Re: RE: RE: [U-Boot-Users] Does u-boot relocate absolute symbols?
Rune: I'm sorry for the inconvenience, but I sent this mail to you instead of the U-Boot mailinglist.
And WD already slapped me for sending this example...
30.06.2005 18:54:40, "Rune Torgersen" runet@innovsys.com wrote:
Wow.... This surprises me... I have alwayts thought that *test and test[] would be the same thing.
Only solutionI can see is to change the definition in common.c to be *test, this will still get the address of test[] defined elsewhere. (See attached files)
Thanks, for your effort. Actually your suggestion is the way it's currently working here, but as I described in my first post, I'm looking for a way, which leaves the common code untouched. In my first post on 24.06.05 I've another solution, which is working for Linux, but does not in U-Boot.
Regards, Andreas
Sure, I've tried this. This is the point, where my problemarose. Attached you find twosmall files, you can easily compile under linux (gcc -oarrtest -I ./ ./common.c./array.c). The file "common.c" represents the code I can't(don't want to) touch."array.c" represents my project dependent code. If you runarrtest it will show to you,
Andreas Block
