[U-Boot] [PATCH 1/2] image: fit: Show firmware configuration property if present
SPL ATF support requires to have firmware property which should be also listed by mkimage -l when images is created.
The patch is also using this macro in spl_fit to match keyword.
When image is created: Default Configuration: 'config' Configuration 0 (config) Description: ATF with full u-boot Kernel: unavailable Firmware: atf FDT: dtb
common/image-fit.c | 4 ++++ common/spl/spl_fit.c | 3 ++- include/image.h | 1 + 3 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/common/image-fit.c b/common/image-fit.c index 4b0339045421..06b25fefc7da 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1610,6 +1610,10 @@ void fit_conf_print(const void *fit, int noffset, const char *p) if (uname) printf("%s Init Ramdisk: %s\n", p, uname);
+ uname = fdt_getprop(fit, noffset, FIT_FIRMWARE_PROP, NULL); + if (uname) + printf("%s Firmware: %s\n", p, uname); + for (fdt_index = 0; uname = fdt_stringlist_get(fit, noffset, FIT_FDT_PROP, fdt_index, NULL), uname; diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index be92ca4b4fd0..9f03e2648a31 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -395,7 +395,8 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, * - fall back to using the first 'loadables' entry */ if (node < 0) - node = spl_fit_get_image_node(fit, images, "firmware", 0); + node = spl_fit_get_image_node(fit, images, FIT_FIRMWARE_PROP, + 0); #ifdef CONFIG_SPL_OS_BOOT if (node < 0) node = spl_fit_get_image_node(fit, images, FIT_KERNEL_PROP, 0); diff --git a/include/image.h b/include/image.h index 621abf647f3b..f220b3613898 100644 --- a/include/image.h +++ b/include/image.h @@ -919,6 +919,7 @@ int booti_setup(ulong image, ulong *relocated_addr, ulong *size); #define FIT_DEFAULT_PROP "default" #define FIT_SETUP_PROP "setup" #define FIT_FPGA_PROP "fpga" +#define FIT_FIRMWARE_PROP "firmware"
#define FIT_MAX_HASH_LEN HASH_MAX_DIGEST_SIZE
SPL ATF implementation requires FIT image with partitions where the one is Firmware/ATF and another one Firmware/U-Boot. OS field is used for recording that difference that's why make sense to show values there for Firmware types.
For example: Image 0 (atf) Description: ATF bl31.bin Created: Mon Mar 26 15:58:14 2018 Type: Firmware Compression: uncompressed Data Size: 51152 Bytes = 49.95 KiB = 0.05 MiB Architecture: ARM OS: ARM Trusted Firmware Load Address: 0xfffe0000 Hash algo: md5 Hash value: 36a4212bbb698126bf5a248f0f4b5336 Image 1 (uboot) Description: u-boot.bin Created: Mon Mar 26 15:58:14 2018 Type: Firmware Compression: uncompressed Data Size: 761216 Bytes = 743.38 KiB = 0.73 MiB Architecture: ARM OS: U-Boot Load Address: 0x08000000 Hash algo: md5 Hash value: f22960fe429be72296dc8dc59a47d566
common/image-fit.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/image-fit.c b/common/image-fit.c index 06b25fefc7da..030a3e579f52 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -419,7 +419,8 @@ void fit_image_print(const void *fit, int image_noffset, const char *p) printf("%s Architecture: %s\n", p, genimg_get_arch_name(arch)); }
- if ((type == IH_TYPE_KERNEL) || (type == IH_TYPE_RAMDISK)) { + if ((type == IH_TYPE_KERNEL) || (type == IH_TYPE_RAMDISK) || + (type == IH_TYPE_FIRMWARE)) { fit_image_get_os(fit, image_noffset, &os); printf("%s OS: %s\n", p, genimg_get_os_name(os)); }
But please fix the commit subject 'firwmare'.
ok. Fixed.
Thanks, Michal
2018-03-26 22:31 GMT+08:00 Michal Simek michal.simek@xilinx.com:
Reviewed-by: Jun Nie jun.nie@linaro.org
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Jun Nie jun.nie@linaro.org
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Jun Nie jun.nie@linaro.org Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
participants (5)
Dr. Philipp Tomsich
Jun Nie
Michal Simek
