[U-Boot-Users] [PATCH 3/4] PPC4xx: Use common code for LWMON5 board SDRAM support
This patch also modifies the functionality of the code so that the data-eye search is now done with with the cache disabled.
Signed-off-by: Larry Johnson lrj@acm.org --- diff --git a/board/lwmon5/sdram.c b/board/lwmon5/sdram.c index 399da8a..affaeff 100644 --- a/board/lwmon5/sdram.c +++ b/board/lwmon5/sdram.c @@ -36,8 +36,6 @@ #include <asm/io.h> #include <ppc440.h>
-#include "sdram.h" - /* * This DDR2 setup code can dynamically setup the TLB entries for the DDR2 memory * region. Right now the cache should still be disabled in U-Boot because of the @@ -54,8 +52,13 @@ #define MY_TLB_WORD2_I_ENABLE TLB_WORD2_I_ENABLE /* disable caching on SDRAM */ #endif
-void dcbz_area(u32 start_address, u32 num_bytes); -void dflush(void); +/*-----------------------------------------------------------------------------+ + * Prototypes + *-----------------------------------------------------------------------------*/ +extern int denali_wait_for_dlllock(void); +extern void denali_core_search_data_eye(void); +extern void dcbz_area(u32 start_address, u32 num_bytes); +extern void dflush(void);
static u32 is_ecc_enabled(void) { @@ -87,330 +90,6 @@ void board_add_ram_info(int use_default) printf(", CL%d)", val); }
-static int wait_for_dlllock(void) -{ - u32 val; - int wait = 0; - - /* - * Wait for the DCC master delay line to finish calibration - */ - mtdcr(ddrcfga, DDR0_17); - val = DDR0_17_DLLLOCKREG_UNLOCKED; - - while (wait != 0xffff) { - val = mfdcr(ddrcfgd); - if ((val & DDR0_17_DLLLOCKREG_MASK) == DDR0_17_DLLLOCKREG_LOCKED) - /* dlllockreg bit on */ - return 0; - else - wait++; - } - debug("0x%04x: DDR0_17 Value (dlllockreg bit): 0x%08x\n", wait, val); - debug("Waiting for dlllockreg bit to raise\n"); - - return -1; -} - -#if defined(CONFIG_DDR_DATA_EYE) -int wait_for_dram_init_complete(void) -{ - u32 val; - int wait = 0; - - /* - * Wait for 'DRAM initialization complete' bit in status register - */ - mtdcr(ddrcfga, DDR0_00); - - while (wait != 0xffff) { - val = mfdcr(ddrcfgd); - if ((val & DDR0_00_INT_STATUS_BIT6) == DDR0_00_INT_STATUS_BIT6) - /* 'DRAM initialization complete' bit */ - return 0; - else - wait++; - } - - debug("DRAM initialization complete bit in status register did not rise\n"); - - return -1; -} - -#define NUM_TRIES 64 -#define NUM_READS 10 - -void denali_core_search_data_eye(u32 start_addr, u32 memory_size) -{ - int k, j; - u32 val; - u32 wr_dqs_shift, dqs_out_shift, dll_dqs_delay_X; - u32 max_passing_cases = 0, wr_dqs_shift_with_max_passing_cases = 0; - u32 passing_cases = 0, dll_dqs_delay_X_sw_val = 0; - u32 dll_dqs_delay_X_start_window = 0, dll_dqs_delay_X_end_window = 0; - volatile u32 *ram_pointer; - u32 test[NUM_TRIES] = { - 0x00000000, 0x00000000, 0xFFFFFFFF, 0xFFFFFFFF, - 0x00000000, 0x00000000, 0xFFFFFFFF, 0xFFFFFFFF, - 0xFFFFFFFF, 0xFFFFFFFF, 0x00000000, 0x00000000, - 0xFFFFFFFF, 0xFFFFFFFF, 0x00000000, 0x00000000, - 0xAAAAAAAA, 0xAAAAAAAA, 0x55555555, 0x55555555, - 0xAAAAAAAA, 0xAAAAAAAA, 0x55555555, 0x55555555, - 0x55555555, 0x55555555, 0xAAAAAAAA, 0xAAAAAAAA, - 0x55555555, 0x55555555, 0xAAAAAAAA, 0xAAAAAAAA, - 0xA5A5A5A5, 0xA5A5A5A5, 0x5A5A5A5A, 0x5A5A5A5A, - 0xA5A5A5A5, 0xA5A5A5A5, 0x5A5A5A5A, 0x5A5A5A5A, - 0x5A5A5A5A, 0x5A5A5A5A, 0xA5A5A5A5, 0xA5A5A5A5, - 0x5A5A5A5A, 0x5A5A5A5A, 0xA5A5A5A5, 0xA5A5A5A5, - 0xAA55AA55, 0xAA55AA55, 0x55AA55AA, 0x55AA55AA, - 0xAA55AA55, 0xAA55AA55, 0x55AA55AA, 0x55AA55AA, - 0x55AA55AA, 0x55AA55AA, 0xAA55AA55, 0xAA55AA55, - 0x55AA55AA, 0x55AA55AA, 0xAA55AA55, 0xAA55AA55 }; - - ram_pointer = (volatile u32 *)start_addr; - - for (wr_dqs_shift = 64; wr_dqs_shift < 96; wr_dqs_shift++) { - /*for (wr_dqs_shift=1; wr_dqs_shift<96; wr_dqs_shift++) {*/ - - /* - * De-assert 'start' parameter. - */ - mtdcr(ddrcfga, DDR0_02); - val = (mfdcr(ddrcfgd) & ~DDR0_02_START_MASK) | DDR0_02_START_OFF; - mtdcr(ddrcfgd, val); - - /* - * Set 'wr_dqs_shift' - */ - mtdcr(ddrcfga, DDR0_09); - val = (mfdcr(ddrcfgd) & ~DDR0_09_WR_DQS_SHIFT_MASK) - | DDR0_09_WR_DQS_SHIFT_ENCODE(wr_dqs_shift); - mtdcr(ddrcfgd, val); - - /* - * Set 'dqs_out_shift' = wr_dqs_shift + 32 - */ - dqs_out_shift = wr_dqs_shift + 32; - mtdcr(ddrcfga, DDR0_22); - val = (mfdcr(ddrcfgd) & ~DDR0_22_DQS_OUT_SHIFT_MASK) - | DDR0_22_DQS_OUT_SHIFT_ENCODE(dqs_out_shift); - mtdcr(ddrcfgd, val); - - passing_cases = 0; - - for (dll_dqs_delay_X = 1; dll_dqs_delay_X < 64; dll_dqs_delay_X++) { - /*for (dll_dqs_delay_X=1; dll_dqs_delay_X<128; dll_dqs_delay_X++) {*/ - /* - * Set 'dll_dqs_delay_X'. - */ - /* dll_dqs_delay_0 */ - mtdcr(ddrcfga, DDR0_17); - val = (mfdcr(ddrcfgd) & ~DDR0_17_DLL_DQS_DELAY_0_MASK) - | DDR0_17_DLL_DQS_DELAY_0_ENCODE(dll_dqs_delay_X); - mtdcr(ddrcfgd, val); - /* dll_dqs_delay_1 to dll_dqs_delay_4 */ - mtdcr(ddrcfga, DDR0_18); - val = (mfdcr(ddrcfgd) & ~DDR0_18_DLL_DQS_DELAY_X_MASK) - | DDR0_18_DLL_DQS_DELAY_4_ENCODE(dll_dqs_delay_X) - | DDR0_18_DLL_DQS_DELAY_3_ENCODE(dll_dqs_delay_X) - | DDR0_18_DLL_DQS_DELAY_2_ENCODE(dll_dqs_delay_X) - | DDR0_18_DLL_DQS_DELAY_1_ENCODE(dll_dqs_delay_X); - mtdcr(ddrcfgd, val); - /* dll_dqs_delay_5 to dll_dqs_delay_8 */ - mtdcr(ddrcfga, DDR0_19); - val = (mfdcr(ddrcfgd) & ~DDR0_19_DLL_DQS_DELAY_X_MASK) - | DDR0_19_DLL_DQS_DELAY_8_ENCODE(dll_dqs_delay_X) - | DDR0_19_DLL_DQS_DELAY_7_ENCODE(dll_dqs_delay_X) - | DDR0_19_DLL_DQS_DELAY_6_ENCODE(dll_dqs_delay_X) - | DDR0_19_DLL_DQS_DELAY_5_ENCODE(dll_dqs_delay_X); - mtdcr(ddrcfgd, val); - - ppcMsync(); - ppcMbar(); - - /* - * Assert 'start' parameter. - */ - mtdcr(ddrcfga, DDR0_02); - val = (mfdcr(ddrcfgd) & ~DDR0_02_START_MASK) | DDR0_02_START_ON; - mtdcr(ddrcfgd, val); - - ppcMsync(); - ppcMbar(); - - /* - * Wait for the DCC master delay line to finish calibration - */ - if (wait_for_dlllock() != 0) { - printf("dlllock did not occur !!!\n"); - printf("denali_core_search_data_eye!!!\n"); - printf("wr_dqs_shift = %d - dll_dqs_delay_X = %d\n", - wr_dqs_shift, dll_dqs_delay_X); - hang(); - } - ppcMsync(); - ppcMbar(); - - if (wait_for_dram_init_complete() != 0) { - printf("dram init complete did not occur !!!\n"); - printf("denali_core_search_data_eye!!!\n"); - printf("wr_dqs_shift = %d - dll_dqs_delay_X = %d\n", - wr_dqs_shift, dll_dqs_delay_X); - hang(); - } - udelay(100); /* wait 100us to ensure init is really completed !!! */ - - /* write values */ - for (j=0; j<NUM_TRIES; j++) { - ram_pointer[j] = test[j]; - - /* clear any cache at ram location */ - __asm__("dcbf 0,%0": :"r" (&ram_pointer[j])); - } - - /* read values back */ - for (j=0; j<NUM_TRIES; j++) { - for (k=0; k<NUM_READS; k++) { - /* clear any cache at ram location */ - __asm__("dcbf 0,%0": :"r" (&ram_pointer[j])); - - if (ram_pointer[j] != test[j]) - break; - } - - /* read error */ - if (k != NUM_READS) - break; - } - - /* See if the dll_dqs_delay_X value passed.*/ - if (j < NUM_TRIES) { - /* Failed */ - passing_cases = 0; - /* break; */ - } else { - /* Passed */ - if (passing_cases == 0) - dll_dqs_delay_X_sw_val = dll_dqs_delay_X; - passing_cases++; - if (passing_cases >= max_passing_cases) { - max_passing_cases = passing_cases; - wr_dqs_shift_with_max_passing_cases = wr_dqs_shift; - dll_dqs_delay_X_start_window = dll_dqs_delay_X_sw_val; - dll_dqs_delay_X_end_window = dll_dqs_delay_X; - } - } - - /* - * De-assert 'start' parameter. - */ - mtdcr(ddrcfga, DDR0_02); - val = (mfdcr(ddrcfgd) & ~DDR0_02_START_MASK) | DDR0_02_START_OFF; - mtdcr(ddrcfgd, val); - - } /* for (dll_dqs_delay_X=0; dll_dqs_delay_X<128; dll_dqs_delay_X++) */ - - } /* for (wr_dqs_shift=0; wr_dqs_shift<96; wr_dqs_shift++) */ - - /* - * Largest passing window is now detected. - */ - - /* Compute dll_dqs_delay_X value */ - dll_dqs_delay_X = (dll_dqs_delay_X_end_window + dll_dqs_delay_X_start_window) / 2; - wr_dqs_shift = wr_dqs_shift_with_max_passing_cases; - - debug("DQS calibration - Window detected:\n"); - debug("max_passing_cases = %d\n", max_passing_cases); - debug("wr_dqs_shift = %d\n", wr_dqs_shift); - debug("dll_dqs_delay_X = %d\n", dll_dqs_delay_X); - debug("dll_dqs_delay_X window = %d - %d\n", - dll_dqs_delay_X_start_window, dll_dqs_delay_X_end_window); - - /* - * De-assert 'start' parameter. - */ - mtdcr(ddrcfga, DDR0_02); - val = (mfdcr(ddrcfgd) & ~DDR0_02_START_MASK) | DDR0_02_START_OFF; - mtdcr(ddrcfgd, val); - - /* - * Set 'wr_dqs_shift' - */ - mtdcr(ddrcfga, DDR0_09); - val = (mfdcr(ddrcfgd) & ~DDR0_09_WR_DQS_SHIFT_MASK) - | DDR0_09_WR_DQS_SHIFT_ENCODE(wr_dqs_shift); - mtdcr(ddrcfgd, val); - debug("DDR0_09=0x%08lx\n", val); - - /* - * Set 'dqs_out_shift' = wr_dqs_shift + 32 - */ - dqs_out_shift = wr_dqs_shift + 32; - mtdcr(ddrcfga, DDR0_22); - val = (mfdcr(ddrcfgd) & ~DDR0_22_DQS_OUT_SHIFT_MASK) - | DDR0_22_DQS_OUT_SHIFT_ENCODE(dqs_out_shift); - mtdcr(ddrcfgd, val); - debug("DDR0_22=0x%08lx\n", val); - - /* - * Set 'dll_dqs_delay_X'. - */ - /* dll_dqs_delay_0 */ - mtdcr(ddrcfga, DDR0_17); - val = (mfdcr(ddrcfgd) & ~DDR0_17_DLL_DQS_DELAY_0_MASK) - | DDR0_17_DLL_DQS_DELAY_0_ENCODE(dll_dqs_delay_X); - mtdcr(ddrcfgd, val); - debug("DDR0_17=0x%08lx\n", val); - - /* dll_dqs_delay_1 to dll_dqs_delay_4 */ - mtdcr(ddrcfga, DDR0_18); - val = (mfdcr(ddrcfgd) & ~DDR0_18_DLL_DQS_DELAY_X_MASK) - | DDR0_18_DLL_DQS_DELAY_4_ENCODE(dll_dqs_delay_X) - | DDR0_18_DLL_DQS_DELAY_3_ENCODE(dll_dqs_delay_X) - | DDR0_18_DLL_DQS_DELAY_2_ENCODE(dll_dqs_delay_X) - | DDR0_18_DLL_DQS_DELAY_1_ENCODE(dll_dqs_delay_X); - mtdcr(ddrcfgd, val); - debug("DDR0_18=0x%08lx\n", val); - - /* dll_dqs_delay_5 to dll_dqs_delay_8 */ - mtdcr(ddrcfga, DDR0_19); - val = (mfdcr(ddrcfgd) & ~DDR0_19_DLL_DQS_DELAY_X_MASK) - | DDR0_19_DLL_DQS_DELAY_8_ENCODE(dll_dqs_delay_X) - | DDR0_19_DLL_DQS_DELAY_7_ENCODE(dll_dqs_delay_X) - | DDR0_19_DLL_DQS_DELAY_6_ENCODE(dll_dqs_delay_X) - | DDR0_19_DLL_DQS_DELAY_5_ENCODE(dll_dqs_delay_X); - mtdcr(ddrcfgd, val); - debug("DDR0_19=0x%08lx\n", val); - - /* - * Assert 'start' parameter. - */ - mtdcr(ddrcfga, DDR0_02); - val = (mfdcr(ddrcfgd) & ~DDR0_02_START_MASK) | DDR0_02_START_ON; - mtdcr(ddrcfgd, val); - - ppcMsync(); - ppcMbar(); - - /* - * Wait for the DCC master delay line to finish calibration - */ - if (wait_for_dlllock() != 0) { - printf("dlllock did not occur !!!\n"); - hang(); - } - ppcMsync(); - ppcMbar(); - - if (wait_for_dram_init_complete() != 0) { - printf("dram init complete did not occur !!!\n"); - hang(); - } - udelay(100); /* wait 100us to ensure init is really completed !!! */ -} -#endif /* CONFIG_DDR_DATA_EYE */ - #ifdef CONFIG_DDR_ECC static void wait_ddr_idle(void) { @@ -610,12 +289,23 @@ long int initdram (int board_type) mtsdram(DDR0_02, 0x00000001); /* Activate the denali core */ #endif
- wait_for_dlllock(); + denali_wait_for_dlllock(); + +#if defined(CONFIG_DDR_DATA_EYE) + /* -----------------------------------------------------------+ + * Perform data eye search if requested. + * ----------------------------------------------------------*/ + program_tlb(0, CFG_SDRAM_BASE, CFG_MBYTES_SDRAM << 20, + TLB_WORD2_I_ENABLE); + denali_core_search_data_eye(); + remove_tlb(CFG_SDRAM_BASE, CFG_MBYTES_SDRAM << 20); +#endif
/* * Program tlb entries for this size (dynamic) */ - program_tlb(0, 0, CFG_MBYTES_SDRAM << 20, MY_TLB_WORD2_I_ENABLE); + program_tlb(0, CFG_SDRAM_BASE, CFG_MBYTES_SDRAM << 20, + MY_TLB_WORD2_I_ENABLE);
/* * Setup 2nd TLB with same physical address but different virtual address @@ -623,13 +313,6 @@ long int initdram (int board_type) */ program_tlb(0, CFG_DDR_CACHED_ADDR, CFG_MBYTES_SDRAM << 20, 0);
-#ifdef CONFIG_DDR_DATA_EYE - /* - * Perform data eye search if requested. - */ - denali_core_search_data_eye(CFG_DDR_CACHED_ADDR, CFG_MBYTES_SDRAM << 20); -#endif - #ifdef CONFIG_DDR_ECC /* * If ECC is enabled, initialize the parity bits.
Larry Johnson
