[PATCH 00/13] Qualcomm platform USB support
This series enables USB on Qualcomm SDM845 platforms and lays the foundation for future SoCs as well.
It introduces two new high-speed PHY drivers, one for SDM845 and one for an upcoming platform. The SDM845 clock driver gains support for configuring the USB clocks, and the GPIO driver is updated to use .set_flags which fixes a strange bug where GPIOs would also be configured as input.
Support for super-speed USB modes is not currently available, however configuring the device to be high-speed only requires modifications to DT.
To improve compatibility with upstream DT, we switch Qualcomm platforms over to OF_LIVE and apply fixups to the tree to remove references to the super-speed phy, as well as configure the Qualcomm glue for high-speed only mode.
The db845c requires a vbus-supply to be hooked up for its usb type-A port. A U-Boot dtsi file is added to configure this.
With these patches, it is now also possible to run U-Boot on some SDM845 phones like the OnePlus 6 using a dtb from Linux, and access the U-Boot shell via the CDC ACM USB serial gadget.
This series depends on the ("Qualcomm generic board support") series [1] switching to upstream DT, as well as the ("Qualcomm DWC3 USB support") series [2]. A feature branch based on qcom-next with the necessary dependencies for testing the Dragonboard845c can be found at [3].
I think most of these can go through the Qualcomm tree, but I'm not exactly sure. I'd appreciate any suggestions on if/how to split this series up further.
[1]: https://lore.kernel.org/u-boot/20240130-b4-qcom-common-target-v3-0-e523cbf9e... [2]: https://lore.kernel.org/u-boot/20240131-b4-qcom-usb-v1-0-6438b2a2285e@linaro... [3]: https://git.codelinaro.org/linaro/qcomlt/u-boot/-/tree/b4/dwc3-qcom
--- Bhupesh Sharma (2): phy: qcom: add Qualcomm QUSB2 USB PHY driver phy: qcom: Add USB HS 7nm PHY driver
Caleb Connolly (11): mailmap: update Bhupesh's email address clk/qcom: use offsets for RCG registers clk/qcom: add gdsc_enable helper clk/qcom: sdm845: add USB clocks gpio: msm_gpio: add .set_flags op serial: msm-geni: support livetree mach-snapdragon: fixup USB nodes dts: sdm845-db845c: add u-boot fixups qcom_defconfig: regenerate with savedefconfig qcom_defconfig: enable livetree qcom_defconfig: enable USB
.mailmap | 1 + arch/arm/dts/sdm845-db845c-u-boot.dtsi | 8 + arch/arm/mach-snapdragon/board.c | 88 +++++++ configs/qcom_defconfig | 22 +- drivers/clk/qcom/clock-apq8016.c | 39 +-- drivers/clk/qcom/clock-apq8096.c | 28 +- drivers/clk/qcom/clock-qcom.c | 40 ++- drivers/clk/qcom/clock-qcom.h | 20 +- drivers/clk/qcom/clock-qcs404.c | 121 ++------- drivers/clk/qcom/clock-sdm845.c | 45 ++-- drivers/gpio/msm_gpio.c | 21 +- drivers/phy/qcom/Kconfig | 15 ++ drivers/phy/qcom/Makefile | 2 + drivers/phy/qcom/phy-qcom-qusb2.c | 468 +++++++++++++++++++++++++++++++++ drivers/phy/qcom/phy-qcom-usb-hs-7nm.c | 295 +++++++++++++++++++++ drivers/serial/serial_msm_geni.c | 13 + 16 files changed, 1017 insertions(+), 209 deletions(-) --- base-commit: b5195aca8b5b30071fda8e60bb56013032e06d18
// Caleb (they/them)
Update Bhupesh's email to his new one.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org ---
Cc: Bhupesh Sharma bhupesh.linux@gmail.com --- .mailmap | 1 + 1 file changed, 1 insertion(+)
diff --git a/.mailmap b/.mailmap index d1f08f3eca8a..f6e0847b2168 100644 --- a/.mailmap +++ b/.mailmap @@ -30,6 +30,7 @@ Atish Patra atishp@atishpatra.org atish.patra@wdc.com Bharat Kumar Gogada bharat.kumar.gogada@amd.com bharat.kumar.gogada@xilinx.com Bharat Kumar Gogada bharat.kumar.gogada@amd.com bharatku@xilinx.com Bhargava Sreekantappa Gayathri bhargava.sreekantappa-gayathri@amd.com bhargava.sreekantappa-gayathri@xilinx.com +Bhupesh Sharma bhupesh.linux@gmail.com bhupesh.sharma@linaro.org Bin Meng bmeng.cn@gmail.com bin.meng@windriver.com Boris Brezillon bbrezillon@kernel.org boris.brezillon@bootlin.com Boris Brezillon bbrezillon@kernel.org boris.brezillon@free-electrons.com
The Snapdragon 845 and several other Qualcomm SoCs feature this USB high-speed phy. Add a driver for it based on the Linux driver, with support for the SDM845, and the QCM2290 and SM6115 SoCs which will gain support in U-Boot in future patches.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org [code cleanup, switch to clk_bulk] Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/phy/qcom/Kconfig | 7 + drivers/phy/qcom/Makefile | 1 + drivers/phy/qcom/phy-qcom-qusb2.c | 468 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 476 insertions(+)
diff --git a/drivers/phy/qcom/Kconfig b/drivers/phy/qcom/Kconfig index f4ca174805a4..361dfb6e1126 100644 --- a/drivers/phy/qcom/Kconfig +++ b/drivers/phy/qcom/Kconfig @@ -12,6 +12,13 @@ config PHY_QCOM_IPQ4019_USB help Support for the USB PHY-s on Qualcomm IPQ40xx SoC-s.
+config PHY_QCOM_QUSB2 + tristate "Qualcomm USB QUSB2 PHY driver" + depends on PHY && ARCH_SNAPDRAGON + help + Enable this to support the Super-Speed USB transceiver on various + Qualcomm chipsets. + config PHY_QCOM_USB_HS_28NM tristate "Qualcomm 28nm High-Speed PHY" depends on PHY && ARCH_SNAPDRAGON diff --git a/drivers/phy/qcom/Makefile b/drivers/phy/qcom/Makefile index 2113f178c0c7..f6af985666a4 100644 --- a/drivers/phy/qcom/Makefile +++ b/drivers/phy/qcom/Makefile @@ -1,4 +1,5 @@ obj-$(CONFIG_PHY_QCOM_IPQ4019_USB) += phy-qcom-ipq4019-usb.o obj-$(CONFIG_MSM8916_USB_PHY) += msm8916-usbh-phy.o +obj-$(CONFIG_PHY_QCOM_QUSB2) += phy-qcom-qusb2.o obj-$(CONFIG_PHY_QCOM_USB_HS_28NM) += phy-qcom-usb-hs-28nm.o obj-$(CONFIG_PHY_QCOM_USB_SS) += phy-qcom-usb-ss.o diff --git a/drivers/phy/qcom/phy-qcom-qusb2.c b/drivers/phy/qcom/phy-qcom-qusb2.c new file mode 100644 index 000000000000..5b654403a181 --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qusb2.c @@ -0,0 +1,468 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023 Bhupesh Sharma bhupesh.sharma@linaro.org + * + * Based on Linux driver + */ + +#include <dm.h> +#include <generic-phy.h> +#include <linux/bitops.h> +#include <asm/io.h> +#include <reset.h> +#include <clk.h> +#include <linux/delay.h> + +#include <dt-bindings/phy/phy-qcom-qusb2.h> + +#define QUSB2PHY_PLL 0x0 +#define QUSB2PHY_PLL_TEST 0x04 +#define CLK_REF_SEL BIT(7) + +#define QUSB2PHY_PLL_TUNE 0x08 +#define QUSB2PHY_PLL_USER_CTL1 0x0c +#define QUSB2PHY_PLL_USER_CTL2 0x10 +#define QUSB2PHY_PLL_AUTOPGM_CTL1 0x1c +#define QUSB2PHY_PLL_PWR_CTRL 0x18 + +/* QUSB2PHY_PLL_STATUS register bits */ +#define PLL_LOCKED BIT(5) + +/* QUSB2PHY_PLL_COMMON_STATUS_ONE register bits */ +#define CORE_READY_STATUS BIT(0) + +/* QUSB2PHY_PORT_POWERDOWN register bits */ +#define CLAMP_N_EN BIT(5) +#define FREEZIO_N BIT(1) +#define POWER_DOWN BIT(0) + +/* QUSB2PHY_PWR_CTRL1 register bits */ +#define PWR_CTRL1_VREF_SUPPLY_TRIM BIT(5) +#define PWR_CTRL1_CLAMP_N_EN BIT(1) + +#define QUSB2PHY_REFCLK_ENABLE BIT(0) + +#define PHY_CLK_SCHEME_SEL BIT(0) + +/* QUSB2PHY_INTR_CTRL register bits */ +#define DMSE_INTR_HIGH_SEL BIT(4) +#define DPSE_INTR_HIGH_SEL BIT(3) +#define CHG_DET_INTR_EN BIT(2) +#define DMSE_INTR_EN BIT(1) +#define DPSE_INTR_EN BIT(0) + +/* QUSB2PHY_PLL_CORE_INPUT_OVERRIDE register bits */ +#define CORE_PLL_EN_FROM_RESET BIT(4) +#define CORE_RESET BIT(5) +#define CORE_RESET_MUX BIT(6) + +/* QUSB2PHY_IMP_CTRL1 register bits */ +#define IMP_RES_OFFSET_MASK GENMASK(5, 0) +#define IMP_RES_OFFSET_SHIFT 0x0 + +/* QUSB2PHY_PLL_BIAS_CONTROL_2 register bits */ +#define BIAS_CTRL2_RES_OFFSET_MASK GENMASK(5, 0) +#define BIAS_CTRL2_RES_OFFSET_SHIFT 0x0 + +/* QUSB2PHY_CHG_CONTROL_2 register bits */ +#define CHG_CTRL2_OFFSET_MASK GENMASK(5, 4) +#define CHG_CTRL2_OFFSET_SHIFT 0x4 + +/* QUSB2PHY_PORT_TUNE1 register bits */ +#define HSTX_TRIM_MASK GENMASK(7, 4) +#define HSTX_TRIM_SHIFT 0x4 +#define PREEMPH_WIDTH_HALF_BIT BIT(2) +#define PREEMPHASIS_EN_MASK GENMASK(1, 0) +#define PREEMPHASIS_EN_SHIFT 0x0 + +/* QUSB2PHY_PORT_TUNE2 register bits */ +#define HSDISC_TRIM_MASK GENMASK(1, 0) +#define HSDISC_TRIM_SHIFT 0x0 + +#define QUSB2PHY_PLL_ANALOG_CONTROLS_TWO 0x04 +#define QUSB2PHY_PLL_CLOCK_INVERTERS 0x18c +#define QUSB2PHY_PLL_CMODE 0x2c +#define QUSB2PHY_PLL_LOCK_DELAY 0x184 +#define QUSB2PHY_PLL_DIGITAL_TIMERS_TWO 0xb4 +#define QUSB2PHY_PLL_BIAS_CONTROL_1 0x194 +#define QUSB2PHY_PLL_BIAS_CONTROL_2 0x198 +#define QUSB2PHY_PWR_CTRL2 0x214 +#define QUSB2PHY_IMP_CTRL1 0x220 +#define QUSB2PHY_IMP_CTRL2 0x224 +#define QUSB2PHY_CHG_CTRL2 0x23c + +struct qusb2_phy_init_tbl { + unsigned int offset; + unsigned int val; + /* + * register part of layout ? + * if yes, then offset gives index in the reg-layout + */ + int in_layout; +}; + +struct qusb2_phy_cfg { + const struct qusb2_phy_init_tbl *tbl; + /* number of entries in the table */ + unsigned int tbl_num; + /* offset to PHY_CLK_SCHEME register in TCSR map */ + unsigned int clk_scheme_offset; + + /* array of registers with different offsets */ + const unsigned int *regs; + unsigned int mask_core_ready; + unsigned int disable_ctrl; + unsigned int autoresume_en; + + /* true if PHY has PLL_TEST register to select clk_scheme */ + bool has_pll_test; + + /* true if TUNE1 register must be updated by fused value, else TUNE2 */ + bool update_tune1_with_efuse; + + /* true if PHY has PLL_CORE_INPUT_OVERRIDE register to reset PLL */ + bool has_pll_override; +}; + +/* set of registers with offsets different per-PHY */ +enum qusb2phy_reg_layout { + QUSB2PHY_PLL_CORE_INPUT_OVERRIDE, + QUSB2PHY_PLL_STATUS, + QUSB2PHY_PORT_TUNE1, + QUSB2PHY_PORT_TUNE2, + QUSB2PHY_PORT_TUNE3, + QUSB2PHY_PORT_TUNE4, + QUSB2PHY_PORT_TUNE5, + QUSB2PHY_PORT_TEST1, + QUSB2PHY_PORT_TEST2, + QUSB2PHY_PORT_POWERDOWN, + QUSB2PHY_INTR_CTRL, +}; + +#define QUSB2_PHY_INIT_CFG(o, v) \ + { \ + .offset = o, .val = v, \ + } + +#define QUSB2_PHY_INIT_CFG_L(o, v) \ + { \ + .offset = o, .val = v, .in_layout = 1, \ + } + +static const struct qusb2_phy_init_tbl sm6115_init_tbl[] = { + QUSB2_PHY_INIT_CFG_L(QUSB2PHY_PORT_TUNE1, 0xf8), + QUSB2_PHY_INIT_CFG_L(QUSB2PHY_PORT_TUNE2, 0x53), + QUSB2_PHY_INIT_CFG_L(QUSB2PHY_PORT_TUNE3, 0x81), + QUSB2_PHY_INIT_CFG_L(QUSB2PHY_PORT_TUNE4, 0x17), + + QUSB2_PHY_INIT_CFG(QUSB2PHY_PLL_TUNE, 0x30), + QUSB2_PHY_INIT_CFG(QUSB2PHY_PLL_USER_CTL1, 0x79), + QUSB2_PHY_INIT_CFG(QUSB2PHY_PLL_USER_CTL2, 0x21), + + QUSB2_PHY_INIT_CFG_L(QUSB2PHY_PORT_TEST2, 0x14), + + QUSB2_PHY_INIT_CFG(QUSB2PHY_PLL_AUTOPGM_CTL1, 0x9f), + QUSB2_PHY_INIT_CFG(QUSB2PHY_PLL_PWR_CTRL, 0x00), +}; + +static const unsigned int sm6115_regs_layout[] = { + [QUSB2PHY_PLL_STATUS] = 0x38, [QUSB2PHY_PORT_TUNE1] = 0x80, + [QUSB2PHY_PORT_TUNE2] = 0x84, [QUSB2PHY_PORT_TUNE3] = 0x88, + [QUSB2PHY_PORT_TUNE4] = 0x8c, [QUSB2PHY_PORT_TUNE5] = 0x90, + [QUSB2PHY_PORT_TEST1] = 0xb8, [QUSB2PHY_PORT_TEST2] = 0x9c, + [QUSB2PHY_PORT_POWERDOWN] = 0xb4, [QUSB2PHY_INTR_CTRL] = 0xbc, +}; + +static const struct qusb2_phy_init_tbl qusb2_v2_init_tbl[] = { + QUSB2_PHY_INIT_CFG(QUSB2PHY_PLL_ANALOG_CONTROLS_TWO, 0x03), + QUSB2_PHY_INIT_CFG(QUSB2PHY_PLL_CLOCK_INVERTERS, 0x7c), + QUSB2_PHY_INIT_CFG(QUSB2PHY_PLL_CMODE, 0x80), + QUSB2_PHY_INIT_CFG(QUSB2PHY_PLL_LOCK_DELAY, 0x0a), + QUSB2_PHY_INIT_CFG(QUSB2PHY_PLL_DIGITAL_TIMERS_TWO, 0x19), + QUSB2_PHY_INIT_CFG(QUSB2PHY_PLL_BIAS_CONTROL_1, 0x40), + QUSB2_PHY_INIT_CFG(QUSB2PHY_PLL_BIAS_CONTROL_2, 0x20), + QUSB2_PHY_INIT_CFG(QUSB2PHY_PWR_CTRL2, 0x21), + QUSB2_PHY_INIT_CFG(QUSB2PHY_IMP_CTRL1, 0x0), + QUSB2_PHY_INIT_CFG(QUSB2PHY_IMP_CTRL2, 0x58), + + QUSB2_PHY_INIT_CFG_L(QUSB2PHY_PORT_TUNE1, 0x30), + QUSB2_PHY_INIT_CFG_L(QUSB2PHY_PORT_TUNE2, 0x29), + QUSB2_PHY_INIT_CFG_L(QUSB2PHY_PORT_TUNE3, 0xca), + QUSB2_PHY_INIT_CFG_L(QUSB2PHY_PORT_TUNE4, 0x04), + QUSB2_PHY_INIT_CFG_L(QUSB2PHY_PORT_TUNE5, 0x03), + + QUSB2_PHY_INIT_CFG(QUSB2PHY_CHG_CTRL2, 0x0), +}; + +static const unsigned int qusb2_v2_regs_layout[] = { + [QUSB2PHY_PLL_CORE_INPUT_OVERRIDE] = 0xa8, + [QUSB2PHY_PLL_STATUS] = 0x1a0, + [QUSB2PHY_PORT_TUNE1] = 0x240, + [QUSB2PHY_PORT_TUNE2] = 0x244, + [QUSB2PHY_PORT_TUNE3] = 0x248, + [QUSB2PHY_PORT_TUNE4] = 0x24c, + [QUSB2PHY_PORT_TUNE5] = 0x250, + [QUSB2PHY_PORT_TEST1] = 0x254, + [QUSB2PHY_PORT_TEST2] = 0x258, + [QUSB2PHY_PORT_POWERDOWN] = 0x210, + [QUSB2PHY_INTR_CTRL] = 0x230, +}; + +static const struct qusb2_phy_cfg sm6115_phy_cfg = { + .tbl = sm6115_init_tbl, + .tbl_num = ARRAY_SIZE(sm6115_init_tbl), + .regs = sm6115_regs_layout, + + .has_pll_test = true, + .disable_ctrl = (CLAMP_N_EN | FREEZIO_N | POWER_DOWN), + .mask_core_ready = PLL_LOCKED, + .autoresume_en = BIT(3), +}; + +static const struct qusb2_phy_cfg qusb2_v2_phy_cfg = { + .tbl = qusb2_v2_init_tbl, + .tbl_num = ARRAY_SIZE(qusb2_v2_init_tbl), + .regs = qusb2_v2_regs_layout, + + .disable_ctrl = (PWR_CTRL1_VREF_SUPPLY_TRIM | PWR_CTRL1_CLAMP_N_EN | + POWER_DOWN), + .mask_core_ready = CORE_READY_STATUS, + .has_pll_override = true, + .autoresume_en = BIT(0), + .update_tune1_with_efuse = true, +}; + +/** + * struct qusb2_phy - structure holding qusb2 phy attributes + * + * @phy: generic phy + * @base: iomapped memory space for qubs2 phy + * + * @cfg_ahb_clk: AHB2PHY interface clock + * @phy_rst: phy reset control + * + * @cfg: phy config data + * @has_se_clk_scheme: indicate if PHY has single-ended ref clock scheme + */ +struct qusb2_phy { + struct phy *phy; + void __iomem *base; + + struct clk cfg_ahb_clk; + struct reset_ctl phy_rst; + + const struct qusb2_phy_cfg *cfg; + bool has_se_clk_scheme; +}; + +static inline void qusb2_write_mask(void __iomem *base, u32 offset, u32 val, + u32 mask) +{ + u32 reg; + + reg = readl(base + offset); + reg &= ~mask; + reg |= val & mask; + writel(reg, base + offset); + + /* Ensure above write is completed */ + readl(base + offset); +} + +static inline void qusb2_setbits(void __iomem *base, u32 offset, u32 val) +{ + u32 reg; + + reg = readl(base + offset); + reg |= val; + writel(reg, base + offset); + + /* Ensure above write is completed */ + readl(base + offset); +} + +static inline void qusb2_clrbits(void __iomem *base, u32 offset, u32 val) +{ + u32 reg; + + reg = readl(base + offset); + reg &= ~val; + writel(reg, base + offset); + + /* Ensure above write is completed */ + readl(base + offset); +} + +static inline void qusb2_phy_configure(void __iomem *base, + const unsigned int *regs, + const struct qusb2_phy_init_tbl tbl[], + int num) +{ + int i; + + for (i = 0; i < num; i++) { + if (tbl[i].in_layout) + writel(tbl[i].val, base + regs[tbl[i].offset]); + else + writel(tbl[i].val, base + tbl[i].offset); + } +} + +static int qusb2phy_do_reset(struct qusb2_phy *qphy) +{ + int ret; + + ret = reset_assert(&qphy->phy_rst); + if (ret) + return ret; + + udelay(10); + + ret = reset_deassert(&qphy->phy_rst); + if (ret) + return ret; + + return 0; +} + +static int qusb2phy_power_on(struct phy *phy) +{ + struct qusb2_phy *qphy = dev_get_priv(phy->dev); + const struct qusb2_phy_cfg *cfg = qphy->cfg; + int ret; + u32 val; + + ret = qusb2phy_do_reset(qphy); + if (ret) + return ret; + + /* Disable the PHY */ + qusb2_setbits(qphy->base, cfg->regs[QUSB2PHY_PORT_POWERDOWN], + qphy->cfg->disable_ctrl); + + if (cfg->has_pll_test) { + /* save reset value to override reference clock scheme later */ + val = readl(qphy->base + QUSB2PHY_PLL_TEST); + } + + qusb2_phy_configure(qphy->base, cfg->regs, cfg->tbl, cfg->tbl_num); + + /* Enable the PHY */ + qusb2_clrbits(qphy->base, cfg->regs[QUSB2PHY_PORT_POWERDOWN], + POWER_DOWN); + + /* Required to get phy pll lock successfully */ + udelay(150); + + if (cfg->has_pll_test) { + val |= CLK_REF_SEL; + + writel(val, qphy->base + QUSB2PHY_PLL_TEST); + + /* ensure above write is through */ + readl(qphy->base + QUSB2PHY_PLL_TEST); + } + + /* Required to get phy pll lock successfully */ + udelay(100); + + val = readb(qphy->base + cfg->regs[QUSB2PHY_PLL_STATUS]); + if (!(val & cfg->mask_core_ready)) { + pr_err("QUSB2PHY pll lock failed: status reg = %x\n", val); + ret = -EBUSY; + return ret; + } + + return 0; +} + +static int qusb2phy_power_off(struct phy *phy) +{ + struct qusb2_phy *qphy = dev_get_priv(phy->dev); + + /* Disable the PHY */ + qusb2_setbits(qphy->base, qphy->cfg->regs[QUSB2PHY_PORT_POWERDOWN], + qphy->cfg->disable_ctrl); + + reset_assert(&qphy->phy_rst); + + clk_disable(&qphy->cfg_ahb_clk); + + return 0; +} + +static int qusb2phy_clk_init(struct udevice *dev, struct qusb2_phy *qphy) +{ + int ret; + + /* We ignore the ref clock as we currently lack a driver for rpmcc/rpmhcc where + * it usually comes from - we assume it's always on. + */ + ret = clk_get_by_name(dev, "cfg_ahb", &qphy->cfg_ahb_clk); + if (ret == -ENOSYS || ret == -ENOENT) + return 0; + if (ret) + return ret; + + ret = clk_enable(&qphy->cfg_ahb_clk); + if (ret) { + return ret; + } + + return 0; +} + +static int qusb2phy_probe(struct udevice *dev) +{ + struct qusb2_phy *qphy = dev_get_priv(dev); + int ret; + + qphy->base = (void __iomem *)dev_read_addr(dev); + if (IS_ERR(qphy->base)) + return PTR_ERR(qphy->base); + + ret = qusb2phy_clk_init(dev, qphy); + if (ret) { + printf("%s: Couldn't get clocks: %d\n", __func__, ret); + return ret; + } + + ret = reset_get_by_index(dev, 0, &qphy->phy_rst); + if (ret) { + printf("%s: Couldn't get resets: %d\n", __func__, ret); + return ret; + } + + qphy->cfg = (const struct qusb2_phy_cfg *)dev_get_driver_data(dev); + if (!qphy->cfg) { + printf("%s: Couldn't get driver data\n", __func__); + return -EINVAL; + } + + debug("%s success qusb phy cfg %p\n", __func__, qphy->cfg); + return 0; +} + +static struct phy_ops qusb2phy_ops = { + .power_on = qusb2phy_power_on, + .power_off = qusb2phy_power_off, +}; + +static const struct udevice_id qusb2phy_ids[] = { + { .compatible = "qcom,qusb2-phy" }, + { .compatible = "qcom,qcm2290-qusb2-phy", + .data = (ulong)&sm6115_phy_cfg }, + { .compatible = "qcom,sm6115-qusb2-phy", + .data = (ulong)&sm6115_phy_cfg }, + { .compatible = "qcom,qusb2-v2-phy", .data = (ulong)&qusb2_v2_phy_cfg }, + {} +}; + +U_BOOT_DRIVER(qcom_qusb2_phy) = { + .name = "qcom-qusb2-phy", + .id = UCLASS_PHY, + .of_match = qusb2phy_ids, + .ops = &qusb2phy_ops, + .probe = qusb2phy_probe, + .priv_auto = sizeof(struct qusb2_phy), +};
Some Qualcomm SoCs newer than SDM845 feature a so-called "7nm phy" driver, notable the SM8250 SoC which will gain U-Boot support in upcoming patches.
Introduce a driver based on the Linux driver.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org [code cleanup, switch to clk/reset_bulk APIs] Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/phy/qcom/Kconfig | 8 + drivers/phy/qcom/Makefile | 1 + drivers/phy/qcom/phy-qcom-usb-hs-7nm.c | 295 +++++++++++++++++++++++++++++++++ 3 files changed, 304 insertions(+)
diff --git a/drivers/phy/qcom/Kconfig b/drivers/phy/qcom/Kconfig index 361dfb6e1126..3fc59dc65650 100644 --- a/drivers/phy/qcom/Kconfig +++ b/drivers/phy/qcom/Kconfig @@ -19,6 +19,14 @@ config PHY_QCOM_QUSB2 Enable this to support the Super-Speed USB transceiver on various Qualcomm chipsets.
+config PHY_QCOM_USB_HS_7NM + tristate "Qualcomm 7nm High-Speed PHY" + depends on PHY && ARCH_SNAPDRAGON + help + Enable this to support the Qualcomm Synopsys DesignWare Core 7nm + High-Speed PHY driver. This driver supports the Hi-Speed PHY which + is usually paired with Synopsys DWC3 USB IPs on MSM SOCs. + config PHY_QCOM_USB_HS_28NM tristate "Qualcomm 28nm High-Speed PHY" depends on PHY && ARCH_SNAPDRAGON diff --git a/drivers/phy/qcom/Makefile b/drivers/phy/qcom/Makefile index f6af985666a4..39219ecd24aa 100644 --- a/drivers/phy/qcom/Makefile +++ b/drivers/phy/qcom/Makefile @@ -1,5 +1,6 @@ obj-$(CONFIG_PHY_QCOM_IPQ4019_USB) += phy-qcom-ipq4019-usb.o obj-$(CONFIG_MSM8916_USB_PHY) += msm8916-usbh-phy.o obj-$(CONFIG_PHY_QCOM_QUSB2) += phy-qcom-qusb2.o +obj-$(CONFIG_PHY_QCOM_USB_HS_7NM) += phy-qcom-usb-hs-7nm.o obj-$(CONFIG_PHY_QCOM_USB_HS_28NM) += phy-qcom-usb-hs-28nm.o obj-$(CONFIG_PHY_QCOM_USB_SS) += phy-qcom-usb-ss.o diff --git a/drivers/phy/qcom/phy-qcom-usb-hs-7nm.c b/drivers/phy/qcom/phy-qcom-usb-hs-7nm.c new file mode 100644 index 000000000000..65128b45937b --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-usb-hs-7nm.c @@ -0,0 +1,295 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023 Bhupesh Sharma bhupesh.sharma@linaro.org + * + * Based on Linux driver + */ + +#include <clk.h> +#include <clk-uclass.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <dm/devres.h> +#include <generic-phy.h> +#include <malloc.h> +#include <reset.h> + +#include <asm/io.h> +#include <linux/bitops.h> +#include <linux/clk-provider.h> +#include <linux/delay.h> +#include <linux/iopoll.h> + +#define USB2_PHY_USB_PHY_UTMI_CTRL0 (0x3c) +#define SLEEPM BIT(0) +#define OPMODE_MASK GENMASK(4, 3) +#define OPMODE_NORMAL (0x00) +#define OPMODE_NONDRIVING BIT(3) +#define TERMSEL BIT(5) + +#define USB2_PHY_USB_PHY_UTMI_CTRL1 (0x40) +#define XCVRSEL BIT(0) + +#define USB2_PHY_USB_PHY_UTMI_CTRL5 (0x50) +#define POR BIT(1) + +#define USB2_PHY_USB_PHY_HS_PHY_CTRL_COMMON0 (0x54) +#define SIDDQ BIT(2) +#define RETENABLEN BIT(3) +#define FSEL_MASK GENMASK(6, 4) +#define FSEL_DEFAULT (0x3 << 4) + +#define USB2_PHY_USB_PHY_HS_PHY_CTRL_COMMON1 (0x58) +#define VBUSVLDEXTSEL0 BIT(4) +#define PLLBTUNE BIT(5) + +#define USB2_PHY_USB_PHY_HS_PHY_CTRL_COMMON2 (0x5c) +#define VREGBYPASS BIT(0) + +#define USB2_PHY_USB_PHY_HS_PHY_CTRL1 (0x60) +#define VBUSVLDEXT0 BIT(0) + +#define USB2_PHY_USB_PHY_HS_PHY_CTRL2 (0x64) +#define USB2_AUTO_RESUME BIT(0) +#define USB2_SUSPEND_N BIT(2) +#define USB2_SUSPEND_N_SEL BIT(3) + +#define USB2_PHY_USB_PHY_HS_PHY_OVERRIDE_X0 (0x6c) +#define USB2_PHY_USB_PHY_HS_PHY_OVERRIDE_X1 (0x70) +#define USB2_PHY_USB_PHY_HS_PHY_OVERRIDE_X2 (0x74) +#define USB2_PHY_USB_PHY_HS_PHY_OVERRIDE_X3 (0x78) +#define PARAM_OVRD_MASK 0xFF + +#define USB2_PHY_USB_PHY_CFG0 (0x94) +#define UTMI_PHY_DATAPATH_CTRL_OVERRIDE_EN BIT(0) +#define UTMI_PHY_CMN_CTRL_OVERRIDE_EN BIT(1) + +#define USB2_PHY_USB_PHY_REFCLK_CTRL (0xa0) +#define REFCLK_SEL_MASK GENMASK(1, 0) +#define REFCLK_SEL_DEFAULT (0x2 << 0) + +#define HS_DISCONNECT_MASK GENMASK(2, 0) +#define SQUELCH_DETECTOR_MASK GENMASK(7, 5) + +#define HS_AMPLITUDE_MASK GENMASK(3, 0) +#define PREEMPHASIS_DURATION_MASK BIT(5) +#define PREEMPHASIS_AMPLITUDE_MASK GENMASK(7, 6) + +#define HS_RISE_FALL_MASK GENMASK(1, 0) +#define HS_CROSSOVER_VOLTAGE_MASK GENMASK(3, 2) +#define HS_OUTPUT_IMPEDANCE_MASK GENMASK(5, 4) + +#define LS_FS_OUTPUT_IMPEDANCE_MASK GENMASK(3, 0) + +#define SNPS_HS_NUM_VREGS ARRAY_SIZE(hs_7nm_vreg_names) + +struct override_param { + s32 value; + u8 reg_val; +}; + +struct override_param_map { + const char *prop_name; + const struct override_param *param_table; + u8 table_size; + u8 reg_offset; + u8 param_mask; +}; + +struct phy_override_seq { + bool need_update; + u8 offset; + u8 value; + u8 mask; +}; + +#define NUM_HSPHY_TUNING_PARAMS (9) + +/* struct hs_7nm_phy_cfg - per-PHY initialization config */ +struct hs_7nm_phy_cfg { + /* resets to be requested */ + struct reset_ctl *resets; + int num_resets; + + struct override_param_map *map_cfg; + struct phy_override_seq update_seq_cfg[NUM_HSPHY_TUNING_PARAMS]; +}; + +/** + * struct hs_7nm_phy_priv - snps hs phy attributes + */ +struct hs_7nm_phy_priv { + void __iomem *base; + + /* clocks to be requested */ + struct clk_bulk clks; + + /* resets to be requested */ + struct reset_ctl_bulk resets; + + struct hs_7nm_phy_cfg *cfg; +}; + +static inline void hs_7nm_write_mask(void __iomem *base, u32 offset, u32 mask, + u32 val) +{ + u32 reg; + + reg = readl_relaxed(base + offset); + + reg &= ~mask; + reg |= val & mask; + writel_relaxed(reg, base + offset); + + /* Ensure above write is completed */ + readl_relaxed(base + offset); +} + +static int hs_7nm_usb_init(struct phy *phy) +{ + struct hs_7nm_phy_priv *hs_7nm = dev_get_priv(phy->dev); + + hs_7nm_write_mask(hs_7nm->base, USB2_PHY_USB_PHY_CFG0, + UTMI_PHY_CMN_CTRL_OVERRIDE_EN, + UTMI_PHY_CMN_CTRL_OVERRIDE_EN); + hs_7nm_write_mask(hs_7nm->base, USB2_PHY_USB_PHY_UTMI_CTRL5, POR, POR); + hs_7nm_write_mask(hs_7nm->base, USB2_PHY_USB_PHY_HS_PHY_CTRL_COMMON0, + FSEL_MASK, 0); + hs_7nm_write_mask(hs_7nm->base, USB2_PHY_USB_PHY_HS_PHY_CTRL_COMMON1, + PLLBTUNE, PLLBTUNE); + hs_7nm_write_mask(hs_7nm->base, USB2_PHY_USB_PHY_REFCLK_CTRL, + REFCLK_SEL_DEFAULT, REFCLK_SEL_MASK); + hs_7nm_write_mask(hs_7nm->base, USB2_PHY_USB_PHY_HS_PHY_CTRL_COMMON1, + VBUSVLDEXTSEL0, VBUSVLDEXTSEL0); + hs_7nm_write_mask(hs_7nm->base, USB2_PHY_USB_PHY_HS_PHY_CTRL1, + VBUSVLDEXT0, VBUSVLDEXT0); + + hs_7nm_write_mask(hs_7nm->base, USB2_PHY_USB_PHY_HS_PHY_CTRL_COMMON2, + VREGBYPASS, VREGBYPASS); + + hs_7nm_write_mask(hs_7nm->base, USB2_PHY_USB_PHY_HS_PHY_CTRL2, + USB2_SUSPEND_N_SEL | USB2_SUSPEND_N, + USB2_SUSPEND_N_SEL | USB2_SUSPEND_N); + + hs_7nm_write_mask(hs_7nm->base, USB2_PHY_USB_PHY_UTMI_CTRL0, SLEEPM, + SLEEPM); + + hs_7nm_write_mask(hs_7nm->base, USB2_PHY_USB_PHY_HS_PHY_CTRL_COMMON0, + SIDDQ, 0); + + hs_7nm_write_mask(hs_7nm->base, USB2_PHY_USB_PHY_UTMI_CTRL5, POR, 0); + + hs_7nm_write_mask(hs_7nm->base, USB2_PHY_USB_PHY_HS_PHY_CTRL2, + USB2_SUSPEND_N_SEL, 0); + + hs_7nm_write_mask(hs_7nm->base, USB2_PHY_USB_PHY_CFG0, + UTMI_PHY_CMN_CTRL_OVERRIDE_EN, 0); + + return 0; +} + +static int hs_7nm_phy_power_on(struct phy *phy) +{ + struct hs_7nm_phy_priv *hs_7nm = dev_get_priv(phy->dev); + int ret; + + clk_enable_bulk(&hs_7nm->clks); + + ret = reset_deassert_bulk(&hs_7nm->resets); + if (ret) + return ret; + + ret = hs_7nm_usb_init(phy); + if (ret) + return ret; + + return 0; +} + +static int hs_7nm_phy_power_off(struct phy *phy) +{ + struct hs_7nm_phy_priv *hs_7nm = dev_get_priv(phy->dev); + + reset_assert_bulk(&hs_7nm->resets); + clk_disable_bulk(&hs_7nm->clks); + + return 0; +} + +static int hs_7nm_phy_clk_init(struct udevice *dev, + struct hs_7nm_phy_priv *hs_7nm) +{ + int ret; + + ret = clk_get_bulk(dev, &hs_7nm->clks); + /* We may have no clocks */ + if (ret == -ENOENT) { + debug("%s: no clocks\n", __func__); + return 0; + } + if (ret < 0) { + printf("%s: Failed to get clocks %d\n", __func__, ret); + return ret; + } + + return 0; +} + +static int hs_7nm_phy_probe(struct udevice *dev) +{ + struct hs_7nm_phy_priv *hs_7nm = dev_get_priv(dev); + int ret; + + hs_7nm->base = (void __iomem *)dev_read_addr(dev); + if (IS_ERR(hs_7nm->base)) + return PTR_ERR(hs_7nm->base); + + hs_7nm->cfg = (struct hs_7nm_phy_cfg *)dev_get_driver_data(dev); + + ret = hs_7nm_phy_clk_init(dev, hs_7nm); + if (ret) { + printf("%s: hs_7nm_phy_clk_init %d\n", __func__, ret); + return ret; + } + + ret = reset_get_bulk(dev, &hs_7nm->resets); + if (ret < 0) { + printf("failed to get resets, ret = %d\n", ret); + return ret; + } + + clk_enable_bulk(&hs_7nm->clks); + reset_deassert_bulk(&hs_7nm->resets); + + return 0; +} + +static struct phy_ops hs_7nm_phy_ops = { + .power_on = hs_7nm_phy_power_on, + .power_off = hs_7nm_phy_power_off, +}; + +static const struct udevice_id hs_7nm_phy_ids[] = { + { + .compatible = "qcom,sm8150-usb-hs-phy", + }, + { + .compatible = "qcom,usb-snps-hs-5nm-phy", + }, + { + .compatible = "qcom,usb-snps-hs-7nm-phy", + }, + { + .compatible = "qcom,usb-snps-femto-v2-phy", + }, + {} +}; + +U_BOOT_DRIVER(qcom_usb_hs_7nm) = { + .name = "qcom-usb-hs-7nm", + .id = UCLASS_PHY, + .of_match = hs_7nm_phy_ids, + .ops = &hs_7nm_phy_ops, + .probe = hs_7nm_phy_probe, + .priv_auto = sizeof(struct hs_7nm_phy_priv), +};
The RCG registers always have the same offsets, so only store the base CMD register address and calculate the others relative to that.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/clk/qcom/clock-apq8016.c | 39 +------------ drivers/clk/qcom/clock-apq8096.c | 28 +-------- drivers/clk/qcom/clock-qcom.c | 22 +++---- drivers/clk/qcom/clock-qcom.h | 16 +++--- drivers/clk/qcom/clock-qcs404.c | 121 +++++---------------------------------- drivers/clk/qcom/clock-sdm845.c | 16 +----- 6 files changed, 39 insertions(+), 203 deletions(-)
diff --git a/drivers/clk/qcom/clock-apq8016.c b/drivers/clk/qcom/clock-apq8016.c index 9de0ad5ed32d..67d2d108326c 100644 --- a/drivers/clk/qcom/clock-apq8016.c +++ b/drivers/clk/qcom/clock-apq8016.c @@ -23,11 +23,7 @@ #define APCS_CLOCK_BRANCH_ENA_VOTE (0x45004)
#define SDCC_BCR(n) ((n * 0x1000) + 0x41000) -#define SDCC_CMD_RCGR(n) ((n * 0x1000) + 0x41004) -#define SDCC_CFG_RCGR(n) ((n * 0x1000) + 0x41008) -#define SDCC_M(n) ((n * 0x1000) + 0x4100C) -#define SDCC_N(n) ((n * 0x1000) + 0x41010) -#define SDCC_D(n) ((n * 0x1000) + 0x41014) +#define SDCC_CMD_RCGR(n) (((n + 1) * 0x1000) + 0x41004) #define SDCC_APPS_CBCR(n) ((n * 0x1000) + 0x41018) #define SDCC_AHB_CBCR(n) ((n * 0x1000) + 0x4101C)
@@ -38,31 +34,10 @@ #define BLSP1_UART2_BCR (0x3028) #define BLSP1_UART2_APPS_CBCR (0x302C) #define BLSP1_UART2_APPS_CMD_RCGR (0x3034) -#define BLSP1_UART2_APPS_CFG_RCGR (0x3038) -#define BLSP1_UART2_APPS_M (0x303C) -#define BLSP1_UART2_APPS_N (0x3040) -#define BLSP1_UART2_APPS_D (0x3044)
/* GPLL0 clock control registers */ #define GPLL0_STATUS_ACTIVE BIT(17)
-static const struct bcr_regs sdc_regs[] = { - { - .cfg_rcgr = SDCC_CFG_RCGR(1), - .cmd_rcgr = SDCC_CMD_RCGR(1), - .M = SDCC_M(1), - .N = SDCC_N(1), - .D = SDCC_D(1), - }, - { - .cfg_rcgr = SDCC_CFG_RCGR(2), - .cmd_rcgr = SDCC_CMD_RCGR(2), - .M = SDCC_M(2), - .N = SDCC_N(2), - .D = SDCC_D(2), - } -}; - static struct pll_vote_clk gpll0_vote_clk = { .status = GPLL0_STATUS, .status_bit = GPLL0_STATUS_ACTIVE, @@ -86,7 +61,7 @@ static int clk_init_sdc(struct msm_clk_priv *priv, int slot, uint rate)
clk_enable_cbc(priv->base + SDCC_AHB_CBCR(slot)); /* 800Mhz/div, gpll0 */ - clk_rcg_set_rate_mnd(priv->base, &sdc_regs[slot], div, 0, 0, + clk_rcg_set_rate_mnd(priv->base, SDCC_CMD_RCGR(slot), div, 0, 0, CFG_CLK_SRC_GPLL0, 8); clk_enable_gpll0(priv->base, &gpll0_vote_clk); clk_enable_cbc(priv->base + SDCC_APPS_CBCR(slot)); @@ -94,14 +69,6 @@ static int clk_init_sdc(struct msm_clk_priv *priv, int slot, uint rate) return rate; }
-static const struct bcr_regs uart2_regs = { - .cfg_rcgr = BLSP1_UART2_APPS_CFG_RCGR, - .cmd_rcgr = BLSP1_UART2_APPS_CMD_RCGR, - .M = BLSP1_UART2_APPS_M, - .N = BLSP1_UART2_APPS_N, - .D = BLSP1_UART2_APPS_D, -}; - /* UART: 115200 */ static int clk_init_uart(struct msm_clk_priv *priv) { @@ -109,7 +76,7 @@ static int clk_init_uart(struct msm_clk_priv *priv) clk_enable_vote_clk(priv->base, &gcc_blsp1_ahb_clk);
/* 7372800 uart block clock @ GPLL0 */ - clk_rcg_set_rate_mnd(priv->base, &uart2_regs, 1, 144, 15625, + clk_rcg_set_rate_mnd(priv->base, BLSP1_UART2_APPS_CMD_RCGR, 1, 144, 15625, CFG_CLK_SRC_GPLL0, 16);
/* Vote for gpll0 clock */ diff --git a/drivers/clk/qcom/clock-apq8096.c b/drivers/clk/qcom/clock-apq8096.c index a4731613c5e0..479f9771a464 100644 --- a/drivers/clk/qcom/clock-apq8096.c +++ b/drivers/clk/qcom/clock-apq8096.c @@ -26,31 +26,15 @@ #define SDCC2_APPS_CBCR (0x14004) /* branch control */ #define SDCC2_AHB_CBCR (0x14008) #define SDCC2_CMD_RCGR (0x14010) -#define SDCC2_CFG_RCGR (0x14014) -#define SDCC2_M (0x14018) -#define SDCC2_N (0x1401C) -#define SDCC2_D (0x14020)
#define BLSP2_AHB_CBCR (0x25004) #define BLSP2_UART2_APPS_CBCR (0x29004) #define BLSP2_UART2_APPS_CMD_RCGR (0x2900C) -#define BLSP2_UART2_APPS_CFG_RCGR (0x29010) -#define BLSP2_UART2_APPS_M (0x29014) -#define BLSP2_UART2_APPS_N (0x29018) -#define BLSP2_UART2_APPS_D (0x2901C)
/* GPLL0 clock control registers */ #define GPLL0_STATUS_ACTIVE BIT(30) #define APCS_GPLL_ENA_VOTE_GPLL0 BIT(0)
-static const struct bcr_regs sdc_regs = { - .cfg_rcgr = SDCC2_CFG_RCGR, - .cmd_rcgr = SDCC2_CMD_RCGR, - .M = SDCC2_M, - .N = SDCC2_N, - .D = SDCC2_D, -}; - static const struct pll_vote_clk gpll0_vote_clk = { .status = GPLL0_STATUS, .status_bit = GPLL0_STATUS_ACTIVE, @@ -69,7 +53,7 @@ static int clk_init_sdc(struct msm_clk_priv *priv, uint rate) int div = 5;
clk_enable_cbc(priv->base + SDCC2_AHB_CBCR); - clk_rcg_set_rate_mnd(priv->base, &sdc_regs, div, 0, 0, + clk_rcg_set_rate_mnd(priv->base, SDCC2_CMD_RCGR, div, 0, 0, CFG_CLK_SRC_GPLL0, 8); clk_enable_gpll0(priv->base, &gpll0_vote_clk); clk_enable_cbc(priv->base + SDCC2_APPS_CBCR); @@ -77,21 +61,13 @@ static int clk_init_sdc(struct msm_clk_priv *priv, uint rate) return rate; }
-static const struct bcr_regs uart2_regs = { - .cfg_rcgr = BLSP2_UART2_APPS_CFG_RCGR, - .cmd_rcgr = BLSP2_UART2_APPS_CMD_RCGR, - .M = BLSP2_UART2_APPS_M, - .N = BLSP2_UART2_APPS_N, - .D = BLSP2_UART2_APPS_D, -}; - static int clk_init_uart(struct msm_clk_priv *priv) { /* Enable AHB clock */ clk_enable_vote_clk(priv->base, &gcc_blsp2_ahb_clk);
/* 7372800 uart block clock @ GPLL0 */ - clk_rcg_set_rate_mnd(priv->base, &uart2_regs, 1, 192, 15625, + clk_rcg_set_rate_mnd(priv->base, BLSP2_UART2_APPS_CMD_RCGR, 1, 192, 15625, CFG_CLK_SRC_GPLL0, 16);
/* Vote for gpll0 clock */ diff --git a/drivers/clk/qcom/clock-qcom.c b/drivers/clk/qcom/clock-qcom.c index 7c683e519226..d912b673d0d8 100644 --- a/drivers/clk/qcom/clock-qcom.c +++ b/drivers/clk/qcom/clock-qcom.c @@ -95,7 +95,7 @@ void clk_bcr_update(phys_addr_t apps_cmd_rcgr) * root set rate for clocks with half integer and MND divider * div should be pre-calculated ((div * 2) - 1) */ -void clk_rcg_set_rate_mnd(phys_addr_t base, const struct bcr_regs *regs, +void clk_rcg_set_rate_mnd(phys_addr_t base, uint32_t cmd_rcgr, int div, int m, int n, int source, u8 mnd_width) { u32 cfg; @@ -111,12 +111,12 @@ void clk_rcg_set_rate_mnd(phys_addr_t base, const struct bcr_regs *regs, debug("m %#x n %#x d %#x div %#x mask %#x\n", m_val, n_val, d_val, div, mask);
/* Program MND values */ - writel(m_val & mask, base + regs->M); - writel(n_val & mask, base + regs->N); - writel(d_val & mask, base + regs->D); + writel(m_val & mask, base + cmd_rcgr + RCG_M_REG); + writel(n_val & mask, base + cmd_rcgr + RCG_N_REG); + writel(d_val & mask, base + cmd_rcgr + RCG_D_REG);
/* setup src select and divider */ - cfg = readl(base + regs->cfg_rcgr); + cfg = readl(base + cmd_rcgr + RCG_CFG_REG); cfg &= ~(CFG_SRC_SEL_MASK | CFG_MODE_MASK | CFG_HW_CLK_CTRL_MASK); cfg |= source & CFG_SRC_SEL_MASK; /* Select clock source */
@@ -126,20 +126,20 @@ void clk_rcg_set_rate_mnd(phys_addr_t base, const struct bcr_regs *regs, if (n && n != m) cfg |= CFG_MODE_DUAL_EDGE;
- writel(cfg, base + regs->cfg_rcgr); /* Write new clock configuration */ + writel(cfg, base + cmd_rcgr + RCG_CFG_REG); /* Write new clock configuration */
/* Inform h/w to start using the new config. */ - clk_bcr_update(base + regs->cmd_rcgr); + clk_bcr_update(base + cmd_rcgr); }
/* root set rate for clocks with half integer and mnd_width=0 */ -void clk_rcg_set_rate(phys_addr_t base, const struct bcr_regs *regs, int div, +void clk_rcg_set_rate(phys_addr_t base, uint32_t cmd_rcgr, int div, int source) { u32 cfg;
/* setup src select and divider */ - cfg = readl(base + regs->cfg_rcgr); + cfg = readl(base + cmd_rcgr + RCG_CFG_REG); cfg &= ~(CFG_SRC_SEL_MASK | CFG_MODE_MASK | CFG_HW_CLK_CTRL_MASK); cfg |= source & CFG_CLK_SRC_MASK; /* Select clock source */
@@ -150,10 +150,10 @@ void clk_rcg_set_rate(phys_addr_t base, const struct bcr_regs *regs, int div, if (div) cfg |= (2 * div - 1) & CFG_SRC_DIV_MASK;
const struct freq_tbl *qcom_find_freq(const struct freq_tbl *f, uint rate) diff --git a/drivers/clk/qcom/clock-qcom.h b/drivers/clk/qcom/clock-qcom.h index 01088c19015a..7eb26369cd8f 100644 --- a/drivers/clk/qcom/clock-qcom.h +++ b/drivers/clk/qcom/clock-qcom.h @@ -12,6 +12,11 @@ #define CFG_CLK_SRC_GPLL0_EVEN (6 << 8) #define CFG_CLK_SRC_MASK (7 << 8)
+#define RCG_CFG_REG 0x4 +#define RCG_M_REG 0x8 +#define RCG_N_REG 0xc +#define RCG_D_REG 0x10 + struct pll_vote_clk { uintptr_t status; int status_bit; @@ -24,13 +29,6 @@ struct vote_clk { uintptr_t ena_vote; int vote_bit; }; -struct bcr_regs { - uintptr_t cfg_rcgr; - uintptr_t cmd_rcgr; - uintptr_t M; - uintptr_t N; - uintptr_t D; -};
struct freq_tbl { uint freq; @@ -82,9 +80,9 @@ void clk_bcr_update(phys_addr_t apps_cmd_rgcr); void clk_enable_cbc(phys_addr_t cbcr); void clk_enable_vote_clk(phys_addr_t base, const struct vote_clk *vclk); const struct freq_tbl *qcom_find_freq(const struct freq_tbl *f, uint rate); -void clk_rcg_set_rate_mnd(phys_addr_t base, const struct bcr_regs *regs, +void clk_rcg_set_rate_mnd(phys_addr_t base, uint32_t cmd_rcgr, int div, int m, int n, int source, u8 mnd_width); -void clk_rcg_set_rate(phys_addr_t base, const struct bcr_regs *regs, int div, +void clk_rcg_set_rate(phys_addr_t base, uint32_t cmd_rcgr, int div, int source);
static inline void qcom_gate_clk_en(const struct msm_clk_priv *priv, unsigned long id) diff --git a/drivers/clk/qcom/clock-qcs404.c b/drivers/clk/qcom/clock-qcs404.c index 03fd65a9328b..3ebfb9030dd0 100644 --- a/drivers/clk/qcom/clock-qcs404.c +++ b/drivers/clk/qcom/clock-qcs404.c @@ -28,35 +28,22 @@ #define BLSP1_UART2_BCR (0x3028) #define BLSP1_UART2_APPS_CBCR (0x302C) #define BLSP1_UART2_APPS_CMD_RCGR (0x3034) -#define BLSP1_UART2_APPS_CFG_RCGR (0x3038) -#define BLSP1_UART2_APPS_M (0x303C) -#define BLSP1_UART2_APPS_N (0x3040) -#define BLSP1_UART2_APPS_D (0x3044)
/* I2C controller clock control registerss */ #define BLSP1_QUP0_I2C_APPS_CBCR (0x6028) #define BLSP1_QUP0_I2C_APPS_CMD_RCGR (0x602C) -#define BLSP1_QUP0_I2C_APPS_CFG_RCGR (0x6030) #define BLSP1_QUP1_I2C_APPS_CBCR (0x2008) #define BLSP1_QUP1_I2C_APPS_CMD_RCGR (0x200C) -#define BLSP1_QUP1_I2C_APPS_CFG_RCGR (0x2010) #define BLSP1_QUP2_I2C_APPS_CBCR (0x3010) #define BLSP1_QUP2_I2C_APPS_CMD_RCGR (0x3000) -#define BLSP1_QUP2_I2C_APPS_CFG_RCGR (0x3004) #define BLSP1_QUP3_I2C_APPS_CBCR (0x4020) #define BLSP1_QUP3_I2C_APPS_CMD_RCGR (0x4000) -#define BLSP1_QUP3_I2C_APPS_CFG_RCGR (0x4004) #define BLSP1_QUP4_I2C_APPS_CBCR (0x5020) #define BLSP1_QUP4_I2C_APPS_CMD_RCGR (0x5000) -#define BLSP1_QUP4_I2C_APPS_CFG_RCGR (0x5004)
/* SD controller clock control registers */ #define SDCC_BCR(n) (((n) * 0x1000) + 0x41000) -#define SDCC_CMD_RCGR(n) (((n) * 0x1000) + 0x41004) -#define SDCC_CFG_RCGR(n) (((n) * 0x1000) + 0x41008) -#define SDCC_M(n) (((n) * 0x1000) + 0x4100C) -#define SDCC_N(n) (((n) * 0x1000) + 0x41010) -#define SDCC_D(n) (((n) * 0x1000) + 0x41014) +#define SDCC_CMD_RCGR(n) (((n + 1) * 0x1000) + 0x41004) #define SDCC_APPS_CBCR(n) (((n) * 0x1000) + 0x41018) #define SDCC_AHB_CBCR(n) (((n) * 0x1000) + 0x4101C)
@@ -70,10 +57,6 @@ #define USB30_MOCK_UTMI_CMD_RCGR (0x3901C) #define USB30_MOCK_UTMI_CFG_RCGR (0x39020) #define USB30_MASTER_CMD_RCGR (0x39028) -#define USB30_MASTER_CFG_RCGR (0x3902C) -#define USB30_MASTER_M (0x39030) -#define USB30_MASTER_N (0x39034) -#define USB30_MASTER_D (0x39038) #define USB2A_PHY_SLEEP_CBCR (0x4102C) #define USB_HS_PHY_CFG_AHB_CBCR (0x41030)
@@ -85,10 +68,6 @@ #define EMAC_PTP_CMD_RCGR (0x4e014) #define EMAC_PTP_CFG_RCGR (0x4e018) #define EMAC_CMD_RCGR (0x4e01c) -#define EMAC_CFG_RCGR (0x4e020) -#define EMAC_M (0x4e024) -#define EMAC_N (0x4e028) -#define EMAC_D (0x4e02c)
/* GPLL0 clock control registers */ @@ -103,22 +82,6 @@ static struct vote_clk gcc_blsp1_ahb_clk = { .vote_bit = BIT(10) | BIT(5) | BIT(4), };
-static const struct bcr_regs uart2_regs = { - .cfg_rcgr = BLSP1_UART2_APPS_CFG_RCGR, - .cmd_rcgr = BLSP1_UART2_APPS_CMD_RCGR, - .M = BLSP1_UART2_APPS_M, - .N = BLSP1_UART2_APPS_N, - .D = BLSP1_UART2_APPS_D, -}; - -static const struct bcr_regs sdc_regs = { - .cfg_rcgr = SDCC_CFG_RCGR(1), - .cmd_rcgr = SDCC_CMD_RCGR(1), - .M = SDCC_M(1), - .N = SDCC_N(1), - .D = SDCC_D(1), -}; - static struct pll_vote_clk gpll0_vote_clk = { .status = GPLL0_STATUS, .status_bit = GPLL0_STATUS_ACTIVE, @@ -133,60 +96,6 @@ static struct pll_vote_clk gpll1_vote_clk = { .vote_bit = BIT(1), };
-static const struct bcr_regs usb30_master_regs = { - .cfg_rcgr = USB30_MASTER_CFG_RCGR, - .cmd_rcgr = USB30_MASTER_CMD_RCGR, - .M = USB30_MASTER_M, - .N = USB30_MASTER_N, - .D = USB30_MASTER_D, -}; - -static const struct bcr_regs emac_regs = { - .cfg_rcgr = EMAC_CFG_RCGR, - .cmd_rcgr = EMAC_CMD_RCGR, - .M = EMAC_M, - .N = EMAC_N, - .D = EMAC_D, -}; - -static const struct bcr_regs emac_ptp_regs = { - .cfg_rcgr = EMAC_PTP_CFG_RCGR, - .cmd_rcgr = EMAC_PTP_CMD_RCGR, - .M = EMAC_M, - .N = EMAC_N, - .D = EMAC_D, -}; - -static const struct bcr_regs blsp1_qup0_i2c_apps_regs = { - .cmd_rcgr = BLSP1_QUP0_I2C_APPS_CMD_RCGR, - .cfg_rcgr = BLSP1_QUP0_I2C_APPS_CFG_RCGR, - /* mnd_width = 0 */ -}; - -static const struct bcr_regs blsp1_qup1_i2c_apps_regs = { - .cmd_rcgr = BLSP1_QUP1_I2C_APPS_CMD_RCGR, - .cfg_rcgr = BLSP1_QUP1_I2C_APPS_CFG_RCGR, - /* mnd_width = 0 */ -}; - -static const struct bcr_regs blsp1_qup2_i2c_apps_regs = { - .cmd_rcgr = BLSP1_QUP2_I2C_APPS_CMD_RCGR, - .cfg_rcgr = BLSP1_QUP2_I2C_APPS_CFG_RCGR, - /* mnd_width = 0 */ -}; - -static const struct bcr_regs blsp1_qup3_i2c_apps_regs = { - .cmd_rcgr = BLSP1_QUP3_I2C_APPS_CMD_RCGR, - .cfg_rcgr = BLSP1_QUP3_I2C_APPS_CFG_RCGR, - /* mnd_width = 0 */ -}; - -static const struct bcr_regs blsp1_qup4_i2c_apps_regs = { - .cmd_rcgr = BLSP1_QUP4_I2C_APPS_CMD_RCGR, - .cfg_rcgr = BLSP1_QUP4_I2C_APPS_CFG_RCGR, - /* mnd_width = 0 */ -}; - static ulong qcs404_clk_set_rate(struct clk *clk, ulong rate) { struct msm_clk_priv *priv = dev_get_priv(clk->dev); @@ -194,7 +103,7 @@ static ulong qcs404_clk_set_rate(struct clk *clk, ulong rate) switch (clk->id) { case GCC_BLSP1_UART2_APPS_CLK: /* UART: 115200 */ - clk_rcg_set_rate_mnd(priv->base, &uart2_regs, 0, 12, 125, + clk_rcg_set_rate_mnd(priv->base, BLSP1_UART2_APPS_CMD_RCGR, 0, 12, 125, CFG_CLK_SRC_CXO, 16); clk_enable_cbc(priv->base + BLSP1_UART2_APPS_CBCR); break; @@ -203,7 +112,7 @@ static ulong qcs404_clk_set_rate(struct clk *clk, ulong rate) break; case GCC_SDCC1_APPS_CLK: /* SDCC1: 200MHz */ - clk_rcg_set_rate_mnd(priv->base, &sdc_regs, 7, 0, 0, + clk_rcg_set_rate_mnd(priv->base, SDCC_CMD_RCGR(0), 7, 0, 0, CFG_CLK_SRC_GPLL0, 8); clk_enable_gpll0(priv->base, &gpll0_vote_clk); clk_enable_cbc(priv->base + SDCC_APPS_CBCR(1)); @@ -213,16 +122,16 @@ static ulong qcs404_clk_set_rate(struct clk *clk, ulong rate) break; case GCC_ETH_RGMII_CLK: if (rate == 250000000) - clk_rcg_set_rate_mnd(priv->base, &emac_regs, 3, 0, 0, + clk_rcg_set_rate_mnd(priv->base, EMAC_CMD_RCGR, 3, 0, 0, CFG_CLK_SRC_GPLL1, 8); else if (rate == 125000000) - clk_rcg_set_rate_mnd(priv->base, &emac_regs, 7, 0, 0, + clk_rcg_set_rate_mnd(priv->base, EMAC_CMD_RCGR, 7, 0, 0, CFG_CLK_SRC_GPLL1, 8); else if (rate == 50000000) - clk_rcg_set_rate_mnd(priv->base, &emac_regs, 19, 0, 0, + clk_rcg_set_rate_mnd(priv->base, EMAC_CMD_RCGR, 19, 0, 0, CFG_CLK_SRC_GPLL1, 8); else if (rate == 5000000) - clk_rcg_set_rate_mnd(priv->base, &emac_regs, 3, 1, 50, + clk_rcg_set_rate_mnd(priv->base, EMAC_CMD_RCGR, 3, 1, 50, CFG_CLK_SRC_GPLL1, 8); return rate; } @@ -238,7 +147,7 @@ static int qcs404_clk_enable(struct clk *clk) switch (clk->id) { case GCC_USB30_MASTER_CLK: clk_enable_cbc(priv->base + USB30_MASTER_CBCR); - clk_rcg_set_rate_mnd(priv->base, &usb30_master_regs, 7, 0, 0, + clk_rcg_set_rate_mnd(priv->base, USB30_MASTER_CMD_RCGR, 7, 0, 0, CFG_CLK_SRC_GPLL0, 8); break; case GCC_SYS_NOC_USB3_CLK: @@ -260,14 +169,14 @@ static int qcs404_clk_enable(struct clk *clk) /* SPEED_1000: freq -> 250MHz */ clk_enable_cbc(priv->base + ETH_PTP_CBCR); clk_enable_gpll0(priv->base, &gpll1_vote_clk); - clk_rcg_set_rate_mnd(priv->base, &emac_ptp_regs, 3, 0, 0, + clk_rcg_set_rate_mnd(priv->base, EMAC_PTP_CMD_RCGR, 3, 0, 0, CFG_CLK_SRC_GPLL1, 8); break; case GCC_ETH_RGMII_CLK: /* SPEED_1000: freq -> 250MHz */ clk_enable_cbc(priv->base + ETH_RGMII_CBCR); clk_enable_gpll0(priv->base, &gpll1_vote_clk); - clk_rcg_set_rate_mnd(priv->base, &emac_regs, 3, 0, 0, + clk_rcg_set_rate_mnd(priv->base, EMAC_CMD_RCGR, 3, 0, 0, CFG_CLK_SRC_GPLL1, 8); break; case GCC_ETH_SLAVE_AHB_CLK: @@ -281,27 +190,27 @@ static int qcs404_clk_enable(struct clk *clk) break; case GCC_BLSP1_QUP0_I2C_APPS_CLK: clk_enable_cbc(priv->base + BLSP1_QUP0_I2C_APPS_CBCR); - clk_rcg_set_rate(priv->base, &blsp1_qup0_i2c_apps_regs, 0, + clk_rcg_set_rate(priv->base, BLSP1_QUP0_I2C_APPS_CMD_RCGR, 0, CFG_CLK_SRC_CXO); break; case GCC_BLSP1_QUP1_I2C_APPS_CLK: clk_enable_cbc(priv->base + BLSP1_QUP1_I2C_APPS_CBCR); - clk_rcg_set_rate(priv->base, &blsp1_qup1_i2c_apps_regs, 0, + clk_rcg_set_rate(priv->base, BLSP1_QUP1_I2C_APPS_CMD_RCGR, 0, CFG_CLK_SRC_CXO); break; case GCC_BLSP1_QUP2_I2C_APPS_CLK: clk_enable_cbc(priv->base + BLSP1_QUP2_I2C_APPS_CBCR); - clk_rcg_set_rate(priv->base, &blsp1_qup2_i2c_apps_regs, 0, + clk_rcg_set_rate(priv->base, BLSP1_QUP2_I2C_APPS_CMD_RCGR, 0, CFG_CLK_SRC_CXO); break; case GCC_BLSP1_QUP3_I2C_APPS_CLK: clk_enable_cbc(priv->base + BLSP1_QUP3_I2C_APPS_CBCR); - clk_rcg_set_rate(priv->base, &blsp1_qup3_i2c_apps_regs, 0, + clk_rcg_set_rate(priv->base, BLSP1_QUP3_I2C_APPS_CMD_RCGR, 0, CFG_CLK_SRC_CXO); break; case GCC_BLSP1_QUP4_I2C_APPS_CLK: clk_enable_cbc(priv->base + BLSP1_QUP4_I2C_APPS_CBCR); - clk_rcg_set_rate(priv->base, &blsp1_qup4_i2c_apps_regs, 0, + clk_rcg_set_rate(priv->base, BLSP1_QUP4_I2C_APPS_CMD_RCGR, 0, CFG_CLK_SRC_CXO); break; default: diff --git a/drivers/clk/qcom/clock-sdm845.c b/drivers/clk/qcom/clock-sdm845.c index 36ffee79d966..5d6c0cdaeee5 100644 --- a/drivers/clk/qcom/clock-sdm845.c +++ b/drivers/clk/qcom/clock-sdm845.c @@ -19,13 +19,7 @@
#include "clock-qcom.h"
-#define SE9_AHB_CBCR 0x25004 -#define SE9_UART_APPS_CBCR 0x29004 #define SE9_UART_APPS_CMD_RCGR 0x18148 -#define SE9_UART_APPS_CFG_RCGR 0x1814C -#define SE9_UART_APPS_M 0x18150 -#define SE9_UART_APPS_N 0x18154 -#define SE9_UART_APPS_D 0x18158
static const struct freq_tbl ftbl_gcc_qupv3_wrap0_s0_clk_src[] = { F(7372800, CFG_CLK_SRC_GPLL0_EVEN, 1, 384, 15625), @@ -46,14 +40,6 @@ static const struct freq_tbl ftbl_gcc_qupv3_wrap0_s0_clk_src[] = { { } };
-static const struct bcr_regs uart2_regs = { - .cfg_rcgr = SE9_UART_APPS_CFG_RCGR, - .cmd_rcgr = SE9_UART_APPS_CMD_RCGR, - .M = SE9_UART_APPS_M, - .N = SE9_UART_APPS_N, - .D = SE9_UART_APPS_D, -}; - static ulong sdm845_clk_set_rate(struct clk *clk, ulong rate) { struct msm_clk_priv *priv = dev_get_priv(clk->dev); @@ -62,7 +48,7 @@ static ulong sdm845_clk_set_rate(struct clk *clk, ulong rate) switch (clk->id) { case GCC_QUPV3_WRAP1_S1_CLK: /* UART9 */ freq = qcom_find_freq(ftbl_gcc_qupv3_wrap0_s0_clk_src, rate); - clk_rcg_set_rate_mnd(priv->base, &uart2_regs, + clk_rcg_set_rate_mnd(priv->base, SE9_UART_APPS_CMD_RCGR, freq->pre_div, freq->m, freq->n, freq->src, 16); return freq->freq; default:
Global Distributed Switch Controllers are per-domain switches which are used to toggle power and clocks to an entire subsystem. They live under the GCC block and might need to be enabled before certain clocks, so handle them as part of the clock driver.
Linux models these as power domains, however this additional complexity doesn't offer much benefit to us in U-Boot. For now they can be turned on as-needed when a relevant clock is enabled.
In the future, we can add a power-domain driver to model these properly.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/clk/qcom/clock-qcom.c | 18 ++++++++++++++++++ drivers/clk/qcom/clock-qcom.h | 4 ++++ 2 files changed, 22 insertions(+)
diff --git a/drivers/clk/qcom/clock-qcom.c b/drivers/clk/qcom/clock-qcom.c index d912b673d0d8..0e89e7fe429e 100644 --- a/drivers/clk/qcom/clock-qcom.c +++ b/drivers/clk/qcom/clock-qcom.c @@ -39,6 +39,24 @@ void clk_enable_cbc(phys_addr_t cbcr) ; }
+/* Global Distributed Switch Controller - these are + * breaker switches for entire peripherals like USB, + * they control power and clocks and must be turned on + * before configuring clocks or accessing the peripheral. + */ +void gdsc_enable(phys_addr_t gdscr) +{ + u32 count; + + clrbits_le32(gdscr, GDSC_SW_COLLAPSE); + for (count = 0; count < 1500; count++) { + if (readl(gdscr) & GDSC_PWR_ON) + break; + udelay(1); + } + WARN(count == 1500, "WARNING: GDSC @ %#llx stuck at off\n", gdscr); +} + void clk_enable_gpll0(phys_addr_t base, const struct pll_vote_clk *gpll0) { if (readl(base + gpll0->status) & gpll0->status_bit) diff --git a/drivers/clk/qcom/clock-qcom.h b/drivers/clk/qcom/clock-qcom.h index 7eb26369cd8f..2e074d0401c4 100644 --- a/drivers/clk/qcom/clock-qcom.h +++ b/drivers/clk/qcom/clock-qcom.h @@ -12,6 +12,9 @@ #define CFG_CLK_SRC_GPLL0_EVEN (6 << 8) #define CFG_CLK_SRC_MASK (7 << 8)
+#define GDSC_PWR_ON BIT(31) +#define GDSC_SW_COLLAPSE BIT(0) + #define RCG_CFG_REG 0x4 #define RCG_M_REG 0x8 #define RCG_N_REG 0xc @@ -78,6 +81,7 @@ int qcom_cc_bind(struct udevice *parent); void clk_enable_gpll0(phys_addr_t base, const struct pll_vote_clk *gpll0); void clk_bcr_update(phys_addr_t apps_cmd_rgcr); void clk_enable_cbc(phys_addr_t cbcr); +void gdsc_enable(phys_addr_t gdscr); void clk_enable_vote_clk(phys_addr_t base, const struct vote_clk *vclk); const struct freq_tbl *qcom_find_freq(const struct freq_tbl *f, uint rate); void clk_rcg_set_rate_mnd(phys_addr_t base, uint32_t cmd_rcgr,
Most devices only initialise the USB clocks for us if we boot via "fastboot boot", add the missing clock configuration to get both USB ports working regardless of the bootloader state.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/clk/qcom/clock-sdm845.c | 29 +++++++++++++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/drivers/clk/qcom/clock-sdm845.c b/drivers/clk/qcom/clock-sdm845.c index 5d6c0cdaeee5..e5033cacb216 100644 --- a/drivers/clk/qcom/clock-sdm845.c +++ b/drivers/clk/qcom/clock-sdm845.c @@ -21,6 +21,13 @@
+#define USB30_PRIM_MASTER_CLK_CMD_RCGR 0xf018 +#define USB30_PRIM_MOCK_UTMI_CLK_CMD_RCGR 0xf030 +#define USB3_PRIM_PHY_AUX_CMD_RCGR 0xf05c + +#define USB30_PRIM_GDSCR 0xf004 +#define USB30_SEC_GDSCR 0x10004 + static const struct freq_tbl ftbl_gcc_qupv3_wrap0_s0_clk_src[] = { F(7372800, CFG_CLK_SRC_GPLL0_EVEN, 1, 384, 15625), F(14745600, CFG_CLK_SRC_GPLL0_EVEN, 1, 768, 15625), @@ -57,6 +64,8 @@ static ulong sdm845_clk_set_rate(struct clk *clk, ulong rate) }
static const struct gate_clk sdm845_clks[] = { + GATE_CLK(GCC_AGGRE_USB3_SEC_AXI_CLK, 0x82020, 0x00000001), + GATE_CLK(GCC_CFG_NOC_USB3_SEC_AXI_CLK, 0x05030, 0x00000001), GATE_CLK(GCC_QUPV3_WRAP0_S0_CLK, 0x5200c, 0x00000400), GATE_CLK(GCC_QUPV3_WRAP0_S1_CLK, 0x5200c, 0x00000800), GATE_CLK(GCC_QUPV3_WRAP0_S2_CLK, 0x5200c, 0x00001000), @@ -121,6 +130,26 @@ static int sdm845_clk_enable(struct clk *clk)
debug("%s: clk %s\n", __func__, sdm845_clks[clk->id].name);
+ switch (clk->id) { + case GCC_USB30_PRIM_MASTER_CLK: + gdsc_enable(priv->base + USB30_PRIM_GDSCR); + qcom_gate_clk_en(priv, GCC_USB_PHY_CFG_AHB2PHY_CLK); + /* These numbers are just pulled from the frequency tables in the Linux driver */ + clk_rcg_set_rate_mnd(priv->base, USB30_PRIM_MASTER_CLK_CMD_RCGR, + (4.5 * 2) - 1, 0, 0, 1 << 8, 8); + clk_rcg_set_rate_mnd(priv->base, USB30_PRIM_MOCK_UTMI_CLK_CMD_RCGR, + 1, 0, 0, 0, 8); + clk_rcg_set_rate_mnd(priv->base, USB3_PRIM_PHY_AUX_CMD_RCGR, + 1, 0, 0, 0, 8); + case GCC_USB30_SEC_MASTER_CLK: + gdsc_enable(priv->base + USB30_SEC_GDSCR); + qcom_gate_clk_en(priv, GCC_USB3_SEC_PHY_AUX_CLK); + + qcom_gate_clk_en(priv, GCC_USB3_SEC_CLKREF_CLK); + qcom_gate_clk_en(priv, GCC_USB3_SEC_PHY_COM_AUX_CLK); + break; + } + qcom_gate_clk_en(priv, clk->id);
- switch (clk->id) {
- case GCC_USB30_PRIM_MASTER_CLK:
1, 0, 0, 0, 8);
1, 0, 0, 0, 8);
- case GCC_USB30_SEC_MASTER_CLK:
Is this supposed to break? Otherwise can we add a "fallthrough;" annotation?
break;
regards, dan carpenter
The .direction_input and .direction_output ops are deprecated, and don't seem to behave properly for us. Implement our own .set_flags op to handle this correctly.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/gpio/msm_gpio.c | 21 ++++++++++++++++++--- 1 file changed, 18 insertions(+), 3 deletions(-)
diff --git a/drivers/gpio/msm_gpio.c b/drivers/gpio/msm_gpio.c index 80cd28bb231f..0230305af299 100644 --- a/drivers/gpio/msm_gpio.c +++ b/drivers/gpio/msm_gpio.c @@ -72,6 +72,23 @@ static int msm_gpio_direction_output(struct udevice *dev, unsigned int gpio, return 0; }
+static int msm_gpio_set_flags(struct udevice *dev, unsigned int gpio, ulong flags) +{ + if (flags & GPIOD_IS_OUT_ACTIVE) { + return msm_gpio_direction_output(dev, gpio, 1); + } else if (flags & GPIOD_IS_OUT) { + return msm_gpio_direction_output(dev, gpio, 0); + } else if (flags & GPIOD_IS_IN) { + return msm_gpio_direction_input(dev, gpio); + if (flags & GPIOD_PULL_UP) + return msm_gpio_set_value(dev, gpio, 1); + else if (flags & GPIOD_PULL_DOWN) + return msm_gpio_set_value(dev, gpio, 0); + } + + return 0; +} + static int msm_gpio_get_value(struct udevice *dev, unsigned int gpio) { struct msm_gpio_bank *priv = dev_get_priv(dev); @@ -90,10 +107,8 @@ static int msm_gpio_get_function(struct udevice *dev, unsigned int gpio) }
static const struct dm_gpio_ops gpio_msm_ops = { - .direction_input = msm_gpio_direction_input, - .direction_output = msm_gpio_direction_output, + .set_flags = msm_gpio_set_flags, .get_value = msm_gpio_get_value, - .set_value = msm_gpio_set_value, .get_function = msm_gpio_get_function, };
- if (flags & GPIOD_IS_OUT_ACTIVE) {
- } else if (flags & GPIOD_IS_OUT) {
- } else if (flags & GPIOD_IS_IN) {
These lines are unreachable code.
When using OF_LIVE, the debug UART driver won't be probed if it's a subnode of the geni-se-qup controller. Add a NOP driver for the controller to correctly discover its child nodes.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/serial/serial_msm_geni.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/serial/serial_msm_geni.c b/drivers/serial/serial_msm_geni.c index e5c3dcffc1c6..6455b0fff63c 100644 --- a/drivers/serial/serial_msm_geni.c +++ b/drivers/serial/serial_msm_geni.c @@ -606,6 +606,19 @@ U_BOOT_DRIVER(serial_msm_geni) = { .flags = DM_FLAG_PRE_RELOC, };
+static const struct udevice_id geniqup_ids[] = { + { .compatible = "qcom,geni-se-qup" }, + { } +}; + +U_BOOT_DRIVER(geni_se_qup) = { + .name = "geni-se-qup", + .id = UCLASS_NOP, + .of_match = geniqup_ids, + .bind = dm_scan_fdt_dev, + .flags = DM_FLAG_PRE_RELOC, +}; + #ifdef CONFIG_DEBUG_UART_MSM_GENI
static struct msm_serial_data init_serial_data = {
We don't support USB super-speed in U-Boot yet, we lack the SS PHY drivers, however from my testing even with a PHY driver there seem to be other issues when talking to super-speed peripherals.
In pursuit of maintaining upstream DT compatibility, and simplifying porting for new devices, let's implement the DT fixups necessary to configure USB in high-speed only mode at runtime. The pattern is identical for all Qualcomm boards that use the Synaptics DWC3 controller:
* Add an additional property on the Qualcomm wrapper node * Remove the super-speed phy phandle and phy-name entries.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/mach-snapdragon/board.c | 88 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 88 insertions(+)
diff --git a/arch/arm/mach-snapdragon/board.c b/arch/arm/mach-snapdragon/board.c index ca300dc843a9..44925e369d8e 100644 --- a/arch/arm/mach-snapdragon/board.c +++ b/arch/arm/mach-snapdragon/board.c @@ -146,6 +146,93 @@ int board_usb_init(int index, enum usb_init_type init) return 0; }
+/* U-Boot only supports USB high-speed mode on Qualcomm platforms with DWC3 + * USB controllers. Rather than requiring source level DT changes, we fix up + * DT here. This improves compatibility with upstream DT and simplifies the + * porting process for new devices. + */ +#if CONFIG_IS_ENABLED(OF_LIVE) +static int fixup_qcom_dwc3(struct device_node *glue_np) +{ + struct device_node *dwc3; + int ret, len, hsphy_idx = 1; + const __be32 *phandles; + const char *second_phy_name; + + debug("Fixing up %s\n", glue_np->name); + + /* Tell the glue driver to configure the wrapper for high-speed only operation */ + ret = of_write_prop(glue_np, "qcom,select-utmi-as-pipe-clk", NULL, 0); + if (ret) { + log_err("Failed to add property 'qcom,select-utmi-as-pipe-clk': %d\n", ret); + return ret; + } + + /* Find the DWC3 node itself */ + dwc3 = of_find_compatible_node(glue_np, NULL, "snps,dwc3"); + if (!dwc3) { + log_err("Failed to find dwc3 node\n"); + return -ENOENT; + } + + phandles = of_get_property(dwc3, "phys", &len); + len /= sizeof(*phandles); + if (len == 1) { + log_debug("Only one phy, not a superspeed controller\n"); + return 0; + } + + /* Figure out if the superspeed phy is present and if so then which phy is it? */ + ret = of_property_read_string_index(dwc3, "phy-names", 1, &second_phy_name); + if (ret == -ENODATA) { + log_debug("Only one phy, not a super-speed controller\n"); + return 0; + } else if (ret) { + log_err("Failed to read second phy name: %d\n", ret); + return ret; + } + + if (!strncmp("usb3-phy", second_phy_name, strlen("usb3-phy"))) { + log_debug("Second phy isn't superspeed (is '%s') assuming first phy is SS\n", + second_phy_name); + hsphy_idx = 0; + } + + /* Overwrite the "phys" property to only contain the high-speed phy */ + ret = of_write_prop(dwc3, "phys", sizeof(*phandles), phandles + hsphy_idx); + if (ret) { + log_err("Failed to overwrite 'phys' property: %d\n", ret); + return ret; + } + + /* Overwrite "phy-names" to only contain a single entry */ + ret = of_write_prop(dwc3, "phy-names", strlen("usb2-phy"), "usb2-phy"); + if (ret) { + log_err("Failed to overwrite 'phy-names' property: %d\n", ret); + return ret; + } + + return 0; +} + +static void fixup_usb_nodes(void) +{ + struct device_node *glue_np = NULL; + int ret; + + while ((glue_np = of_find_compatible_node(glue_np, NULL, "qcom,dwc3"))) { + ret = fixup_qcom_dwc3(glue_np); + if (ret) + log_warning("Failed to fixup node %s: %d\n", glue_np->name, ret); + } +} +#else +static void fixup_usb_nodes(void) +{ + log_debug("Unable to dynamically fixup USB nodes, please enable CONFIG_OF_LIVE\n"); +} +#endif + /* * Some boards still need board specific init code, they can implement that by * overriding this function. @@ -159,6 +246,7 @@ void __weak qcom_board_init(void) int board_init(void) { show_psci_version(); + fixup_usb_nodes(); qcom_board_init(); return 0; }
The USB VBUS supply for the type-A port is enabled via a GPIO regulator. This is incorrectly modelled in Linux where only the PCIe dependency is expressed. Add a U-Boot specific dtsi snippet so that this supply will get enabled when initialising USB.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/sdm845-db845c-u-boot.dtsi | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/dts/sdm845-db845c-u-boot.dtsi b/arch/arm/dts/sdm845-db845c-u-boot.dtsi new file mode 100644 index 000000000000..3c83e21251c4 --- /dev/null +++ b/arch/arm/dts/sdm845-db845c-u-boot.dtsi @@ -0,0 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0 + +/* This GPIO must be turned on to enable the 5v VBUS + * supply on the USB port. + */ +&usb_2_dwc3 { + vbus-supply = <&pcie0_3p3v_dual>; +};
Prepare to enable some additional features.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- configs/qcom_defconfig | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/configs/qcom_defconfig b/configs/qcom_defconfig index 3c6bdc2071b2..659775852c07 100644 --- a/configs/qcom_defconfig +++ b/configs/qcom_defconfig @@ -12,13 +12,13 @@ CONFIG_BOOTSTD_FULL=y # CONFIG_BOOTMETH_SCRIPT is not set CONFIG_BOOTDELAY=1 CONFIG_USE_PREBOOT=y +CONFIG_SYS_CBSIZE=512 CONFIG_LOG_MAX_LEVEL=9 CONFIG_LOG_DEFAULT_LEVEL=4 # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=64 -CONFIG_SYS_CBSIZE=512 CONFIG_CMD_BOOTMENU=y CONFIG_CMD_CLK=y CONFIG_CMD_GPIO=y @@ -33,6 +33,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_LOG=y CONFIG_EFI_PARTITION=y # CONFIG_NET is not set +CONFIG_BUTTON_QCOM_PMIC=y CONFIG_CLK=y CONFIG_CLK_QCOM_QCS404=y CONFIG_CLK_QCOM_SDM845=y @@ -40,7 +41,6 @@ CONFIG_MSM_GPIO=y CONFIG_QCOM_PMIC_GPIO=y CONFIG_DM_KEYBOARD=y CONFIG_BUTTON_KEYBOARD=y -CONFIG_BUTTON_QCOM_PMIC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_MSM=y CONFIG_PHY=y @@ -50,7 +50,6 @@ CONFIG_PINCTRL_QCOM_SDM845=y CONFIG_DM_PMIC=y CONFIG_PMIC_QCOM=y CONFIG_SCSI=y -CONFIG_DM_SCSI=y CONFIG_MSM_SERIAL=y CONFIG_MSM_GENI_SERIAL=y CONFIG_SPMI_MSM=y
Qualcomm FDTs are on the larger size, and with the addition of DT modifications during board_init() it makes sense to enable OF_LIVE globally. The cost of building the tree should be offset by the increased efficiency at which we can walk it.
Some rough measurements with CONFIG_BOOTSTAGE suggests that this might add 0.1-0.2ms to the boot-to-console time. However the reset-to-reset timer difference is in the range of 0.5ms so this could just be noise.
Suffice to say, no significant slow down.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- configs/qcom_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/qcom_defconfig b/configs/qcom_defconfig index 659775852c07..3935fe2ef59f 100644 --- a/configs/qcom_defconfig +++ b/configs/qcom_defconfig @@ -32,7 +32,9 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_LOG=y CONFIG_EFI_PARTITION=y +CONFIG_OF_LIVE=y # CONFIG_NET is not set +# CONFIG_OFNODE_MULTI_TREE is not set CONFIG_BUTTON_QCOM_PMIC=y CONFIG_CLK=y CONFIG_CLK_QCOM_QCS404=y
Enable support for the DWC3 USB controller and required dependencies for Qualcomm boards, specifically the DB845c: * IOMMU / SMMU * USB high-speed PHYs * Mass storage and ACM gadgets
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- configs/qcom_defconfig | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/configs/qcom_defconfig b/configs/qcom_defconfig index 3935fe2ef59f..dedd5f20b719 100644 --- a/configs/qcom_defconfig +++ b/configs/qcom_defconfig @@ -13,6 +13,7 @@ CONFIG_BOOTSTD_FULL=y CONFIG_BOOTDELAY=1 CONFIG_USE_PREBOOT=y CONFIG_SYS_CBSIZE=512 +# CONFIG_SYS_DEVICE_NULLDEV is not set CONFIG_LOG_MAX_LEVEL=9 CONFIG_LOG_DEFAULT_LEVEL=4 # CONFIG_DISPLAY_CPUINFO is not set @@ -26,6 +27,8 @@ CONFIG_CMD_MMC=y CONFIG_CMD_PART=y CONFIG_CMD_UFS=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_UMS_ABORT_KEYED=y CONFIG_CMD_CAT=y CONFIG_CMD_BMP=y CONFIG_CMD_FAT=y @@ -35,6 +38,7 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_LIVE=y # CONFIG_NET is not set # CONFIG_OFNODE_MULTI_TREE is not set +CONFIG_DM_WARN=y CONFIG_BUTTON_QCOM_PMIC=y CONFIG_CLK=y CONFIG_CLK_QCOM_QCS404=y @@ -43,14 +47,21 @@ CONFIG_MSM_GPIO=y CONFIG_QCOM_PMIC_GPIO=y CONFIG_DM_KEYBOARD=y CONFIG_BUTTON_KEYBOARD=y +CONFIG_IOMMU=y +CONFIG_QCOM_HYP_SMMU=y +CONFIG_MISC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_MSM=y CONFIG_PHY=y +CONFIG_PHY_QCOM_QUSB2=y +CONFIG_PHY_QCOM_USB_HS_7NM=y CONFIG_PINCTRL=y CONFIG_PINCTRL_QCOM_QCS404=y CONFIG_PINCTRL_QCOM_SDM845=y CONFIG_DM_PMIC=y CONFIG_PMIC_QCOM=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y CONFIG_SCSI=y CONFIG_MSM_SERIAL=y CONFIG_MSM_GENI_SERIAL=y @@ -61,7 +72,11 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_FUNCTION_ACM=y CONFIG_UFS=y CONFIG_VIDEO=y # CONFIG_VIDEO_FONT_8X16 is not set
Caleb Connolly
Dan Carpenter
