[PATCH] spi: altera_spi: Do not abuse CONFIG namespace
The value CONFIG_ALTERA_SPI_IDLE_VAL is never re-defined by a board. Rename this to ALTERA_SPI_IDLE_VAL.
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/spi/altera_spi.c | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/spi/altera_spi.c b/drivers/spi/altera_spi.c index fadc9f39657d..989679e881b5 100644 --- a/drivers/spi/altera_spi.c +++ b/drivers/spi/altera_spi.c @@ -19,9 +19,7 @@ #define ALTERA_SPI_STATUS_RRDY_MSK BIT(7) #define ALTERA_SPI_CONTROL_SSO_MSK BIT(10)
-#ifndef CONFIG_ALTERA_SPI_IDLE_VAL -#define CONFIG_ALTERA_SPI_IDLE_VAL 0xff -#endif +#define ALTERA_SPI_IDLE_VAL 0xff
struct altera_spi_regs { u32 rxdata; @@ -119,7 +117,7 @@ static int altera_spi_xfer(struct udevice *dev, unsigned int bitlen, if (txp) data = *txp++; else - data = CONFIG_ALTERA_SPI_IDLE_VAL; + data = ALTERA_SPI_IDLE_VAL;
debug("%s: tx:%x ", __func__, data); writel(data, ®s->txdata);
Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Bin Meng bmeng.cn@gmail.com
Bin Meng
