[U-Boot] [PATCH 1/5] pico-imx7d: Sync pico-hobbit-imx7d_defconfig
Update pico-hobbit-imx7d_defconfig using pico-imx7d_defconfig as base to fix device tree file generation. With this all pico-imx7d are creating u-boot-dtb.img files.
Signed-off-by: Fabio Berton fabio.berton@ossystems.com.br Signed-off-by: Otavio Salvador otavio@ossystems.com.br ---
configs/pico-hobbit-imx7d_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index 3869eb70cc..aaf916c2d0 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -41,7 +41,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="imx7d-pico-hobbit" +CONFIG_DEFAULT_DEVICE_TREE="imx7d-pico-pi" CONFIG_DFU_MMC=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000
This add the boot menu option for the DWARF baseboard as well as a specific config file for users which wish to use it as a pre-defined board.
configs/pico-dwarf-imx7d_defconfig | 68 ++++++++++++++++++++++++++++++ include/configs/pico-imx7d.h | 4 +- 2 files changed, 71 insertions(+), 1 deletion(-) create mode 100644 configs/pico-dwarf-imx7d_defconfig
diff --git a/configs/pico-dwarf-imx7d_defconfig b/configs/pico-dwarf-imx7d_defconfig new file mode 100644 index 0000000000..b8a5fb60ad --- /dev/null +++ b/configs/pico-dwarf-imx7d_defconfig @@ -0,0 +1,68 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX7=y +CONFIG_SYS_TEXT_BASE=0x87800000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_PICO_IMX7D=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_ARMV7_BOOT_SEC_DEFAULT=y +CONFIG_IMX_RDC=y +CONFIG_IMX_BOOTAUX=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" +CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" +CONFIG_DEFAULT_FDT_FILE="imx7d-pico-dwarf.dtb" +CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x00911000 +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_USB_HOST_SUPPORT=y +CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_USB_SDP_SUPPORT=y +# CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTMENU=y +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 +CONFIG_CMD_DFU=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_MII is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx7d-pico-pi" +CONFIG_DFU_MMC=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x82000000 +CONFIG_FASTBOOT_BUF_SIZE=0x10000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_DM_GPIO=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_ESDHC=y +CONFIG_PHYLIB=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX7=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_MXC_USB_OTG_HACTIVE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_VIDEO=y diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index 91015402ef..e66fa3e5e1 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -70,7 +70,9 @@ #define PICO_BOOT_ENV \ "bootmenu_0=Boot using PICO-Hobbit baseboard=" \ "setenv fdtfile imx7d-pico-hobbit.dtb\0" \ - "bootmenu_1=Boot using PICO-Pi baseboard=" \ + "bootmenu_1=Boot using PICO-Dwarf baseboard=" \ + "setenv fdtfile imx7d-pico-dwarf.dtb\0" \ + "bootmenu_2=Boot using PICO-Pi baseboard=" \ "setenv fdtfile imx7d-pico-pi.dtb\0" \ BOOTENV #endif
On Thu, 12 Sep 2019 16:04:58 -0300 Otavio Salvador otavio@ossystems.com.br wrote: ...
+CONFIG_FSL_ESDHC=y
Please change this to CONFIG_FSL_USDHC=y
-- Anatolij
This add the boot menu option for the NYMPH baseboard as well as a specific config file for users which wish to use it as a pre-defined board.
configs/pico-nymph-imx7d_defconfig | 68 ++++++++++++++++++++++++++++++ include/configs/pico-imx7d.h | 4 +- 2 files changed, 71 insertions(+), 1 deletion(-) create mode 100644 configs/pico-nymph-imx7d_defconfig
diff --git a/configs/pico-nymph-imx7d_defconfig b/configs/pico-nymph-imx7d_defconfig new file mode 100644 index 0000000000..b8a5fb60ad --- /dev/null +++ b/configs/pico-nymph-imx7d_defconfig @@ -0,0 +1,68 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX7=y +CONFIG_SYS_TEXT_BASE=0x87800000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_PICO_IMX7D=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_ARMV7_BOOT_SEC_DEFAULT=y +CONFIG_IMX_RDC=y +CONFIG_IMX_BOOTAUX=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" +CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" +CONFIG_DEFAULT_FDT_FILE="imx7d-pico-dwarf.dtb" +CONFIG_BOUNCE_BUFFER=y +CONFIG_SPL_TEXT_BASE=0x00911000 +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_USB_HOST_SUPPORT=y +CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_USB_SDP_SUPPORT=y +# CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTMENU=y +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 +CONFIG_CMD_DFU=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_MII is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx7d-pico-pi" +CONFIG_DFU_MMC=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x82000000 +CONFIG_FASTBOOT_BUF_SIZE=0x10000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_DM_GPIO=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_ESDHC=y +CONFIG_PHYLIB=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX7=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_MXC_USB_OTG_HACTIVE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_VIDEO=y diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index e66fa3e5e1..cd86cf2d2d 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -72,7 +72,9 @@ "setenv fdtfile imx7d-pico-hobbit.dtb\0" \ "bootmenu_1=Boot using PICO-Dwarf baseboard=" \ "setenv fdtfile imx7d-pico-dwarf.dtb\0" \ - "bootmenu_2=Boot using PICO-Pi baseboard=" \ + "bootmenu_2=Boot using PICO-Nymph baseboard=" \ + "setenv fdtfile imx7d-pico-nymph.dtb\0" \ + "bootmenu_3=Boot using PICO-Pi baseboard=" \ "setenv fdtfile imx7d-pico-pi.dtb\0" \ BOOTENV #endif
On Thu, 12 Sep 2019 16:04:59 -0300 Otavio Salvador otavio@ossystems.com.br wrote: ...
+CONFIG_FSL_ESDHC=y
-- Anatolij
Improve the README by adding instructions on how to boot using Falcon mode, which allows the SPL to load the kernel directly, without using U-Boot proper.
Signed-off-by: Fabio Estevam festevam@gmail.com Signed-off-by: Otavio Salvador otavio@ossystems.com.br ---
board/technexion/pico-imx7d/README | 91 ++++++++++++++++++++++++++++++ 1 file changed, 91 insertions(+)
diff --git a/board/technexion/pico-imx7d/README b/board/technexion/pico-imx7d/README index 6aa0d25af5..4d57cdbfa8 100644 --- a/board/technexion/pico-imx7d/README +++ b/board/technexion/pico-imx7d/README @@ -66,3 +66,94 @@ Remove power from the pico board. Put pico board into normal boot mode.
Power up the board and the new updated U-Boot should boot from eMMC. + +Booting in Falcon mode +====================== + +Generate a uImage kernel: + +$ make imx_v6_v7_defconfig (Using the default imx_v6_v7_defconfig configuration +just for an example. In order to boot faster the user should customize the +defconfig by only enabling the minimal required drivers). + +$ make -j4 uImage LOADADDR=0x80008000 + +$ cp arch/arm/boot/uImage /tftpboot +$ cp arch/arm/boot/dts/imx7d-pico-pi.dtb /tftpboot + +In the U-Boot prompt: + +Setup the server and board IP addresses: +=> setenv serverip 192.168.0.10 +=> setenv ipaddr 192.168.0.11 + +Get the dtb file: +=> tftp ${fdt_addr} imx7d-pico-pi.dtb + +Get the kernel: +=> tftp ${loadaddr} uImage + +Write the kernel at 2MB offset: +=> mmc write ${loadaddr} 0x1000 0x5000 + +Setup the bootargs: +=> setenv bootargs 'console=ttymxc4,115200 root=/dev/mmcblk2p1 rootfstype=ext4 rootwait rw' + +Prepare args: +=> spl export fdt ${loadaddr} - ${fdt_addr} +## Booting kernel from Legacy Image at 80800000 ... + Image Name: Linux-5.2.14 + Image Type: ARM Linux Kernel Image (uncompressed) + Data Size: 9077544 Bytes = 8.7 MiB + Load Address: 80008000 + Entry Point: 80008000 + Verifying Checksum ... OK +## Flattened Device Tree blob at 83000000 + Booting using the fdt blob at 0x83000000 + Loading Kernel Image + Using Device Tree in place at 83000000, end 8300b615 +subcommand not supported +subcommand not supported + Using Device Tree in place at 83000000, end 8300e615 +Argument image is now in RAM: 0x83000000 +=> + +Write 1MB of args data (0x800 sectors) to 1MB offset (0x800 sectors): + +=> mmc write ${fdt_addr} 0x800 0x800 + +In order to boot with Falcon mode, activate the CONFIG_SPL_OS_BOOT +option in the defconfig + +--- a/configs/pico-imx7d_defconfig ++++ b/configs/pico-imx7d_defconfig +@@ -67,3 +67,4 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0525 + CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 + CONFIG_CI_UDC=y + CONFIG_VIDEO=y ++CONFIG_SPL_OS_BOOT=y + +Then rebuild U-Boot: + +$ make pico-imx7d_defconfig +$ make -j4 + +Launch UMS: +=> ums 0 mmc 0 + +Flash the new binaries: + +$ sudo dd if=SPL of=/dev/sdX bs=1k seek=1; sync +$ sudo dd if=u-boot-dtb.img of=/dev/sdX bs=1k seek=69; sync + +And then SPL binary will load and jump directly to the kernel: + +U-Boot SPL 2019.10-rc3-00284-g001c8ea94a-dirty (Sep 10 2019 - 12:46:01 -0300) +Trying to boot from MMC1 +[ 0.000000] Booting Linux on physical CPU 0x0 +[ 0.000000] Linux version 5.2.14 (fabio@fabio-OptiPlex-7010) (gcc version 7.4.0 (Ubuntu/Linaro 7.4.0-1ubuntu1~18.04.1)) #30 SMP Wed Sep 10 12:36:27 -03 2019 +[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d +[ 0.000000] CPU: div instructions available: patching division code +[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache +[ 0.000000] OF: fdt: Machine model: TechNexion PICO-IMX7D Board and PI baseboard +...
When CONFIG_SPL_OS_BOOT is selected, it is still convenient to be able to escape from Falcon mode and boot to U-Boot proper.
Add a mechanism that allows booting in U-Boot proper when the key 'c' is entered on console at boot time.
board/technexion/pico-imx7d/spl.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/technexion/pico-imx7d/spl.c b/board/technexion/pico-imx7d/spl.c index c55a35d864..8955622b81 100644 --- a/board/technexion/pico-imx7d/spl.c +++ b/board/technexion/pico-imx7d/spl.c @@ -21,6 +21,10 @@ #ifdef CONFIG_SPL_OS_BOOT int spl_start_uboot(void) { + /* Break into full U-Boot on 'c' */ + if (serial_tstc() && serial_getc() == 'c') + return 1; + return 0; } #endif
Anatolij Gustschin
Otavio Salvador
