[U-Boot] usb, g_dnl: make possibility to fixup the device_desc board specific
add a weak dummy function g_dnl_fixup to add the possibility to update the device_desc board specific. Used on the upcoming siemens board support, where idVendor and idProduct is stored in an eeprom.
Signed-off-by: Heiko Schocher hs@denx.de Cc: Marek Vasut marek.vasut@gmail.com Cc: Lukasz Majewski l.majewski@samsung.com Cc: Kyungmin Park kyungmin.park@samsung.com --- drivers/usb/gadget/g_dnl.c | 7 +++++++ include/g_dnl.h | 2 +- 2 Dateien geändert, 8 Zeilen hinzugefügt(+), 1 Zeile entfernt(-)
diff --git a/drivers/usb/gadget/g_dnl.c b/drivers/usb/gadget/g_dnl.c index cc3f344..8a3777b 100644 --- a/drivers/usb/gadget/g_dnl.c +++ b/drivers/usb/gadget/g_dnl.c @@ -125,6 +125,12 @@ static int g_dnl_config_register(struct usb_composite_dev *cdev) return usb_add_config(cdev, &config); }
+__weak +int g_dnl_bind_fixup(struct usb_device_descriptor *dev) +{ + return 0; +} + static int g_dnl_bind(struct usb_composite_dev *cdev) { struct usb_gadget *gadget = cdev->gadget; @@ -147,6 +153,7 @@ static int g_dnl_bind(struct usb_composite_dev *cdev) g_dnl_string_defs[1].id = id; device_desc.iProduct = id;
+ g_dnl_bind_fixup(&device_desc); ret = g_dnl_config_register(cdev); if (ret) goto error; diff --git a/include/g_dnl.h b/include/g_dnl.h index f47395f..f8affd8 100644 --- a/include/g_dnl.h +++ b/include/g_dnl.h @@ -23,7 +23,7 @@
#include <linux/usb/ch9.h> #include <linux/usb/gadget.h> - +int g_dnl_bind_fixup(struct usb_device_descriptor *); int g_dnl_register(const char *s); void g_dnl_unregister(void);
Hi Heiko,
Reviewed-by: Lukasz Majewski l.majewski@samsung.com
- g_dnl_bind_fixup(&device_desc); ret = g_dnl_config_register(cdev); if (ret) goto error;
Heiko Schocher
Lukasz Majewski
