[U-Boot] Please pull u-boot-ti/master
Hello,
The following changes since commit 90639feaa0d66a204f9d03a325ab14e2f97f6cbb:
arm/km: add support for kmsuv31 board (2013-04-12 21:42:22 +0530)
git://git.denx.de/u-boot-ti.git master
for you to fetch changes up to 46afd3eff3e53e29613c489af0c128203bb3c5b4:
omap5_common.h: Switch to ext4 (2013-04-12 15:29:23 -0400)
---------------------------------------------------------------- Tom Rini (2): am335x: Really correct DDR timings on new BeagleBone part omap5_common.h: Switch to ext4
man.huber@arcor.de (1): omap3: Display MHz instead of mHz on the console
arch/arm/cpu/armv7/omap3/sys_info.c | 4 ++-- arch/arm/include/asm/arch-am33xx/ddr_defs.h | 14 +++++++------- include/configs/omap5_common.h | 2 +- 3 files changed, 10 insertions(+), 10 deletions(-)
We have a real important fix (DDR timing, sigh), a pretty important fix (ext3 is bad for SD cards, use ext4) and a harmless print fixup since I'm in here.
Hi Tom,
On Fri, 12 Apr 2013 16:47:07 -0400, Tom Rini trini@ti.com wrote:
Hello,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
