[U-Boot] [PATCH] mpc8xxx: Remove cpu-handles for cpus we delete
We may have cpu-handles pointing to the cpu nodes we delete. If so we should delete the handles as well.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc8xxx/fdt.c | 36 ++++++++++++++++++++++++++++++------ 1 files changed, 30 insertions(+), 6 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/fdt.c b/arch/powerpc/cpu/mpc8xxx/fdt.c index 738394f..c9956b6 100644 --- a/arch/powerpc/cpu/mpc8xxx/fdt.c +++ b/arch/powerpc/cpu/mpc8xxx/fdt.c @@ -28,6 +28,25 @@ #include <fdt_support.h>
#if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) +static int ft_del_cpuhandle(void *blob, int cpuhandle) +{ + int off, ret = -FDT_ERR_NOTFOUND; + + /* if we find a match, we'll delete at it which point the offsets are + * invalid so we start over from the beginning + */ + off = fdt_node_offset_by_prop_value(blob, -1, "cpu-handle", + &cpuhandle, 4); + while (off != -FDT_ERR_NOTFOUND) { + fdt_delprop(blob, off, "cpu-handle"); + ret = 1; + off = fdt_node_offset_by_prop_value(blob, -1, "cpu-handle", + &cpuhandle, 4); + } + + return ret; +} + void ft_fixup_num_cores(void *blob) { int off, num_cores, del_cores;
@@ -38,13 +57,18 @@ void ft_fixup_num_cores(void *blob) { while (off != -FDT_ERR_NOTFOUND) { u32 *reg = (u32 *)fdt_getprop(blob, off, "reg", 0);
- /* if we find a cpu node outside of what we expect delete it - * and reset the offset back to the start since we can't - * trust the offsets anymore - */ if (*reg > num_cores-1) { - fdt_del_node(blob, off); - del_cores++; + int ph = fdt_get_phandle(blob, off); + + /* Delete the cpu node once there are no cpu handles */ + if (-FDT_ERR_NOTFOUND == ft_del_cpuhandle(blob, ph)) { + fdt_del_node(blob, off); + del_cores++; + } + /* either we deleted some cpu handles or the cpu node + * so we reset the offset back to the start since we + * can't trust the offsets anymore + */ off = -1; } off = fdt_node_offset_by_prop_value(blob, off,
applied to 85xx
- k
Kumar Gala
