[PATCH v1] net: sun8i-emac: Add support for fixed-link phy
Based on dt-specs fixed-link doesn't require phy-handle to be used. Fix driver to only read phy related setting when phy-handle is found.
Signed-off-by: Maksim Kiselev bigunclemax@gmail.com --- drivers/net/sun8i_emac.c | 7 ++----- 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 04c3274fbe..0e339d69e0 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -834,11 +834,8 @@ static int sun8i_emac_eth_of_to_plat(struct udevice *dev) priv->use_internal_phy = false;
offset = fdtdec_lookup_phandle(gd->fdt_blob, node, "phy-handle"); - if (offset < 0) { - debug("%s: Cannot find PHY address\n", __func__); - return -EINVAL; - } - priv->phyaddr = fdtdec_get_int(gd->fdt_blob, offset, "reg", -1); + if (offset >= 0) + priv->phyaddr = fdtdec_get_int(gd->fdt_blob, offset, "reg", -1);
pdata->phy_interface = dev_read_phy_mode(dev); debug("phy interface %d\n", pdata->phy_interface);
if (offset < 0) {
return -EINVAL;
if (offset >= 0)
priv->phyaddr = fdtdec_get_int(gd->fdt_blob, offset, "reg", -1); pdata->phy_interface = dev_read_phy_mode(dev); debug("phy interface %d\n", pdata->phy_interface);
-- 2.39.2
Reviewed-by: Ramon Fried rfried.dev@gmail.com
On Thu, 15 Jun 2023 00:44:06 +0300 Maxim Kiselev bigunclemax@gmail.com wrote:
Hi Maxim,
Do you have such a board? And where is that written down? I don't see it explicitly mentioned as optional in ethernet-controller.yaml or in the DT spec PDF. The sun8i EMAC binding lists phy-handle as required, so that would need to be relaxed there then.
The patch itself looks fine, we already specify -1 as the default when the PHY DT node does not contain a reg property, so that looks like it would work.
Cheers, Andre
- if (offset < 0) {
return -EINVAL;
if (offset >= 0)
вт, 16 янв. 2024 г. в 03:18, Andre Przywara andre.przywara@arm.com:
Hi Maxim,
Yes, I had a custom board with T113 SoC which has fixed phy eth.
Sorry for that commit description. I just found the similar commit, that fixes the same problem for zynq_gem 3888c8d1979289efe685fe29276aed4d4b685975 ("net: zynq_gem: Add support for fixed-link phy") and copied the description from there.
Oh, indeed. So it will require to send dt-binding changes to Linux first...
Therefore, I think we can live without fixed-phy support for sun8i EMAC. At least until some device with such a configuration appears on the market :)
Cheers, Andre
if (offset < 0) {
return -EINVAL;
if (offset >= 0)
Best wishes, Maksim
On Tue, 16 Jan 2024 19:58:56 +0300 Maxim Kiselev bigunclemax@gmail.com wrote:
Hi Maxim,
Hi Maxim,
Well, in the long run yes, but this doesn't mean that this patch needs to wait - if that fixes a problem for you. I think in general that rationale is probably true and phy-handle should be optional, especially since the code can already cope with it.
I would just like to have this documented in the commit message.
Cheers, Andre
Cheers, Andre
if (offset < 0) {
return -EINVAL;
if (offset >= 0)
Best wishes, Maksim
Hi Maxim,
Hi Maxim,
So just to clarify: this board connected something like a switch directly to the MAC, just using RMII/RGMII? And then you have a fixed-phy node in the DT, detailing the speed and duplex parameters? Matching the fixed-phy node description in ethernet-controller.yaml? And drivers/net/phy/fixed.c takes care of parsing that?
Well, I am fine with that patch if it fixes a problem for you. It looks like requiring the phy-handle property is too strict, and just needs to be relaxed in the binding. If I see this correctly, the driver would still accept every valid DT, by today's and future bindings?
If you could just confirm my above assumptions, and maybe send a v2 with an amended commit message, I would be happy to merge that patch.
Cheers, Andre
Cheers, Andre
if (offset < 0) {
return -EINVAL;
if (offset >= 0)
Best wishes, Maksim
Hi Andre,
пт, 19 янв. 2024 г. в 20:35, Andre Przywara andre.przywara@arm.com:
Hi Maxim,
Hi Maxim,
Yes, you are absolutely right. The T113s connected directly to the switch port via RMII interface. Here is the part of DT, that describes that configuration
&emac { pinctrl-names = "default"; pinctrl-0 = <&rmii_pg_pins>; phy-mode = "rmii"; snps,reset-gpio = <&pio 4 12 GPIO_ACTIVE_LOW>; /* PE12 */ allwinner,tx-delay-ps = <700>; allwinner,rx-delay-ps = <3100>;
fixed-link { speed = <100>; full-duplex; }; };
Sure, I'll fix the commit description and send v2 asap.
Cheers, Andre
Cheers, Andre
if (offset < 0) {
return -EINVAL;
if (offset >= 0)
Best wishes, Maksim
Best wishes, Maksim
On Fri, 19 Jan 2024 21:11:07 +0300 Maxim Kiselev bigunclemax@gmail.com wrote:
Hi Maxim,
Hi Maxim,
Hi Maxim,
Excellent, thanks for the confirmation!
Looking forward to v2!
Cheers, Andre
Cheers, Andre
Cheers, Andre
if (offset < 0) {
return -EINVAL;
if (offset >= 0)
Best wishes, Maksim
Best wishes, Maksim
Andre Przywara
Maxim Kiselev
Ramon Fried
