[PATCH] Clear previous CPU release address when reset
HSD #18013461252: CPU release address is stored in system manager boot scratch register.This patch fixes the CPU crash issue during cold reset in ATF boot flow for Diamond Mesa device.
In Diamond Mesa device, boot scratch register will be cleared on POR only. In ATF boot flow, when a cold reset happen on Diamond Mesa device, the boot scratch register still contains previous CPU release address which point to ATF firmware. When primary and secondary core executions reaches lowlevel_init function, it will jump to previous CPU release address and causes crash.
This patch will clear the previous CPU release address if the core is reset by cold reset, warm reset or watchdog reset.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- arch/arm/mach-socfpga/lowlevel_init_soc64.S | 51 +++++++++++++++++++++ 1 file changed, 51 insertions(+)
diff --git a/arch/arm/mach-socfpga/lowlevel_init_soc64.S b/arch/arm/mach-socfpga/lowlevel_init_soc64.S index 875927cc4d..7b37b6eeef 100644 --- a/arch/arm/mach-socfpga/lowlevel_init_soc64.S +++ b/arch/arm/mach-socfpga/lowlevel_init_soc64.S @@ -14,6 +14,55 @@ ENTRY(lowlevel_init)
#if defined(CONFIG_GICV2) || defined(CONFIG_GICV3) #if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_ATF) + + /* + * In ATF flow, need to clear the old CPU address when cold reset + * being triggered, but shouldn't clear CPU address if it is reset + * by CPU-ON, so that the core can correctly jump to ATF code after + * reset by CPU-ON. CPU-ON trigger the reset via mpumodrst. + * + * Hardware will set 1 to core*_irq in mpurststat register in + * reset manager if the core is reset by mpumodrst. + * + * The following code will check the mpurststat to identify if the + * core is reset by mpumodrst, and it will skip CPU address clearing + * if the core is reset by mpumodrst. At last, the code need to clear + * the core*_irq by set it to 1. So that it can reflect the correct + * and latest status in next reset. + */ + + /* Retrieve mpurststat register in reset manager */ + ldr x4, =SOCFPGA_RSTMGR_ADDRESS + ldr w5, [x4, #0x04] + + /* Set mask based on current core id */ + mrs x0, mpidr_el1 + and x1, x0, #0xF + ldr x2, =0x00000100 + lsl x2, x2, x1 + + /* Skip if core*_irq register is set */ + and x6, x5, x2 + cbnz x6, skip_clear_cpu_address + + /* + * Reach here means core*_irq is 0, means the core is + * reset by cold, warm or watchdog reset. + * Clear previous CPU release address + */ + ldr x4, =CPU_RELEASE_ADDR + str wzr, [x4] + b skip_clear_core_irq + +skip_clear_cpu_address: + /* Clear core*_irq register by writing 1 */ + ldr x4, =SOCFPGA_RSTMGR_ADDRESS + str w2, [x4, #0x04] + +skip_clear_core_irq: + /* Master CPU (CPU0) does not need to wait for atf */ + branch_if_master x0, x1, master_cpu + wait_for_atf: ldr x4, =CPU_RELEASE_ADDR ldr x5, [x4] @@ -21,6 +70,8 @@ wait_for_atf: br x5 slave_wait_atf: branch_if_slave x0, wait_for_atf + +master_cpu: #else branch_if_slave x0, 1f #endif
Jit Loon Lim
