[U-Boot] [PATCH V2 1/5] mmc: uniphier-sd: Factor out register IO
This patch prepares the driver to support controller(s) with registers at locations shifted by constant. Pull out the readl()/writel() from the driver into separate functions, where the adjustment of the register offset can be easily contained.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Jaehoon Chung jh80.chung@samsung.com --- V2: Use unsigned int for the reg argument --- drivers/mmc/uniphier-sd.c | 115 +++++++++++++++++++++++++--------------------- 1 file changed, 63 insertions(+), 52 deletions(-)
diff --git a/drivers/mmc/uniphier-sd.c b/drivers/mmc/uniphier-sd.c index e272b14153..b5c608d866 100644 --- a/drivers/mmc/uniphier-sd.c +++ b/drivers/mmc/uniphier-sd.c @@ -134,6 +134,17 @@ struct uniphier_sd_priv { #define UNIPHIER_SD_CAP_DIV1024 BIT(2) /* divisor 1024 is available */ };
+static u32 uniphier_sd_readl(struct uniphier_sd_priv *priv, unsigned int reg) +{ + return readl(priv->regbase + reg); +} + +static void uniphier_sd_writel(struct uniphier_sd_priv *priv, + const u32 val, unsigned int reg) +{ + writel(val, priv->regbase + reg); +} + static dma_addr_t __dma_map_single(void *ptr, size_t size, enum dma_data_direction dir) { @@ -157,7 +168,7 @@ static void __dma_unmap_single(dma_addr_t addr, size_t size, static int uniphier_sd_check_error(struct udevice *dev) { struct uniphier_sd_priv *priv = dev_get_priv(dev); - u32 info2 = readl(priv->regbase + UNIPHIER_SD_INFO2); + u32 info2 = uniphier_sd_readl(priv, UNIPHIER_SD_INFO2);
if (info2 & UNIPHIER_SD_INFO2_ERR_RTO) { /* @@ -195,7 +206,7 @@ static int uniphier_sd_wait_for_irq(struct udevice *dev, unsigned int reg, long wait = 1000000; int ret;
- while (!(readl(priv->regbase + reg) & flag)) { + while (!(uniphier_sd_readl(priv, reg) & flag)) { if (wait-- < 0) { dev_err(dev, "timeout\n"); return -ETIMEDOUT; @@ -227,14 +238,14 @@ static int uniphier_sd_pio_read_one_block(struct udevice *dev, u32 **pbuf, * Clear the status flag _before_ read the buffer out because * UNIPHIER_SD_INFO2_BRE is edge-triggered, not level-triggered. */ - writel(0, priv->regbase + UNIPHIER_SD_INFO2); + uniphier_sd_writel(priv, 0, UNIPHIER_SD_INFO2);
if (likely(IS_ALIGNED((unsigned long)*pbuf, 4))) { for (i = 0; i < blocksize / 4; i++) - *(*pbuf)++ = readl(priv->regbase + UNIPHIER_SD_BUF); + *(*pbuf)++ = uniphier_sd_readl(priv, UNIPHIER_SD_BUF); } else { for (i = 0; i < blocksize / 4; i++) - put_unaligned(readl(priv->regbase + UNIPHIER_SD_BUF), + put_unaligned(uniphier_sd_readl(priv, UNIPHIER_SD_BUF), (*pbuf)++); }
@@ -253,15 +264,15 @@ static int uniphier_sd_pio_write_one_block(struct udevice *dev, if (ret) return ret;
if (likely(IS_ALIGNED((unsigned long)*pbuf, 4))) { for (i = 0; i < blocksize / 4; i++) - writel(*(*pbuf)++, priv->regbase + UNIPHIER_SD_BUF); + uniphier_sd_writel(priv, *(*pbuf)++, UNIPHIER_SD_BUF); } else { for (i = 0; i < blocksize / 4; i++) - writel(get_unaligned((*pbuf)++), - priv->regbase + UNIPHIER_SD_BUF); + uniphier_sd_writel(priv, get_unaligned((*pbuf)++), + UNIPHIER_SD_BUF); }
return 0; @@ -292,22 +303,22 @@ static void uniphier_sd_dma_start(struct uniphier_sd_priv *priv, { u32 tmp;
- writel(0, priv->regbase + UNIPHIER_SD_DMA_INFO1); - writel(0, priv->regbase + UNIPHIER_SD_DMA_INFO2); + uniphier_sd_writel(priv, 0, UNIPHIER_SD_DMA_INFO1); + uniphier_sd_writel(priv, 0, UNIPHIER_SD_DMA_INFO2);
/* enable DMA */ - tmp = readl(priv->regbase + UNIPHIER_SD_EXTMODE); + tmp = uniphier_sd_readl(priv, UNIPHIER_SD_EXTMODE); tmp |= UNIPHIER_SD_EXTMODE_DMA_EN; - writel(tmp, priv->regbase + UNIPHIER_SD_EXTMODE); + uniphier_sd_writel(priv, tmp, UNIPHIER_SD_EXTMODE);
- writel(dma_addr & U32_MAX, priv->regbase + UNIPHIER_SD_DMA_ADDR_L); + uniphier_sd_writel(priv, dma_addr & U32_MAX, UNIPHIER_SD_DMA_ADDR_L);
/* suppress the warning "right shift count >= width of type" */ dma_addr >>= min_t(int, 32, 8 * sizeof(dma_addr));
- writel(dma_addr & U32_MAX, priv->regbase + UNIPHIER_SD_DMA_ADDR_H); + uniphier_sd_writel(priv, dma_addr & U32_MAX, UNIPHIER_SD_DMA_ADDR_H);
- writel(UNIPHIER_SD_DMA_CTL_START, priv->regbase + UNIPHIER_SD_DMA_CTL); + uniphier_sd_writel(priv, UNIPHIER_SD_DMA_CTL_START, UNIPHIER_SD_DMA_CTL); }
static int uniphier_sd_dma_wait_for_irq(struct udevice *dev, u32 flag, @@ -316,7 +327,7 @@ static int uniphier_sd_dma_wait_for_irq(struct udevice *dev, u32 flag, struct uniphier_sd_priv *priv = dev_get_priv(dev); long wait = 1000000 + 10 * blocks;
- while (!(readl(priv->regbase + UNIPHIER_SD_DMA_INFO1) & flag)) { + while (!(uniphier_sd_readl(priv, UNIPHIER_SD_DMA_INFO1) & flag)) { if (wait-- < 0) { dev_err(dev, "timeout during DMA\n"); return -ETIMEDOUT; @@ -325,7 +336,7 @@ static int uniphier_sd_dma_wait_for_irq(struct udevice *dev, u32 flag, udelay(10); }
- if (readl(priv->regbase + UNIPHIER_SD_DMA_INFO2)) { + if (uniphier_sd_readl(priv, UNIPHIER_SD_DMA_INFO2)) { dev_err(dev, "error during DMA\n"); return -EIO; } @@ -343,7 +354,7 @@ static int uniphier_sd_dma_xfer(struct udevice *dev, struct mmc_data *data) u32 poll_flag, tmp; int ret;
- tmp = readl(priv->regbase + UNIPHIER_SD_DMA_MODE); + tmp = uniphier_sd_readl(priv, UNIPHIER_SD_DMA_MODE);
if (data->flags & MMC_DATA_READ) { buf = data->dest; @@ -357,7 +368,7 @@ static int uniphier_sd_dma_xfer(struct udevice *dev, struct mmc_data *data) tmp &= ~UNIPHIER_SD_DMA_MODE_DIR_RD; }
- writel(tmp, priv->regbase + UNIPHIER_SD_DMA_MODE); + uniphier_sd_writel(priv, tmp, UNIPHIER_SD_DMA_MODE);
dma_addr = __dma_map_single(buf, len, dir);
@@ -396,27 +407,27 @@ static int uniphier_sd_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, int ret; u32 tmp;
- if (readl(priv->regbase + UNIPHIER_SD_INFO2) & UNIPHIER_SD_INFO2_CBSY) { + if (uniphier_sd_readl(priv, UNIPHIER_SD_INFO2) & UNIPHIER_SD_INFO2_CBSY) { dev_err(dev, "command busy\n"); return -EBUSY; }
/* clear all status flags */ - writel(0, priv->regbase + UNIPHIER_SD_INFO1); - writel(0, priv->regbase + UNIPHIER_SD_INFO2); + uniphier_sd_writel(priv, 0, UNIPHIER_SD_INFO1); + uniphier_sd_writel(priv, 0, UNIPHIER_SD_INFO2);
/* disable DMA once */ - tmp = readl(priv->regbase + UNIPHIER_SD_EXTMODE); + tmp = uniphier_sd_readl(priv, UNIPHIER_SD_EXTMODE); tmp &= ~UNIPHIER_SD_EXTMODE_DMA_EN; - writel(tmp, priv->regbase + UNIPHIER_SD_EXTMODE); + uniphier_sd_writel(priv, tmp, UNIPHIER_SD_EXTMODE);
- writel(cmd->cmdarg, priv->regbase + UNIPHIER_SD_ARG); + uniphier_sd_writel(priv, cmd->cmdarg, UNIPHIER_SD_ARG);
tmp = cmd->cmdidx;
if (data) { - writel(data->blocksize, priv->regbase + UNIPHIER_SD_SIZE); - writel(data->blocks, priv->regbase + UNIPHIER_SD_SECCNT); + uniphier_sd_writel(priv, data->blocksize, UNIPHIER_SD_SIZE); + uniphier_sd_writel(priv, data->blocks, UNIPHIER_SD_SECCNT);
/* Do not send CMD12 automatically */ tmp |= UNIPHIER_SD_CMD_NOSTOP | UNIPHIER_SD_CMD_DATA; @@ -457,7 +468,7 @@ static int uniphier_sd_send_cmd(struct udevice *dev, struct mmc_cmd *cmd,
dev_dbg(dev, "sending CMD%d (SD_CMD=%08x, SD_ARG=%08x)\n", cmd->cmdidx, tmp, cmd->cmdarg); - writel(tmp, priv->regbase + UNIPHIER_SD_CMD); + uniphier_sd_writel(priv, tmp, UNIPHIER_SD_CMD);
ret = uniphier_sd_wait_for_irq(dev, UNIPHIER_SD_INFO1, UNIPHIER_SD_INFO1_RSP); @@ -465,10 +476,10 @@ static int uniphier_sd_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, return ret;
if (cmd->resp_type & MMC_RSP_136) { - u32 rsp_127_104 = readl(priv->regbase + UNIPHIER_SD_RSP76); - u32 rsp_103_72 = readl(priv->regbase + UNIPHIER_SD_RSP54); - u32 rsp_71_40 = readl(priv->regbase + UNIPHIER_SD_RSP32); - u32 rsp_39_8 = readl(priv->regbase + UNIPHIER_SD_RSP10); + u32 rsp_127_104 = uniphier_sd_readl(priv, UNIPHIER_SD_RSP76); + u32 rsp_103_72 = uniphier_sd_readl(priv, UNIPHIER_SD_RSP54); + u32 rsp_71_40 = uniphier_sd_readl(priv, UNIPHIER_SD_RSP32); + u32 rsp_39_8 = uniphier_sd_readl(priv, UNIPHIER_SD_RSP10);
cmd->response[0] = ((rsp_127_104 & 0x00ffffff) << 8) | ((rsp_103_72 & 0xff000000) >> 24); @@ -479,7 +490,7 @@ static int uniphier_sd_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, cmd->response[3] = (rsp_39_8 & 0xffffff) << 8; } else { /* bit 39-8 */ - cmd->response[0] = readl(priv->regbase + UNIPHIER_SD_RSP10); + cmd->response[0] = uniphier_sd_readl(priv, UNIPHIER_SD_RSP10); }
if (data) { @@ -518,10 +529,10 @@ static int uniphier_sd_set_bus_width(struct uniphier_sd_priv *priv, return -EINVAL; }
- tmp = readl(priv->regbase + UNIPHIER_SD_OPTION); + tmp = uniphier_sd_readl(priv, UNIPHIER_SD_OPTION); tmp &= ~UNIPHIER_SD_OPTION_WIDTH_MASK; tmp |= val; - writel(tmp, priv->regbase + UNIPHIER_SD_OPTION); + uniphier_sd_writel(priv, tmp, UNIPHIER_SD_OPTION);
return 0; } @@ -531,12 +542,12 @@ static void uniphier_sd_set_ddr_mode(struct uniphier_sd_priv *priv, { u32 tmp;
- tmp = readl(priv->regbase + UNIPHIER_SD_IF_MODE); + tmp = uniphier_sd_readl(priv, UNIPHIER_SD_IF_MODE); if (mmc->ddr_mode) tmp |= UNIPHIER_SD_IF_MODE_DDR; else tmp &= ~UNIPHIER_SD_IF_MODE_DDR; - writel(tmp, priv->regbase + UNIPHIER_SD_IF_MODE); + uniphier_sd_writel(priv, tmp, UNIPHIER_SD_IF_MODE); }
static void uniphier_sd_set_clk_rate(struct uniphier_sd_priv *priv, @@ -573,21 +584,21 @@ static void uniphier_sd_set_clk_rate(struct uniphier_sd_priv *priv, else val = UNIPHIER_SD_CLKCTL_DIV1024;
- tmp = readl(priv->regbase + UNIPHIER_SD_CLKCTL); + tmp = uniphier_sd_readl(priv, UNIPHIER_SD_CLKCTL); if (tmp & UNIPHIER_SD_CLKCTL_SCLKEN && (tmp & UNIPHIER_SD_CLKCTL_DIV_MASK) == val) return;
/* stop the clock before changing its rate to avoid a glitch signal */ tmp &= ~UNIPHIER_SD_CLKCTL_SCLKEN; - writel(tmp, priv->regbase + UNIPHIER_SD_CLKCTL); + uniphier_sd_writel(priv, tmp, UNIPHIER_SD_CLKCTL);
tmp &= ~UNIPHIER_SD_CLKCTL_DIV_MASK; tmp |= val | UNIPHIER_SD_CLKCTL_OFFEN; - writel(tmp, priv->regbase + UNIPHIER_SD_CLKCTL); + uniphier_sd_writel(priv, tmp, UNIPHIER_SD_CLKCTL);
tmp |= UNIPHIER_SD_CLKCTL_SCLKEN; - writel(tmp, priv->regbase + UNIPHIER_SD_CLKCTL); + uniphier_sd_writel(priv, tmp, UNIPHIER_SD_CLKCTL);
udelay(1000); } @@ -617,7 +628,7 @@ static int uniphier_sd_get_cd(struct udevice *dev) if (priv->caps & UNIPHIER_SD_CAP_NONREMOVABLE) return 1;
- return !!(readl(priv->regbase + UNIPHIER_SD_INFO1) & + return !!(uniphier_sd_readl(priv, UNIPHIER_SD_INFO1) & UNIPHIER_SD_INFO1_CD); }
@@ -632,28 +643,28 @@ static void uniphier_sd_host_init(struct uniphier_sd_priv *priv) u32 tmp;
/* soft reset of the host */ - tmp = readl(priv->regbase + UNIPHIER_SD_SOFT_RST); + tmp = uniphier_sd_readl(priv, UNIPHIER_SD_SOFT_RST); tmp &= ~UNIPHIER_SD_SOFT_RST_RSTX; - writel(tmp, priv->regbase + UNIPHIER_SD_SOFT_RST); + uniphier_sd_writel(priv, tmp, UNIPHIER_SD_SOFT_RST); tmp |= UNIPHIER_SD_SOFT_RST_RSTX; - writel(tmp, priv->regbase + UNIPHIER_SD_SOFT_RST); + uniphier_sd_writel(priv, tmp, UNIPHIER_SD_SOFT_RST);
/* FIXME: implement eMMC hw_reset */
- writel(UNIPHIER_SD_STOP_SEC, priv->regbase + UNIPHIER_SD_STOP); + uniphier_sd_writel(priv, UNIPHIER_SD_STOP_SEC, UNIPHIER_SD_STOP);
/* * Connected to 32bit AXI. * This register dropped backward compatibility at version 0x10. * Write an appropriate value depending on the IP version. */ - writel(priv->version >= 0x10 ? 0x00000101 : 0x00000000, - priv->regbase + UNIPHIER_SD_HOST_MODE); + uniphier_sd_writel(priv, priv->version >= 0x10 ? 0x00000101 : 0x00000000, + UNIPHIER_SD_HOST_MODE);
if (priv->caps & UNIPHIER_SD_CAP_DMA_INTERNAL) { - tmp = readl(priv->regbase + UNIPHIER_SD_DMA_MODE); + tmp = uniphier_sd_readl(priv, UNIPHIER_SD_DMA_MODE); tmp |= UNIPHIER_SD_DMA_MODE_ADDR_INC; - writel(tmp, priv->regbase + UNIPHIER_SD_DMA_MODE); + uniphier_sd_writel(priv, tmp, UNIPHIER_SD_DMA_MODE); } }
@@ -724,7 +735,7 @@ static int uniphier_sd_probe(struct udevice *dev) NULL)) priv->caps |= UNIPHIER_SD_CAP_NONREMOVABLE;
- priv->version = readl(priv->regbase + UNIPHIER_SD_VERSION) & + priv->version = uniphier_sd_readl(priv, UNIPHIER_SD_VERSION) & UNIPHIER_SD_VERSION_IP; dev_dbg(dev, "version %x\n", priv->version); if (priv->version >= 0x10) {
The Renesas RCar Gen3 contains the same controller, originally Matsushita, yet the register addresses are shifted by 1 to the left. The whole controller is also 64bit, including the data FIFOs and RSP registers. This patch adds support for handling the register IO by shifting the register offset by 1 in the IO accessor functions.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/uniphier-sd.c | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/uniphier-sd.c b/drivers/mmc/uniphier-sd.c index b5c608d866..742d936d98 100644 --- a/drivers/mmc/uniphier-sd.c +++ b/drivers/mmc/uniphier-sd.c @@ -132,17 +132,24 @@ struct uniphier_sd_priv { #define UNIPHIER_SD_CAP_NONREMOVABLE BIT(0) /* Nonremovable e.g. eMMC */ #define UNIPHIER_SD_CAP_DMA_INTERNAL BIT(1) /* have internal DMA engine */ #define UNIPHIER_SD_CAP_DIV1024 BIT(2) /* divisor 1024 is available */ +#define UNIPHIER_SD_CAP_64BIT BIT(3) /* Controller is 64bit */ };
static u32 uniphier_sd_readl(struct uniphier_sd_priv *priv, unsigned int reg) { - return readl(priv->regbase + reg); + if (priv->caps & UNIPHIER_SD_CAP_64BIT) + return readl(priv->regbase + (reg << 1)); + else + return readl(priv->regbase + reg); }
static void uniphier_sd_writel(struct uniphier_sd_priv *priv, const u32 val, unsigned int reg) { - writel(val, priv->regbase + reg); + if (priv->caps & UNIPHIER_SD_CAP_64BIT) + writel(val, priv->regbase + (reg << 1)); + else + writel(val, priv->regbase + reg); }
The Renesas RCar Gen3 contains the same controller, originally Matsushita. This patch adds support for handling of the 64bit FIFO on this controller.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Jaehoon Chung jh80.chung@samsung.com --- V2: - Use unsigned int for the reg argument of IO accessors - Rework the handling of aligned and unaligned data --- drivers/mmc/uniphier-sd.c | 101 +++++++++++++++++++++++++++++++++++++--------- 1 file changed, 83 insertions(+), 18 deletions(-)
diff --git a/drivers/mmc/uniphier-sd.c b/drivers/mmc/uniphier-sd.c index 742d936d98..12b2f1f38f 100644 --- a/drivers/mmc/uniphier-sd.c +++ b/drivers/mmc/uniphier-sd.c @@ -135,6 +135,23 @@ struct uniphier_sd_priv { #define UNIPHIER_SD_CAP_64BIT BIT(3) /* Controller is 64bit */ };
+static u64 uniphier_sd_readq(struct uniphier_sd_priv *priv, unsigned int reg) +{ + if (priv->caps & UNIPHIER_SD_CAP_64BIT) + return readq(priv->regbase + (reg << 1)); + else + return readq(priv->regbase + reg); +} + +static void uniphier_sd_writeq(struct uniphier_sd_priv *priv, + const u64 val, unsigned int reg) +{ + if (priv->caps & UNIPHIER_SD_CAP_64BIT) + writeq(val, priv->regbase + (reg << 1)); + else + writeq(val, priv->regbase + reg); +} + static u32 uniphier_sd_readl(struct uniphier_sd_priv *priv, unsigned int reg) { if (priv->caps & UNIPHIER_SD_CAP_64BIT) @@ -229,7 +246,7 @@ static int uniphier_sd_wait_for_irq(struct udevice *dev, unsigned int reg, return 0; }
-static int uniphier_sd_pio_read_one_block(struct udevice *dev, u32 **pbuf, +static int uniphier_sd_pio_read_one_block(struct udevice *dev, char *pbuf, uint blocksize) { struct uniphier_sd_priv *priv = dev_get_priv(dev); @@ -247,20 +264,42 @@ static int uniphier_sd_pio_read_one_block(struct udevice *dev, u32 **pbuf, */ uniphier_sd_writel(priv, 0, UNIPHIER_SD_INFO2);
- if (likely(IS_ALIGNED((unsigned long)*pbuf, 4))) { - for (i = 0; i < blocksize / 4; i++) - *(*pbuf)++ = uniphier_sd_readl(priv, UNIPHIER_SD_BUF); + if (priv->caps & UNIPHIER_SD_CAP_64BIT) { + u64 *buf = (u64 *)pbuf; + if (likely(IS_ALIGNED((uintptr_t)buf, 8))) { + for (i = 0; i < blocksize / 8; i++) { + *buf++ = uniphier_sd_readq(priv, + UNIPHIER_SD_BUF); + } + } else { + for (i = 0; i < blocksize / 8; i++) { + u64 data; + data = uniphier_sd_readq(priv, + UNIPHIER_SD_BUF); + put_unaligned(data, buf++); + } + } } else { - for (i = 0; i < blocksize / 4; i++) - put_unaligned(uniphier_sd_readl(priv, UNIPHIER_SD_BUF), - (*pbuf)++); + u32 *buf = (u32 *)pbuf; + if (likely(IS_ALIGNED((uintptr_t)buf, 4))) { + for (i = 0; i < blocksize / 4; i++) { + *buf++ = uniphier_sd_readl(priv, + UNIPHIER_SD_BUF); + } + } else { + for (i = 0; i < blocksize / 4; i++) { + u32 data; + data = uniphier_sd_readl(priv, UNIPHIER_SD_BUF); + put_unaligned(data, buf++); + } + } }
return 0; }
static int uniphier_sd_pio_write_one_block(struct udevice *dev, - const u32 **pbuf, uint blocksize) + const char *pbuf, uint blocksize) { struct uniphier_sd_priv *priv = dev_get_priv(dev); int i, ret; @@ -273,13 +312,34 @@ static int uniphier_sd_pio_write_one_block(struct udevice *dev,
- if (likely(IS_ALIGNED((unsigned long)*pbuf, 4))) { - for (i = 0; i < blocksize / 4; i++) - uniphier_sd_writel(priv, *(*pbuf)++, UNIPHIER_SD_BUF); + if (priv->caps & UNIPHIER_SD_CAP_64BIT) { + const u64 *buf = (const u64 *)pbuf; + if (likely(IS_ALIGNED((uintptr_t)buf, 8))) { + for (i = 0; i < blocksize / 8; i++) { + uniphier_sd_writeq(priv, *buf++, + UNIPHIER_SD_BUF); + } + } else { + for (i = 0; i < blocksize / 8; i++) { + u64 data = get_unaligned(buf++); + uniphier_sd_writeq(priv, data, + UNIPHIER_SD_BUF); + } + } } else { - for (i = 0; i < blocksize / 4; i++) - uniphier_sd_writel(priv, get_unaligned((*pbuf)++), - UNIPHIER_SD_BUF); + const u32 *buf = (const u32 *)pbuf; + if (likely(IS_ALIGNED((uintptr_t)buf, 4))) { + for (i = 0; i < blocksize / 4; i++) { + uniphier_sd_writel(priv, *buf++, + UNIPHIER_SD_BUF); + } + } else { + for (i = 0; i < blocksize / 4; i++) { + u32 data = get_unaligned(buf++); + uniphier_sd_writel(priv, data, + UNIPHIER_SD_BUF); + } + } }
return 0; @@ -287,19 +347,24 @@ static int uniphier_sd_pio_write_one_block(struct udevice *dev,
static int uniphier_sd_pio_xfer(struct udevice *dev, struct mmc_data *data) { - u32 *dest = (u32 *)data->dest; - const u32 *src = (const u32 *)data->src; + const char *src = data->src; + char *dest = data->dest; int i, ret;
for (i = 0; i < data->blocks; i++) { if (data->flags & MMC_DATA_READ) - ret = uniphier_sd_pio_read_one_block(dev, &dest, + ret = uniphier_sd_pio_read_one_block(dev, dest, data->blocksize); else - ret = uniphier_sd_pio_write_one_block(dev, &src, + ret = uniphier_sd_pio_write_one_block(dev, src, data->blocksize); if (ret) return ret; + + if (data->flags & MMC_DATA_READ) + dest += data->blocksize; + else + src += data->blocksize; }
Check if the OF match has any associated data and if so, use those data as the controller quirks, otherwise fallback to the old method of reading the controller version register to figure out the quirks. This allows us to supply controller quirks on controllers which ie. do not have version register.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/uniphier-sd.c | 23 ++++++++++++++--------- 1 file changed, 14 insertions(+), 9 deletions(-)
diff --git a/drivers/mmc/uniphier-sd.c b/drivers/mmc/uniphier-sd.c index 12b2f1f38f..4d0c032f92 100644 --- a/drivers/mmc/uniphier-sd.c +++ b/drivers/mmc/uniphier-sd.c @@ -752,6 +752,7 @@ static int uniphier_sd_probe(struct udevice *dev) struct uniphier_sd_plat *plat = dev_get_platdata(dev); struct uniphier_sd_priv *priv = dev_get_priv(dev); struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + const u32 quirks = dev_get_driver_data(dev); fdt_addr_t base; struct clk clk; int ret; @@ -803,18 +804,22 @@ static int uniphier_sd_probe(struct udevice *dev) return -EINVAL; }
+ if (quirks) { + priv->caps = quirks; + } else { + priv->version = uniphier_sd_readl(priv, UNIPHIER_SD_VERSION) & + UNIPHIER_SD_VERSION_IP; + dev_dbg(dev, "version %x\n", priv->version); + if (priv->version >= 0x10) { + priv->caps |= UNIPHIER_SD_CAP_DMA_INTERNAL; + priv->caps |= UNIPHIER_SD_CAP_DIV1024; + } + } + if (fdt_get_property(gd->fdt_blob, dev_of_offset(dev), "non-removable", NULL)) priv->caps |= UNIPHIER_SD_CAP_NONREMOVABLE;
- priv->version = uniphier_sd_readl(priv, UNIPHIER_SD_VERSION) & - UNIPHIER_SD_VERSION_IP; - dev_dbg(dev, "version %x\n", priv->version); - if (priv->version >= 0x10) { - priv->caps |= UNIPHIER_SD_CAP_DMA_INTERNAL; - priv->caps |= UNIPHIER_SD_CAP_DIV1024; - } - uniphier_sd_host_init(priv);
plat->cfg.voltages = MMC_VDD_165_195 | MMC_VDD_32_33 | MMC_VDD_33_34; @@ -829,7 +834,7 @@ static int uniphier_sd_probe(struct udevice *dev) }
static const struct udevice_id uniphier_sd_match[] = { - { .compatible = "socionext,uniphier-sdhc" }, + { .compatible = "socionext,uniphier-sdhc", .data = 0 }, { /* sentinel */ } };
Add OF match entries and quirks for Renesas RCar Gen3 controllers into the driver. The IP this driver handles is in fact Matsushita one and in used both in Socionext and Renesas chips.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/Kconfig | 7 ++++--- drivers/mmc/uniphier-sd.c | 2 ++ 2 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 51a87cdd77..7a83975c6e 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -182,12 +182,13 @@ config SH_SDHI Support for the on-chip SDHI host controller on SuperH/Renesas ARM SoCs platform
config MMC_UNIPHIER - bool "UniPhier SD/MMC Host Controller support" - depends on ARCH_UNIPHIER + bool "UniPhier/RCar SD/MMC Host Controller support" + depends on ARCH_UNIPHIER || ARCH_RMOBILE depends on BLK && DM_MMC_OPS depends on OF_CONTROL help - This selects support for the SD/MMC Host Controller on UniPhier SoCs. + This selects support for the Matsushita SD/MMC Host Controller on + SocioNext UniPhier and Renesas RCar SoCs.
config MMC_SANDBOX bool "Sandbox MMC support" diff --git a/drivers/mmc/uniphier-sd.c b/drivers/mmc/uniphier-sd.c index 4d0c032f92..798c0fbaaa 100644 --- a/drivers/mmc/uniphier-sd.c +++ b/drivers/mmc/uniphier-sd.c @@ -834,6 +834,8 @@ static int uniphier_sd_probe(struct udevice *dev) }
static const struct udevice_id uniphier_sd_match[] = { + { .compatible = "renesas,sdhi-r8a7795", .data = UNIPHIER_SD_CAP_64BIT }, + { .compatible = "renesas,sdhi-r8a7796", .data = UNIPHIER_SD_CAP_64BIT }, { .compatible = "socionext,uniphier-sdhc", .data = 0 }, { /* sentinel */ } };
