV_IS_IN_MMC) @@ -190,7 +189,6 @@ NANDTGTS \ #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET 0x40000 /* TODO: Adresse definieren */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT
#elif defined(CONFIG_ENV_IS_IN_NAND) /* No NAND env support in SPL */ diff --git a/include/configs/brsmarc1.h b/include/configs/brsmarc1.h index 19e796edb12d..47d7a8772899 100644 --- a/include/configs/brsmarc1.h +++ b/include/configs/brsmarc1.h @@ -69,7 +69,6 @@ BUR_COMMON_ENV \ /* SPI Flash */
diff --git a/include/configs/brxre1.h b/include/configs/brxre1.h index c6e308b04d05..30bd8cb3837b 100644 --- a/include/configs/brxre1.h +++ b/include/configs/brxre1.h @@ -69,6 +69,5 @@ BUR_COMMON_ENV \ #define CONFIG_ENV_SIZE 0x10000 #define CONFIG_ENV_OFFSET 0x40000 /* TODO: Adresse definieren */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT
#endif /* __CONFIG_BRXRE1_H__ */ diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index 13c15bd79f5a..8141aece410d 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -166,7 +166,6 @@ #else #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #endif
/* Network. */ diff --git a/include/configs/cm_t54.h b/include/configs/cm_t54.h index 2387f864e32b..7368fd85bb0a 100644 --- a/include/configs/cm_t54.h +++ b/include/configs/cm_t54.h @@ -37,7 +37,6 @@ #define CONFIG_ENV_OFFSET 0xc0000 /* (in bytes) 768 KB */ #define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT
/* Enhance our eMMC support / experience. */ #define CONFIG_HSMMC2_8BIT diff --git a/include/configs/dart_6ul.h b/include/configs/dart_6ul.h index 4f99805ee263..801011cf7799 100644 --- a/include/configs/dart_6ul.h +++ b/include/configs/dart_6ul.h @@ -41,7 +41,6 @@ /* Environment settings */ #define CONFIG_ENV_SIZE SZ_8K #define CONFIG_ENV_OFFSET (14 * SZ_64K) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_OFFSET_REDUND \ (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index 86c119203528..d4bd88f5114b 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -138,7 +138,6 @@
/* Environment */ #define CONFIG_ENV_SIZE (16 * 1024) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT
#if defined(CONFIG_ENV_IS_IN_SPI_FLASH) #define CONFIG_ENV_OFFSET (1024 * 1024) diff --git a/include/configs/display5.h b/include/configs/display5.h index 65dae1f62fae..7b171489e381 100644 --- a/include/configs/display5.h +++ b/include/configs/display5.h @@ -352,7 +352,6 @@ /* The 0x120000 value corresponds to above SPI-NOR memory MAP */ #define CONFIG_ENV_OFFSET (0x120000) #define CONFIG_ENV_SECT_SIZE (SZ_64K) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 3487b8ac1b30..0ad23ce4b943 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -22,7 +22,6 @@ /* MMC ENV related defines */ #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #endif
#if (CONFIG_CONS_INDEX == 1) @@ -84,7 +83,6 @@ #define CONFIG_SYS_SPI_ARGS_OFFS 0x140000 #define CONFIG_SYS_SPI_ARGS_SIZE 0x80000 #if defined(CONFIG_QSPI_BOOT) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SIZE (64 << 10) #define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64 KB sectors */ #define CONFIG_ENV_OFFSET 0x1C0000 diff --git a/include/configs/gardena-smart-gateway-mt7688.h b/include/configs/gardena-smart-gateway-mt7688.h index e83a96ad5e1f..94c5b8daf349 100644 --- a/include/configs/gardena-smart-gateway-mt7688.h +++ b/include/configs/gardena-smart-gateway-mt7688.h @@ -41,7 +41,6 @@ #define CONFIG_ENV_OFFSET 0xa0000 #define CONFIG_ENV_SIZE (64 << 10) #define CONFIG_ENV_SECT_SIZE (64 << 10) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 829a5c782557..64c968b63ba4 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -158,8 +158,6 @@ int get_scl(void); #define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) #endif
-#define CONFIG_SYS_REDUNDAND_ENVIRONMENT - #define KM_FLASH_GPIO_PIN 16
#define CONFIG_KM_UPDATE_UBOOT \ diff --git a/include/configs/kmp204x.h b/include/configs/kmp204x.h index 75480a8a584e..f83b98c879b6 100644 --- a/include/configs/kmp204x.h +++ b/include/configs/kmp204x.h @@ -56,8 +56,6 @@ #define CONFIG_ENV_OFFSET_REDUND 0x110000 #define CONFIG_ENV_TOTAL_SIZE 0x020000
-#define CONFIG_SYS_REDUNDAND_ENVIRONMENT - #ifndef __ASSEMBLY__ unsigned long get_board_sys_clk(unsigned long dummy); #endif diff --git a/include/configs/kp_imx53.h b/include/configs/kp_imx53.h index 55bfa0fe591f..ff564b27ec83 100644 --- a/include/configs/kp_imx53.h +++ b/include/configs/kp_imx53.h @@ -99,7 +99,6 @@ /* environment organization */ #define CONFIG_ENV_OFFSET (SZ_1M) #define CONFIG_ENV_SIZE (SZ_8K) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 0 diff --git a/include/configs/kp_imx6q_tpc.h b/include/configs/kp_imx6q_tpc.h index f6746a93ca25..fc3896e7d10f 100644 --- a/include/configs/kp_imx6q_tpc.h +++ b/include/configs/kp_imx6q_tpc.h @@ -129,6 +129,5 @@ #define CONFIG_ENV_SIZE (SZ_8K) #define CONFIG_ENV_OFFSET 0x100000 #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT
#endif /* __KP_IMX6Q_TPC_IMX6_CONFIG_H_ */ diff --git a/include/configs/mccmon6.h b/include/configs/mccmon6.h index c685de65516e..c75519c1958f 100644 --- a/include/configs/mccmon6.h +++ b/include/configs/mccmon6.h @@ -251,7 +251,6 @@ #define CONFIG_ENV_SECT_SIZE (SZ_128K) #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x40000)
-#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_ADDR_REDUND (CONFIG_SYS_FLASH_BASE + 0x60000) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index dd045804ae1b..2fad2c7a8492 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -44,7 +44,6 @@
/* Environment is in SPI flash */ #if defined(CONFIG_CMD_SF) && defined(CONFIG_ENV_IS_IN_SPI_FLASH) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_OFFSET 0x40000 /* 256K */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #define CONFIG_ENV_SECT_SIZE 0x1000 diff --git a/include/configs/omap5_uevm.h b/include/configs/omap5_uevm.h index 3710a71ae94e..ff811569b99c 100644 --- a/include/configs/omap5_uevm.h +++ b/include/configs/omap5_uevm.h @@ -33,7 +33,6 @@ /* MMC ENV related defines */ #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT
/* Enhance our eMMC support / experience. */ #define CONFIG_HSMMC2_8BIT diff --git a/include/configs/pcl063_ull.h b/include/configs/pcl063_ull.h index 650caaa573e2..23e491236cb4 100644 --- a/include/configs/pcl063_ull.h +++ b/include/configs/pcl063_ull.h @@ -23,7 +23,6 @@ /* Environment settings */ #define CONFIG_ENV_SIZE (0x4000) #define CONFIG_ENV_OFFSET (0x80000) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_OFFSET_REDUND \ (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
diff --git a/include/configs/pcm058.h b/include/configs/pcm058.h index 855bc445fe1e..b9f5ad326082 100644 --- a/include/configs/pcm058.h +++ b/include/configs/pcm058.h @@ -76,7 +76,6 @@ #define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_OFFSET (1024 * SZ_1K) #define CONFIG_ENV_SECT_SIZE (64 * SZ_1K) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE diff --git a/include/configs/pfla02.h b/include/configs/pfla02.h index c21b993a62bb..9a169351a3a0 100644 --- a/include/configs/pfla02.h +++ b/include/configs/pfla02.h @@ -77,7 +77,6 @@ #define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_OFFSET (1024 * SZ_1K) #define CONFIG_ENV_SECT_SIZE (64 * SZ_1K) -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE diff --git a/include/configs/sksimx6.h b/include/configs/sksimx6.h index 4f7ec2d7e99c..e1a7d724c161 100644 --- a/include/configs/sksimx6.h +++ b/include/configs/sksimx6.h @@ -56,7 +56,6 @@ #define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SIZE) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index 3a8ccc302169..e1a48715fb0d 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -28,7 +28,6 @@ #define CONFIG_SYS_BOOTCOUNT_BE
/* Environment setting for SPI flash */ -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_OFFSET 0x000e0000 diff --git a/include/configs/socfpga_vining_fpga.h b/include/configs/socfpga_vining_fpga.h index debf3ea94bcd..abde883487e8 100644 --- a/include/configs/socfpga_vining_fpga.h +++ b/include/configs/socfpga_vining_fpga.h @@ -195,7 +195,6 @@ "fi\0" \ "socfpga_legacy_reset_compat=1\0"
-#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_OFFSET 0x100000 diff --git a/include/configs/theadorable-x86-common.h b/include/configs/theadorable-x86-common.h index 0c563e714ddd..2d7be7d5b96e 100644 --- a/include/configs/theadorable-x86-common.h +++ b/include/configs/theadorable-x86-common.h @@ -23,7 +23,6 @@ #define CONFIG_BMP_16BPP
/* Environment settings */ -#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #undef CONFIG_ENV_SIZE #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x1000 diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index 13e3d60bfe7b..3c1d629d251f 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -148,7 +148,6 @@ #define TQMA6_UBOOT_SIZE (TQMA6_UBOOT_SECTOR_SIZE * \ TQMA6_UBOOT_SECTOR_COUNT)
-#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_OFFSET (TQMA6_UBOOT_SIZE) #define CONFIG_ENV_SECT_SIZE TQMA6_SPI_FLASH_SECTOR_SIZE #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ diff --git a/include/configs/vcoreiii.h b/include/configs/vcoreiii.h index 8c68372026e9..7ed952435937 100644 --- a/include/configs/vcoreiii.h +++ b/include/configs/vcoreiii.h @@ -30,7 +30,6 @@ #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_ENV_SECT_SIZE (256 * 1024)
-#define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SECT_SIZE)
diff --git a/include/env_internal.h b/include/env_internal.h index 88c36b32a1e5..d520e6a55b5c 100644 --- a/include/env_internal.h +++ b/include/env_internal.h @@ -58,21 +58,12 @@ (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) # define ENV_IS_EMBEDDED # endif -# if defined(CONFIG_ENV_ADDR_REDUND) || defined(CONFIG_ENV_OFFSET_REDUND) -# define CONFIG_SYS_REDUNDAND_ENVIRONMENT -# endif # ifdef CONFIG_ENV_IS_EMBEDDED # error "do not define CONFIG_ENV_IS_EMBEDDED in your board config" # error "it is calculated automatically for you" # endif #endif /* CONFIG_ENV_IS_IN_FLASH */
-#if defined(CONFIG_ENV_IS_IN_MMC) -# ifdef CONFIG_ENV_OFFSET_REDUND -# define CONFIG_SYS_REDUNDAND_ENVIRONMENT -# endif -#endif - #if defined(CONFIG_ENV_IS_IN_NAND) # if defined(CONFIG_ENV_OFFSET_OOB) # ifdef CONFIG_ENV_OFFSET_REDUND @@ -85,9 +76,6 @@ extern unsigned long nand_env_oob_offset; # ifndef CONFIG_ENV_OFFSET # error "Need to define CONFIG_ENV_OFFSET when using CONFIG_ENV_IS_IN_NAND" # endif -# ifdef CONFIG_ENV_OFFSET_REDUND -# define CONFIG_SYS_REDUNDAND_ENVIRONMENT -# endif # endif /* CONFIG_ENV_OFFSET_OOB */ # ifndef CONFIG_ENV_SIZE # error "Need to define CONFIG_ENV_SIZE when using CONFIG_ENV_IS_IN_NAND" @@ -101,9 +89,6 @@ extern unsigned long nand_env_oob_offset; # ifndef CONFIG_ENV_UBI_VOLUME # error "Need to define CONFIG_ENV_UBI_VOLUME when using CONFIG_ENV_IS_IN_UBI" # endif -# if defined(CONFIG_ENV_UBI_IS_VOLUME_REDUND) -# define CONFIG_SYS_REDUNDAND_ENVIRONMENT -# endif # ifndef CONFIG_ENV_SIZE # error "Need to define CONFIG_ENV_SIZE when using CONFIG_ENV_IS_IN_UBI" # endif diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index bbc1cb1033c9..b680c554c15a 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -3756,7 +3756,6 @@ CONFIG_SYS_RCAR_I2C2_BASE CONFIG_SYS_RCAR_I2C3_BASE CONFIG_SYS_RCWH_PCIHOST CONFIG_SYS_READ_SPD -CONFIG_SYS_REDUNDAND_ENVIRONMENT CONFIG_SYS_RESET_ADDR CONFIG_SYS_RESET_ADDRESS CONFIG_SYS_RESET_SCTRL diff --git a/tools/envcrc.c b/tools/envcrc.c index 672ef4d675e7..95776828289e 100644 --- a/tools/envcrc.c +++ b/tools/envcrc.c @@ -40,9 +40,6 @@ ((CONFIG_ENV_ADDR + CONFIG_ENV_SIZE) <= (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN)) # define ENV_IS_EMBEDDED # endif -# if defined(CONFIG_ENV_ADDR_REDUND) || defined(CONFIG_ENV_OFFSET_REDUND) -# define CONFIG_SYS_REDUNDAND_ENVIRONMENT -# endif #endif /* CONFIG_ENV_IS_IN_FLASH */
#if defined(ENV_IS_EMBEDDED) && !defined(CONFIG_BUILD_ENVCRC)
On Sun, Nov 10, 2019 at 09:19:10PM -0500, Tom Rini wrote:
Move this symbol to Kconfig. As part of this we can drop a UBI-specific symbol that was a stop-gap for not having this particular symbol in Kconfig.
Signed-off-by: Tom Rini trini@konsulko.com
On Sun, Nov 10, 2019 at 09:19:08PM -0500, Tom Rini wrote:
This board is setting CONFIG_ENV_IS_IN_MMC in the header rather than defconfig, fix.
Cc: Kever Yang kever.yang@rock-chips.com Signed-off-by: Tom Rini trini@konsulko.com
