[U-Boot] [PATCH] OMAP3: TAM3517: update ehci interface
Changed the EHCI interface using the ulpi framework.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Tom Rini tom.rini@gmail.com ---
This patch is based and tested on top of Govindraj's patches for EHCI omap: http://patchwork.ozlabs.org/patch/139377/
board/technexion/twister/twister.c | 32 ++++++++++++++++++++++++++++++++ include/configs/tam3517-common.h | 2 ++ 2 files changed, 34 insertions(+), 0 deletions(-)
diff --git a/board/technexion/twister/twister.c b/board/technexion/twister/twister.c index 4d34d24..831fb4c 100644 --- a/board/technexion/twister/twister.c +++ b/board/technexion/twister/twister.c @@ -33,6 +33,10 @@ #include <asm/arch/mmc_host_def.h> #include <i2c.h> #include <asm/gpio.h> +#ifdef CONFIG_USB_EHCI +#include <usb.h> +#include <asm/ehci-omap.h> +#endif #include "twister.h"
DECLARE_GLOBAL_DATA_PTR; @@ -56,6 +60,34 @@ static const u32 gpmc_XR16L2751[] = { XR16L2751_GPMC_CONFIG6, };
+#ifdef CONFIG_USB_EHCI + +static struct omap_usbhs_board_data usbhs_bdata = { + .port_mode[0] = OMAP_EHCI_PORT_MODE_PHY, + .port_mode[1] = OMAP_EHCI_PORT_MODE_PHY, + .port_mode[2] = OMAP_EHCI_PORT_MODE_PHY, +}; + +int ehci_hcd_init(void) +{ + int ret; + + ret = omap_ehci_hcd_init(&usbhs_bdata); + if (ret < 0) + return ret; + + return 0; +} + +int ehci_hcd_stop(void) +{ + int ret; + + ret = omap_ehci_hcd_stop(); + return ret; +} +#endif + int board_init(void) { gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 817d468..13eeadb 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -100,6 +100,8 @@ #define CONFIG_OMAP3_GPIO_5 #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_OMAP +#define CONFIG_USB_ULPI +#define CONFIG_USB_ULPI_VIEWPORT_OMAP #define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 25 #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 #define CONFIG_USB_STORAGE
Hi Stefano,
- .port_mode[0] = OMAP_EHCI_PORT_MODE_PHY,
- .port_mode[1] = OMAP_EHCI_PORT_MODE_PHY,
- .port_mode[2] = OMAP_EHCI_PORT_MODE_PHY,
OMAP EHCI port3 is TLL only, so the above does not look right...
- int ret;
- ret = omap_ehci_hcd_init(&usbhs_bdata);
- if (ret < 0)
return ret;
return omap_ehci_hcd_init(&usbhs_bdata); ?
- int ret;
- ret = omap_ehci_hcd_stop();
- return ret;
return omap_ehci_hcd_stop(); ?
+} +#endif
On 06/02/2012 15:55, Igor Grinberg wrote:
Hi Stefano,
Hi Igor,
This is a strange effect. I have tested setting OMAP_EHCI_PORT_MODE_PHY (of course the phy is on another port), and everything works. However, after setting port_mode[2] to OMAP_USBHS_PORT_MODE_NONE, it does not work anymore and no storage are detected. I have not an explanation, maybe some of you can give some hints. Really, the change should have no effect...
Right, I'll fix
I fix this, too
Best regards, Stefano Babic
I get the cause in ehci-omap.c:
rev = readl(&uhh->rev); if (rev == OMAP_USBHS_REV1) { if (is_ehci_phy_mode(usbhs_pdata->port_mode[0])) clrbits_le32(®, OMAP_UHH_HOSTCONFIG_ULPI_P1_BYPASS); else setbits_le32(®, OMAP_UHH_HOSTCONFIG_ULPI_P1_BYPASS);
if (is_ehci_phy_mode(usbhs_pdata->port_mode[1])) clrbits_le32(®, OMAP_UHH_HOSTCONFIG_ULPI_P2_BYPASS); else setbits_le32(®, OMAP_UHH_HOSTCONFIG_ULPI_P1_BYPASS);
if (is_ehci_phy_mode(usbhs_pdata->port_mode[2])) clrbits_le32(®, OMAP_UHH_HOSTCONFIG_ULPI_P3_BYPASS); else setbits_le32(®, OMAP_UHH_HOSTCONFIG_ULPI_P1_BYPASS); ^--but these should be cleared for port 0
So if PORT2 is set to unused, as it should be and discovered by Igor, omap_ehci_hcd_init sets OMAP_UHH_HOSTCONFIG_ULPI_P1_BYPASS against port 0.
What do you think about ?
Stefano
Hi Stefano,
Looks like this is copy paste error from my side, (for port2/3 it should have been bypass for port2/3 rather its port1 set in bypass mode)
I will correct this part and repost the patch.
Thanks for catching this.
-- Thanks, Govindraj.R
Thanks - only for info, I have already tested with these changes and everything works.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Tom Rini tom.rini@gmail.com --- This patch is based and tested on top of Govindraj's patches for EHCI omap: http://patchwork.ozlabs.org/patch/139377/
Changes since V1: - do not use temporary variable to return values (Igor Grinberg) - port 2 is TTL, cannot be PHY (Igor Grinberg)
board/technexion/twister/twister.c | 22 ++++++++++++++++++++++ include/configs/tam3517-common.h | 2 ++ 2 files changed, 24 insertions(+), 0 deletions(-)
diff --git a/board/technexion/twister/twister.c b/board/technexion/twister/twister.c index 4d34d24..b927586 100644 --- a/board/technexion/twister/twister.c +++ b/board/technexion/twister/twister.c @@ -33,6 +33,10 @@ #include <asm/arch/mmc_host_def.h> #include <i2c.h> #include <asm/gpio.h> +#ifdef CONFIG_USB_EHCI +#include <usb.h> +#include <asm/ehci-omap.h> +#endif #include "twister.h"
DECLARE_GLOBAL_DATA_PTR; @@ -56,6 +60,24 @@ static const u32 gpmc_XR16L2751[] = { XR16L2751_GPMC_CONFIG6, };
+#ifdef CONFIG_USB_EHCI +static struct omap_usbhs_board_data usbhs_bdata = { + .port_mode[0] = OMAP_EHCI_PORT_MODE_PHY, + .port_mode[1] = OMAP_EHCI_PORT_MODE_PHY, + .port_mode[2] = OMAP_USBHS_PORT_MODE_UNUSED, +}; + +int ehci_hcd_init(void) +{ + return omap_ehci_hcd_init(&usbhs_bdata); +} + +int ehci_hcd_stop(void) +{ + return omap_ehci_hcd_stop(); +} +#endif + int board_init(void) { gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 817d468..13eeadb 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -100,6 +100,8 @@ #define CONFIG_OMAP3_GPIO_5 #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_OMAP +#define CONFIG_USB_ULPI +#define CONFIG_USB_ULPI_VIEWPORT_OMAP #define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 25 #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 #define CONFIG_USB_STORAGE
Acked-by: Igor Grinberg grinberg@compulab.co.il
Changes since V1:
- .port_mode[2] = OMAP_USBHS_PORT_MODE_UNUSED,
- return omap_ehci_hcd_init(&usbhs_bdata);
- return omap_ehci_hcd_stop();
+} +#endif
Govindraj
Igor Grinberg
Stefano Babic
