[U-Boot] [PATCH 04/11] video: Add 32-bit color depth support for VBE
The TunnelCreek IGD VBE reports 32-bit color depth regardless 24-bit color depth is configured. Since 24-bit mode already uses 4 bytes internally, it should be OK to just add this option in switch case.
Signed-off-by: Jian Luo jian.luo4@boschrexroth.de Tested-by: Bin Meng bmeng.cn@gmail.com ---
drivers/pci/pci_rom.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/pci/pci_rom.c b/drivers/pci/pci_rom.c index e6f4806..83c69a5 100644 --- a/drivers/pci/pci_rom.c +++ b/drivers/pci/pci_rom.c @@ -202,6 +202,7 @@ int vbe_get_video_info(struct graphic_device *gdev) gdev->gdfBytesPP = vesa->bits_per_pixel / 8;
switch (vesa->bits_per_pixel) { + case 32: case 24: gdev->gdfIndex = GDF_32BIT_X888RGB; break;
Bin Meng
