[PATCH] sunxi: h616: add initial support for T95 AXP313 TV Box
T95 is a most commonly known for being a box with a pre-installed malware. It uses Allwinner H616 and comes with eMMC and DDR3 memory. This device comes with two versions - one with AXP305 PMIC and another with AXP313 PMIC. The AXP313 version comes with Secure Boot enabled and locked bootloader, so the u-boot has to be built with TOC0. DRAM settings are taken from Allwinner's boot0 for this box.
Cc: Andre Przywara andre.przywara@arm.com
Signed-off-by: Kamil Kasperski ressetkk@gmail.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun50i-h616-t95-axp313.dts | 148 ++++++++++++++++++++++++ configs/t95_axp313_defconfig | 27 +++++ 3 files changed, 177 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun50i-h616-t95-axp313.dts create mode 100644 configs/t95_axp313_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b102ffb5f6..144daf6c48 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -842,7 +842,8 @@ dtb-$(CONFIG_MACH_SUN50I_H616) += \ sun50i-h618-orangepi-zero2w.dtb \ sun50i-h618-orangepi-zero3.dtb \ sun50i-h618-transpeed-8k618-t.dtb \ - sun50i-h616-x96-mate.dtb + sun50i-h616-x96-mate.dtb \ + sun50i-h616-t95-axp313.dtb dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-amarula-relic.dtb \ sun50i-a64-bananapi-m64.dtb \ diff --git a/arch/arm/dts/sun50i-h616-t95-axp313.dts b/arch/arm/dts/sun50i-h616-t95-axp313.dts new file mode 100644 index 0000000000..b006f363d5 --- /dev/null +++ b/arch/arm/dts/sun50i-h616-t95-axp313.dts @@ -0,0 +1,148 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2021 Arm Ltd. + */ + +/dts-v1/; + +#include "sun50i-h616.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + +/ { + model = "T95 (AXP313)"; + compatible = "mbox,t95-axp313", "allwinner,sun50i-h616"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + reg_vcc5v: vcc5v { + /* board wide 5V supply directly from the DC input */ + compatible = "regulator-fixed"; + regulator-name = "vcc-5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci2 { + status = "okay"; +}; + +&ir { + status = "okay"; +}; + +&mmc0 { + cd-gpios = <&pio 8 16 GPIO_ACTIVE_LOW>; /* PI16 */ + vmmc-supply = <®_dldo1>; + status = "okay"; +}; + +&mmc2 { + vmmc-supply = <®_dldo1>; + vqmmc-supply = <®_aldo1>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci2 { + status = "okay"; +}; + +&r_i2c { + status = "okay"; + + axp313: pmic@36 { + compatible = "x-powers,axp313a"; + reg = <0x36>; + #interrupt-cells = <1>; + interrupt-controller; + interrupt-parent = <&pio>; + interrupts = <2 9 IRQ_TYPE_LEVEL_LOW>; /* PC9 */ + + vin1-supply = <®_vcc5v>; + vin2-supply = <®_vcc5v>; + vin3-supply = <®_vcc5v>; + + regulators { + /* Supplies VCC-PLL, so needs to be always on. */ + reg_aldo1: aldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc1v8"; + }; + + /* Supplies VCC-IO, so needs to be always on. */ + reg_dldo1: dldo1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc3v3"; + }; + + reg_dcdc1: dcdc1 { + regulator-always-on; + regulator-min-microvolt = <810000>; + regulator-max-microvolt = <990000>; + regulator-name = "vdd-gpu-sys"; + }; + + reg_dcdc2: dcdc2 { + regulator-always-on; + regulator-min-microvolt = <810000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpu"; + }; + + reg_dcdc3: dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1360000>; + regulator-max-microvolt = <1360000>; + regulator-name = "vdd-dram"; + }; + }; + }; +}; + +&pio { + vcc-pc-supply = <®_aldo1>; + vcc-pg-supply = <®_dldo1>; + vcc-ph-supply = <®_dldo1>; + vcc-pi-supply = <®_dldo1>; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_ph_pins>; + status = "okay"; +}; + +&usbotg { + dr_mode = "host"; /* USB A type receptable */ + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; diff --git a/configs/t95_axp313_defconfig b/configs/t95_axp313_defconfig new file mode 100644 index 0000000000..6542b5bc88 --- /dev/null +++ b/configs/t95_axp313_defconfig @@ -0,0 +1,27 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_DEFAULT_DEVICE_TREE="sun50i-h616-t95-axp313" +CONFIG_SPL=y +CONFIG_MACH_SUN50I_H616=y +CONFIG_DRAM_CLK=648 +CONFIG_DRAM_SUN50I_H616_ODT_EN=0x1 +CONFIG_DRAM_SUN50I_H616_DX_ODT=0x03030303 +CONFIG_DRAM_SUN50I_H616_DX_DRI=0x0e0e0e0e +CONFIG_DRAM_SUN50I_H616_CA_DRI=0x1c1c +CONFIG_DRAM_SUN50I_H616_TPR10=0x2f0006 +CONFIG_DRAM_SUN50I_H616_TPR11=0xffffdddd +CONFIG_DRAM_SUN50I_H616_TPR12=0xfedf7657 +CONFIG_SUNXI_DRAM_H616_DDR3_1333=y +CONFIG_R_I2C_ENABLE=y +CONFIG_SPL_I2C=y +CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_SYS_I2C_SLAVE=0x7f +CONFIG_SYS_I2C_SPEED=400000 +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_AXP313_POWER=y +CONFIG_AXP_DCDC3_VOLT=1360 +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y +CONFIG_SUN8I_EMAC=y +CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y
On Sat, 9 Mar 2024 19:24:26 +0000 Kamil Kasperski ressetkk@gmail.com wrote:
Hi Kamil,
many thanks for sending a patch, that looks mostly good from the technical point of view, only some smaller comments.
But please note that the devicetree needs to go through the Linux mailing lists and repo first, and we automatically copy it from the Linux tree once it has been merged there. This is to ensure proper review and checks with the Linux tooling.
So can you please send just the .dts file to the DT and sunxi maintainers the respective lists, as reported by get_maintainer.pl? Then we can take it from there.
Ah, thanks for figuring those out, that's very helpful.
- sun50i-h616-x96-mate.dtb \
- sun50i-h616-t95-axp313.dtb
- Copyright (C) 2021 Arm Ltd.
Please change this copyright you and this year.
+/dts-v1/;
- model = "T95 (AXP313)";
- compatible = "mbox,t95-axp313", "allwinner,sun50i-h616";
What is "mbox"? Do you have any more information about this vendor? In any case a new vendor would need to be added to Documentation/devicetree/bindings/vendor-prefixes.yaml, in a separate patch. Also you need a patch to add this compatible combination to Documentation/devicetree/bindings/arm/sunxi.yaml.
Cheers, Andre
- aliases {
serial0 = &uart0;
- chosen {
- reg_vcc5v: vcc5v {
+&ehci0 {
- status = "okay";
+&ehci2 {
- status = "okay";
+&ir {
- status = "okay";
+&mmc0 {
- cd-gpios = <&pio 8 16 GPIO_ACTIVE_LOW>; /* PI16 */
- vmmc-supply = <®_dldo1>;
- status = "okay";
+&mmc2 {
- vqmmc-supply = <®_aldo1>;
- bus-width = <8>;
- non-removable;
- cap-mmc-hw-reset;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- status = "okay";
+&ohci0 {
- status = "okay";
+&ohci2 {
- status = "okay";
+&r_i2c {
- status = "okay";
- axp313: pmic@36 {
reg = <0x36>;
regulators {
reg_aldo1: aldo1 {
reg_dldo1: dldo1 {
reg_dcdc1: dcdc1 {
reg_dcdc2: dcdc2 {
reg_dcdc3: dcdc3 {
+&pio {
- vcc-pc-supply = <®_aldo1>;
- vcc-pg-supply = <®_dldo1>;
- vcc-ph-supply = <®_dldo1>;
- vcc-pi-supply = <®_dldo1>;
+&uart0 {
- pinctrl-names = "default";
- pinctrl-0 = <&uart0_ph_pins>;
- status = "okay";
+&usbotg {
- dr_mode = "host"; /* USB A type receptable */
- status = "okay";
+&usbphy {
- status = "okay";
Hello Andre, Thanks for your reply and thanks for pointing some stuff out.
"MBOX" refers to the "Model" string from system properties. The problem is that it's quite hard to pin the correct vendor, since the OS is built based on Google Pixel 2. You can see that the fingerprint contains strings only for this phone: [ro.build.fingerprint]: [google/walley/walleye:10/QP1A.191105.004/eng.cmj.20220408.125005:userdebug/test-keys] Setting the device model as Vendor string seemed to be the most safe bet. If you have any other suggestions, please let me know.
Thanks for pointing that out. I'll contact Linux maintainers and will send updated patch.
Best regards, Kamil
Hi Kamil,
+/dts-v1/;
Cheers, Andre
aliases {
serial0 = &uart0;
chosen {
reg_vcc5v: vcc5v {
+&ehci0 {
status = "okay";
+&ehci2 {
status = "okay";
+&ir {
status = "okay";
+&mmc0 {
status = "okay";
+&mmc2 {
bus-width = <8>;
non-removable;
cap-mmc-hw-reset;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
status = "okay";
+&ohci0 {
status = "okay";
+&ohci2 {
status = "okay";
+&r_i2c {
status = "okay";
axp313: pmic@36 {
reg = <0x36>;
regulators {
reg_aldo1: aldo1 {
reg_dldo1: dldo1 {
reg_dcdc1: dcdc1 {
reg_dcdc2: dcdc2 {
reg_dcdc3: dcdc3 {
+&pio {
+&uart0 {
status = "okay";
+&usbotg {
status = "okay";
+&usbphy {
status = "okay";
Maybe a suggestion could be "YAGALA"
If you look on amazon, aliexpress you could find some vendors setting the brand to this name.
Regards,
Best regards, Kamil
Hi Kamil,
+/dts-v1/;
Cheers, Andre
aliases {
serial0 = &uart0;
chosen {
reg_vcc5v: vcc5v {
+&ehci0 {
status = "okay";
+&ehci2 {
status = "okay";
+&ir {
status = "okay";
+&mmc0 {
status = "okay";
+&mmc2 {
bus-width = <8>;
non-removable;
cap-mmc-hw-reset;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
status = "okay";
+&ohci0 {
status = "okay";
+&ohci2 {
status = "okay";
+&r_i2c {
status = "okay";
axp313: pmic@36 {
reg = <0x36>;
regulators {
reg_aldo1: aldo1 {
reg_dldo1: dldo1 {
reg_dcdc1: dcdc1 {
reg_dcdc2: dcdc2 {
reg_dcdc3: dcdc3 {
+&pio {
+&uart0 {
status = "okay";
+&usbotg {
status = "okay";
+&usbphy {
status = "okay";
-- Kamil Kasperski
Andre Przywara
Clément Péron
Kamil Kasperski
