[PATCH 1/1] doc: man-page for the sound command
Provide a man-page for the sound command.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- doc/usage/cmd/sound.rst | 41 +++++++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 2 files changed, 42 insertions(+) create mode 100644 doc/usage/cmd/sound.rst
diff --git a/doc/usage/cmd/sound.rst b/doc/usage/cmd/sound.rst new file mode 100644 index 0000000000..bfde3ff6ee --- /dev/null +++ b/doc/usage/cmd/sound.rst @@ -0,0 +1,41 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright 2022, Heinrich Schuchardt heinrich.schuchardt@canonical.com + +sound command +============= + +Synopsis +-------- + +:: + + sound init + sound play [len] [freq] + +Description +----------- + +The *sound* command is used to play a beep sound. + +sound init + initializes the sound driver. + +sound play + plays a square wave sound. It does not depend on previously calling + *sound init*. + +len + duration of the sound in ms + +freq + frequency of the sound in Hz + +Configuration +------------- + +The sound command is enabled by CONFIG_CMD_SOUND=y. + +Return value +------------ + +The return value $? is 0 (true) if the command succeeds, 1 (false) otherwise. diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 0bc82887e9..bbd40a6e18 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -73,6 +73,7 @@ Shell commands cmd/scp03 cmd/setexpr cmd/size + cmd/sound cmd/temperature cmd/tftpput cmd/true
On Mon, 5 Dec 2022 at 04:23, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
