[U-Boot] [PATCH 1/2] RFT: arm: Switch 32-bit ARM to using generic global_data setup
There is quite a bit of assembler code that can be removed if we use the generic global_data setup. Less arch-specific code makes it easier to add new features and maintain the start-up code.
Drop the unneeded code and adjust the hooks in board_f.c to cope.
arch/arm/lib/crt0.S | 28 ++++------------------------ 1 file changed, 4 insertions(+), 24 deletions(-)
diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index afd4f10..fc1252d 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -76,31 +76,11 @@ ENTRY(_main) #else bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ #endif - mov r2, sp - sub sp, sp, #GD_SIZE /* allocate one GD above SP */ -#if defined(CONFIG_CPU_V7M) /* v7M forbids using SP as BIC destination */ - mov r3, sp - bic r3, r3, #7 - mov sp, r3 -#else - bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ -#endif - mov r9, sp /* GD is above SP */ - mov r1, sp + mov r0, sp + bl board_init_f_mem + mov sp, r0 + mov r0, #0 -clr_gd: - cmp r1, r2 /* while not at end of GD */ -#if defined(CONFIG_CPU_V7M) - itt lo -#endif - strlo r0, [r1] /* clear 32-bit GD word */ - addlo r1, r1, #4 /* move to next */ - blo clr_gd -#if defined(CONFIG_SYS_MALLOC_F_LEN) - sub sp, sp, #CONFIG_SYS_MALLOC_F_LEN - str sp, [r9, #GD_MALLOC_BASE] -#endif - /* mov r0, #0 not needed due to above code */ bl board_init_f
#if ! defined(CONFIG_SPL_BUILD)
arch/arm/lib/crt0_64.S | 15 +++------------ 1 file changed, 3 insertions(+), 12 deletions(-)
diff --git a/arch/arm/lib/crt0_64.S b/arch/arm/lib/crt0_64.S index 98a906e..31fc3b4 100644 --- a/arch/arm/lib/crt0_64.S +++ b/arch/arm/lib/crt0_64.S @@ -66,19 +66,10 @@ ENTRY(_main) #else ldr x0, =(CONFIG_SYS_INIT_SP_ADDR) #endif - sub x18, x0, #GD_SIZE /* allocate one GD above SP */ - bic x18, x18, #0x7 /* 8-byte alignment for GD */ -zero_gd: - sub x0, x0, #0x8 - str xzr, [x0] - cmp x0, x18 - b.gt zero_gd -#if defined(CONFIG_SYS_MALLOC_F_LEN) - ldr x0, =CONFIG_SYS_MALLOC_F_LEN - sub x0, x18, x0 - str x0, [x18, #GD_MALLOC_BASE] -#endif bic sp, x0, #0xf /* 16-byte alignment for ABI compliance */ + bl board_init_f_mem + mov sp, x0 + mov x0, #0 bl board_init_f
Sorry for top posting. Replying from OWA while traveling.
Tested on LS2085ARDB and LS2085AQDS.
Tested-by: York Sun yorksun@freescale.com
________________________________________ From: U-Boot u-boot-bounces@lists.denx.de on behalf of Simon Glass sjg@chromium.org Sent: Monday, August 17, 2015 8:43 PM To: U-Boot Mailing List Cc: Tom Rini; Wood Scott-B07421; Thierry Reding; Sun York-R58495 Subject: [U-Boot] [PATCH 2/2] RFT: arm: Switch aarch64 to using generic global_data setup
-- 2.5.0.276.gf5e568e
_______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
-zero_gd:
- sub x0, x0, #0x8
- str xzr, [x0]
- cmp x0, x18
- b.gt zero_gd
- sub x0, x18, x0
- bl board_init_f_mem
- mov sp, x0
- mov x0, #0 bl board_init_f
Let me try again. Previous reply went to a separated thread in patchwork.
Tested on LS2085ARDB and LS2085AQDS (armv8 SoC).
York Sun
