[U-Boot] [PATCH v2] travis: move orangepi to vendor job
move orangepi builds into a new job, and exclude orangepi builds from sunxi and rockchip jobs.
Signed-off-by: Heiko Schocher hs@denx.de --- travis build: https://travis-ci.org/hsdenx/u-boot-test/builds/614396275
Changes in v2: - collect orangepi builds in an separate job as boards as Tom suggested. - change subject, old was "travis: split 32bit sun8i job"
.travis.yml | 11 +++++++---- 1 file changed, 7 insertions(+), 4 deletions(-)
diff --git a/.travis.yml b/.travis.yml index d5f34f96cc..5da046ca7e 100644 --- a/.travis.yml +++ b/.travis.yml @@ -236,16 +236,16 @@ matrix: - BUILDMAN="sun7i" - name: "buildman 64bit sun8i" env: - - BUILDMAN="sun8i&aarch64" + - BUILDMAN="sun8i&aarch64 -x orangepi" - name: "buildman 32bit sun8i" env: - - BUILDMAN="sun8i&armv7" + - BUILDMAN="sun8i&armv7 -x orangepi" - name: "buildman sun9i" env: - BUILDMAN="sun9i" - name: "buildman sun50i" env: - - BUILDMAN="sun50i" + - BUILDMAN="sun50i -x orangepi" - name: "buildman catch-all ARM" env: - BUILDMAN="arm -x arm11,arm7,arm9,aarch64,at91,bcm,freescale,kirkwood,mvebu,siemens,tegra,uniphier,mx,samsung,sunxi,am33xx,omap,rockchip,toradex,socfpga,k2,k3,zynq" @@ -314,6 +314,9 @@ matrix: - name: "buildman omap" env: - BUILDMAN="omap" + - name: "buildman orangepi" + env: + - BUILDMAN="orangepi" - name: "buildman uniphier" env: - BUILDMAN="uniphier" @@ -322,7 +325,7 @@ matrix: - BUILDMAN="aarch64 -x bcm,k3,tegra,ls1,ls2,mvebu,uniphier,sunxi,samsung,rockchip,versal,zynq" - name: "buildman rockchip" env: - - BUILDMAN="rockchip" + - BUILDMAN="rockchip -x orangepi" - name: "buildman sh" env: - BUILDMAN="sh -x arm"
Hi Heiko,
Why this is needed? You can use 'buildman orangepi' locally, but I can't
understand why this need to be a separate job on Travis.
If people want to use buildman with sunxi or rockchip, I think it would like
to build all the boards with the SoC from vendor, so it would be better to
keep the board build in sunxi/rockchip jobs.
The travis jobs are sort by soc vendor or SoC, no board vendor, if add an
orangepi and remove it from sunxi and rockchip, there will be more board
vendor and do the same, seems like jobs for the soc and vendor class are
broken.
Thanks,
- Kever
Changes in v2:
- BUILDMAN="sun50i"
env:
On Fri, Nov 22, 2019 at 09:47:46AM +0800, Kever Yang wrote:
Hi Heiko,
Why this is needed? You can use 'buildman orangepi' locally, but I can't understand why this need to be a separate job on Travis.
Because the sun8i 32bit build job exceeded the travis build time limit, as sometimes happens
If people want to use buildman with sunxi or rockchip, I think it would like to build all the boards with the SoC from vendor, so it would be better to keep the board build in sunxi/rockchip jobs.
The travis jobs are sort by soc vendor or SoC, no board vendor, if add an orangepi and remove it from sunxi and rockchip, there will be more board vendor and do the same, seems like jobs for the soc and vendor class are broken.
Note that we have a number of other board-vendor jobs, this is not the first one. If this is too contentious, this travis failure is not frequent and we can just drop this I suppose.
Signed-off-by: Heiko Schocher hs@denx.de Reviewed-by: Tom Rini trini@konsulko.com
Heiko Schocher
Kever Yang
