[U-Boot] [PATCH v1] armv8: fsl-layerscape: LS1044A/1048A: enable Only 1x 10GE port
LS1044A/1048A is LS1088 personality which support only one 1x 10GE port. MAC1 and MAC2 are associated with 1G SGMII, 2.5G SGMII, and XFI. Disable MAC1 to have only one 1x 10GE port
Signed-off-by: Pramod Kumar pramod.kumar_1@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c | 33 +++++++++++++++++++++- 1 file changed, 32 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c index 8e8b45a..11090e8 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1088a_serdes.c @@ -5,6 +5,11 @@
#include <common.h> #include <asm/arch/fsl_serdes.h> +#include <asm/arch/soc.h> +#include <asm/io.h> +#define PERSONALITY_LS1088A_TYPE 0 +#define PERSONALITY_LS1044A_LS1048A_TYPE 1 +#define PERSONALITY_INVALID_TYPE -1
struct serdes_config { u8 ip_protocol; @@ -32,6 +37,7 @@ static struct serdes_config serdes1_cfg_tbl[] = { {0x3A, {SGMII3, PCIE1, SGMII1, SGMII2 }, {3, 5, 3, 3 } }, {} }; + static struct serdes_config serdes2_cfg_tbl[] = { /* SerDes 2 */ {0x0C, {PCIE1, PCIE1, PCIE1, PCIE1 }, {8, 8, 8, 8 } }, @@ -48,6 +54,22 @@ static struct serdes_config *serdes_cfg_tbl[] = { serdes2_cfg_tbl, };
+int check_personality_type(void) +{ + struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + unsigned int svr, ver; + int personality; + + svr = gur_in32(&gur->svr); + ver = SVR_SOC_VER(svr); + if (ver == SVR_LS1088A) + personality = PERSONALITY_LS1088A_TYPE; + else + personality = PERSONALITY_LS1044A_LS1048A_TYPE; + + return personality; +} + int serdes_get_number(int serdes, int cfg) { struct serdes_config *ptr; @@ -84,10 +106,19 @@ int serdes_get_number(int serdes, int cfg) enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane) { struct serdes_config *ptr; + int personality_type;
if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) return 0; - + /* + * LS1044A/1048A support only one XFI port + * Disable MAC1 for LS1044A/1048A + */ + if (!serdes && lane == 2) { + personality_type = check_personality_type(); + if (personality_type == PERSONALITY_LS1044A_LS1048A_TYPE) + return 0; + } ptr = serdes_cfg_tbl[serdes]; while (ptr->ip_protocol) { if (ptr->ip_protocol == cfg)
-----Original Message----- From: Pramod Kumar Sent: Wednesday, September 18, 2019 4:52 PM To: u-boot@lists.denx.de Cc: York Sun york.sun@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Priyanka Jain priyanka.jain@nxp.com; Pramod Kumar pramod.kumar_1@nxp.com Subject: [PATCH v1] armv8: fsl-layerscape: LS1044A/1048A: enable Only 1x 10GE port
Please correct grammar. LS1044A, LS1048A are LS1088A personalities
- struct ccsr_gur __iomem *gur = (void
- unsigned int svr, ver;
- int personality;
- svr = gur_in32(&gur->svr);
- ver = SVR_SOC_VER(svr);
- if (ver == SVR_LS1088A)
- else
- return personality;
SVR_SOC_VER macro is to return personality type. No need to add another function check_personality_type() If you intend to check presence of MAC1, you might rename it to something like soc_has_mac1 and return true/false accordingly.
--priyankajain
- if (!serdes && lane == 2) {
- } ptr = serdes_cfg_tbl[serdes]; while (ptr->ip_protocol) { if (ptr->ip_protocol == cfg)
-- 2.7.4
Pramod Kumar
Priyanka Jain
