[U-Boot] [PATCH 1/3] powerpc/p1010rdb: SECURE BOOT- define CONFIG_SYS_RAMBOOT for NAND boot
In case of secure boot, boot from NAND is ramboot. It was removed by some other commit. So defining it again.
Signed-off-by: Aneesh Bansal aneesh.bansal@freescale.com --- include/configs/P1010RDB.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index ea5cb65..c21cf07 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -446,7 +446,8 @@ extern unsigned long get_sdram_size(void); FTIM2_GPCM_TWP(0x1f)) #define CONFIG_SYS_CS3_FTIM3 0x0
-#if defined(CONFIG_RAMBOOT_SDCARD) || defined(CONFIG_RAMBOOT_SPIFLASH) +#if defined(CONFIG_RAMBOOT_SDCARD) || defined(CONFIG_RAMBOOT_SPIFLASH) || \ + defined(CONFIG_RAMBOOT_NAND) #define CONFIG_SYS_RAMBOOT #define CONFIG_SYS_EXTRA_ENV_RELOC #else
In case of not-secure-boot, it's not ramboot.
What user of CONFIG_SYS_RAMBOOT are you concerned about? Many of them look like this:
#elif !defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SECURE_BOOT)
...which doesn't make sense if secure boot is always considered ramboot.
-Scott
-Scott
CONFIG_SYS_RAMBOOT is for secure boot from NAND, SPI and SD. CONFIG_SYS_RAMBOOT is not used for secure boot from NOR.
Dear "aneesh.bansal@freescale.com",
In message 680c371d651d49a08b33ddd4d01fb3bd@DM2PR03MB415.namprd03.prod.outlook.com you wrote:
-Scott
This is a misuse of the variable. The established meaning does NOT include booding from standard boot media like NAND, SPI and SD. It refers to booting from RAM "directly", after the image has been placed into RAM by "external" means, say by a JTAG debugger, or by copying it to a PCI card's memory.
Please avoid such misleading usage.
I think I have caused some confusion when trying to explain. I will try and elaborate on it further. Please see inline.
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Monday, January 27, 2014 7:52 PM To: Bansal Aneesh-B39320 Cc: Wood Scott-B07421; u-boot@lists.denx.de; Sun York-R58495 Subject: Re: [U-Boot] [PATCH 1/3] powerpc/p1010rdb: SECURE BOOT- define CONFIG_SYS_RAMBOOT for NAND boot
ramboot.
This code snippet is from the file start.S. This for the scenarios when 1. We are NOT booting from RAM and 2. Secure booting is configured
i.e. the above case is for secure Boot from NOR.
-Scott
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Time is a drug. Too much of it kills you. - Terry Pratchett, _Small Gods_
Sorry for the misleading statement. Yes, CONFIG_SYS_RAMBOOT is for booting from RAM directly and we have used it for the same purpose in the patch. Let me try and explain.
What I meant is that for P1010 like platforms for normal (non-secure) boot in case of NAND, we don’t use the CONFIG_SYS_RAMBOOT as we don’t boot from RAM directly in this case.
However in case of secure boot, even for NAND, we boot from RAM directly with boot ROM (ISBC) code copying the image from NAND to RAM. So in P1010RDB.h config file, for NAND Secure boot, we have defined CONFIG_RAMBOOT_NAND and then further are enabling CONFIG_SYS_RAMBOOT for the same.
#ifdef CONFIG_NAND_SECBOOT /* NAND Boot */ #define CONFIG_RAMBOOT_NAND . . . #if defined(CONFIG_RAMBOOT_SDCARD) || defined(CONFIG_RAMBOOT_SPIFLASH) || \ defined(CONFIG_RAMBOOT_NAND) #define CONFIG_SYS_RAMBOOT
Regards, Aneesh Bansal
Dear Aneesh,
In message 7f771c64c5c44208b24e38c75e159f28@DM2PR03MB415.namprd03.prod.outlook.com you wrote:
Mind the "directly" in this sentence, and no, you have not used it in this way.
What I meant is that for P1010 like platforms for normal (non-secure) boot in case of NAND, we don't use the CONFIG_SYS_RAMBOOT as we don't boot from RAM directly in this case.
You also do not boot directly from RAM in the secure case.
This is NOT a RAM boot. This is a completely normal boot process from NAND. You must not declare this as RAM booting, as it is NOT.
This is wrong. You have the ROM boot loader booting from NAND and not from RAM.
The name CONFIG_RAMBOOT_NAND is an oxymoron in itself (and it's undocumented as well). This should be fixed, as it makes no sense.
You cannot "RAM-boot form NAND" - you can always boot from a single boot device only - either NOR or NAND or SDCard or ... or RAM.
On 01/27/2014 09:35 PM, Wolfgang Denk wrote:
Dear Aneesh,
Let me try to get the bottom of the CONFIG_SYS_RAMBOOT.
When a complete u-boot image boots from RAM (DDR, SRAM, etc), we can call it RAMBOOT regardless how the image is loaded there. It can be JTAG, PBI, or other bootloader. This line becomes blurred when we have SPL, TPL, secure boot. We need to go back to see why we had CONFIG_SYS_RAMBOOT at the first place. If I remember correctly, we had this RAMBOOT because we didn't want u-boot to initialized DRAM for obvious reason. If we still have the same purpose of RAMBOOT, then it is not difficult to draw the line for current situations.
Any booting method which initializes DRAM in its complete image is not a RAMBOOT. So clearly NAND boot has its own DDR init code, even sometimes using fixed register settings. So a normal NAND boot is not RAMBOOT. If a u-boot image is wrapped by another bootloader, and the bootloader is responsible to initialize DRAM, the u-boot image runs from DRAM doesn't init DRAM again, this u-boot is a RAMBOOT.
Now we are back to secure NAND boot. Does the secure boot mechanism initialize DRAM and load a complete u-boot image from NAND to DRAM? If true, then we can call that image a RAMBOOT. But if the image has its own code to initialize DRAM, it is not a RAMBOOT.
Do we all agree on this clarification?
York
-----Original Message----- From: Sun York-R58495 Sent: Tuesday, March 04, 2014 10:42 PM To: Wolfgang Denk; Bansal Aneesh-B39320 Cc: Wood Scott-B07421; u-boot@lists.denx.de; Gupta Ruchika-R66431 Subject: Re: [U-Boot] [PATCH 1/3] powerpc/p1010rdb: SECURE BOOT- define CONFIG_SYS_RAMBOOT for NAND boot
Dear Aneesh,
In message
<7f771c64c5c44208b24e38c75e159f28@DM2PR03MB415.namprd03.prod.outlook.c om> you wrote:
in
in
this way.
secure)
don't
from
not
from RAM.
York
Yes, in case of secure boot from NAND, the DRAM is initialized by the BootROM and complete u-boot image is copied from NAND to DRAM by the BootROM. So, it should be called RAMBOOT.
Aneesh
DRAM or SRAM? Having ROM initialize DDR is a bit scary.
-Scott
-----Original Message----- From: Wood Scott-B07421 Sent: Wednesday, March 05, 2014 11:30 PM To: Bansal Aneesh-B39320 Cc: Sun York-R58495; Wolfgang Denk; u-boot@lists.denx.de; Gupta Ruchika-R66431 Subject: Re: [U-Boot] [PATCH 1/3] powerpc/p1010rdb: SECURE BOOT- define CONFIG_SYS_RAMBOOT for NAND boot
the
BootROM.
-Scott
It can be either DDR or SRAM. It is not hardcoded in BootROM to initialize DDR. This depends on the config words (CF_WORDS) in the CF_HEADER. The Boot ROM code parses the config words and programs the addresses with data values accordingly. The user may opt to initialize DDR and get the image copied onto DDR or configure CPC as SRAM and get the Image copied onto SRAM. On 1010, the CPC size is not big enough to accommodate the U-boot image. So, currently the CF_WORDS are for DDR to be initialized and copy the image on DDR.
the
BootROM.
-Scott
Does it use similar technique like PBI to initialize DDR? If so, it has static settings which cannot adapt to various speeds. That's OK if you have to do so. In this case, your u-boot image is a RAMBOOT. I suggest you to update the subject to avoid mixing NAND boot with RAMBOOT, and add comment or commit message to explain the image is loaded into DDR and run directly from there.
York
the
BootROM.
-Scott
P1010? LS1010? Something else?
Generally if SPD is present, it should be used to init DDR rather than using hardcoded values. If U-Boot doesn't fit in SRAM, you can use SPL instead of hardcoded init.
-Scott
the
BootROM.
-Scott
I agree with Scott on this point. Using hardcoded values totally skip DDR driver. You don't only lose the flexibility of various speeds, you also skip all workarounds implemented in DDR driver.
York
-----Original Message----- From: Sun York-R58495 Sent: Saturday, March 08, 2014 12:31 AM To: Bansal Aneesh-B39320 Cc: Wood Scott-B07421; Wolfgang Denk; u-boot@lists.denx.de; Gupta Ruchika-R66431 Subject: Re: [U-Boot] [PATCH 1/3] powerpc/p1010rdb: SECURE BOOT- define CONFIG_SYS_RAMBOOT for NAND boot
the
BootROM.
-Scott
initialize DDR.
addresses
and
On 1010,
the image on DDR.
than
York
Currently we are following the same approach which was there for SPI and SD on P1010 i.e hardcoded initialization of DDR in platforms like P1010, 9131/9132 using config words.
Aneesh
the
BootROM.
-Scott
initialize DDR.
addresses
and
On 1010,
the image on DDR.
than
York
Understood.
York
the
BootROM.
-Scott
initialize DDR.
addresses
and
On 1010,
the image on DDR.
than
York
I don't know about 9131/9132, but on P1010RDB we now use SPL to init DDR when booting from SPI/SD.
In any case, "we've always done it this way" isn't really a good reason.
-Scott
On Tue, 2014-03-04 at 23:30 -0600, Bansal Aneesh-B39320 wrote: > Yes, in case of secure boot from NAND, the DRAM is initialized by the > BootROM and complete u-boot image is copied from NAND to DRAM by > the BootROM. > So, it should be called RAMBOOT.
-Scott
initialize DDR.
addresses
and
On 1010,
the image on DDR.
than
York
We should move to SPL for SD/SPI/NAND. Let's take step by step. I intend to accept the updated patch to get NAND SECURE boot working for this board. Aneesh will submit patches to move to SPL, for SD/SPI/NAND.
York
participants (5)
Aneesh Bansal
Scott Wood
York Sun
