[U-Boot] [PATCH] i2c: muxes: pca954x: Add support for GPIO reset line
This commit adds support for GPIO reset lines matching the common linux "reset-gpios" devicetree binding.
Signed-off-by: Moritz Fischer moritz.fischer@ettus.com Cc: Heiko Schocher hs@denx.de Cc: Stefan Roese sr@denx.de Cc: Marek Behún marek.behun@nic.cz Cc: Simon Glass sjg@chromium.org Cc: Michal Simek monstr@monstr.eu
--- drivers/i2c/muxes/pca954x.c | 44 +++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 43 insertions(+), 1 deletion(-)
diff --git a/drivers/i2c/muxes/pca954x.c b/drivers/i2c/muxes/pca954x.c index 383f72f552..dd28ff057b 100644 --- a/drivers/i2c/muxes/pca954x.c +++ b/drivers/i2c/muxes/pca954x.c @@ -1,5 +1,6 @@ /* * Copyright (C) 2015 - 2016 Xilinx, Inc. + * Copyright (C) 2017 National Instruments Corp * Written by Michal Simek * * SPDX-License-Identifier: GPL-2.0+ @@ -9,7 +10,10 @@ #include <dm.h> #include <errno.h> #include <i2c.h> -#include <asm/gpio.h> + +#if CONFIG_DM_GPIO +# include <asm-generic/gpio.h> +#endif /* CONFIG_DM_GPIO */
DECLARE_GLOBAL_DATA_PTR;
@@ -30,6 +34,9 @@ struct chip_desc { struct pca954x_priv { u32 addr; /* I2C mux address */ u32 width; /* I2C mux width - number of busses */ +#ifdef CONFIG_DM_GPIO + struct gpio_desc gpio_mux_reset; +#endif /* CONFIG_DM_GPIO */ };
static const struct chip_desc chips[] = { @@ -105,10 +112,45 @@ static int pca954x_ofdata_to_platdata(struct udevice *dev) return 0; }
+static int pca954x_probe(struct udevice *dev) +{ +#ifdef CONFIG_DM_GPIO + struct pca954x_priv *priv = dev_get_priv(dev); + int err; + + err = gpio_request_by_name(dev, "reset-gpios", 0, + &priv->gpio_mux_reset, GPIOD_IS_OUT); + + /* it's optional so only bail if we get a real error */ + if (err && (err != -ENOENT)) + return err; + + /* dm will take care of polarity */ + if (dm_gpio_is_valid(&priv->gpio_mux_reset)) + dm_gpio_set_value(&priv->gpio_mux_reset, 0); + +#endif /* CONFIG_DM_GPIO */ + return 0; +} + +static int pca954x_remove(struct udevice *dev) +{ +#ifdef CONFIG_DM_GPIO + struct pca954x_priv *priv = dev_get_priv(dev); + + if (dm_gpio_is_valid(&priv->gpio_mux_reset)) + dm_gpio_free(dev, &priv->gpio_mux_reset); + +#endif /* CONFIG_DM_GPIO */ + return 0; +} + U_BOOT_DRIVER(pca954x) = { .name = "pca954x", .id = UCLASS_I2C_MUX, .of_match = pca954x_ids, + .probe = pca954x_probe, + .remove = pca954x_remove, .ops = &pca954x_ops, .ofdata_to_platdata = pca954x_ofdata_to_platdata, .priv_auto_alloc_size = sizeof(struct pca954x_priv),
- Copyright (C) 2015 - 2016 Xilinx, Inc.
- Copyright (C) 2017 National Instruments Corp
- Written by Michal Simek
Can we drop the #ifdef?
Can we use if (IS_ENABLED(CONFIG_DM_GPIO)) ?
int err;
return err;
-- 2.14.1
Hi Simon,
Yeah, will do.
I suppose. I was wondering. Is this in general preferable?
int err;
return err;
-- 2.14.1
Thanks for the review,
Moritz
+Tom for question below
Hi Moritz,
On 8 September 2017 at 23:27, Moritz Fischer moritz.fischer@ettus.com wrote:
Hi Simon,
Yeah, will do.
Well one benefit is that it reduces build-time code branching so we can potentially detect build errors more easily (e.g. this driver could be enabled for sandbox). We have traditionally had loads of #ifdefs in U-Boot and IMO they make the code harder to read. Note that using if() relies on not using -O0 in many cases but I think we gave up on supporting -O0 some time ago since debugging of optimised code is better these days.
Tom, what do you think?
Moritz Fischer
