[U-Boot] [PATCH 1/2 v2] 85xx: CONFIG_MP Boot Page Translation update
Previously, when CONFIG_MP was defined Boot Page Translation was unconditionally enabled and secondary cores were put in a spin loop at address 0xfffff000. The 0xfffffxxx address range (ie the Boot Page) was being remapped to SDRAM via the BPTR register.
This change puts secondary cores into spin loops at their 'true' address in SDRAM and doesn't require Boot Page Translation to always be enabled. The main advantage of this change is that Boot Page Translation can be disabled after the secondary cores are brought up which allows the memory region at 0xfffffxxx to be used for other peripherals, etc.
By default, Boot Page Translation remains enabled while U-Boot executes. A new CONFIG_MPC8xxx_DISABLE_BPTR define has been added which causes Boot Page Translation to be disabled for those boards which wish to use the 0xfffffxxx address range as part of their normal memory map.
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- Changes since v1: - Use clrbits_be32() instead of in/out_be32()
This is very similar to "85xx: Fix mapping of 0xfffffxxx when CONFIG_MP" The 2 differences are:
- Boot page translation is only disabled when CONFIG_MPC8xxx_DISABLT_BPTR is defined.
- Instead of zeroing out BPTR when disabling translation, this patch only disables translation, but maintins the translation address. This should make it easier to properly re-enable translation if need be.
cpu/mpc85xx/mp.c | 22 ++++++++++++++++++++-- cpu/mpc85xx/release.S | 30 +++++++++++++++++++++++++----- 2 files changed, 45 insertions(+), 7 deletions(-)
diff --git a/cpu/mpc85xx/mp.c b/cpu/mpc85xx/mp.c index 76f02a4..53fc3be 100644 --- a/cpu/mpc85xx/mp.c +++ b/cpu/mpc85xx/mp.c @@ -129,7 +129,7 @@ ulong get_spin_addr(void)
ulong addr = (ulong)&__spin_table - (ulong)&__secondary_start_page; - addr += 0xfffff000; + addr += determine_mp_bootpg();
return addr; } @@ -137,7 +137,8 @@ ulong get_spin_addr(void) static void pq3_mp_up(unsigned long bootpg) { u32 up, cpu_up_mask, whoami; - u32 *table = (u32 *)get_spin_addr(); + /* The table is at 0xfffffxxx due to boot page translation below */ + u32 *table = (u32 *)(0xfffff000 | get_spin_addr()); volatile u32 bpcr; volatile ccsr_local_ecm_t *ecm = (void *)(CONFIG_SYS_MPC85xx_ECM_ADDR); volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); @@ -146,6 +147,8 @@ static void pq3_mp_up(unsigned long bootpg) int timeout = 10;
whoami = in_be32(&pic->whoami); + + /* Translate 0xfffffxxx 'bootpg' address range to SDRAM */ out_be32(&ecm->bptr, 0x80000000 | (bootpg >> 12));
/* disable time base at the platform */ @@ -194,6 +197,17 @@ static void pq3_mp_up(unsigned long bootpg)
devdisr &= ~(MPC85xx_DEVDISR_TB0 | MPC85xx_DEVDISR_TB1); out_be32(&gur->devdisr, devdisr); + +#ifdef CONFIG_MPC8xxx_DISABLE_BPTR + /* + * Disabling Boot Page Translation allows the memory region 0xfffff000 + * to 0xffffffff to be used normally. Leaving Boot Page Translation + * enabled remaps 0xfffff000 to SDRAM which makes that memory region + * unusable for normal operation but it does allow OSes to easily + * reset a processor core to put it back into U-Boot's spinloop. + */ + clrbits_be32(&ecm->bptr, 0x80000000); +#endif }
void cpu_mp_lmb_reserve(struct lmb *lmb) @@ -206,9 +220,13 @@ void cpu_mp_lmb_reserve(struct lmb *lmb) void setup_mp(void) { extern ulong __secondary_start_page; + extern ulong __bootpg_addr; ulong fixup = (ulong)&__secondary_start_page; u32 bootpg = determine_mp_bootpg();
+ /* Store the bootpg's SDRAM address for use by secondary CPU cores */ + __bootpg_addr = bootpg; + memcpy((void *)bootpg, (void *)fixup, 4096); flush_cache(bootpg, 4096);
diff --git a/cpu/mpc85xx/release.S b/cpu/mpc85xx/release.S index fbefc2c..6799633 100644 --- a/cpu/mpc85xx/release.S +++ b/cpu/mpc85xx/release.S @@ -114,23 +114,38 @@ __secondary_start_page: stw r3,ENTRY_R6_UPPER(r10) stw r3,ENTRY_R6_LOWER(r10)
+ /* load r13 with the address of the 'bootpg' in SDRAM */ + lis r13,toreset(__bootpg_addr)@h + ori r13,r13,toreset(__bootpg_addr)@l + lwz r13,0(r13) + /* setup mapping for AS = 1, and jump there */ lis r11,(MAS0_TLBSEL(1)|MAS0_ESEL(1))@h mtspr SPRN_MAS0,r11 lis r11,(MAS1_VALID|MAS1_IPROT)@h ori r11,r11,(MAS1_TS|MAS1_TSIZE(BOOKE_PAGESZ_4K))@l mtspr SPRN_MAS1,r11 - lis r11,(0xfffff000|MAS2_I)@h - ori r11,r11,(0xfffff000|MAS2_I)@l + oris r11,r13,(MAS2_I)@h + ori r11,r13,(MAS2_I)@l mtspr SPRN_MAS2,r11 - lis r11,(0xfffff000|MAS3_SX|MAS3_SW|MAS3_SR)@h - ori r11,r11,(0xfffff000|MAS3_SX|MAS3_SW|MAS3_SR)@l + oris r11,r13,(MAS3_SX|MAS3_SW|MAS3_SR)@h + ori r11,r13,(MAS3_SX|MAS3_SW|MAS3_SR)@l mtspr SPRN_MAS3,r11 tlbwe
bl 1f 1: mflr r11 - addi r11,r11,28 + /* + * OR in 0xfff to create a mask of the bootpg SDRAM address. We use + * this mask to fixup the cpu spin table and the address that we want + * to jump to, eg change them from 0xfffffxxx to 0x7ffffxxx if the + * bootpg is at 0x7ffff000 in SDRAM. + */ + ori r13,r13,0xfff + and r11, r11, r13 + and r10, r10, r13 + + addi r11,r11,(2f-1b) mfmsr r13 ori r12,r13,MSR_IS|MSR_DS@l
@@ -200,6 +215,11 @@ __secondary_start_page: mtspr SPRN_SRR1,r13 rfi
+ /* Allocate some space for the SDRAM address of the bootpg */ + .globl __bootpg_addr +__bootpg_addr: + .long 0 + .align L1_CACHE_SHIFT .globl __spin_table __spin_table:
Also, disable Boot Page Translation after the secondary core is enabled so that the 0xfffff000-0xffffffff memory region can still be utilized for flash similar to other X-ES boards
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- include/configs/XPEDITE5370.h | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/include/configs/XPEDITE5370.h b/include/configs/XPEDITE5370.h index acb62ad..0847db8 100644 --- a/include/configs/XPEDITE5370.h +++ b/include/configs/XPEDITE5370.h @@ -34,6 +34,8 @@ #define CONFIG_E500 1 /* BOOKE e500 family */ #define CONFIG_MPC85xx 1 /* MPC8540/60/55/41/48 */ #define CONFIG_MPC8572 1 +#define CONFIG_MP +#define CONFIG_MPC8xxx_DISABLE_BPTR /* Disable boot page translation */ #define CONFIG_XPEDITE5370 1 #define CONFIG_SYS_BOARD_NAME "XPedite5370" #define CONFIG_NUM_CPUS 2 /* 2 Cores */
Changes since v1:
- addr += determine_mp_bootpg();
changing this has some issues. We expect the the address that the spin table is at to be marked cache-inhibited.
- /* The table is at 0xfffffxxx due to boot page translation below */
- u32 *table = (u32 *)(0xfffff000 | get_spin_addr()); volatile u32 bpcr; volatile ccsr_local_ecm_t *ecm = (void *)
0xfffff000
- clrbits_be32(&ecm->bptr, 0x80000000);
+#endif }
- __bootpg_addr = bootpg;
- memcpy((void *)bootpg, (void *)fixup, 4096); flush_cache(bootpg, 4096);
- /* load r13 with the address of the 'bootpg' in SDRAM */
- lis r13,toreset(__bootpg_addr)@h
- ori r13,r13,toreset(__bootpg_addr)@l
- lwz r13,0(r13)
- /* setup mapping for AS = 1, and jump there */ lis r11,(MAS0_TLBSEL(1)|MAS0_ESEL(1))@h mtspr SPRN_MAS0,r11 lis r11,(MAS1_VALID|MAS1_IPROT)@h ori r11,r11,(MAS1_TS|MAS1_TSIZE(BOOKE_PAGESZ_4K))@l mtspr SPRN_MAS1,r11
- oris r11,r13,(MAS2_I)@h
- ori r11,r13,(MAS2_I)@l mtspr SPRN_MAS2,r11
bl 1f
1: mflr r11
- addi r11,r11,28
want
- ori r13,r13,0xfff
- and r11, r11, r13
- and r10, r10, r13
- addi r11,r11,(2f-1b) mfmsr r13 ori r12,r13,MSR_IS|MSR_DS@l
- /* Allocate some space for the SDRAM address of the bootpg */
- .globl __bootpg_addr
+__bootpg_addr:
- .long 0
- .align L1_CACHE_SHIFT .globl __spin_table
__spin_table:
1.6.2.1
The secondary cores will be running with the spin table in cache-inhibited memory and it looks like Linux accesses the spin table after ioremapping it, so that flow looks OK.
I assumed the e500 Coherency Module will ensure that the cpu_status() function should also be OK as is.
It looks like I should have added 2 cache flushes to U-Boot's cpu_release(), like:
--- a/cpu/mpc85xx/mp.c +++ b/cpu/mpc85xx/mp.c @@ -106,9 +106,11 @@ int cpu_release(int nr, int argc, char *argv[]) table[BOOT_ENTRY_ADDR_UPPER] = (u32)(boot_addr >> 32);
/* ensure all table updates complete before final address write */ - eieio(); + ppcDcbf((unsigned long)table); + asm("msync");
table[BOOT_ENTRY_ADDR_LOWER] = (u32)(boot_addr & 0xffffffff); + ppcDcbf((unsigned long)table);
return 0; }
I'll resubmit with the change above, let me know if I'm off base.
Thanks, Peter
write */
eieio();
asm("msync"); table[BOOT_ENTRY_ADDR_LOWER] = (u32)(boot_addr & 0xffffffff);
ppcDcbf((unsigned long)table); return 0;
There's another issue with this, its possible that the location in memory is not mapped in the TLBs. We typically max out @ 2G of DDR mapped (via the TLBs). So what happens if we have 3G of DDR.
- k
write */
eieio();
Ick... I hope to have some spare time in the next few days and will look into fixing this patch up then.
Thanks, Peter
Kumar Gala
Peter Tyser
