[U-Boot] [PATCH] sunxi: display: Make lcd display clk phase configurable
While running some tests with an Olinuxino-A13-Micro + a 7" Olimex LCD module I noticed that the screen flickered. This is caused by the lcd display clk phase reg value being set to 0, where it should be 1 in this setup.
This commit adds a Kconfig option for the lcd display clk phase, so that we can set it per board. This defaults to 1, because looking at all the fex files in sunxi-boards, that is by far the most used value.
This commit updated the Ippo and MSI Primo73 tablet defconfigs to override the default of 1 with 0, as that is the correct value for those tablets, this keeps the register settings the same as before this commit.
The Olinuxino-A13 defconfigs are not updated, changing the register setting for these boards from 0 to 1, this is intentional.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/include/asm/arch-sunxi/display.h | 4 +--- board/sunxi/Kconfig | 7 +++++++ configs/Ippo_q8h_v1_2_defconfig | 1 + configs/Ippo_q8h_v5_defconfig | 1 + configs/MSI_Primo73_defconfig | 1 + drivers/video/sunxi_display.c | 7 +------ 6 files changed, 12 insertions(+), 9 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/display.h b/arch/arm/include/asm/arch-sunxi/display.h index 2ac8a87..ff92a10 100644 --- a/arch/arm/include/asm/arch-sunxi/display.h +++ b/arch/arm/include/asm/arch-sunxi/display.h @@ -249,9 +249,7 @@ struct sunxi_tve_reg { #define SUNXI_LCDC_TCON0_TIMING_V_TOTAL(n) (((n) * 2) << 16) #define SUNXI_LCDC_TCON0_LVDS_INTF_BITWIDTH(n) ((n) << 26) #define SUNXI_LCDC_TCON0_LVDS_INTF_ENABLE (1 << 31) -#define SUNXI_LCDC_TCON0_IO_POL_DCLK_PHASE0 (0 << 28) -#define SUNXI_LCDC_TCON0_IO_POL_DCLK_PHASE60 (1 << 28) -#define SUNXI_LCDC_TCON0_IO_POL_DCLK_PHASE120 (2 << 28) +#define SUNXI_LCDC_TCON0_IO_POL_DCLK_PHASE(x) ((x) << 28) #define SUNXI_LCDC_TCON1_CTRL_CLK_DELAY(n) (((n) & 0x1f) << 4) #define SUNXI_LCDC_TCON1_CTRL_ENABLE (1 << 31) #define SUNXI_LCDC_TCON1_TIMING_H_BP(n) (((n) - 1) << 0) diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 8d897c9..847a86f 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -342,6 +342,13 @@ config VIDEO_LCD_MODE This is in drivers/video/videomodes.c: video_get_params() format, e.g. x:800,y:480,depth:18,pclk_khz:33000,le:16,ri:209,up:22,lo:22,hs:30,vs:1,sync:0,vmode:0
+config VIDEO_LCD_DCLK_PHASE + int "LCD panel display clock phase" + depends on VIDEO + default 1 + ---help--- + Select LCD panel display clock phase shift, range 0-3. + config VIDEO_LCD_POWER string "LCD panel power enable pin" depends on VIDEO diff --git a/configs/Ippo_q8h_v1_2_defconfig b/configs/Ippo_q8h_v1_2_defconfig index 3e6d3cc..192a461 100644 --- a/configs/Ippo_q8h_v1_2_defconfig +++ b/configs/Ippo_q8h_v1_2_defconfig @@ -4,6 +4,7 @@ CONFIG_FDTFILE="sun8i-a23-ippo-q8h-v1.2.dtb" CONFIG_USB_MUSB_SUNXI=y CONFIG_USB0_VBUS_PIN="axp_drivebus" CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:167,up:31,lo:13,hs:1,vs:1,sync:3,vmode:0" +CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" diff --git a/configs/Ippo_q8h_v5_defconfig b/configs/Ippo_q8h_v5_defconfig index b96985e..c894948 100644 --- a/configs/Ippo_q8h_v5_defconfig +++ b/configs/Ippo_q8h_v5_defconfig @@ -4,6 +4,7 @@ CONFIG_FDTFILE="sun8i-a23-ippo-q8h-v5.dtb" CONFIG_USB_MUSB_SUNXI=y CONFIG_USB0_VBUS_PIN="axp_drivebus" CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:168,up:31,lo:13,hs:1,vs:1,sync:3,vmode:0" +CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" diff --git a/configs/MSI_Primo73_defconfig b/configs/MSI_Primo73_defconfig index ef1adc5..d731053 100644 --- a/configs/MSI_Primo73_defconfig +++ b/configs/MSI_Primo73_defconfig @@ -2,6 +2,7 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER" CONFIG_FDTFILE="sun7i-a20-primo73.dtb" CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:18,pclk_khz:60000,le:60,ri:160,up:13,lo:12,hs:100,vs:10,sync:3,vmode:0" +CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" diff --git a/drivers/video/sunxi_display.c b/drivers/video/sunxi_display.c index 8da45a5..46025ea 100644 --- a/drivers/video/sunxi_display.c +++ b/drivers/video/sunxi_display.c @@ -592,12 +592,7 @@ static void sunxi_lcdc_tcon0_mode_set(const struct ctfb_res_modes *mode) &lcdc->tcon0_frm_ctrl); }
-#ifdef CONFIG_VIDEO_LCD_IF_PARALLEL - val = SUNXI_LCDC_TCON0_IO_POL_DCLK_PHASE0; -#endif -#ifdef CONFIG_VIDEO_LCD_IF_LVDS - val = SUNXI_LCDC_TCON0_IO_POL_DCLK_PHASE60; -#endif + val = SUNXI_LCDC_TCON0_IO_POL_DCLK_PHASE(CONFIG_VIDEO_LCD_DCLK_PHASE); if (!(mode->sync & FB_SYNC_HOR_HIGH_ACT)) val |= SUNXI_LCDC_TCON_HSYNC_MASK; if (!(mode->sync & FB_SYNC_VERT_HIGH_ACT))
Could've sworn I replied to this one, but apparently not: Acked-by: Ian Campbell ijc@hellion.org.uk
Hi Hans,
Are you planning to move this to device tree at some point?
On 18-01-15 04:12, Simon Glass wrote:
Hi Hans,
Yes, one of the free-electrons guys is working on a kms driver, once we've that and thus stable devicetree bindings for the display blocks I want to move all this over to devicetree.
Regards,
Hans
Hi Hans,
Hi Hans,
OK thanks. More generally for sunxi I am wondering how common the board code can be. Already you have managed to support all sun7i boards in essentially a single config, for example. I wonder if we might support all sun7i boards with just different device trees? Not sure about other variants?
On 19-01-15 20:46, Simon Glass wrote:
Hi Hans,
Hi Hans,
My long term vision is along the lines of having one u-boot binary each for sun4i, sun5i, sun6i, etc. and then be able to append a dtb to that u-boot binary, combine it with the right spl, and presto we've u-boot ready for the specific board as described by the dtb.
The tricky bit is making the spl board agnostic, as we only have 32k sram to work with, some of which is used by the BROM. We can overwrite it when booting from mmc, but not when FEL booting (sunxi BROM usb gadget mode boot), and we also need to put the initial stack there, so dtb parsing is sort of out of the question since the dtb itself would likely already be larger then the space we've. So the spl side will likely end up using some linker magic to put a struct with config parameters (like dram parameters) at a fixed offset and then use some utility to extract those from a dtb and patch them into the spl or some such.
Note this is where I would like to be, currently thinks like supporting newer sunxi SoCs has higher priority though, but if you want to help us getting there that would be great :)
Regards,
Hans
Hi Hans,
Hi Hans,
Hi Hans,
Sounds good.
I did write an fdtgrep tool to cut down a device tree to only selected nodes, etc. So it might be possible, and the simplest option. If you do the linker magic idea, we should try to unify it across all SoCs. Exynos already has a binary table - in Chrome OS we have a tool which converts the device tree to the binary table. It's best avoided though.
I think it would make sense to support newer devices with driver model and device tree, at least. I have already helped a little, I have my hands full for quite a while on various things at present.
What is the name of this option in fex files?
Good question on sun4i / sun5i / sun7i it is stored in lcd_io_cfg0 but as a raw register value, rather then the clk phase value, so you need to shift right by 28 to get the actual value, e.g.:
lcd_io_cfg0 = 268435456
Means (0x10000000 >> 28) == 1
On sun6i / sun8i it is not clear, the allwinner kernel code uses lcd_hv_clk_phase which gets converted to an actual register value in a complicated method unfortunately, see the allwinner kernel sources.
Where as the fex files seem to use lcd_io_phase which is not used by the kernel AFAICT ...
Looking at the register values used under android it just seems to end up being 0 on sun6i / sun8i.
Regards,
Hans
Hans de Goede
Ian Campbell
Siarhei Siamashka
