[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit b7e84c93c450480ca4ff51ad2eb56bd83c1dc368:
Merge branch 'master' of http://git.denx.de/u-boot-sunxi (2015-08-31 12:12:27 -0400)
git://git.denx.de/u-boot-fsl-qoriq.git master
for you to fetch changes up to 6923b069bd50b3ac519b16b6ae6aabbd2984c391:
pci/layerscape: Setup mmu-masters property for the PCIe (2015-09-01 21:49:27 -0500)
---------------------------------------------------------------- Alison Wang (1): armv8: fsl-lsch3: Rewrite MMU translation table entries
Aneesh Bansal (1): SECURE_BOOT: Disable IE Key feature for RAMBOOT
Bhupesh Sharma (1): armv8: Add framework for CCN-504 interconnect configuration
Claudiu Manoil (1): ls102xa: etsec: Use proper settings for BE BDs
Prabhakar Kushwaha (7): armv8: ls2085a: Update bootargs as per default target console armv8: ls2085a: Add support of CONFIG_CMD_GREPENV armv8: ls2085a: Update serdes1_cfg_tbl for 0x33 & 0x35 protocol armv8: fsl-lsch3: Initiaze 4 MACs per QSGMII in dpmac_info net: phy/vitesse: Add support for VSC8584 phy armv8: ls2085qds: Add support of X-QSGMII-16PORT riser card driver: misc: debug server: Update Error message
Priyanka Jain (2): rtc:ds3232/ds3231: Add support to generate 32KHz output armv8/ls2085aqds: enable 32KHz rtc output
Varun Sethi (1): pci/layerscape: Setup mmu-masters property for the PCIe
Yangbo Lu (1): armv8/ls2085a_simu: enable eSDHC
York Sun (1): armv8/ls2085a_emu: Drop DDR3 emulation target
Zhuoyu Zhang (1): arm/ls102xa:add hwconfig setting to support disable unused devices
arch/arm/cpu/armv8/cache_v8.c | 17 +- arch/arm/cpu/armv8/fsl-lsch3/README | 71 +++ arch/arm/cpu/armv8/fsl-lsch3/cpu.c | 474 +++++++++++++------- arch/arm/cpu/armv8/fsl-lsch3/fsl_lsch3_serdes.c | 33 +- arch/arm/cpu/armv8/fsl-lsch3/lowlevel.S | 72 ++- arch/arm/cpu/armv8/fsl-lsch3/ls2085a_serdes.c | 6 +- arch/arm/include/asm/arch-fsl-lsch3/config.h | 12 + arch/arm/include/asm/arch-ls102xa/config.h | 14 - arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 2 +- arch/arm/include/asm/arch-ls102xa/ls102xa_devdis.h | 52 +++ arch/arm/include/asm/armv8/mmu.h | 8 +- arch/arm/include/asm/fsl_secure_boot.h | 22 + arch/arm/lib/Makefile | 1 + arch/arm/lib/ccn504.S | 61 +++ arch/powerpc/include/asm/fsl_secure_boot.h | 6 +- board/freescale/ls1021aqds/ls1021aqds.c | 8 +- board/freescale/ls1021atwr/ls1021atwr.c | 8 +- board/freescale/ls2085a/MAINTAINERS | 1 - board/freescale/ls2085aqds/README | 81 ++++ board/freescale/ls2085aqds/eth.c | 466 ++++++++++++++++++- board/freescale/ls2085aqds/ls2085aqds.c | 2 + configs/ls2085a_emu_D4_defconfig | 14 - configs/ls2085a_emu_defconfig | 2 +- drivers/misc/Makefile | 1 + drivers/misc/fsl_debug_server.c | 10 +- drivers/misc/fsl_devdis.c | 29 ++ drivers/net/phy/vitesse.c | 11 + drivers/net/tsec.c | 6 - drivers/pci/pcie_layerscape.c | 9 + drivers/rtc/ds3231.c | 10 + include/configs/ls1021aqds.h | 4 +- include/configs/ls1021atwr.h | 4 +- include/configs/ls2085a_common.h | 5 +- include/configs/ls2085a_simu.h | 11 + include/configs/ls2085aqds.h | 17 + include/configs/ls2085ardb.h | 6 + include/fsl_devdis.h | 18 + include/rtc.h | 1 + 38 files changed, 1324 insertions(+), 251 deletions(-) create mode 100644 arch/arm/include/asm/arch-ls102xa/ls102xa_devdis.h create mode 100644 arch/arm/lib/ccn504.S delete mode 100644 configs/ls2085a_emu_D4_defconfig create mode 100644 drivers/misc/fsl_devdis.c create mode 100644 include/fsl_devdis.h
Thanks.
York
On Tue, Sep 01, 2015 at 10:00:22PM -0500, York Sun wrote:
Tom,
York Sun
