[U-Boot] [PATCH 2/2][v2] board/bsc9132qds: Configure DSP DDR controller
BSC9132 SoC has two separate DDR controllers for PowerPC side and DSP side DDR. They are mapped to PowerPC and DSP CCSR space respectively. BSC9132QDS has two on-board MC34716EP DDR3 memory one connected to PowerPC and other to DSP side controller.
Configure DSP DDR controller similar to PowerPC side DDR controller as memories are exactly similar.
Signed-off-by: Manish Jaggi manish.jaggi@freescale.com Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com --- Changes for v2: Added Manish's email-id
arch/powerpc/include/asm/immap_85xx.h | 6 ++++++ board/freescale/bsc9132qds/bsc9132qds.c | 22 ++++++++++++++++++++++ 2 files changed, 28 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index db70d04..ae9a016 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -3047,6 +3047,12 @@ struct ccsr_pman { #define CONFIG_SYS_MPC85xx_GUTS_OFFSET 0xE0000 #define CONFIG_SYS_FSL_SRIO_OFFSET 0xC0000
+#if defined(CONFIG_BSC9132) +#define CONFIG_SYS_FSL_DSP_CCSR_DDR_OFFSET 0x10000 +#define CONFIG_SYS_FSL_DSP_CCSR_DDR_ADDR \ + (CONFIG_SYS_FSL_DSP_CCSRBAR + CONFIG_SYS_FSL_DSP_CCSR_DDR_OFFSET) +#endif + #define CONFIG_SYS_FSL_CPC_ADDR \ (CONFIG_SYS_CCSRBAR + CONFIG_SYS_FSL_CPC_OFFSET) #define CONFIG_SYS_FSL_QMAN_ADDR \ diff --git a/board/freescale/bsc9132qds/bsc9132qds.c b/board/freescale/bsc9132qds/bsc9132qds.c index ddc9d0a..b084c1b 100644 --- a/board/freescale/bsc9132qds/bsc9132qds.c +++ b/board/freescale/bsc9132qds/bsc9132qds.c @@ -141,6 +141,27 @@ void board_config_serdes_mux(void) } }
+/* Configure DSP DDR controller */ +void dsp_ddr_configure(void) +{ + /* + *There are separate DDR-controllers for DSP and PowerPC side DDR. + *copy the ddr controller settings from PowerPC side DDR controller + *to the DSP DDR controller as connected DDR memories are similar. + */ + ccsr_ddr_t __iomem *pa_ddr = + (ccsr_ddr_t __iomem *)CONFIG_SYS_MPC8xxx_DDR_ADDR; + ccsr_ddr_t temp_ddr; + ccsr_ddr_t __iomem *dsp_ddr = + (ccsr_ddr_t __iomem *)CONFIG_SYS_FSL_DSP_CCSR_DDR_ADDR; + + memcpy(&temp_ddr, pa_ddr, sizeof(ccsr_ddr_t)); + temp_ddr.cs0_bnds = CONFIG_SYS_DDR1_CS0_BNDS; + temp_ddr.sdram_cfg &= ~SDRAM_CFG_MEM_EN; + memcpy(dsp_ddr, &temp_ddr, sizeof(ccsr_ddr_t)); + dsp_ddr->sdram_cfg |= SDRAM_CFG_MEM_EN; +} + int board_early_init_r(void) { #ifndef CONFIG_SYS_NO_FLASH @@ -169,6 +190,7 @@ int board_early_init_r(void) 0, flash_esel+1, BOOKE_PAGESZ_64M, 1); #endif board_config_serdes_mux(); + dsp_ddr_configure(); return 0; }
Priyanka Jain
