[U-Boot] [PATCH 0/5] sunxi: env: Load environment from boot media
At the moment we need to configure the place where U-Boot tries to load its environment from at compile time. This is not only inflexible, but also unnecessary, as we have easy access to the boot source.
This series prepares U-Boot on Allwinner boards to load the environment from the same media where the SPL and U-Boot proper were loaded from. This allows to keep one firmware binary, and copy it to an SD card, eMMC or even SPI flash, without needing to configure it differently.
Patches 1 and 2 introduce that runtime decision for a raw MMC environment, patches 3 and 4 for FAT. Patch 5 considers the boot source when working out the location priority for the environment: it will always consider the boot source first, then fall back to the existing algorithm.
This enables to build flasher images, which boot from SD card, but for instance provide a bootmenu with the option to copy this very image to eMMC or SPI flash.
Cheers, Andre.
Andre Przywara (5): env: allow undefined CONFIG_SYS_MMC_ENV_DEV sunxi: autodetect SD/eMMC device for environment env: allow runtime determination of FAT environment partition sunxi: use FAT environment from boot source sunxi: use boot source for determining environment location
board/sunxi/board.c | 67 +++++++++++++++++++++++++++++++++++++----- env/fat.c | 13 +++++--- env/mmc.c | 4 +++ include/configs/sunxi-common.h | 7 ----- include/environment.h | 4 +++ 5 files changed, 76 insertions(+), 19 deletions(-)
So far we are required to always define the CONFIG_SYS_MMC_ENV_DEV variable, even if a platform specific function overrides the weak function that is using it.
Check for the existence of this Kconfig variable, eliminating the need to define a dummy value.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- env/mmc.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/env/mmc.c b/env/mmc.c index c3cf35d01b..122fec3af8 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -124,7 +124,11 @@ __weak int mmc_get_env_addr(struct mmc *mmc, int copy, u32 *env_addr)
__weak int mmc_get_env_dev(void) { +#ifdef CONFIG_SYS_MMC_ENV_DEV return CONFIG_SYS_MMC_ENV_DEV; +#else + return 0; +#endif }
#ifdef CONFIG_SYS_MMC_ENV_PART
+#endif }
Since 0 is a valid device, I'm concerned this might lead to unintended behavior. Can we return some error code here and catch it later?
On Sat, 8 Jun 2019 09:13:52 -0400 Tom Rini trini@konsulko.com wrote:
Hi Tom,
thanks for having a look!
+#endif }
I see your point. I think originally my idea was that 0 would hopefully be a valid device in any case, so it would just work in those cases. But I see the trouble that this papers over a bug (namely CONFIG_SYS_MMC_ENV_DEV not being defined). Looking at all those users I find it rather dangerous (and tedious) to check for this in all callers.
What about printing an error message, here in that function? Ideally this would be spotted immediately upon initial testing, so would never be exposed to a real user. Something like "Please either define CONFIG_SYS_MMC_ENV_DEV or provide a mmc_get_en_dev() implementation."?
Cheers, Andre.
Hi Tom,
+#endif }
That might be OK. Just check the resulting binaries that the string does get discarded from the build when we have a non-weak function in that case. Thanks!
When using the environment from a raw MMC device, we are required to specify the desired device number at configuration time. This creates problems when the same image is booted from SD cards and eMMC devices.
Override the generic weak definition of mmc_get_env_dev() to query for the boot source, returning the corresponding device number. This will automatically pick the environment from the right device.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- board/sunxi/board.c | 19 +++++++++++++++++++ include/configs/sunxi-common.h | 7 ------- 2 files changed, 19 insertions(+), 7 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 98bc3cd0c1..973dba4578 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -208,6 +208,25 @@ enum env_location env_get_location(enum env_operation op, int prio) } #endif
+/* Determine whether to use the environment from SD card or eMMC. */ +int mmc_get_env_dev(void) +{ + /* Use the environment from the boot device, if booted from (e)MMC. */ + switch (sunxi_get_boot_device()) { + case BOOT_DEVICE_MMC1: + return 0; + case BOOT_DEVICE_MMC2: + return 1; + } + + /* If there is no eMMC configured, use the SD card. */ + if (CONFIG_MMC_SUNXI_SLOT_EXTRA == -1) + return 0; + + /* Otherwise use the environment on the eMMC. */ + return 1; +} + #ifdef CONFIG_DM_MMC static void mmc_pinmux_setup(int sdc); #endif diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index fceb812448..aca0eca806 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -138,13 +138,6 @@ #define CONFIG_BOARD_SIZE_LIMIT 0x7e000 #endif
-#if CONFIG_MMC_SUNXI_SLOT_EXTRA != -1 -/* If we have two devices (most likely eMMC + MMC), favour the eMMC */ -#define CONFIG_SYS_MMC_ENV_DEV 1 -#else -/* Otherwise, use the only device we have */ -#define CONFIG_SYS_MMC_ENV_DEV 0 -#endif #define CONFIG_SYS_MMC_MAX_DEVICE 4 #endif
Currently the FAT device and partition which contains the environment must be configured at compile time. This creates problems for boards which have multiple bootable devices (like SD card and eMMC).
Similar to what we do for raw MMC environments, introduce a weak function to allow boards to override this static configuration. Right now we just return the Kconfig variable.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- env/fat.c | 13 +++++++++---- include/environment.h | 4 ++++ 2 files changed, 13 insertions(+), 4 deletions(-)
diff --git a/env/fat.c b/env/fat.c index 7f74c64dfe..320f73b6d3 100644 --- a/env/fat.c +++ b/env/fat.c @@ -30,6 +30,11 @@ # endif #endif
+__weak char *fat_get_env_dev_part(void) +{ + return CONFIG_ENV_FAT_DEVICE_AND_PART; +} + #ifdef CMD_SAVEENV static int env_fat_save(void) { @@ -45,8 +50,8 @@ static int env_fat_save(void) return err;
part = blk_get_device_part_str(CONFIG_ENV_FAT_INTERFACE, - CONFIG_ENV_FAT_DEVICE_AND_PART, - &dev_desc, &info, 1); + fat_get_env_dev_part(), + &dev_desc, &info, 1); if (part < 0) return 1;
@@ -92,8 +97,8 @@ static int env_fat_load(void) #endif
part = blk_get_device_part_str(CONFIG_ENV_FAT_INTERFACE, - CONFIG_ENV_FAT_DEVICE_AND_PART, - &dev_desc, &info, 1); + fat_get_env_dev_part(), + &dev_desc, &info, 1); if (part < 0) goto err_env_relocate;
diff --git a/include/environment.h b/include/environment.h index cd96676141..364adc76ba 100644 --- a/include/environment.h +++ b/include/environment.h @@ -65,6 +65,10 @@ # endif #endif
+#if defined(CONFIG_ENV_IS_IN_FAT) +char *fat_get_env_dev_part(void); +#endif + #if defined(CONFIG_ENV_IS_IN_NAND) # if defined(CONFIG_ENV_OFFSET_OOB) # ifdef CONFIG_ENV_OFFSET_REDUND
Until now we were required to configure the environment FAT partition and device at compile time, which led to problems if boards have both SD cards and eMMC and we wanted to use the same image for booting from both.
Check the boot source and use this device for finding the environment.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- board/sunxi/board.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 973dba4578..5802b079b6 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -227,6 +227,15 @@ int mmc_get_env_dev(void) return 1; }
+static char fat_device[7]; + +char *fat_get_env_dev_part(void) +{ + sprintf(fat_device, "%d:auto", mmc_get_env_dev()); + + return fat_device; +} + #ifdef CONFIG_DM_MMC static void mmc_pinmux_setup(int sdc); #endif
Currently we only support to load the environment from raw MMC or FAT locations on Allwinner boards. With the advent of SPI flash we probably also want to support using the environment there, so we need to become a bit more flexible.
Change the environment priority function to take the boot source into account. When booted from eMMC or SD card, we use FAT or MMC, if configured, as before. If we are booted from SPI flash, we try to use the environment from there, if possible. The same is true for NAND flash booting, although this is somewhat theoretical right now (as untested).
This way we can use the same image for SD and SPI flash booting, which allows us to simply copy a booted image from SD card to the SPI flash, for instance.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- board/sunxi/board.c | 39 +++++++++++++++++++++++++++++++-------- 1 file changed, 31 insertions(+), 8 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 5802b079b6..b95a1a0feb 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -192,21 +192,44 @@ void i2c_init_board(void) #endif }
-#if defined(CONFIG_ENV_IS_IN_MMC) && defined(CONFIG_ENV_IS_IN_FAT) enum env_location env_get_location(enum env_operation op, int prio) { - switch (prio) { - case 0: - return ENVL_FAT; + enum env_location boot_loc = ENVL_UNKNOWN;
- case 1: - return ENVL_MMC; + gd->env_load_prio = prio;
+ switch (sunxi_get_boot_device()) { + case BOOT_DEVICE_MMC1: + case BOOT_DEVICE_MMC2: + boot_loc = ENVL_FAT; + break; + case BOOT_DEVICE_NAND: +#ifdef CONFIG_ENV_IS_IN_NAND + boot_loc = ENVL_NAND; +#endif + break; + case BOOT_DEVICE_SPI: +#ifdef CONFIG_ENV_IS_IN_SPI_FLASH + boot_loc = ENVL_SPI_FLASH; +#endif + break; + case BOOT_DEVICE_BOARD: + boot_loc = ENVL_FAT; /* dummy to prevent crash */ + break; default: - return ENVL_UNKNOWN; + break; } -} + + /* Always try to access the environment on the boot device first. */ + if (prio == 0) + return boot_loc; + +#ifdef CONFIG_ENV_IS_IN_MMC + if (prio == 1 && boot_loc == ENVL_FAT) + return ENVL_MMC; #endif + return ENVL_UNKNOWN; +}
/* Determine whether to use the environment from SD card or eMMC. */ int mmc_get_env_dev(void)
This does change a couple of things though. The environment used to be loaded always from the same source, no matter the boot device. This means that if you would set an SD card, you would get the environment from the eMMC. Same thing for FEL. This is no longer the case.
I don't know whether it's a good or a bad thing, but it should be mentionned.
Maxime
-- Maxime Ripard, Bootlin Embedded Linux and Kernel engineering https://bootlin.com
On Mon, 10 Jun 2019 10:30:37 +0200 Maxime Ripard maxime.ripard@bootlin.com wrote:
Hi Maxime,
This is true, I failed to mention that.
To start a discussion on this: I consider the current (fixed location) behaviour somewhat surprising and limiting, and couldn't find a real use case where this would be required. Happy to hear of one! Instead I thought about those cases: - There is some botched U-Boot plus environment on the eMMC. You want to boot from SD card to have a clean start, possibly to fix it. But it will load the possibly outdated, broken or even unrelated environment from eMMC. - You want to boot from SD card without touching the eMMC at all. Saving the environment will spoil that. - You want to have one image for all possible boot media. Putting the environment on eMMC seems like a commonly accessible place, but isn't really reliable for those eMMC socket boards. I guess not many actually have a chip connected in the Pine64-LTS, SoPine or Pine-H64, for instance. Forcing the environment to SD card is equally troublesome.
I think the situation gets even worse with SPI flash booting (which was the trigger for these patches). And no, we definitely don't want multiple defconfig files per board just to cover those cases. Also asking the user to manually change the config sounds more like a workaround.
Happy to hear of cases where this behaviour would cause trouble.
For the context: These patches are part of a branch of mine, which allows to create a nice flasher image for the Pine64-LTS (and other boards with SPI flash): It boots from SD card and presents a U-Boot bootmenu, which among normal boot options offers to install this image to SPI flash, or eMMC, if connected. The installer bootmenu items live in "raw MMC" envirnment on the SD card and are not copied to SPI flash. So with these changes everything falls into place naturally.
Cheers, Andre.
Hi Maxime,
This one might be a feature though. Being able to restore / fix an environment in the eMMC running from an SD card has save me a couple of times. Or booting from the SD card because the U-Boot on the eMMC is broken, while the environment is working.
But it goes against that one, which might be more important / sensible.
That won't happen, only because NAND is a thing.
And even then, I'm not really sure that it's a good thing. A U-Boot build these days is roughly in the same sizes than a stripped down Linux image. For an inferior solution in pretty much every aspect.
Loading the environment from the boot device instead of hardcoding is pretty orthogonal to that though.
Yeah, that's true. I guess we could also rely on whether the eMMC / SD is reseponding to commands, but I don't see any particular benefit to do that.
Yeah, well, let's agree to disagree on this one.
Maxime
Hi Maxime,
Some of this is perhaps an argument for adding a sub-command to specify where the environment is to be read from. Heuristics are still only a best guess and won't get it right every time.
Hey now. We aren't _quite_ that large. And we are (really!) trying to find a happy medium between "distros want X/Y/Z for everyone" and "can we commonly get back to UNDER 512kB maybe? Please?".
Hi!
Hi Maxime,
I was mostly talking about the distribution of the image itself. While eMMC, SD and SPI flash can be made to take the same image, NAND will require a particular ECC and randomizer setup that requires that it's bundled separately.
I'm exagerating a little, but barely. A current build for the SoC Andre was mentionning takes 600kB. And since the trend has been for the binaries to grow for quite some time now, I'm pretty sure everyone will reserve 1MB just to be sure they have some room to spare.
Now, getting a kernel image to fit in a MB takes a bit of time, but it's not really impossible to achieve. And if you can reclaim that MB dedicated to U-Boot, it's actually fairly easy to do.
I've tried to have the size reduced at some time because we were corrupting our U-Boot binary as soon as we where using saveenv (which is probably one of the worst issue we could have), and it ended up with everyone agreeing that we needed to reduce the size, just not the one they were using.
It's kind of weird that people haven't yet embraced defconfig as they are in Linux, where every distro has its own configuration, and it's perfectly fine.
Maxime
On Tue, Jun 11, 2019 at 04:53:58PM +0200, Maxime Ripard wrote:
Hi!
Hi Maxime,
Right. But as you noted, there's use cases for boot from one to fix another.
Yes, it's larger than I would like, and features keep being added. But also, yes, DM stuff needs a harder look.
To the last point, distributions seemingly very much want to avoid building U-Boot and there's a growing contingent that wishes the hardware shipped with the DTB for the hardware as well.
On Tue, 11 Jun 2019 16:53:58 +0200 Maxime Ripard maxime.ripard@bootlin.com wrote:
Hi Maxime,
Looks like there are exactly 2 out of 146 Allwinner boards with mainline (_defconfig) NAND support out there, and fortunately I haven't seen NAND flash on modern (sunxi) boards in a while. And if I see this correctly, there is neither eMMC nor SD card on the C.H.I.P. devices? So their defconfig will also "boot on all possible boot media". What I was aiming at with "have one image for all possible boot media" is to not throw away what works already: the _defconfig build for most (all?) boards works naturally on eMMC and SD card, also on SPI flash, for the SPL and for U-Boot proper. It's just the environment that requires fixing. Which is what this series is about.
Yeah, I was wondering about this as well. Maxime's case of: "I want to save the environment to this device" seems like a valid use case.
Wouldn't a parameter to "saveenv" solve this rather elegantly? Happy to look into a patch for this.
Well, we can't save everyone ;-) But given the number of boards with NAND flash out there and their mainline U-Boot support ...
I think that illustrates that we are coming from *very* different areas: My kernels are 16-20 MB (distro kernels or my own monolithic test kernels), plus tons of modules. I don't care about U-Boot being less than 600KB, since it goes into the first MB of an SD card or eMMC device, or into the SPI flash, which is at least 2MB, but mostly 16MB. And honestly I don't use the U-Boot environment too much, I am just relying on the distro defaults environment to find the EFI boot app. Your use cases seem to be quite different, mostly embedded in the original sense ("doesn't look like a computer"), I guess. Also I guess you will have your tailored config, probably plus tailored environment anyway.
So do you want a CONFIG_ option to turn this new behaviour off (or on)? As mentioned I couldn't think of too many use cases, so considered this as not needed.
That's indeed one thing I realised as well. In the past U-Boot wasn't very good as using menuconfig to tailor some defconfig, though I think this mostly works now. But I am not sure that's a real problem: if people care about bootloader tuning, they are hopefully professionals and can be bothered with providing their own .config.
Cheers, Andre.
Hi Maxime,
On Sat, Jun 08, 2019 at 02:26:53AM +0100, Andre Przywara wrote: > At the moment we need to configure the place where U-Boot tries to load > its environment from at compile time. This is not only inflexible, but > also unnecessary, as we have easy access to the boot source. > > This series prepares U-Boot on Allwinner boards to load the environment > from the same media where the SPL and U-Boot proper were loaded from. > This allows to keep one firmware binary, and copy it to an SD card, > eMMC or even SPI flash, without needing to configure it differently.
I was thinking for the whole of "env". Pass in a string maybe, and then re-init the env portion based on that. I think that might cover the most cases of "we guessed wrong".
Is it even anything other than CHIP?
This I think is helpful in illustrating the problem we have, which is a very wide set of use cases. We could save 70kB by dropping EFI loader, and probably another "big" chunk of kB if we drop the oddball and largely only used by "distro boot" commands. But that would very much break the distro boot use case, which is important :)
And not to single out EFI, since Heinrich is working on splitting out "needed for UEFI self test" vs "needed for common use case/EBBR" functionality, but the defaults for that start to conflict with "why is my bootloader more than 256kB?". And I think we need to take a harder look at the DM framework and see if/how we can trim space. Maybe figure out a way to link-time/compile-time optimize the one-board/one-dts case.
We're getting farther with the Kconfig migration but it's still a good bit from complete. And even then, people expect the defconfig to be "it".
Hi Maxime,
That's a rather big underestimation though. Most of the boards before the H3 era have a NAND. UBI cannot deal with the NAND chips technology yet, but they do have a NAND chip that should be supported in the future.
Yes.
But not the Olinuxinos, Cubieboard, pcduino's, etc. Basically all the A10/A13/A20/A33 boards have a NAND chip, and most of them will also have an SD card slot.
It works because the support is not complete at this point, so it's pretty fragile to market it as such.
Yeah, passing the argument is pretty elegant.
Yeah, but my main objection is that you're saying you want to :)
Like I said, it's pretty much 50/50.
It's not really my point though. My point is that as U-Boot grows bigger, we are wandering in the same order of magnitude that Linux, and Linux can be turned into a "bootloader" as well. Loading Linux, then loading your actual Linux image and kexec'ing is a thing.
The closer we come to Linux, the more valid that solution is, especially now that everything that could be provided by U-Boot (like PSCI) has been pushed down to ATF.
(And yeah, on embedded systems, you can even skip the kexec and just run the minimal kernel)
Maxime
Andre Przywara
Maxime Ripard
