[U-Boot-Users] [PATCH] (Resubmit) Added support toflash_real_protect for Atmel flash devices (tested with AT49BV6416)
Some of the flash memories produced by ATMEL start in read-only mode. We need to unprotect it. This patch allows the AT49BV6416 to work with cfi_flash memories. Tested in the at91rm9200ek board.
Signed-off-by: Rafael Campos Las Heras rafael.campos@hanscan.com --- drivers/mtd/cfi_flash.c | 40 ++++++++++++++++++++++++++++++++++------ 1 files changed, 34 insertions(+), 6 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 4340b1b..8d12eb8 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -103,6 +103,10 @@ #define AMD_STATUS_TOGGLE 0x40 #define AMD_STATUS_ERROR 0x20
+#define ATM_CMD_UNLOCK_SECT 0x70 +#define ATM_CMD_SOFTLOCK_START 0x80 +#define ATM_CMD_LOCK_SECT 0x40 + #define FLASH_OFFSET_MANUFACTURER_ID 0x00 #define FLASH_OFFSET_DEVICE_ID 0x01 #define FLASH_OFFSET_DEVICE_ID2 0x0E @@ -1348,12 +1352,36 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) { int retcode = 0;
- flash_write_cmd (info, sector, 0, FLASH_CMD_CLEAR_STATUS); - flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT); - if (prot) - flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT_SET); - else - flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT_CLEAR); + switch (info->vendor) { + case CFI_CMDSET_INTEL_PROG_REGIONS: + case CFI_CMDSET_INTEL_STANDARD: + flash_write_cmd (info, sector, 0, FLASH_CMD_CLEAR_STATUS); + flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT); + if (prot) + flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT_SET); + else + flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT_CLEAR); + break; + case CFI_CMDSET_AMD_EXTENDED: + case CFI_CMDSET_AMD_STANDARD: +#ifdef CONFIG_FLASH_CFI_LEGACY + case CFI_CMDSET_AMD_LEGACY: +#endif + /* U-Boot only checks the first byte */ + if (info->manufacturer_id == (uchar)ATM_MANUFACT ) { + if (prot) { + flash_unlock_seq(info, 0); + flash_write_cmd (info, 0, info->addr_unlock1, ATM_CMD_SOFTLOCK_START); + flash_unlock_seq(info, 0); + flash_write_cmd (info, sector, 0, ATM_CMD_LOCK_SECT); + } else { + flash_write_cmd (info, 0, info->addr_unlock1, AMD_CMD_UNLOCK_START); + if (info->device_id == ATM_ID_BV6416) + flash_write_cmd (info, sector, 0, ATM_CMD_UNLOCK_SECT); + } + } + break; + }
if ((retcode = flash_full_status_check (info, sector, info->erase_blk_tout,
else
Patch is line wrapped and cannot be applied.
------_=_NextPart_001_01C8ED81.9A3C1059 Content-Type: text/html; charset="iso-8859-1" Content-Transfer-Encoding: quoted-printable
And *STOP* posting HTML!!!!
Rafael Campos - Hanscan Spain
