[U-Boot-Users] [Patch] Configure SMC for a second flash device if required
If SMC_CSR2_VAL is defined in the board configuration file, the static memory controller will be configured for it. --- cpu/arm920t/at91rm9200/lowlevel_init.S | 10 ++++++++-- 1 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/cpu/arm920t/at91rm9200/lowlevel_init.S b/cpu/arm920t/at91rm9200/lowlevel_init.S index 98363eb..bb4b95f 100644 --- a/cpu/arm920t/at91rm9200/lowlevel_init.S +++ b/cpu/arm920t/at91rm9200/lowlevel_init.S @@ -47,6 +47,7 @@ #define MC_AASR 0xFFFFFF08 #define EBI_CFGR 0xFFFFFF64 #define SMC_CSR0 0xFFFFFF70 +#define SMC_CSR2 0xFFFFFF78
/* clocks */ #define PLLAR 0xFFFFFC28 @@ -96,7 +97,7 @@ LoopOsc: ldr r0, =SMRDATA ldr r1, _MTEXT_BASE sub r0, r0, r1 - add r2, r0, #80 + add r2, r0, #(SMRDATA1-SMRDATA) 0: /* the address */ ldr r1, [r0], #4 @@ -113,7 +114,7 @@ LoopOsc: ldr r0, =SMRDATA1 ldr r1, _MTEXT_BASE sub r0, r0, r1 - add r2, r0, #176 + add r2, r0, #(SMRDATA2-SMRDATA1) 2: /* the address */ ldr r1, [r0], #4 @@ -148,6 +149,10 @@ SMRDATA: .word EBI_CFGR_VAL .word SMC_CSR0 .word SMC_CSR0_VAL +#ifdef SMC_CSR2_VAL + .word SMC_CSR2 + .word SMC_CSR2_VAL +#endif .word PLLAR .word PLLAR_VAL .word PLLBR @@ -202,4 +207,5 @@ SMRDATA1: .word SDRAM .word SDRAM_VAL /* SMRDATA1 is 176 bytes long */ +SMRDATA2: #endif /* CONFIG_SKIP_LOWLEVEL_INIT */ -- 1.4.3.4
Signed-off-by: Christian Eggers ceggers@gmx.de
Christian Eggers
