[U-Boot] [PATCH 1/1] efi_loader: documentation of image loader
- Add missing function descriptions. - Update existing function descriptions to match Sphinx style. - Add lib/efi_loader/efi_image_loader.c to the input files for Sphinx generated documentation.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- Documentation/efi.rst | 6 ++++++ lib/efi_loader/efi_image_loader.c | 28 +++++++++++++++++++--------- 2 files changed, 25 insertions(+), 9 deletions(-)
diff --git a/Documentation/efi.rst b/Documentation/efi.rst index 51c1de24f8..5337a55c3b 100644 --- a/Documentation/efi.rst +++ b/Documentation/efi.rst @@ -9,6 +9,12 @@ Boot services .. kernel-doc:: lib/efi_loader/efi_boottime.c :internal:
+Image relocation +~~~~~~~~~~~~~~~~ + +.. kernel-doc:: lib/efi_loader/efi_image_loader.c + :internal: + Runtime services ----------------
diff --git a/lib/efi_loader/efi_image_loader.c b/lib/efi_loader/efi_image_loader.c index b55c2840e8..cec17eabaa 100644 --- a/lib/efi_loader/efi_image_loader.c +++ b/lib/efi_loader/efi_image_loader.c @@ -42,8 +42,8 @@ static int machines[] = { #endif 0 };
-/* - * Print information about a loaded image. +/** + * efi_print_image_info() - print information about a loaded image * * If the program counter is located within the image the offset to the base * address is shown. @@ -51,7 +51,7 @@ static int machines[] = { * @obj: EFI object * @image: loaded image * @pc: program counter (use NULL to suppress offset output) - * @return: status code + * Return: status code */ static efi_status_t efi_print_image_info(struct efi_loaded_image_obj *obj, struct efi_loaded_image *image, @@ -69,8 +69,8 @@ static efi_status_t efi_print_image_info(struct efi_loaded_image_obj *obj, return EFI_SUCCESS; }
-/* - * Print information about all loaded images. +/** + * efi_print_image_infos() - print information about all loaded images * * @pc: program counter (use NULL to suppress offset output) */ @@ -90,6 +90,15 @@ void efi_print_image_infos(void *pc) } }
+/** + * efi_loader_relocate() - relocate UEFI binary + * + * @rel: pointer to the relocation table + * @rel_size: size of the relocation table in bytes + * @efi_reloc: actual load address of the image + * @pref_address: preferred load address of the image + * Return: status code + */ static efi_status_t efi_loader_relocate(const IMAGE_BASE_RELOCATION *rel, unsigned long rel_size, void *efi_reloc, unsigned long pref_address) @@ -159,11 +168,12 @@ void __weak invalidate_icache_all(void) /* If the system doesn't support icache_all flush, cross our fingers */ }
-/* - * Determine the memory types to be used for code and data. +/** + * efi_set_code_and_data_type() - determine the memory types to be used for code + * and data. * - * @loaded_image_info image descriptor - * @image_type field Subsystem of the optional header for + * @loaded_image_info: image descriptor + * @image_type: field Subsystem of the optional header for * Windows specific field */ static void efi_set_code_and_data_type(
