[PATCH] o4-imx-nano: Fix dtc warnings
Remove the LED unit addresses and reg properties to fix the following dtc build warnings:
arch/arm/dts/o4-imx-nano.dtb: Warning (reg_format): /leds/led@0:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1) ... arch/arm/dts/o4-imx-nano.dtb: Warning (avoid_default_addr_size): /leds/led@0: Relying on default #address-cells value
Reported-by: Tom Rini trini@konsulko.com Signed-off-by: Fabio Estevam festevam@denx.de --- arch/arm/dts/o4-imx-nano.dts | 18 ++++++------------ 1 file changed, 6 insertions(+), 12 deletions(-)
diff --git a/arch/arm/dts/o4-imx-nano.dts b/arch/arm/dts/o4-imx-nano.dts index d1785b7dc702..54d32f9dd47b 100644 --- a/arch/arm/dts/o4-imx-nano.dts +++ b/arch/arm/dts/o4-imx-nano.dts @@ -24,40 +24,34 @@ leds { compatible = "gpio-leds";
- led@0 { + led0 { color = <LED_COLOR_ID_RED>; gpios = <&pcf8574a 0 GPIO_ACTIVE_LOW>; - reg = <0>; };
- led@1 { + led1{ color = <LED_COLOR_ID_GREEN>; gpios = <&pcf8574a 1 GPIO_ACTIVE_LOW>; - reg = <1>; };
- led@2 { + led2 { gpios = <&pcf8574a 2 GPIO_ACTIVE_LOW>; color = <LED_COLOR_ID_BLUE>; - reg = <2>; };
- led@3 { + led3 { color = <LED_COLOR_ID_RED>; gpios = <&pcf8574a 3 GPIO_ACTIVE_LOW>; - reg = <3>; };
- led@4 { + led4{ color = <LED_COLOR_ID_GREEN>; gpios = <&pcf8574a 4 GPIO_ACTIVE_LOW>; - reg = <4>; };
- led@5 { + led5 { color = <LED_COLOR_ID_BLUE>; gpios = <&pcf8574a 5 GPIO_ACTIVE_LOW>; - reg = <5>; }; };
17.06.21 18:57, Fabio Estevam пише:
led@0 {
reg = <0>;
led@1 {
reg = <1>;
led@2 {
reg = <2>;
led@3 {
reg = <3>;
led@4 {
reg = <4>;
led@5 {
}; };reg = <5>;
Reviewed-by: Oleh Kravchenko oleg@kaa.org.ua
Thanks, applied to -master.
Best regards, Stefano
led@0 {
reg = <0>;
led@1 {
reg = <1>;
led@2 {
reg = <2>;
led@3 {
reg = <3>;
led@4 {
reg = <4>;
led@5 {
}; };reg = <5>;
Fabio Estevam
Oleh Kravchenko
Stefano Babic
