[PATCH v1] dt-bindings: riscv: deprecate riscv,isa
intro =====
When the RISC-V dt-bindings were accepted upstream in Linux, the base ISA etc had yet to be ratified. By the ratification of the base ISA, incompatible changes had snuck into the specifications - for example the Zicsr and Zifencei extensions were spun out of the base ISA.
Fast forward to today, and the reason for this patch. Currently the riscv,isa dt property permits only a specific subset of the ISA string - in particular it excludes version numbering. With the current constraints, it is not possible to discern whether "rv64i" means that the hart supports the fence.i instruction, for example. Future systems may choose to implement their own instruction fencing, perhaps using a vendor extension, or they may not implement the optional counter extensions. Software needs a way to determine this.
versioning schemes ==================
"Use the extension versions that are described in the ISA manual" you may say, and it's not like this has not been considered. Firstly, software that parses the riscv,isa property at runtime will need to contain a lookup table of some sort that maps arbitrary versions to versions it understands. There is not a consistent application of version number applied to extensions, with a higgledy-piggledy collection of tags, "bare" and version documents awaiting the reader on the "recently ratified extensions" page: https://wiki.riscv.org/display/HOME/Recently+Ratified+Extensions
As an aside, this is reflected in the patch too, since many extensions have yet to appear in a release of the ISA specs, and are defined by commits in their respective "working draft" repositories.
Secondly, there is an issue of backwards compatibility, whereby allowing numbers in the ISA string, some parsers may be broken. This would require an additional property to be created to even use the versions in this manner.
boolean properties ==================
If a new property is needed, the whole approach may as well be looked at from the bottom up. A string with limited character choices etc is hardly the best approach for communicating extension information to software.
Switching to using boolean properties, one per extension, allows us to define explicit meanings for the DT representation of each extension - rather than the current situation where different operating systems or other bits of software may impart different meanings to characters in the string. Clearly the best source of meanings is the specifications themselves, this just provides us the ability to choose at what point in time the meaning is set. If an extension changes incompatibility in the future, a new property will be required.
Off-list, some of the RVI folks have committed to shoring up the wording in either the ISA specifications, the riscv-isa-manual or so that in the future, modifications to and additions or removals of features will require a new extension. Codifying that assertion somewhere would make it quite unlikely that compatibility would be broken, but we have the tools required to deal with it, if & when it crops up. It is in our collective interest, as consumers of extension meanings, to define a scheme that enforces compatibility.
The use of boolean properties, rather than elements in a string, will also permit validation that the strings have a meaning, as well as potentially reject mutually exclusive combinations, or enforce dependencies between instructions. That would not be possible with the current dt-schema infrastructure for arbitrary strings, as we would need to add a riscv,isa parser to dt-validate! That's not implemented in this patch, but rather left as future work!
acpi ====
The current ACPI ECR is based on having a string unfortunately, but ideally ACPI will move to another method, perhaps GUIDs, that give explicit meaning to extensions.
parser simplicity =================
Many systems that parse DT at runtime already implement an function that can check for the presence of boolean properties, rather than having to implement - although unfortunately for backwards compatibility with old dtbs, existing parsers may not be removable - which may greatly simplify dt parsing code. For example, in Linux, checking for an extension becomes as simple as: of_property_present(node, "riscv,isa-extension-zicbom")
vendor extensions =================
Compared to riscv,isa, this proposed scheme promotes vendor extensions, oft touted as the strength of RISC-V, to first-class citizens. At present, extensions are defined as meaning what the RISC-V ISA specifications say they do. There is no realistic way of using that interface to provide cross-platform definitions for what vendor extensions mean. Vendor extensions may also have even less consistency than RVI do in terms of versioning, or no care about backwards compatibility. A boolean property allows us to assign explicit meanings on a per vendor extension basis, backed up by a description of their meanings.
fin ===
Create a new file to store the extension meanings, each in the form riscv,isa-extension-<foo> and a new riscv,isa-base property to replace the missing aspect of riscv,isa - the base ISA implemented by a hart. As a starting point, properties were added for extensions currently used in Linux.
Finally, mark riscv,isa as deprecated. o7.
CC: Palmer Dabbelt palmer@dabbelt.com CC: Paul Walmsley paul.walmsley@sifive.com CC: Rob Herring robh+dt@kernel.org CC: Krzysztof Kozlowski krzysztof.kozlowski+dt@linaro.org CC: Alistair Francis alistair.francis@wdc.com CC: Andrew Jones ajones@ventanamicro.com CC: Anup Patel apatel@ventanamicro.com CC: Atish Patra atishp@atishpatra.org CC: Jessica Clarke jrtc27@jrtc27.com CC: Rick Chen rick@andestech.com CC: Leo ycliang@andestech.com CC: linux-riscv@lists.infradead.org CC: qemu-riscv@nongnu.org CC: u-boot@lists.denx.de CC: devicetree@vger.kernel.org CC: linux-kernel@vger.kernel.org Signed-off-by: Conor Dooley conor.dooley@microchip.com --- I've tried to CC a few folks here that would care about this, but I am sure there are more. I'll go cross-post it to sw-dev, if it allows me to post there... --- .../devicetree/bindings/riscv/cpus.yaml | 45 +-- .../devicetree/bindings/riscv/extensions.yaml | 259 ++++++++++++++++++ 2 files changed, 282 insertions(+), 22 deletions(-) create mode 100644 Documentation/devicetree/bindings/riscv/extensions.yaml
diff --git a/Documentation/devicetree/bindings/riscv/cpus.yaml b/Documentation/devicetree/bindings/riscv/cpus.yaml index 3d2934b15e80..446801fb7495 100644 --- a/Documentation/devicetree/bindings/riscv/cpus.yaml +++ b/Documentation/devicetree/bindings/riscv/cpus.yaml @@ -23,6 +23,9 @@ description: | two cores, each of which has two hyperthreads, could be described as having four harts.
+allOf: + - $ref: extensions.yaml + properties: compatible: oneOf: @@ -79,25 +82,6 @@ properties: description: The blocksize in bytes for the Zicboz cache operations.
- riscv,isa: - description: - Identifies the specific RISC-V instruction set architecture - supported by the hart. These are documented in the RISC-V - User-Level ISA document, available from - https://riscv.org/specifications/ - - Due to revisions of the ISA specification, some deviations - have arisen over time. - Notably, riscv,isa was defined prior to the creation of the - Zicsr and Zifencei extensions and thus "i" implies - "zicsr_zifencei". - - While the isa strings in ISA specification are case - insensitive, letters in the riscv,isa string must be all - lowercase to simplify parsing. - $ref: "/schemas/types.yaml#/definitions/string" - pattern: ^rv(?:64|32)imaf?d?q?c?b?k?j?p?v?h?(?:[hsxz](?:[a-z])+)?(?:_[hsxz](?:[a-z])+)*$ - # RISC-V requires 'timebase-frequency' in /cpus, so disallow it here timebase-frequency: false
@@ -133,8 +117,13 @@ properties: DMIPS/MHz, relative to highest capacity-dmips-mhz in the system.
+oneOf: + - required: + - riscv,isa + - required: + - riscv,isa-base + required: - - riscv,isa - interrupt-controller
additionalProperties: true @@ -177,7 +166,13 @@ examples: i-tlb-size = <32>; mmu-type = "riscv,sv39"; reg = <1>; - riscv,isa = "rv64imafdc"; + riscv,isa-base = "rv64i"; + riscv,isa-extension-i; + riscv,isa-extension-m; + riscv,isa-extension-a; + riscv,isa-extension-f; + riscv,isa-extension-d; + riscv,isa-extension-c; tlb-split; cpu_intc1: interrupt-controller { #interrupt-cells = <1>; @@ -196,7 +191,13 @@ examples: device_type = "cpu"; reg = <0>; compatible = "riscv"; - riscv,isa = "rv64imafdc"; + riscv,isa-base = "rv64i"; + riscv,isa-extension-i; + riscv,isa-extension-m; + riscv,isa-extension-a; + riscv,isa-extension-f; + riscv,isa-extension-d; + riscv,isa-extension-c; mmu-type = "riscv,sv48"; interrupt-controller { #interrupt-cells = <1>; diff --git a/Documentation/devicetree/bindings/riscv/extensions.yaml b/Documentation/devicetree/bindings/riscv/extensions.yaml new file mode 100644 index 000000000000..1b4d726f7174 --- /dev/null +++ b/Documentation/devicetree/bindings/riscv/extensions.yaml @@ -0,0 +1,259 @@ +# SPDX-License-Identifier: (GPL-2.0 OR MIT) +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/riscv/extensions.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: RISC-V ISA extensions + +maintainers: + - Paul Walmsley paul.walmsley@sifive.com + - Palmer Dabbelt palmer@sifive.com + - Conor Dooley conor@kernel.org + +description: | + RISC-V has large number of extensions, some of which "standard" extensions, + meaning they are ratified by RISC-V International, and others are "vendor" + extensions. This document defines properties that indicate whether a hart + supports a given extensions. + + Once a standard extension has been ratified, no features can be added or + removed without the creation of a new extension for that sub- or super-set. + The properties for standard extensions therefore map to their originally + ratified states, with the exception of the I, Zicntr & Zihpm extensions. + +select: + properties: + compatible: + contains: + const: riscv + +properties: + riscv,isa: + description: + Identifies the specific RISC-V instruction set architecture + supported by the hart. These are documented in the RISC-V + User-Level ISA document, available from + https://riscv.org/specifications/ + + Due to revisions of the ISA specification, some deviations + have arisen over time. + Notably, riscv,isa was defined prior to the creation of the + Zicsr and Zifencei extensions and thus "i" implies + "zicsr_zifencei". + + While the isa strings in ISA specification are case + insensitive, letters in the riscv,isa string must be all + lowercase to simplify parsing. + + This property has been deprecated due to disparity between the + extension at the time of its creation and ratification of the + base ISA. + + $ref: /schemas/types.yaml#/definitions/string + pattern: ^rv(?:64|32)imaf?d?q?c?b?k?j?p?v?h?(?:[hsxz](?:[a-z])+)?(?:_[hsxz](?:[a-z])+)*$ + deprecated: true + + riscv,isa-base: + description: + The base ISA implemented by this hart, as described by the 20191213 + version of the unprivileged ISA specification. + enum: + - rv32i + - rv64i + + riscv,isa-extension-i: + type: boolean + description: + The base integer instruction set, as ratified in the 20191213 version of the + unprivileged ISA specification. + + riscv,isa-extension-m: + type: boolean + description: + The standard M extension for integer multiplication and division, as + ratified in the 20191213 version of the unprivileged ISA specification. + + riscv,isa-extension-a: + type: boolean + description: + The standard A extension for atomic instructions, as ratified in the + 20191213 version of the unprivileged ISA specification. + + riscv,isa-extension-f: + type: boolean + description: + The standard M extension for single-precision floating point, as + ratified in the 20191213 version of the unprivileged ISA specification. + + riscv,isa-extension-d: + type: boolean + description: + The standard M extension for double-precision floating-point, as + ratified in the 20191213 version of the unprivileged ISA specification. + + riscv,isa-extension-q: + type: boolean + description: + The standard M extension for quad-precision floating-point, as ratified in + the 20191213 version of the unprivileged ISA specification. + + riscv,isa-extension-c: + type: boolean + description: + The standard M extension for compressed instructions, as ratified in the + 20191213 version of the unprivileged ISA specification. + + riscv,isa-extension-v: + type: boolean + description: + The standard V extension for vector operations, as ratified in-and-around + commit 7a6c8ae ("Fix text that describes vfmv.v.f encoding") of the + riscv-v-spec. + + riscv,isa-extension-h: + type: boolean + description: + The standard h extension for hypervisors as ratified in the 20191213 + version of the privileged ISA specification. + + # Additional Standard Extensions, sorted by category then alphabetically + + riscv,isa-extension-zicntr: + type: boolean + description: + The standard Zicntr extension for base counters and timers, as ratified + in the 20191213 version of the unprivileged ISA specification. + + riscv,isa-extension-zicsr: + type: boolean + description: + The standard Zicsr extension for control and status register instructions, + as ratified in the 20191213 version of the unprivileged ISA specification. + + riscv,isa-extension-zifencei: + type: boolean + description: + The standard Zifencei extension for instruction-fetch fence, as ratified + in the 20191213 version of the unprivileged ISA specification. + + riscv,isa-extension-zihpm: + type: boolean + description: + The standard Zihpm extension for hardware performance counters, as + ratified in the 20191213 version of the unprivileged ISA specification. + + riscv,isa-extension-zicbom: + type: boolean + description: + The standard Zicbom extension for base cache management operations as + ratified in commit 3dd606f ("Create cmobase-v1.0.pdf") of riscv-CMOs. + + riscv,isa-extension-zicbop: + type: boolean + description: + The standard Zicbop extension for cache-block prefetch instructions as + ratified in commit 3dd606f ("Create cmobase-v1.0.pdf") of riscv-CMOs. + + riscv,isa-extension-zicboz: + type: boolean + description: + The standard Zicbomz extension for cache-block zeroing as ratified in + commit 3dd606f ("Create cmobase-v1.0.pdf") of riscv-CMOs. + + riscv,isa-extension-zihintpause: + type: boolean + description: | + The standard Zihintpause extension for pause hints, as ratified in + commit d8ab5c7 ("Zihintpause is ratified") of the riscv-isa-manual. + + riscv,isa-extension-zba: + type: boolean + description: | + The standard Zba bit-manipulation extension for address generation + acceleration instructions as ratified at commit 6d33919 ("Merge pull + request #158 from hirooih/clmul-fix-loop-end-condition") of + riscv-bitmanip. + + riscv,isa-extension-zbb: + type: boolean + description: | + The standard Zbb bit-manipulation extension for basic bit-manipulation as + atified at commit 6d33919 ("Merge pull request #158 from + hirooih/clmul-fix-loop-end-condition") of riscv-bitmanip. + + riscv,isa-extension-zbc: + type: boolean + description: | + The standard Zbc bit-manipulation extension for carry-less multiplication + as ratified at commit 6d33919 ("Merge pull request #158 from + hirooih/clmul-fix-loop-end-condition") of riscv-bitmanip. + + riscv,isa-extension-zbs: + type: boolean + description: | + The standard Zbs bit-manipulation extension for single-bit instructions + as ratified at commit 6d33919 ("Merge pull request #158 from + hirooih/clmul-fix-loop-end-condition") of riscv-bitmanip. + + riscv,isa-extension-ztso: + type: boolean + description: + The standard Ztso extension for total store ordering, as ratified in + commit 2e5236 ("Ztso is now ratified.") of the riscv-isa-manual. + + # Standard Supervisor-level Extensions, sorted by category then alphabetically + + 'riscv,isa-extension-smaia': + type: boolean + description: | + The standard Smaia supervisor-level extension for the advanced interrupt + architecture for machine-mode-visible csr and behavioural changes to + interrupts as frozen at commit ccbddab ("Merge pull request #42 from + riscv/jhauser-2023-RC4") of riscv-aia. + + riscv,isa-extension-ssaia: + type: boolean + description: | + The standard Ssaia supervisor-level extension for the advanced interrupt + architecture for supervisor-mode-visible csr and behavioural changes to + interrupts as frozen at commit ccbddab ("Merge pull request #42 from + riscv/jhauser-2023-RC4") of riscv-aia. + + riscv,isa-extension-sscofpmf: + type: boolean + description: | + The standard supervisor-level extension for count overflow and mode-based + filtering as ratified at commit 01d1df0 ("Add ability to manually trigger + workflow. (#2)") of riscv-count-overflow. + + riscv,isa-extension-sstc: + type: boolean + description: + The standard supervisor-level extension for time compare + as ratified at commit 3f9ed34 ("Add ability to manually trigger + workflow. (#2)") of riscv-time-compare. + + riscv,isa-extension-svinval: + type: boolean + description: + The standard Svinval supervisor-level extension for fine-grained + address-translation cache invalidation as ratified in the 20191213 version + of the privileged ISA specification. + + riscv,isa-extension-svnapot: + type: boolean + description: + The standard Svnapot supervisor-level extensions for napot translation + contiguity as ratified in the 20191213 version of the privileged ISA + specification. + + riscv,isa-extension-svpbmt: + type: boolean + description: + The standard Svpbmt supervisor-level extensions for page-based memory + types as ratified in the 20191213 version of the privileged ISA + specification. + +additionalProperties: true +...
On Thu, May 18, 2023 at 09:58:30AM +0100, Conor Dooley wrote:
intro
versioning schemes
boolean properties
acpi
parser simplicity
vendor extensions
fin
+allOf:
- riscv,isa:
- description:
"zicsr_zifencei".
+oneOf:
- required:
- riscv,isa
This is the part Anup keeps reminding me about. We can create better ways to handle extensions in DT and ACPI, but we'll still need to parse ISA strings to handle legacy DTs and holdouts that keep creating ISA strings, at least during the deprecation period, since ISA strings are still "the way to do it" according to the spec.
Also, if we assume the wording in the spec does get shored up, then, unless I'm missing something, the list of advantages for this boolean proposal from your commit message would be
* More character choices for name -- probably not a huge gain for ratified extensions, since the boolean properties will likely still use the same name as the ISA string (riscv,isa-extension-<name>). But, for vendor extensions, this is indeed a major improvement, since vendor extension boolean property names may need to be extended in unambiguous ways to handle changes in the extension.
* Simpler, more complete DT validation (but we still need a best effort for legacy ISA strings)
* Simpler DT parsing (but we still need the current parser for legacy ISA strings)
- required:
- riscv,isa-base
required:
- riscv,isa
+maintainers:
+description: |
- RISC-V has large number of extensions, some of which "standard" extensions,
^ a ^ are
- meaning they are ratified by RISC-V International, and others are "vendor"
- extensions. This document defines properties that indicate whether a hart
- supports a given extensions.
drop 'a' or depluralize 'extensions'
- Once a standard extension has been ratified, no features can be added or
I'd change 'features' to 'changes in behavior', and then...
- removed without the creation of a new extension for that sub- or super-set.
...drop 'for that sub- or super-set'
- The properties for standard extensions therefore map to their originally
- ratified states, with the exception of the I, Zicntr & Zihpm extensions.
Can you elaborate on the exceptions? Or, if the exceptions are described below, maybe a '(see below)' here would help ease the reader's insecurities about their lack of knowledge about these exceptions, as they'll see that the education is coming :-)
+select:
- properties:
- compatible:
contains:
const: riscv
+properties:
- riscv,isa:
- description:
"zicsr_zifencei".
^ the
(but I see this was a faithful move of the current text, so maybe better to fix it up separately)
base ISA.
- $ref: /schemas/types.yaml#/definitions/string
- deprecated: true
- riscv,isa-base:
- description:
- enum:
- rv32i
- rv64i
- riscv,isa-extension-i:
- type: boolean
- description:
- riscv,isa-extension-m:
- type: boolean
- description:
- riscv,isa-extension-a:
- type: boolean
- description:
- riscv,isa-extension-f:
- type: boolean
- description:
^ F
- riscv,isa-extension-d:
- type: boolean
- description:
^ D
- riscv,isa-extension-q:
- type: boolean
- description:
^ Q
- riscv,isa-extension-c:
- type: boolean
- description:
^ C
- riscv,isa-extension-v:
- type: boolean
- description:
riscv-v-spec.
- riscv,isa-extension-h:
- type: boolean
- description:
^ H (might as well keep the case consistent)
- # Additional Standard Extensions, sorted by category then alphabetically
Can we just do pure alphabetically? And the single-letter extensions above don't have a "sorted by" comment above them. I guess they need one, or maybe they can also be alphabetical?
- riscv,isa-extension-zicntr:
- type: boolean
- description:
- riscv,isa-extension-zicsr:
- type: boolean
- description:
- riscv,isa-extension-zifencei:
- type: boolean
- description:
- riscv,isa-extension-zihpm:
- type: boolean
- description:
- riscv,isa-extension-zicbom:
- type: boolean
- description:
- riscv,isa-extension-zicbop:
- type: boolean
- description:
- riscv,isa-extension-zicboz:
- type: boolean
- description:
^ ^Zicboz ^ extra space
(The repetition is making my vision blur, so I'm feeling like I should write a script to compare $a and $b, where $a is riscv,isa-extension-$a and $b is 'The standard $b' to make sure they match :-) But I probably won't...
- riscv,isa-extension-zihintpause:
- type: boolean
- description: |
- riscv,isa-extension-zba:
- type: boolean
- description: |
riscv-bitmanip.
- riscv,isa-extension-zbb:
- type: boolean
- description: |
^ ratified
- riscv,isa-extension-zbc:
- type: boolean
- description: |
- riscv,isa-extension-zbs:
- type: boolean
- description: |
- riscv,isa-extension-ztso:
- type: boolean
- description:
- # Standard Supervisor-level Extensions, sorted by category then alphabetically
The spec only says alphabetical sorting for supervisor-level extensions, no category.
- 'riscv,isa-extension-smaia':
- type: boolean
- description: |
- riscv,isa-extension-ssaia:
- type: boolean
- description: |
- riscv,isa-extension-sscofpmf:
- type: boolean
- description: |
^ Sscofpmf
- riscv,isa-extension-sstc:
- type: boolean
- description:
^ Sstc
- riscv,isa-extension-svinval:
- type: boolean
- description:
- riscv,isa-extension-svnapot:
- type: boolean
- description:
specification.
- riscv,isa-extension-svpbmt:
- type: boolean
- description:
specification.
2.39.2
I'll take your word for it on the versions/dates/commit hashes referenced, at least until we get closer to actually merging this.
Thanks, drew
Hey Drew,
- riscv,isa:
- description:
"zicsr_zifencei".
+oneOf:
- required:
- riscv,isa
Yeah, we cannot remove the string parser from the kernel as we will break existing users. I don't see keeping it as a problem, we should be nice to people rather than intentionally trip them up. Let them trip themselves up when their implicit meaning doesn't match whatever bit of software they are running's.
I am not sure what this means, dt-bindings determine the DT ABI, not what RVI puts in specs.
Well, shored up _AND_ adhered to. Actions speak far, far louder than words in that respect unfortunately!
The "best effort" validation via dt-bindings is the current regex. I've intentionally marked it deprecated, rather than delete it partly for that reason & partly out of consideration for other users.
- Simpler DT parsing (but we still need the current parser for legacy ISA strings)
Speaking only about Linux, we can use these meanings here for interpreting the strings and then apply the fixups that correspond to the difference between the defined meanings & those at the time of the dt-binding originally being merged - unconditionally setting zifencei, zicsr, zicntr, etc. If you don't implement those things, then expect to fall over. Other operating systems etc may have different implicit meanings and their own decisions to make! Oh, and if the "foo" bit of "riscv,isa-extension-foo" doesn't match what you put in riscv,isa then you keep the pieces. For example, if a vendor has a vendor extension Xconor where version 1.0.1 is incompatible with v1.0.0, the properties may be "riscv,isa-extension-xconor" and "riscv,isa-extension-xconor-no-insnx". In that case, for Linux, I would assert that there should/would be no way to get the later version of that extension via riscv,isa. There are no existing situations like this, so no backwards compatibility is broken here. If/when it happens, the property is deprecated and we can direct such cases to the new interface :) Basically the same as: https://lore.kernel.org/linux-riscv/20230504-oncoming-antihero-1ed69bb8f57d@...
That reminds me, I need to re-spin that with more extensions set unconditionally.
If some new OS comes along, they don't need to implement riscv,isa at all as it's deprecated.
I'd like to add another one: * Unified meaning of extensions across bits of software. I actually have no idea what versions of things other OSes map the characters to.
+maintainers:
+description: |
^ a ^ are
Ah crap, I meant to note in the I section that timers were moved to their own home. Since we are defining this stuff now, I felt that it'd make sense to define riscv,isa-extension-i as meaning the ratified spec, sans the counters.
- type: boolean
- description:
^ F
Whoops. All of these are me realising this morning, after checking everything a few times last night, that there was a dt_binding_check complaint which prevented me implementing non-patterns as patternProperties. As a result, I split everything back out into single properties. It's always the last minute bits...
I could have had a mix of properties and pattern properties, but I preferred to keep the ordering as something that people could more easily use to locate properties.
- type: boolean
- description:
riscv-v-spec.
- type: boolean
- description:
I don't really have a preference for ordering. I'm happy to do pure alphabetical.
- type: boolean
- description:
Again, same excuse! Silly me and all that.
Aye & I am hoping that by the time that this could actually be considered for merging that perhaps some of the items will migrate to the riscv-isa-manual, instead of being flung to the four winds.
Thanks, Conor.
Maybe it is just me, but my brain is too used to seeing those ones in something approaching canonical order. I'd rather keep them that way & then alphanumerical for everything else?
I also noticed that the CMO stuff wasn't actually in the comment's order anyway, so needs a re-sort to begin with. A vote in favour of alphanumerical.
intro
versioning schemes
boolean properties
acpi
parser simplicity
vendor extensions
fin
+allOf:
- riscv,isa:
- description:
"zicsr_zifencei".
+oneOf:
- required:
- riscv,isa
Coming up with an alternate way in DT is fine but we can't deprecate ISA strings since ISA strings are widely used: 1) Various bootloaders 2) It is part of /proc/cpuinfo 3) Hypervisors use it to communicate HW features to Guest/VM. Hypervisors can't get away from generating ISA strings because Hypervisors don't know what is running inside Guest/VM.
In the case of ACPI, it is a very different situation. Like Sunil mentioned, ACPI will always follow mechanisms defined by RVI (such as ISA string). Other ACPI approaches such as GUID for ISA extension are simply not scalable and will take a lot more memory for ACPI tables compared to ISA strings.
IMO, we should try our best to have the wordings changed in RVI spec.
- required:
- riscv,isa-base
required:
- riscv,isa
One downside of this new approach is it will increase the size of DTB. Imaging 50 such DT properties in 46 CPU DT nodes.
Regards, Anup
+maintainers:
+description: |
^ a ^ are
+select:
- properties:
- compatible:
contains:
const: riscv
+properties:
- riscv,isa:
- description:
"zicsr_zifencei".
^ the (but I see this was a faithful move of the current text, so maybe better to fix it up separately)
base ISA.
- deprecated: true
- riscv,isa-base:
- description:
- enum:
- rv32i
- rv64i
- type: boolean
- description:
- type: boolean
- description:
- type: boolean
- description:
- type: boolean
- description:
^ F
- type: boolean
- description:
^ D
- type: boolean
- description:
^ Q
- type: boolean
- description:
^ C
- type: boolean
- description:
riscv-v-spec.
- type: boolean
- description:
- type: boolean
- description:
- type: boolean
- description:
- type: boolean
- description:
- type: boolean
- description:
- type: boolean
- description:
- type: boolean
- description:
- type: boolean
- description:
- type: boolean
- description: |
- type: boolean
- description: |
riscv-bitmanip.
- type: boolean
- description: |
^ ratified
- type: boolean
- description: |
- type: boolean
- description: |
- type: boolean
- description:
- type: boolean
- description: |
- type: boolean
- description: |
- type: boolean
- description: |
^ Sscofpmf
- type: boolean
- description:
^ Sstc
- type: boolean
- description:
- type: boolean
- description:
specification.
- type: boolean
- description:
specification.
2.39.2
Thanks, drew
- riscv,isa:
- description:
"zicsr_zifencei".
+oneOf:
- required:
- riscv,isa
- Various bootloaders
Aye, for the reason, as I mentioned earlier and in the RFC thread, removing existing parsers isn't a good idea.
- It is part of /proc/cpuinfo
That is irrelevant.
- Hypervisors use it to communicate HW features to Guest/VM.
Generate both :) As things stand, your guests could interpret what you communicate to them via riscv,isa differently!
My proposal should actually suit ACPI, at least for Linux, as it would be a chance to align currently misaligned definitions. I won't speak to GUIDs or whatever as that's someone else's problem :)
Yes, doing so is beneficial for all of us regardless of what happens here. I do think that it is partially orthogonal - it allows us to not design an interface that needs to be capable of communicating a wide variety of versions, but I don't think it solves some of the issues that riscv,isa has. If I thought it did, I would not have gone to the trouble of respinning this patch out of the other approach.
- required:
- riscv,isa-base
required:
- riscv,isa
I should do a comparison between 50 extensions in riscv,isa and doing this 50 times and see what the sizes are.
- riscv,isa:
- description:
"zicsr_zifencei".
+oneOf:
- required:
- riscv,isa
Removing and deprecating are different. We can deprecate stuff.
That is irrelevant.
We talked a bit in the patchwork meeting with Drew about ACPI. Any actual spec/encoding would need to be different, of course, but conceptually it seems to fit fine. It's also broadly similar to what we've done with riscv_hwprobe() for userspace, which is nice.
- required:
- riscv,isa-base
required:
- riscv,isa
I'm not sure how sensitive people are to DT size (presumably it'd be DTB size)?
It's also not clear what we can do about it: RISC-V has lots of extensions, that's going to take encoding space. Sticking with an ambiguous encoding because it's smaller seems like a way to get burned in the long run.
I did actually go an look at this. I cheated a little and renamed the properties to "riscv,isa-ext-foo", which is about as communicative IMO as the longer name I currently have, but may seem more agreeable to the size conscious. I added 30 cpu nodes to mpfs.dtsi, each with 100 extensions of 6 chars long. With just the string, containing "rv64imafdc_zabcde_...", it was unreadable, but "only" took up 46k. I then removed the multiletter extensions from riscv,isa & switched to riscv,isa-base & 100 booleans. IMO it was more readable (although still quite bad!), but took up 62k. Removing all of the boolean properties, leaving me with 30 addtional harts with "rv64imafdc" only, was 26k.
I think the generic limit for dtb files is 2 MiB? To me the size increase doesn't sound like a bit problem.
- riscv,isa:
- description:
"zicsr_zifencei".
+oneOf:
- required:
- riscv,isa
That is irrelevant.
- required:
- riscv,isa-base
required:
- riscv,isa
Why not just have something like
mycpu { ... riscv,isa { i; m; a; zicsr; ... }; };
--Sean
- riscv,isa:
- description:
"zicsr_zifencei".
+oneOf:
- required:
- riscv,isa
That is irrelevant.
- required:
- riscv,isa-base
required:
- riscv,isa
Naming of the node aside (perhaps that could be riscv,isa-extensions) there's not something hitting me immediately as to why that is a no-no. If the size is a concern, this would certainly be more efficient & not like the probing would be anything other than trivial more difficult what I have in my proposal.
Rob's AFK at the moment, and I was hoping that he would take a look at the idea, so I won't respin til he is back, but I'll give this a go in the interim.
Cheers, Conor.
Having started messing around with this, one of the main advantages, to me, of this approach is proper validation. cpus.yaml has additionalProperties: true in it, which would have had to be sorted out, or worked around, but creating a child-node with the properties in it allows setting additionalProperties: false.
Mechanically, the conversion of the patch isn't difficult, but I'll still wait for Rob to come back before sending a v2. But that v2 will more than likely implement your suggestion.
Cheers, Conor.
I prefer property names be globally unique. The tools are geared towards that too. That's largely a symptom of having 0 type information in the DT.
For example if you had an extension called 'reg', it would be a problem.
That's an issue on my radar to fix. I started that for the Arm cpus.yaml a while back. Sadly it involves adding all the misc properties vendors added. It's not a lot, but still better to get in front of that for Risc-V.
I haven't read the whole thread, but the initial proposal looks okay to me.
Another way you could do this is a list of strings:
riscv,isa-ext = "i", "m", "zicsr";
I think we have a helper to test is a string in the list.
Rob
Per the current ISA rules, that'd not be valid. But then again, I do have trust issues & it's not like "reg" is the only property name in DT land.
Yeah, guess I can append that to my todo list.
Perhaps I should've waited a bit longer than a month for a v2 - I sent one this afternoon doing what Sean suggested: https://lore.kernel.org/all/20230608-sitting-bath-31eddc03c5a5@spud/
I'll do some poking at the strings and see what I think of it.
Cheers, Conor.
Rob, Before I press on with more versions...
...you say "prefer" here. Is that a NAK, or a "you keep the pieces"?
Don't do the above node.
Rob
> > Why not just have something like > > mycpu { > ... > riscv,isa { > i; > m; > a; > zicsr; > ...
Yeah, that's more helpful wording than "prefer" for sure!
If that's a no-go & so are the booleans prefixed with "riscv,whatever-", since people have size concerns, I guess that leaves your string suggestion (there is a helper in Linux at least, haven't checked elsewhere yet).
I guess that means something like:
riscv,isa-extensions: $ref: /schemas/types.yaml#/definitions/string-array minItems: 1 description: Extensions supported by the hart. items: anyOf: - const: i description: foo - const: m description: foo - const: a description: foo - const: f description: foo - const: d description: foo - const: c description: foo - const: zifencei description: foo - etc
Obviously with "foo" replaced by the existing descriptions in this patch.
participants (7)
Andrew Jones
Anup Patel
Conor Dooley
Conor Dooley
Palmer Dabbelt
Rob Herring
Sean Anderson
