[U-Boot] [PATCH] spi: kirkwood_spi: Add support for multiple chip-selects on MVEBU
Currently only chip-select 0 is supported by the kirkwood SPI driver. The Armada XP / 38x SoCs also use this driver and support multiple chip selects. This patch adds support for multiple CS on MVEBU.
The register definitions are restructured a bit with this patch. Grouping them to the corresponding registers.
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr Cc: Jagan Teki jteki@openedev.com --- arch/arm/include/asm/arch-mvebu/spi.h | 17 ++++++++++++----- drivers/spi/kirkwood_spi.c | 6 ++++++ 2 files changed, 18 insertions(+), 5 deletions(-)
diff --git a/arch/arm/include/asm/arch-mvebu/spi.h b/arch/arm/include/asm/arch-mvebu/spi.h index e512dce..4b66499 100644 --- a/arch/arm/include/asm/arch-mvebu/spi.h +++ b/arch/arm/include/asm/arch-mvebu/spi.h @@ -32,13 +32,15 @@ struct kwspi_registers { #define SCK_MPP10 (1 << 1) #define MISO_MPP11 (1 << 2)
+/* Control Register */ +#define KWSPI_CSN_ACT (1 << 0) /* Activates serial memory interface */ +#define KWSPI_SMEMRDY (1 << 1) /* SerMem Data xfer ready */ +#define KWSPI_CS_SHIFT 2 /* chip select shift */ +#define KWSPI_CS_MASK 0x7 /* chip select mask */ + +/* Configuration Register */ #define KWSPI_CLKPRESCL_MASK 0x1f #define KWSPI_CLKPRESCL_MIN 0x12 -#define KWSPI_CSN_ACT 1 /* Activates serial memory interface */ -#define KWSPI_SMEMRDY (1 << 1) /* SerMem Data xfer ready */ -#define KWSPI_IRQUNMASK 1 /* unmask SPI interrupt */ -#define KWSPI_IRQMASK 0 /* mask SPI interrupt */ -#define KWSPI_SMEMRDIRQ 1 /* SerMem data xfer ready irq */ #define KWSPI_XFERLEN_1BYTE 0 #define KWSPI_XFERLEN_2BYTE (1 << 5) #define KWSPI_XFERLEN_MASK (1 << 5) @@ -47,6 +49,11 @@ struct kwspi_registers { #define KWSPI_ADRLEN_3BYTE (2 << 8) #define KWSPI_ADRLEN_4BYTE (3 << 8) #define KWSPI_ADRLEN_MASK (3 << 8) + +#define KWSPI_IRQUNMASK 1 /* unmask SPI interrupt */ +#define KWSPI_IRQMASK 0 /* mask SPI interrupt */ +#define KWSPI_SMEMRDIRQ 1 /* SerMem data xfer ready irq */ + #define KWSPI_TIMEOUT 10000
#endif /* __KW_SPI_H__ */ diff --git a/drivers/spi/kirkwood_spi.c b/drivers/spi/kirkwood_spi.c index 7890796..fa30be4 100644 --- a/drivers/spi/kirkwood_spi.c +++ b/drivers/spi/kirkwood_spi.c @@ -280,6 +280,12 @@ static int mvebu_spi_xfer(struct udevice *dev, unsigned int bitlen, struct udevice *bus = dev->parent; struct mvebu_spi_platdata *plat = dev_get_platdata(bus);
+#ifdef CONFIG_ARCH_MVEBU + clrsetbits_le32(&plat->spireg->ctrl, + KWSPI_CS_MASK << KWSPI_CS_SHIFT, + spi_chip_select(dev) << KWSPI_CS_SHIFT); +#endif + return _spi_xfer(plat->spireg, bitlen, dout, din, flags); }
Hi Stefan,
This looks clearing a desired cs from 'sf probe' why is this need here? I think we can do the desired cs activate or deactivate through existing spi_cs_activate/deactivate functions itself.
thanks!
Hi Jagan,
please excuse the long delay here. Some comments below.
Its not clearing a CS but configuring the CS number in the CTRL register. This configured CS number will get enabled or disabled exactly the same way as when its zero (without this patch) in the existing spi_cs_activate/deactivate functions
This is exactly what this patch does. The CS number is configured with the clrsetbits_le32() call above. And activated / deactivated in the existing functions.
Or do you mean something else?
Thanks, Stefan
Hi Jagan,
On 23.03.2016 15:36, Stefan Roese wrote:
Hi Jagan,
Any updates on this? I would like to have this multiple CS support added in this release. I can push it via the marvell git repository if you have no objections.
Thanks, Stefan
Hi Stefan,
On 5 April 2016 at 11:32, Stefan Roese sr@denx.de wrote:
Hi Jagan,
Hi Jagan,
OK, if ie the case configure doesn't require for each spi_xfer, isn't it? may be we can put this on to probe or setup_slave area?
thanks!
Hi Jagan,
Hi Jagan,
Hi Jagan,
Correct.
AFAIK, probe() is only called once per SPI controller. Without any device (chip-select) to use. We need a function that's called per SPI device for this specific chip-select configuration. Checking a bit further, I could use claim_bus() for this. If you are okay, I'll send a v2, using clain_bus() for this CS configuration.
Okay?
Thanks, Stefan
Jagan Teki
Jagan Teki
Stefan Roese
