[U-Boot] [PATCH] ppc4xx/fdt/flash: Fix bug in fdt_fixup_nor_flash_node()
This patch fixes a bug in fdt_fixup_nor_flash_node() when the reg property has multiple reg tuples, like:
reg = <0 0x00000000 0x04000000 0 0x04000000 0x04000000>;
In this case this function did not update the reg property correctly.
Signed-off-by: Stefan Roese sr@denx.de --- common/fdt_support.c | 17 ++++++++++------- 1 files changed, 10 insertions(+), 7 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index 6f32e3f..0ed6e77 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -620,7 +620,7 @@ int fdt_fixup_nor_flash_size(void *blob) int off; int len; struct fdt_property *prop; - u32 *reg; + u32 *reg, *reg2; int i;
for (i = 0; i < 2; i++) { @@ -640,18 +640,21 @@ int fdt_fixup_nor_flash_size(void *blob) * There might be multiple reg-tuples, * so loop through them all */ - len /= tuple_size; - reg = (u32 *)&prop->data[0]; - for (idx = 0; idx < len; idx++) { + reg = reg2 = (u32 *)&prop->data[0]; + for (idx = 0; idx < (len / tuple_size); idx++) { /* * Update size in reg property */ reg[2] = flash_get_bank_size(reg[0], idx); - fdt_setprop(blob, off, "reg", reg, - tuple_size); - reg += tuple_size; + + /* + * Point to next reg tuple + */ + reg += 3; } + + fdt_setprop(blob, off, "reg", reg2, len); }
/* Move to next compatible node */
Applied to u-boot-ppc4xx/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
